Home » Eclipse Projects » Eclipse 4 » Starting birt from e4 application
Starting birt from e4 application [message #756522] Mon, 14 November 2011 03:10
we are developing an Eclipse e4 application that uses birt as Report Engine. The user should be able to modify the report design via the Birt Designer. We want the user to select a Report Design in our appliction then start the Birt Designer from our Appliction to edit the selected Design.
I think there are to possible Solutions:
1. Start the birt Perspective in a new Window from the installed plugin.
2. Start the Birt rcp Designer in the same vm.
Our Application needs to know if the report design is modified or new to do some post processing.
Does anybody know how to achieve this?
Previous Topic:Are draw2d objects turned into modeled objects?
Next Topic:Enable/Disable a Menu Element in a Processor
Current Time: Wed Oct 29 00:25:10 EDT 2025
Powered by FUDForum. Page generated in 0.30340 seconds
