Home » Language IDEs » C / C++ IDE (CDT) » Returning structure reference in a C function
Returning structure reference in a C function [message #759319] Mon, 28 November 2011 06:19 Go to next message
I was wondering if someone could let me know if there are any issues with the CDT and returning structure references.
I have the below code for reading file content into a linked list:
struct list_node
  char dir[BUFSIZ];
  struct list_node *next;
typedef struct list_node list;
int main( )
	parse_file();
//list is structure
/*Error line*/ list * parse_file()
	const char filename[] = "find_inotify.txt";
	FILE *file = fopen(filename, "r");
	list *curr;
	list *head;
	char * errorcode = NULL;
	head = NULL;
	if ( file )
			char line [ BUFSIZ ];
			while ( fgets(line, sizeof line, file) )
				curr = (list *)malloc(sizeof(list));
				strcpy(curr->dir, line);
				curr->next  = head;
				head = curr;
			while(head) {
				printf("%s\n", curr->dir);
				head = head->next ;
		else
		perror(filename);
	return head;
Everything works fine except for the function return type. Changing the return type to int and returning a random integer fixes this. I am looking for a way for this function to return the linked list.
Thanks.
Eclipse build error at /*Error line*/ : conflicting types for 'parse_file'
OS : Ubuntu 11.10
Eclipse Version: 3.7.0
[Updated on: Mon, 28 November 2011 06:19] by Moderator
Re: Returning structure reference in a C function [message #759566 is a reply to message #759319] Tue, 29 November 2011 03:40 Go to previous messageGo to next message
Your code is wrong. In C (not C++ !) you have to declare the prototype of a function before you use it.
Add the following before your main() routine
list * parse_file();
Alternatively, you could move the main() routine at the end of the file.
Re: Returning structure reference in a C function [message #760353 is a reply to message #759566] Fri, 02 December 2011 00:43 Go to previous message
Thanks Alex. Everything is going on fine now!
Previous Topic:!!!FATAL ERROR!!!: No such file or directory??
Next Topic:How do I see the step before termination in debug mode?
Current Time: Thu Sep 25 03:32:40 EDT 2025
Powered by FUDForum. Page generated in 0.03023 seconds
