Home » General (non-technical) » Eclipse Foundation » Installing BIRT Professional designer as a plug-in
Installing BIRT Professional designer as a plug-in [message #758332] Tue, 22 November 2011 13:56 Go to next message
Hi All
Not sure if this is the right place for this issue
I just installed Professional Designer as a plug-in for Eclipse
Installation went ok, however after eclipse restarted I don't see the perspective for Report Design, when I go to the Help window -> about eclipse, I see that BIRT is installed,
One thing I noticed is when you to go to the BIRT help screen the column signed shows that none of the BIRT plug-in are signed.That could be the problem? if so how to fix it?
Thanks for your tips on this one
Re: Installing BIRT Professional designer as a plug-in [message #758349 is a reply to message #758332] Tue, 22 November 2011 15:59 Go to previous message
Comments below.
On 22/11/2011 7:56 PM, JulioC wrote:
> Hi All
No. There's eclipse.birt for BIRT questions.
> eclipse, I see that BIRT is installed, One thing I noticed is when you
Previous Topic: Eclipse CVS advice
Next Topic:Eclipse Community Awards 2012
Current Time: Mon Oct 27 19:58:25 EDT 2025
Powered by FUDForum. Page generated in 0.03824 seconds
