Ant Security Exception when opening ant file [message #757155] |
Wed, 16 November 2011 20:00 |
Missing name Missing name Messages: 1 Registered: November 2011 |
I am new to the forums and I have searched to no end regarding an issue I am encountering every time I open an ant file in Eclipse or Flash Builder.
For reasons I cannot figure out, when I open an ant xml file, I get an error that says "Could not open the editor: An unexpected exception was thrown." What is strange is it is happening more and more often and it only requires opening the file. I have read online about this possibly being related to the folding of Ant files. Unfortunately, this solution hasn't helped.
Here are the details of the error.
org.eclipse.ant.core.AntSecurityException
at org.eclipse.ant.internal.core.AntSecurityManager.checkPermission(AntSecurityManager.java:226)
at java.lang.System.setProperty(Unknown Source)
at org.eclipse.ant.internal.ui.model.AntModel.processAntHome(AntModel.java:517)
at org.eclipse.ant.internal.ui.model.AntModel.initializeProject(AntModel.java:403)
at org.eclipse.ant.internal.ui.model.AntModel.prepareForFullParse(AntModel.java:377)
at org.eclipse.ant.internal.ui.model.AntModel.parseDocument(AntModel.java:340)
at org.eclipse.ant.internal.ui.model.AntModel.reconcile(AntModel.java:298)
at org.eclipse.ant.internal.ui.model.AntModel.getProjectNode(AntModel.java:1427)
at org.eclipse.ant.internal.ui.model.AntModel.getProjectNode(AntModel.java:1437)
at org.eclipse.ant.internal.ui.editor.text.AntFoldingStructureProvider.updateFoldingRegions(AntFoldingStructureProvider.java:89)
at org.eclipse.ant.internal.ui.editor.AntEditor.projectionEnabled(AntEditor.java:1217)
at org.eclipse.jface.text.source.projection.ProjectionViewer.fireProjectionEnabled(ProjectionViewer.java:489)
at org.eclipse.jface.text.source.projection.ProjectionViewer.enableProjection(ProjectionViewer.java:537)
at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.java:1441)
at org.eclipse.ant.internal.ui.editor.AntEditor$StatusLineSourceViewer.doOperation(AntEditor.java:212)
at org.eclipse.ant.internal.ui.editor.AntEditor.createPartControl(AntEditor.java:950)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2945)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:355)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:164)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
Would someone please provide some insight on why this is happening? It would be much appreciated.
Scott Deschenes
FUDForum. Page generated in 0.02996 seconds
