Home » Eclipse Projects » EclipseLink » Locking and Version
icon5.gif  Locking and Version [message #759243] Sun, 27 November 2011 21:37 Go to next message
I need to clarify some of my doubts related to eclipselink locking.
How can i configure eclipselink that a row level lock should be held rather than a table level? I'm using spring transactions and havn't touched any configurations related to locking in eclipselink, so it uses default locking (optimistic). Please correct me if i'm wrong here.
I have added @Version column in my entity classes to support locking mechanism. Is this a good way or do i have to use the Locking API in code too like entityManager.lock or @Lock etc? Should i use these locks in code even when i have configured database transactions through spring? I'm confused with the usage of code level locking and declarative transaction management.
Thanks.
Re: Locking and Version [message #759369 is a reply to message #759243] Mon, 28 November 2011 08:48 Go to previous message
Row versus table locks are up to your database, and can only be configured on your database. You can execute a native SQL query if you really want to lock an entire table, although not normally a good idea.
See,
http://en.wikibooks.org/wiki/Java_Persistence/Locking
Previous Topic:EclipseLink Maven repository missing
Next Topic:Locking and Version
Current Time: Mon Oct 27 03:57:33 EDT 2025
Powered by FUDForum. Page generated in 0.38523 seconds
