| Virgo web server(tomcat) 3.0.0 [message #760413] |
Fri, 02 December 2011 05:18  |
Hello friends,
I have using virgo web server 2.1.0 and spring osgi technology in my project and working fine. but I have move to virgo web server 3.0.0 using my project came to error below that.
Failed to start web bundle 'sample-web' version '0.0.0': consult serviceability/logs/log.log for further details.
[2011-12-02 15:21:08.236] start-signalling-4 <DE0006E> Start failed for bundle 'sample-web' version '0.0.0'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:132)
at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:247)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:294)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:291)
at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:229)
at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:143)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedException: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/sample-web' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:108)
at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
... 8 common frames omitted
Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/sample-web' failed to start. Check the logs for more details.
at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:125)
at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:91)
... 9 common frames omitted
[2011-12-02 15:21:08.248] start-signalling-4 <DE0010I> Stopping bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.250] start-signalling-4 <DE0011I> Stopped bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.252] TCP Connection(4)-127.0.0.1 <DE0013I> Uninstalling bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.265] TCP Connection(4)-127.0.0.1 <DE0014I> Uninstalled bundle 'sample-web' version '0.0.0'.
[2011-12-02 15:21:08.471] TCP Connection(4)-127.0.0.1 <DE0000I> Installing bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:08.502] TCP Connection(4)-127.0.0.1 <DE0001I> Installed bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:08.516] TCP Connection(4)-127.0.0.1 <DE0004I> Starting bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:08.524] start-signalling-4 <DE0005I> Started bundle 'samplemiddletierservice-dm' version '0.0.0'.
[2011-12-02 15:21:12.790] start-signalling-2 <WE0001I> Started web bundle 'org.eclipse.virgo.apps.splash' version '3.0.0.RELEASE' with context path '/'.
[2011-12-02 15:21:12.791] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.virgo.apps.splash' version '3.0.0.RELEASE'.
My project environment :
Linux OS, Spring MVC, OSGI Frame Work Currently using virgo web server 2.1.0 it's working fine and deployed war file also fine.
NOTE: But still now i am facing the problem, at the same project i have change the runtime server configure change the virgo web server 3.0.0, Its not run the project otherwise came to bundle startup error.
Please help me any body. ASAP.....
[Updated on: Fri, 02 December 2011 05:19] by Moderator
| Re: Virgo web server(tomcat) 3.0.0 [message #761289 is a reply to message #761013] |
Tue, 06 December 2011 03:47   |
Hi Violeta Georgieva,
I have follow your information please below the your instruction:
* Can you tell me what is the value for WABHeaders property. (this is your instruction)
I try to change the value for Virgo home-->repository-->ext-->org.eclipse.viro.wep.prop-->WABHeaders=strict replaced to defaulted it's correct
* Can you log also to telnet then invoke "b <bundle-id-for-your-web-app>" and post here the Bundle-Classpath header value?
How to invoke the bundle id in my web application
* Do you have something in <VIRGO-HOME>/serviceability/logs/log.log?
I have check this log detail but i dont ant idea?
[2011-12-06 14:07:39.902] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=cashmiddletier-web_0.0.0]'
[2011-12-06 14:07:39.903] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default WE0000I Starting web bundle 'sample-web' version '0.0.0' with context path '/sample-web'.
[2011-12-06 14:07:39.915] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-web_0.0.0, BundleEvent STARTED
[2011-12-06 14:07:39.915] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:39.915] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=cashmiddletier-web_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.544] INFO Thread-49 o.a.c.c.C.[Catalina].[localhost].[/sample-web] Initializing Spring root WebApplicationContext
[2011-12-06 14:07:40.545] INFO Thread-49 System.out INFO : org.springframework.web.context.ContextLoader - Root WebApplicationContext: initialization started
[2011-12-06 14:07:40.568] INFO Thread-49 System.out ERROR: org.springframework.web.context.ContextLoader - Context initialization failed
[2011-12-06 14:07:40.568] INFO Thread-49 System.out java.lang.NoSuchMethodError: org.springframework.web.context.ConfigurableWebApplicationContext.setId(Ljava/lang/String;)V
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:264)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4723)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5226)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5221)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
[2011-12-06 14:07:40.568] INFO Thread-49 System.out at java.util.concurrent.FutureTask.run(FutureTask.java:138)
[2011-12-06 14:07:40.569] INFO Thread-49 System.out at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
[2011-12-06 14:07:40.569] INFO Thread-49 System.out at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
[2011-12-06 14:07:40.569] INFO Thread-49 System.out at java.lang.Thread.run(Thread.java:619)
[2011-12-06 14:07:40.572] ERROR Thread-49 o.a.c.c.C.[Catalina].[localhost].[/sample-web] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener java.lang.NoSuchMethodError: org.springframework.web.context.ConfigurableWebApplicationContext.setId(Ljava/lang/String;)V
[2011-12-06 14:07:40.573] ERROR start-signalling-1 org.apache.catalina.core.StandardContext Error listenerStart
[2011-12-06 14:07:40.573] ERROR start-signalling-1 org.apache.catalina.core.StandardContext Context [/sample-web] startup failed due to previous errors
[2011-12-06 14:07:40.593] INFO ication=none,J2EEServer=none o.a.c.c.C.[Catalina].[localhost].[/sample-web] Closing Spring root WebApplicationContext
[2011-12-06 14:07:40.650] ERROR start-signalling-1 org.eclipse.gemini.web.internal.StandardWebApplication Failed to start web application at bundleContext path '/sample-web' org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/sample-web' failed to start. Check the logs for more details.
[2011-12-06 14:07:40.653] ERROR start-signalling-1 org.eclipse.virgo.medic.eventlog.default WE0005E Failed to start web bundle 'sample-web' version '0.0.0': consult serviceability/logs/log.log for further details.
