Home » Modeling » TMF (Xtext) » Where has the OnTheFlyCompiler gone?
Where has the OnTheFlyCompiler gone? [message #761406] Tue, 06 December 2011 07:38 Go to next message
Up to Xtext 2.1.1 I have used the OnTheFlyCompiler to compile my
expressions into Java byte code - In the 2.2 nightly build, this class
does not exist anymore :-( Has this feature been abandoned or has it
just been moved somewhere else and I am too stupid to find it?
Kai
Re: Where has the OnTheFlyCompiler gone? [message #761424 is a reply to message #761406] Tue, 06 December 2011 08:10 Go to previous messageGo to next message
I don't even see it in Xtext 2.1.1 - in which plugin should it live (so I can check against my zillion Xtext installations)?
Re: Where has the OnTheFlyCompiler gone? [message #761437 is a reply to message #761424] Tue, 06 December 2011 08:27 Go to previous messageGo to next message
Sorry, I should have mentioned that it was part of the Xbase plugin, see
http://git.eclipse.org/c/tmf/org.eclipse.xtext.git/tree/plugins/org.eclipse.xtext.xbase/src/org/eclipse/xtext/xbase/compiler/OnTheFlyJavaCompiler.java?h=2.1.x_Maintenance
Re: Where has the OnTheFlyCompiler gone? [message #761557 is a reply to message #761406] Tue, 06 December 2011 11:42 Go to previous messageGo to next message
Hi Kai,
we had to move it to the test bundle since it introduced unwanted
dependencies.
So yes, the feature was removed from xbase core.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 06.12.11 13:38, schrieb Kai Kreuzer:
> Kai
Re: Where has the OnTheFlyCompiler gone? [message #761564 is a reply to message #761557] Tue, 06 December 2011 11:59 Go to previous messageGo to next message
Sounds like an interesting functionality. Is it possible to package it
in its own feature so that it can be ignored when the dependencies are
unacceptable but used when required. Seems like I might like to use it
for OCL 2 Java.
Ed Willink
On 06/12/2011 16:42, Sebastian Zarnekow wrote:
> Hi Kai,
> dependencies.
> Sebastian
Re: Where has the OnTheFlyCompiler gone? [message #761595 is a reply to message #761564] Tue, 06 December 2011 12:46 Go to previous messageGo to next message
It would have been nice if that had been mentioned on the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=354635, which I just
wanted to verify. Very sad to hear, that this feature is not supported
any longer - I quite liked the possibility to directly produce compiled
bytecode for performance reasons...
So I would agree with Ed: It would be nice if that feature could be
moved into a separate bundle to avoid any unwanted dependencies on the
xbase core bundle.
Kai
On 12/6/2011 5:59 PM, Ed Willink wrote:
> Hi
> for OCL 2 Java.
> Regards
> Ed Willink
>> Hi Kai,
>> dependencies.
>> Regards,
>> Sebastian
Re: Where has the OnTheFlyCompiler gone? [message #761635 is a reply to message #761595] Tue, 06 December 2011 14:25 Go to previous messageGo to next message
Hi Kai,
I'm sorry about that one. The ticket about the unwanted deps was another
one. Please file a feature request for the compiler. We may want to
reinstantiate it in the xbase.ui plugin which would allow the necessary
deps.
Sebastian
Am 06.12.11 18:46, schrieb Kai Kreuzer:
> xbase core bundle.
> Cheers,
> Kai
>> Hi
>> for OCL 2 Java.
>> Regards
>> Ed Willink
>>> Hi Kai,
>>> dependencies.
>>> Regards,
>>> Sebastian
Re: Where has the OnTheFlyCompiler gone? [message #761993 is a reply to message #761635] Wed, 07 December 2011 06:55 Go to previous messageGo to next message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=365870
> We may want to reinstantiate it in the xbase.ui plugin which would allow
> the necessary deps.
I do not think that that would be the right place for it - the feature
is mainly required on a runtime and for performance optimization; it is
therefore probably quite likely that the xbase.ui plugin is not even
present.
Re: Where has the OnTheFlyCompiler gone? [message #762004 is a reply to message #761993] Wed, 07 December 2011 07:15 Go to previous message
> is therefore probably quite likely that the xbase.ui plugin is not
> even present.
Indeed. If I can use it for OCL 2 Java, I may not really want xbase at
all, certainly not xbase.ui.
Perhaps this could be a contribution to something more like emf.codegen.
Ed Willink
Previous Topic:creating an Extension Library (documentation?)
Next Topic:[eclipse] Problem upgrading to xtext 2.1.1
Current Time: Tue Nov 04 00:38:01 EST 2025
Powered by FUDForum. Page generated in 0.04595 seconds
