Unable to update Eclipse [message #758555] |
Wed, 23 November 2011 16:22 |
Postholes Messages: 3 Registered: November 2011 |
After this seventh fresh install, switching between Indigo 3.7 and helios 3.6. I have yet to get eclipse to connect to update itself, nor install from the google web toolkit local files. When I try the local eclipse goes online and cannot connect to whatever servers it thinks it needs.
I've been trying to run it as administrator, I shut off the local windows firewall to no avail.
I can paste the links into my web browser and download the files. Every topic I have been able to dig up on the net/forums have many of the same issues that I am running in and nobody has offered a suggestion that works, if any at all.
I am using windows 7 ultimate 64bit, Eclipse Indigo 3.7, and Eclipse Helios 3.6.
I had the Java SDK 7, and just this most recent I tried installing the JDK 6.
I also tried installing onto my windows vista 32bit system with the same problems.
When clicking on update, or install new software using the google install path, or the local install files for this it takes roughly 10-20 minutes before I get any notification at all, and all I get is failure to connect when I am clearly able to connect to the location where the files are hosted.
(I had to put spaces into the address so that I could post to the forums)
eclipse.buildId=M20110210-1200
java.version=1.7.0_01
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
Error
Wed Nov 23 07:47:02 PST 2011
Unable to read repository at http: //download.eclipse.org/eclipse /updates/3.6/R-3.6.2-201102101200 /content.jar.
java.net.SocketTimeoutException: Read timed out
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(Unknown Source)
at java.io.BufferedInputStream.read1(Unknown Source)
at java.io.BufferedInputStream.read(Unknown Source)
at org.apache.commons.httpclient.ContentLengthInputStream.read(ContentLengthInputStream.java:170)
at java.io.FilterInputStream.read(Unknown Source)
at org.apache.commons.httpclient.AutoCloseInputStream.read(AutoCloseInputStream.java:108)
at org.apache.commons.httpclient.AutoCloseInputStream.read(AutoCloseInputStream.java:127)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetrieveFileTransfer$1.performFileTransfer(AbstractRetrieveFileTransfer.java:172)
at org.eclipse.ecf.filetransfer.FileTransferJob.run(FileTransferJob.java:74)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
[Updated on: Wed, 23 November 2011 16:23] Report message to a moderator
FUDForum. Page generated in 0.03916 seconds
