Home » Eclipse Projects » Rich Client Platform (RCP) » Activity pattern binding to remove "Previous/Next Annotation" and "Last Edit Location
Activity pattern binding to remove "Previous/Next Annotation" and "Last Edit Location [message #756906] Tue, 15 November 2011 08:43 Go to next message
I know how to remove undesired elements from toolbar in general. However, what is the correct pattern in <activitypatternbinding> to remove "Previous/Next Annotation" and "Last Edit Location" from the toolbar?
Tracing keybinding as described at http://www.vogella.de/articles/EclipseCodeAccess/article.html#keybindings shows that IDs for commands are org.eclipse.ui.edit.text.gotoLastEditPosition, org.eclipse.ui.navigate.next, and org.eclipse.ui.navigate.previous, but adding pattern bindings for .*/org.eclipse.ui.edit.text.gotoLastEditPosition and .*/org.eclipse.ui.navigate.* doesn't work.
Strangely enough, .*/org.eclipse.ui.edit.text.* does, but I will quite likely need some commands for text editing later, so what's the best way to do this?
Re: Activity pattern binding to remove "Previous/Next Annotation" and "Last Edit Loca [message #756913 is a reply to message #756906] Tue, 15 November 2011 09:02 Go to previous messageGo to next message
Try using ALT+SHIFT+F2 and then selecting the toolbar item. The activity patterm is applied against <plugin>/<element.id> not <plugin>/<command.id>.
You can also try the Window>Customize Perspective Dialog and remove the Command Groups that contains those tool items.
PW
Re: Activity pattern binding to remove "Previous/Next Annotation" and "Last Edit Loca [message #756914 is a reply to message #756913] Tue, 15 November 2011 09:07 Go to previous message
Thanks!
Previous Topic:MultiPageEditorPart and menu contribution
Next Topic:DateTime widget with 12h format not working
Current Time: Fri Sep 26 15:17:25 EDT 2025
Powered by FUDForum. Page generated in 0.04080 seconds
