Re: FacesServlet in Snaps makes them invisible to the host? [message #756861 is a reply to message #756454] |
Tue, 15 November 2011 11:24 |
Have you been able to get this working without Snaps in the picture, just the JSF2. Next, I'd have a look as to what Faces does with the default servlet/mappings, there might be some conflicts going on that are overwritting the Snaps servlet, remember that the host and all it's snaps are using the same servlet context.
Thanks for linking the code above, it's nice and simple and I can't see anything obvious wrong but I have no idea what will happen when you have a servlet of the same type registered at the same url pattern twice in a servlet context. Can you get it working if you play around with the url mappings?
Apart from that, I'd have to bring your sample down and get it building, then run it in the debugger and see what is going on inside Snaps. So let me know.
Thanks, Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
FUDForum. Page generated in 0.18150 seconds
