Home » Eclipse Projects » WindowBuilder » Compiler classpath is not being picked up in IvyIDE project
Compiler classpath is not being picked up in IvyIDE project [message #759867] Wed, 30 November 2011 07:02 Go to next message
Hello
I am using IvyIDE plugin with Eclipse.
Eclipse itself successfully picks up Ivy-dependent libraries, no compiler errors appears in project view. But WindowBuilder PRO refuses to build the design, complaining to unresolved imports.
In particular, if fails on Apache Commons logging:
Internal Error
WindowBuilder encountered unexpected internal error.
This could be caused by a WindowBuilder bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.NoClassDefFoundError: org/apache/commons/logging/Log
Stack trace:
java.lang.ClassNotFoundException: org.apache.commons.logging.Log
	at org.eclipse.wb.internal.core.utils.reflect.ProjectClassLoader.findClass(ProjectClassLoader.java:382)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:423)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
Omitting all such imports and calls with "hide" tags would be pretty boring work.
Any other way ? Thank you.
[Updated on: Wed, 30 November 2011 07:03] by Moderator
Re: Compiler classpath is not being picked up in IvyIDE project [message #761102 is a reply to message #759867] Mon, 05 December 2011 17:37 Go to previous messageGo to next message
See Bugzilla Case 365134.
WB gets the classpath from the JDT, so I assume that IVY is doing something unusual.
We don't know anything about IVY, so don't have any suggestions. Someone who uses IVY could load up the WB source and trace through the classpath code.
Re: Compiler classpath is not being picked up in IvyIDE project [message #780645 is a reply to message #759867] Wed, 18 January 2012 16:17 Go to previous messageGo to next message
I am also having this issue. I happen to have the project of the dependency it can't find and if I link to the source, all works fine. It just can't seem to find the jar (managed by Ivy/IvyDE).
Re: Compiler classpath is not being picked up in IvyIDE project [message #780695 is a reply to message #780645] Thu, 19 January 2012 00:29 Go to previous message
The WB committer team has no plans to support Ivy, but we would be happy to review any user-submitted patches that add support for this.
Previous Topic:Custom Layout
Next Topic:resizing problems
Current Time: Tue Sep 23 03:32:16 EDT 2025
Powered by FUDForum. Page generated in 0.05378 seconds
