improving generator development turnaround times? [message #758423] |
Wed, 23 November 2011 09:07 |
Volker Wegert Messages: 182 Registered: July 2009 |
Hi all,
I have some experience with the old Xtend/Xpand packanges, and I've used
Xtext 2 for newer projects. In the old projects, I was able to keep the
secondary Eclipse instance running, modify the generator templates in
the first instance and then re-run the generator from the second
instance. Since the templates were interpreted, this allowed for a very
"interactive" way of developing the generator - change something,
generate to try it and move on. Now, with Xtext 2 compiling the
templates to Java classes, this doesn't seem to work any longer. While
the generator is certainly faster, I now have to close and re-open the
secondary instance to pick up the changes. For some reason, hot code
replacement doesn't work reliably - sometimes it doesn't notice the
changes at alls and more often than not, it kills the secondary instance
because of some incompatible changes. How do you solve this problem?
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
Re: improving generator development turnaround times? [message #758449 is a reply to message #758428] |
Wed, 23 November 2011 10:33 |
Hallvard Traetteberg Messages: 673 Registered: July 2009 Location: Trondheim, Norway |
On 23.11.11 10.19, Christian Dietrich wrote:
> what about calling the generator standalone / from a workflow
> => you wont need to start a runtime
I have been trying this, but found it difficult to make it work. I have
been able to register all the packages etc., load the relevant files
into a resource set with the reader workflow component, but the xtext
linking fails. My project uses/refers to xbase, jvmtypes, ecore and
genmodel using the importedNamespace technique, and I wonder if this
causes a problem for the workflow, e.g. if xtext indexing needs to be
triggered somehow. Are special tricks/techniques needed for making
scoping/linking work when using namespaces and references to external
models (jvmtypes, ecore and genmodel)?
Hallvard
FUDForum. Page generated in 0.03293 seconds
