Save "run as configuration" settings in project files does NOT work: Really export project [message #758221] |
Tue, 22 November 2011 11:34 |
Ben Stover Messages: 108 Registered: January 2010 |
I have a java application in my workspace. When I click now
Run As-->Run Configuration->Arguments tab
then I defined there as Program arguments a file (e.g. foobar.txt)
Everything works.
Now I deleted the whole project from workspace (but not from hard disc).
I copied/moved the whole project directory tree to another folder (or even another computer).
There I imported that project in the Eclipse installation again.
But unfortunately the parameter "foobar.txt" is NOT set.
So it seems to be NOT saved in the .project settings file.
Where is it saved otherwise?
How can I export all relevent project run configuration settings as well?
I want to make all project stuff and all settings portable to other Eclipse installations.
Ben
[Updated on: Tue, 22 November 2011 11:34] Report message to a moderator
FUDForum. Page generated in 0.03848 seconds
