Re: Import of xml into Jubula database by cmd [message #760807 is a reply to message #757125] |
Mon, 05 December 2011 10:39 |
Daniel Vala Messages: 11 Registered: October 2011 |
Thanks, it helped. Now I am able to import database when I delete it first.
But command to delete database does not work. Database is deleted, but it stuck on deleting test results details. Even when use -keepsummary option.
vala@dan:/opt/jubula_5.2.00266/jubula> ./dbtool -delete "TopoNet" 1.0 -keepsummary -dbscheme "Default Embedded (H2)" -dbuser sa -dbpw ""
Mon Dec 05 10:30:54 CET 2011 - [main] Bundle tracker is not set
Mon Dec 05 10:30:54 CET 2011 Commandline parsing finished - performing actions...
Mon Dec 05 10:30:54 CET 2011 Database: Connecting...
Mon Dec 05 10:30:59 CET 2011 Database: Connection established.
Mon Dec 05 10:30:59 CET 2011 Deleting project "MyProject" in version "1.0"...
Mon Dec 05 10:31:10 CET 2011 Deleting of project "TopoNet" finished.
Mon Dec 05 10:31:10 CET 2011 Deleting all test result details...
It is the same on linux and on windows. User has permission to the test_results folder.
[Updated on: Wed, 07 December 2011 12:07] Report message to a moderator
Re: Import of xml into Jubula database by cmd [message #761998 is a reply to message #761347] |
Wed, 07 December 2011 12:06 |
Sorry about confusion of project name, TopoNet is on both places.
Deleting results takes at least 15 minutes and still nothing. Where I can find test result in Jubula GUI? I thought it is html and xml result in my specified folder which I specify when I run tests from command line and there are only few files in that folder. I tried to delete them all and it was still the same. No logs at that time were recorded.
Nevertheless I reinstalled my windows, installed Jubula and imported my TopoNet project. Now it works fine. But even if I do not use option -keepsummary, html and xml files in test folder remains.
I hope it will be working in the future. If not, I get you know.
Re: Import of xml into Jubula database by cmd [message #769561 is a reply to message #769534] |
Thu, 22 December 2011 10:31 |
Hi Andreas
dbtool is a headless OSGi application. It is defined in org.eclipse.jubula.app.dbtool
You may start it from within your IDE by specifying the application id and adding the required plug-ins to the launch configuration. You may try exporting it with PDE tools which should work (but I've never done this myself).
Part of this may be guesswork. Can't help you with this because my development machine with the launch configurations is at work.
Achim
FUDForum. Page generated in 0.05028 seconds
