Dependency problems when upgrading Xtext version in an existing feature project [message #758967] |
Fri, 25 November 2011 12:15 |
John J. Camilleri Messages: 33 Registered: November 2011 Location: Göteborg |
Member |
Could someone outline the steps required to upgrade a project to use a new version of Xtext? Specifically, I am developing a plugin using Xtext 2.0.1 and want to upgrade to 2.1.0; it was starightforward enough to upgrade in my development environment, but when I release the plugin via "Export deployable features" and try to install on a fresh Classic Eclipse, I get errors about dependencies which cannot be found.
For the record, this is what I have tried:
- Installed fresh version of Eclipse + Xtext 2.1.0 from Itemis (see note below)
- Opened my plugin project in the new Eclipse
- Changed org.eclipse.xtext.ui.refactoring.ui.RenameElementHandler to org.eclipse.xtext.ui.refactoring.ui.IRenameElementHandler in plugin.xml of my UI project.
- Re-run GenerateMyDSL.mwe2
I thought I would be able to update Xtext in my dev environment using Eclipse's Upgrade feature, but Xtext did not show up as any of the available updates...
[Updated on: Mon, 05 December 2011 10:25] Report message to a moderator
Re: Steps for upgrading Xtext version in an existing project [message #760832 is a reply to message #760810] |
Mon, 05 December 2011 12:02 |
Member |
Thanks for your help Sebastian, that seems to have allowed me to install the exported feature plugin. For anyone else wondering, I basically added this line to the feature.xml file of my feature project:
<includes
id="org.eclipse.xtext.runtime"
version="0.0.0"
name="Xtext Runtime"
search-location="self"/>
However now when I try to open my custom perspective I get some new errors:
[2011-12-05 13:13:46,951] ERROR Guice creation errors:
1) Could not find a suitable constructor in org.eclipse.xtext.ui.refactoring.impl.DefaultRenameStrategy. Classes must have either one (and only one) constructor annotated with @Inject or a zero-argument constructor that is not private.
at org.eclipse.xtext.ui.refactoring.impl.DefaultRenameStrategy.class(DefaultRenameStrategy.java:96)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:55)
2) No implementation for org.eclipse.xtext.ui.editor.preferences.IPreferenceStoreInitializer annotated with @com.google.inject.name.Named(value=RefactoringPreferences) was bound.
at org.grammaticalframework.eclipse.ui.AbstractGFUiModule.configureIPreferenceStoreInitializer(AbstractGFUiModule.java:218)
2 errors
com.google.inject.CreationException: Guice creation errors:
2 errors
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:354)
at com.google.inject.InjectorBuilder.initializeStatically(InjectorBuilder.java:152)
at com.google.inject.InjectorBuilder.build(InjectorBuilder.java:105)
at com.google.inject.Guice.createInjector(Guice.java:92)
at com.google.inject.Guice.createInjector(Guice.java:69)
at com.google.inject.Guice.createInjector(Guice.java:59)
at org.grammaticalframework.eclipse.ui.internal.GFActivator.registerInjectorFor(GFActivator.java:47)
at org.grammaticalframework.eclipse.ui.internal.GFActivator.start(GFActivator.java:38)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:462)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.registry.PerspectiveDescriptor.createFactory(PerspectiveDescriptor.java:171)
at org.eclipse.ui.internal.Perspective.loadPredefinedPersp(Perspective.java:744)
at org.eclipse.ui.internal.Perspective.createPresentation(Perspective.java:270)
at org.eclipse.ui.internal.Perspective.<init>(Perspective.java:156)
at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createPerspective(Workbench3xImplementation.java:55)
at org.eclipse.ui.internal.WorkbenchPage.createPerspective(WorkbenchPage.java:1748)
at org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(WorkbenchPage.java:1108)
at org.eclipse.ui.internal.WorkbenchPage.access$16(WorkbenchPage.java:1099)
at org.eclipse.ui.internal.WorkbenchPage$19.run(WorkbenchPage.java:3814)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3812)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.openPerspective(ShowPerspectiveHandler.java:146)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.openOther(ShowPerspectiveHandler.java:118)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.execute(ShowPerspectiveHandler.java:57)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:178)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:247)
at org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveMenu.java:376)
at org.eclipse.ui.actions.PerspectiveMenu$3.runWithEvent(PerspectiveMenu.java:130)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
[Updated on: Mon, 05 December 2011 12:15] Report message to a moderator
FUDForum. Page generated in 0.04972 seconds
