Programmatic Contribution Factories not supported [message #760907] |
Mon, 05 December 2011 14:51 |
Matthias Villiger Messages: 232 Registered: September 2011 |
I have a question concerning the compatibility layer and menu contribution factories.
In eclipse 3.7 we extended the ExtensionContributionFactory to programmatically contribute CommandContributionItems using the org.eclipse.ui.menus extension point.
As far as I can see this is not yet supported in the compatibility layer of our eclipse version (Build id: 20111110-1543).
When I check org.eclipse.ui.internal.menus.MenuPersistence there is some removed (commented out) code in the readAdditions() method together with a system-out informing that these factories are not supported.
Now to my question:
Is it planned to integrate this feature in a later build?
If yes: what is the plan on that? By when can we expect to make use of menu contribution factories?
If no: what is the alternative to use?
Matthias
[Updated on: Mon, 05 December 2011 15:54] Report message to a moderator
FUDForum. Page generated in 0.02915 seconds
