Significance of engine parameters [message #756193] |
Fri, 11 November 2011 12:59 |
sam va Messages: 121 Registered: July 2011 |
Until now we were using the following parameters for engine config
EngineConfig.getAppContext().put(DataEngine.MEMORY_USAGE, DataEngine.MEMORY_USAGE_CONSERVATIVE);
EngineConfig.getAppContext().put(DataEngine.DATA_SET_CACHE_ROW_LIMIT, 30000);
EngineConfig.getAppContext().put(DataEngine.MEMORY_BUFFER_SIZE, 2);
We have done a load test with the above parameters set and were able to run 20 large parallel reports. While having this, there were lot of directories created under /tmp in Linux. Something like below
DataEngine*
DataCache*
Now we have commented these lines. Now we dont see those temporary directories created in /tmp. How will this affect performance.
What are the optimum parameters for high performance
[Updated on: Fri, 11 November 2011 13:00] Report message to a moderator
Re: Significance of engine parameters [message #756233 is a reply to message #756193] |
Fri, 11 November 2011 15:22 |
Those tmp files are data sets being cached to disk. I would assume this
is because of the conservative setting. I would look at using this
setting only:
Memory per Query that is used before caching to disk. Defaults to 10
MB. Used inside and outside of designer. Depending on your load type
raising or lowering this value may be helpful
Jason
On 11/11/2011 7:59 AM, sam wrote:
> Hi
> 30000);
> DataEngine*
> DataCache*
> Thanks
Re: Significance of engine parameters [message #759975 is a reply to message #759858] |
Wed, 30 November 2011 18:56 |
I thought that setting was for only cubes. I may be wrong, but in any
case I do not know of any issues with it.
Jason
On 11/30/2011 6:07 AM, sam wrote:
> We are getting better results in lower environments with the following
> parameter set.
> Can we push to production with this setting? Is it safe enough?
> Thanks
FUDForum. Page generated in 0.04326 seconds
