Home » Eclipse Projects » Rich Client Platform (RCP) » ViewPart Menu(How to change a Viewpart tab context menu)
ViewPart Menu [message #756567] Mon, 14 November 2011 06:18 Go to next message
Hi guys,
I am developing a RCP applications, and I have been unable to find how can I change Viewpart's tab menu (the one that have Detached, Move, Close... actions). Could anyone help me?
On the other hand, I want to know if there is a way to translate all these commands, I have tried to override org.eclipse.ui.window.maximizePart without success...
Thank you in advance
Re: ViewPart Menu [message #756617 is a reply to message #756567] Mon, 14 November 2011 09:21 Go to previous messageGo to next message
The pane menu (called the system menu in eclipse) is provided by the presentation (generally the 3.x presentation that provides a presentation factory and follows the presentation API). AFAIK it is not extensible.
PW
Re: ViewPart Menu [message #756719 is a reply to message #756617] Mon, 14 November 2011 14:17 Go to previous messageGo to next message
Here is a code that will allow you to hide that menu; but to change it as Paul is said it is not possible.
BTW, what is your use case for changing that menu?
Display display = PlatformUI.createDisplay();
    display.addFilter(SWT.MenuDetect, new Listener() {
      public void handleEvent(Event aEvent) {
        if (aEvent.widget != null) {
          if (aEvent.widget.getClass() == CTabFolder.class) {
            aEvent.type = SWT.None;
Re: ViewPart Menu [message #757090 is a reply to message #756719] Wed, 16 November 2011 08:22 Go to previous messageGo to next message
Hi again and thanxs for your responses,
the thing is our application is wrotten in Spanish, so I wanted to have this menu translated in that language.
However I think it is not a bad option to hide, so I will put all needed options in the viewpart menu.
Thanks for your help!
Re: ViewPart Menu [message #757158 is a reply to message #757090] Wed, 16 November 2011 15:07 Go to previous messageGo to next message
If it was only the case of translating those entries to spanish then a language fragment will solve your problem.
Please read this article: http://www.eclipse.org/articles/Article-Speak-The-Local-Language/article.html. Then download the appropriate language pack from http://eclipse.org/babel/ and integrate it into your build if necessary. For that menu you have pointed to the 'responsible' plugin containing the properties file is: org.eclipse.ui.workbench.
Note that in my case it was decided by the client to remove those menu entries.
Re: ViewPart Menu [message #788277 is a reply to message #756567] Wed, 01 February 2012 10:45 Go to previous messageGo to next message
Thanks Catalin,
I finally chose to hide that menu, I think it is better this way. Thank's for your help.
Cheers
Re: ViewPart Menu [message #789069 is a reply to message #788277] Thu, 02 February 2012 10:17 Go to previous message
Just a note. That won't work reliable in eclipse 4.2, as the presentation has changed.
PW
Previous Topic:Webstart: jredesc in component ignored: null
Next Topic:View with multiple relative views in perspective extension
Current Time: Sun Nov 09 06:52:02 EST 2025
Powered by FUDForum. Page generated in 0.03828 seconds
