| load profile [message #759303] |
Mon, 28 November 2011 05:32  |
I'am developping a tool to transform UML stereotyped models to JAVA. For this I use an UML profile which contains stereotype that add attributes to classes (designed with papyrus) and wrapped in a specific plugin with an extension point (pathmap://MyProfiles/crio.profile.uml).
Now I want to load this profile within a program. I have found several topics on the subject and tried to follow these hints but it never worked. My plugin has as dependency the previous plugin and I try to load with the resourceSet.getPackageRegistry().put("pathmap://MyProfiles/crio.profile.uml",org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
I also tried to register a factory
public void registerResourceFactories(ResourceSet resourceSet) {
super.registerResourceFactories(resourceSet);
// TODO If you need additional resource factories registrations, do them here. The following line is an example for UML.
// resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put
("uml",
new XMIResourceFactoryImpl()
public Resource createResource(URI uri)
XMIResource xmiResource = new XMIResourceImpl(uri);
return xmiResource;
and the last thing I tried was to load by
final String profile = "profiles/crio.profile.uml";
URL url = getClass().getClassLoader().getResource(profile);
if (url == null)
throw new RuntimeException("Error getting crio.profile.uml");
String urlString = url.toString();
if (!urlString.endsWith(profile))
throw new RuntimeException("Error getting crio.profile.uml. Got: " +
urlString);
urlString = urlString.substring(0, urlString.length() - profile.length());
URI uri = URI.createURI(urlString);org.eclipse.uml2.uml.Package package_ = null;
System.out.println("URI ="+uri+"\n");
try {
Resource resource = resourceSet.getResource(uri, true); //URI.createURI("PATHMAP://MyProfiles/crio.profile.uml")
package_ = (org.eclipse.uml2.uml.Package) EcoreUtil.getObjectByType(
resource.getContents(), UMLPackage.Literals.PACKAGE);
} catch (WrappedException we) {
System.out.println(we.getMessage());
System.exit(1);
Is there somewhere a tutorial/document that explains how to do this ?
Vincent
FUDForum. Page generated in 0.03555 seconds