[2011-12-06 14:07:40.653] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.653] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.654] INFO start-signalling-1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-web' version '0.0.0' in scope 'null' to propagate start failed (stop) event to
[2011-12-06 14:07:40.659] ERROR start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0006E Start failed for bundle 'sample-web' version '0.0.0'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedException: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/cashmiddletier-web' failed to start. Check the logs for more details.
[2011-12-06 14:07:40.660] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.660] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.660] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.665] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0010I Stopping bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.666] INFO start-signalling-1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Bundle 'cashmiddletier-web_0.0.0 [135]' has stopped. Removing its related tracking state.
[2011-12-06 14:07:40.667] INFO start-signalling-1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-web' version '0.0.0' in scope 'null' to propagate stopped event to
[2011-12-06 14:07:40.667] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0011I Stopped bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.668] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle cashmiddletier-web_0.0.0, BundleEvent STOPPED
[2011-12-06 14:07:40.668] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.668] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.668] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.669] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0013I Uninstalling bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.669] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.673] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle cashmiddletier-web_0.0.0, BundleEvent UNRESOLVED
[2011-12-06 14:07:40.674] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing uninstalled event for bundle 'sample-web' version '0.0.0'
[2011-12-06 14:07:40.675] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-web' version '0.0.0' in scope 'null' to propagate uninstalled event to
[2011-12-06 14:07:40.676] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0014I Uninstalled bundle 'sample-web' version '0.0.0'.
[2011-12-06 14:07:40.677] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle cashmiddletier-web_0.0.0, BundleEvent UNINSTALLED
[2011-12-06 14:07:40.677] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=cashmiddletier-web_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]'
[2011-12-06 14:07:40.683] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle org.eclipse.osgi_3.7.0.v20110613, FrameworkEvent PACKAGES REFRESHED
[2011-12-06 14:07:40.701] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-web_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.707] ERROR TCP Connection(3)-127.0.0.1 org.eclipse.virgo.kernel.deployer.management.StandardDeployer Exception filtered from JMX invocation org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/cashmiddletier-web' failed to start. Check the logs for more details.
[2011-12-06 14:07:40.769] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.m.i.deployer.ModelInstallArtifactLifecycleListener Processing installing event for bundle 'sample-dm' version '0.0.0'
[2011-12-06 14:07:40.771] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'cashmiddletierservice-dm' version '0.0.0'.
[2011-12-06 14:07:40.773] INFO TCP Connection(3)-127.0.0.1 o.e.virgo.kernel.userregion.internal.quasi.DependencyCalculator Calculating missing dependencies of bundle(s) 'sample-dm_0.0.0'
[2011-12-06 14:07:40.777] INFO TCP Connection(3)-127.0.0.1 o.e.virgo.kernel.userregion.internal.quasi.DependencyCalculator The dependencies of '[sample-dm_0.0.0]' are '[]'
[2011-12-06 14:07:40.778] INFO TCP Connection(3)-127.0.0.1 o.eclipse.virgo.kernel.model.internal.bundle.ModelBundleListener Processing installed event for bundle 'sample-dm:0.0.0' in region 'org.eclipse.virgo.region.user'
[2011-12-06 14:07:40.779] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-dm_0.0.0, BundleEvent INSTALLED
[2011-12-06 14:07:40.780] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'sample-dm' version '0.0.0'.
[2011-12-06 14:07:40.781] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.782] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-dm_0.0.0, BundleEvent RESOLVED
[2011-12-06 14:07:40.782] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' pushed and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.782] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
[2011-12-06 14:07:40.783] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'sun.misc.Launcher$AppClassLoader@17182c1' pushed and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.783] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' pushed and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.783] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Adding signal 'org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@2629f1' for bundle 'sample-dm_0.0.0 [136]'
[2011-12-06 14:07:40.784] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.a.internal.AtomicInstallArtifactLifecycleListener No atomic parent of bundle 'sample-dm' version '0.0.0' in scope 'null' to propagate starting event to
[2011-12-06 14:07:40.784] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'sample-dm' version '0.0.0'.
[2011-12-06 14:07:40.785] INFO TCP Connection(3)-127.0.0.1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Non-Spring DM powered bundle 'sample-dm_0.0.0 [136]' has started. Driving signals '[org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@2629f1]'.
[2011-12-06 14:07:40.785] INFO start-signalling-1 org.eclipse.virgo.kernel.core.internal.BundleStartTracker Driving signal 'org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal@2629f1'
[2011-12-06 14:07:40.785] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]' pushed and set to 'KernelBundleClassLoader: [bundle=cashmiddletierservice-dm_0.0.0]'
[2011-12-06 14:07:40.786] INFO start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'sample-dm' version '0.0.0'.
[2011-12-06 14:07:40.786] INFO start-signalling-1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=cashmiddletierservice-dm_0.0.0]' popped and set to 'BundleDelegatingClassLoader for [spring-osgi-extender (org.springframework.osgi.extender)]'
[2011-12-06 14:07:40.787] INFO OSGiLogServiceListener@b6ef8 org.osgi.service.log.LogService Bundle sample-dm_0.0.0, BundleEvent STARTED
[2011-12-06 14:07:40.787] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' popped and set to 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]'
[2011-12-06 14:07:40.787] INFO TCP Connection(3)-127.0.0.1 o.e.v.k.i.artifact.internal.bundle.BundleThreadContextManager Thread context class loader 'KernelBundleClassLoader: [bundle=sample-dm_0.0.0]' popped and set to 'sun.misc.Launcher$AppClassLoader@17182c1'
Please help me...
FUDForum. Page generated in 0.05079 seconds
