MySQL driver not found [message #759911] |
Wed, 30 November 2011 14:49 |
I am new to Jubula and love it! It's really great software. Until yet I just used the embedded H2 database which worked out of the box.
Now I added a MySQL database profile in the preferences menu. When I try to connect, the following messages are written in the client log.
Caused by: org.eclipse.persistence.exceptions.DatabaseException:
Internal Exception: java.sql.SQLException: No suitable driver found for jdbc:mysql://localhost:3306/Jubula
Error Code: 0
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:324) ~[org.eclipse.persistence.core_2.2.0.v20110202-r8913.jar:2.2.0.v20110202-r8913]
at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:319) ~[org.eclipse.persistence.core_2.2.0.v20110202-r8913.jar:2.2.0.v20110202-r8913]
at org.eclipse.persistence.sessions.DefaultConnector.connect(DefaultConnector.java:138) ~[org.eclipse.persistence.core_2.2.0.v20110202-r8913.jar:2.2.0.v20110202-r8913]
at org.eclipse.persistence.sessions.DatasourceLogin.connectToDatasource(DatasourceLogin.java:162) ~[org.eclipse.persistence.core_2.2.0.v20110202-r8913.jar:2.2.0.v20110202-r8913]
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:592) ~[org.eclipse.persistence.core_2.2.0.v20110202-r8913.jar:2.2.0.v20110202-r8913]
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:233) ~[org.eclipse.persistence.jpa_2.2.0.v20110202-r8913.jar:2.2.0.v20110202-r8913]
at org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl.deploy(EntityManagerSetupImpl.java:394) ~[org.eclipse.persistence.jpa_2.2.0.v20110202-r8913.jar:2.2.0.v20110202-r8913]
... 9 common frames omitted
Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql://localhost:3306/Jubula
at java.sql.DriverManager.getConnection(Unknown Source) ~[na:1.6.0_18]
How can I add the driver to the classpath? Or any other solution to this problem?
I am using Jubula (standalone) version 1.1.0
Any help is much appreciated,
Amir
Re: MySQL driver not found [message #759923 is a reply to message #759911] |
Wed, 30 November 2011 15:16 |
I am really sorry, I really searched for 1.5h now. Answer is the bug in Bugzilla with ID 342706 (I am not allowed to post a link).
The username had no permission to access the database specified, but the exception message was not really helpful. Sorry!
Re: MySQL driver not found [message #759940 is a reply to message #759924] |
Wed, 30 November 2011 15:58 |
OK sorry for having to post again, but now I don't believe this was the exact solution. There have to be different bugs.
Problem is: First connection to an empty database works fine (it creates tables), but when I want to create a project or even open it, then I get the error that the table "Node" doesn't exist. By the way the exception text again contains the "no suitable driver" message.
Any other ideas?
FUDForum. Page generated in 0.10433 seconds
