Re: BIRT without Jetty [message #760992 is a reply to message #760837] |
Mon, 05 December 2011 18:53 |
Do you mean it is only returning 500 rows? Because that is a setting
you can alter. Look at Window->preferences->Report
Design->Preview->Data Number of rows to display.
Jason
On 12/5/2011 7:24 AM, Onno van der Straaten wrote:
> Is it possible to use BIRT without Jetty?
> The Jetty http server looks a bit buggy. On my laptop the Jetty server
> will only return 500 internal servers. It did work at one time but after
> installing multiple Eclipse based products it will except on very rare
> occasion do only 500 errors.
> If it cannot be used without Jetty I think I will have to reset my
> laptop with a new Windows 7 image to get it to work again :(
Re: BIRT without Jetty [message #762240 is a reply to message #762073] |
Wed, 07 December 2011 18:45 |
Eclipse uses jetty for the help system. Is that launching?
Can you download the 2.5.2 birt allinone download in a separate location
and give it a try as a test?
http://www.eclipse.org/downloads/download.php?file=/birt/downloads/drops/R-R1-2_5_2-201002221500/birt-report-designer-all-in-one-2_5_2.zip
Jason
On 12/7/2011 9:09 AM, Onno van der Straaten wrote:
> I mean 500 http response code. Which indicates an internal server error.
> Initially I thought my laptop configuration was the problem but now I'm
> looking at these errors on a brand new laptop. Got the latop today.
> Fresh Windows 7 installation and then install of Rational Method
> Composer which includes
> Quote:
>> Business Intelligence and Reporting Tools
>> Version: 2.5.2.v20090925-9dE-9CGJexwJPcfpfqGkK_4lg9Ti
>> Build id: v20100210-0630
>> (c) Copyright Eclipse contributors and others 2000, 2007. All rights
>> reserved.
>> Visit http://www.eclipse.org/birt
> Incredible that this is just not working. I'm flabbergasted. Looks like
> my first BIRT experience will include debugging BIRT/Jetty!
Re: BIRT without Jetty [message #762921 is a reply to message #762527] |
Thu, 08 December 2011 20:13 |
Is the Preview server host and port set in (By default I believe it uses
local host):
Window->Preferences->Report Design->Preview->Preview Server
Jason
On 12/8/2011 3:48 AM, Onno van der Straaten wrote:
> I found a workaround.
> Because BIRT/Jetty don't provide any real clue to what is going wrong I
> tried to get some more information.
> First I changed my shortcut "C:\Program Files_IBM\RMC75\rmc\rmc.exe"
> -console -consoleLog.
> I also changed eclipse.ini. I added
> -Dorg.apache.commons.logging.Log="org.apache.commons.logging.impl.SimpleLog"
> I'm not sure that is correct, but that is what I did and then I was able
> to see some more information. Unfortunately not anything related to
> Jetty. But I did see some vague Eclipse messages about proxy host and
> port. That something was not able to set these correctly. I did specify
> this under preferences menu, my work network uses a proxy server.
> So I started to suspect that this problem has something to do with the
> network, specifically the presence of a proxy server on the network. I
> tried various settings for the proxy server in Eclipse (direct, native,
> manual) but no avail. What does help is to disconnect the computer from
> the network. After I remove the network cable it works 8o
FUDForum. Page generated in 0.03787 seconds
