Home » Archived » BIRT » Birt Missing images on ProxyPass
Birt Missing images on ProxyPass [message #756159] Fri, 11 November 2011 05:23 Go to next message
I am configuring a proxypass from DMZ to my Birt server. It is working otherwise fine, but I am missing all the images included in project. Images like navication pics that are in the viewer are loading fine. Also I am able to export the report with the images.
Viewer Version : 2.6.1
Engine Version: 2.6.1
JRE version: 1.6.0_24
Apache config
<VirtualHost *:443>
    ServerName testbirt.ourdomain.com
    ServerAdmin webadmin@localhost
    ErrorLog logs/ssl_error_log
    TransferLog logs/ssl_access_log
    LogLevel warn
    SSLEngine on
    SSLProtocol all -SSLv2
    SSLCipherSuite ALL:!ADH:!EXPORT:!SSLv2:RC4+RSA:+HIGH:+MEDIUM:+LOW
    SSLCertificateFile /etc/httpd/conf/ssl.crt/sslname.crt
    SSLCertificateKeyFile /etc/httpd/conf/ssl.key/sslname.key
    ProxyRequests Off
    <Proxy *>
      Order deny,allow
      Allow from all
    </Proxy>
    ProxyPass /birt/ http://testbirt.intra.dom:8080/birt/
    ProxyPassReverse /birt/ http://testbirt.intra.dom:8080/birt/
    SetEnvIf User-Agent ".*MSIE.*" \
         nokeepalive ssl-unclean-shutdown \
         downgrade-1.0 force-response-1.0
    CustomLog logs/ssl_request_log \
          "%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b"
</VirtualHost>
This is how the report loads
index.php/fa/6098/0/
Re: Birt Missing images on ProxyPass [message #756228 is a reply to message #756159] Fri, 11 November 2011 10:14 Go to previous messageGo to next message
If you use the /preview servlet mapping instead of the /frameset mapping
do the images come through?
Jason
On 11/11/2011 5:24 AM, Ville Kaukonen wrote:
> Hello,
> Apache config
> <VirtualHost *:443>
> LogLevel warn
> SSLEngine on
> ProxyRequests Off
> <Proxy *>
> Order deny,allow
> Allow from all
> </Proxy>
> </VirtualHost>
Re: Birt Missing images on ProxyPass [message #756536 is a reply to message #756228] Mon, 14 November 2011 04:06 Go to previous messageGo to next message
Jason Weathersby wrote on Fri, 11 November 2011 10:14
Jason
Yes on preview the images load fine.
Re: Birt Missing images on ProxyPass [message #756663 is a reply to message #756536] Mon, 14 November 2011 10:39 Go to previous messageGo to next message
Are you setting the base_url in the viewer properties?
Have a look at these:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=303453
https://bugs.eclipse.org/bugs/show_bug.cgi?id=266346
Jason
>> mapping do the images come through?
>> Jason
Re: Birt Missing images on ProxyPass [message #756809 is a reply to message #756663] Tue, 15 November 2011 03:50 Go to previous message
Jason Weathersby wrote on Mon, 14 November 2011 10:39
Jason
I haven't set base_url.
Joseph 2010-05-25 07:54:07 EDT on Bug 303453
There is no know way to configure BIRT so that it will work BOTH when access
directly and when accessed behind a reverse proxy.
Direct access is more important for me. Actually I can settle with the preview and pdf-format reports on DMZ-access. Maybe later setup another instance of Birt and configure it working properly from proxypass.
[Updated on: Tue, 15 November 2011 03:50] by Moderator
Previous Topic:PHP BIRT - Delete Session Folders
Next Topic:How to display empty columns in a crosstab
Current Time: Mon Jun 16 09:56:49 EDT 2025
Powered by FUDForum. Page generated in 0.09400 seconds
