Re: Passing Arguments [message #756363 is a reply to message #756360] |
Sat, 12 November 2011 11:39 |
Call:
'call' name=[Function] '(' defres+=DefRef* ')';
DefRef:
def=[Define];
Please not: you reference Defines in your case not by "name" but by "param"
=> You have to change IQualifiedNameProvider to return the param of a Define as its qualifiedname
+ you will need a validator to check type and length of the DefRefs
Update:
are you sure you refernce defines by name and by param? if yes you do not have to change the IQualifiedNameProvider but the DefaultResourceDescriptionStrategy
to "export" Defines by "name" and by "param"
Twitter : @chrdietrich
[Updated on: Sat, 12 November 2011 12:03] Report message to a moderator
Re: Passing Arguments [message #756466 is a reply to message #756459] |
Sun, 13 November 2011 18:16 |
Bahad?r KIN Messages: 3 Registered: November 2011 |
Christian Dietrich wrote on Sun, 13 November 2011 11:25hi, i dont understand your problem, can you elaborate a bit? what do you mean with "bind"?
~Christian
Sorry. I now get it. I will look for both IQualifiedNameProvider and a Validator.
And thanks for your time.
[Updated on: Sun, 13 November 2011 18:22] Report message to a moderator
FUDForum. Page generated in 0.04347 seconds
