Home » Modeling » TMF (Xtext) » Second GeneratorFragment
Second GeneratorFragment [message #756072] Thu, 10 November 2011 14:11 Go to next message
hi,
I have a problem with the second generator and I am getting a strange error message.
In the following I have posted some code to illustrate it (the error message is at the end of the posting).
package org.xtext.gui;
import org.xtext.gui.generator.GuiDslGeneratorAnother;
import com.google.inject.Guice;
import com.google.inject.Injector;
public class AnotherInjector extends GuiDslStandaloneSetup {
	public Injector createInjector() {
		return Guice.createInjector(new AnotherRuntimeModule());
	public class AnotherRuntimeModule extends GuiDslRuntimeModule {
		public Class<? extends org.eclipse.xtext.generator.IGenerator> bindIGenerator() {
			return GuiDslGeneratorAnother.class;
My GuiDslGeneratorMWE.mwe2 in the generator package looks like this:
module org.xtext.gui.generator.GuiDslGeneratorMWE
import org.eclipse.emf.mwe.utils.*
var targetDir = "src-gen"
var modelPath = "dmodel"
Workflow {
	component = org.eclipse.xtext.mwe.Reader {
		// lookup all resources on the classpath
		// useJavaClassPath = true
		// or define search scope explicitly
		path = modelPath
		// this class will be generated by the xtext generator
		register = org.xtext.gui.GuiDslStandaloneSetup {}
		loadResource = {
			slot = "model"
	component = org.eclipse.xtext.generator.GeneratorComponent {
		slot = 'model'
		outlet = {
			path = targetDir
In the generator package I have also created two xtend files:
GuiDslGenerator.xtend
GuiDslGeneratorAnother.xtend
But I am getting a strang error message now.
0 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.gui.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module org.xtext.gui.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:90)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:73)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:64)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:55)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
I hope you can help me out.
regards,
jens.
[Updated on: Thu, 10 November 2011 14:12] by Moderator
Re: Second GeneratorFragment [message #756088 is a reply to message #756072] Thu, 10 November 2011 15:12 Go to previous messageGo to next message
this looks ok from here - besides you dont actually use AnotherInjector .
did you try to debug into the code? from the stacktrace you posted one cannot see
where the InvocationTargetException comes from.
~Christian
Re: Second GeneratorFragment [message #756245 is a reply to message #756088] Fri, 11 November 2011 11:27 Go to previous messageGo to next message
hi,
sorry I don't know how to debug. I tried to keep it more simple.
So now I have only a console output in my generator file.
"run as" of the GuiDslGeneratorMWE.mwe2 file gives me the following response:
0 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
But there is no console output?
- System::out.println("Hello i'm the normal generator!");
package org.xtext.gui.generator
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.IGenerator
import org.eclipse.xtext.generator.IFileSystemAccess
import org.eclipse.xtext.xbase.compiler.*
import org.eclipse.xtext.xbase.*
import org.eclipse.xtext.common.types.*
import com.google.inject.*
import org.xtext.gui.guiDsl.*
import java.util.*
import static extension org.eclipse.xtext.xtend2.lib.ResourceExtensions.*
import org.eclipse.xtext.naming.*
class GuiDslGenerator implements IGenerator {
	@Inject extension IQualifiedNameProvider nameProvider
	override void doGenerate(Resource resource, IFileSystemAccess fsa) {
package org.xtext.gui.generator.another
import java.util.*
class AnotherGenerator implements IGenerator {
		System::out.println("Hello I'm another Generator!");
var modelPath  = "model"
Workflow {
		path = modelPath
		loadResource = {
			slot = "model"
		slot = 'model'
		outlet = {
			path = targetDir
I have created a folder "model" in my workspace.
With the file "gui.mydsl"
package com.gui {
	window win {
and so on..
regards,
jens
Even when I start a complete new project. I don't get the console output.
		for(e: resource.allContentsIterable.filter(typeof(PackageDeclaration))) {
	          	fsa.generateFile(
            	e.fullyQualifiedName.toString.replace(".", "/") + ".java",
            	e.compile)
How can I make sure, that the doGenerate-method is called?
[Updated on: Fri, 11 November 2011 14:21] by Moderator
Re: Second GeneratorFragment [message #756291 is a reply to message #756245] Fri, 11 November 2011 14:31 Go to previous messageGo to next message
here the steps for a new MyDsl Project
(1) create project with wizard and dont change anything and generate the language
(2) create a folder "model" in the runtimeproject and place a test.mydsl there
Hello Generator!
(3) change the generator workflow to
module org.xtext.example.mydsl.generator.MyDslGeneratorMWE
Workflow {
		path = modelPath
		register = org.xtext.example.mydsl.MyDslStandaloneSetup {}
		loadResource = {
			slot = "model"
		slot = 'model'
		outlet = {
			path = targetDir
(4) change the generator itself to
package org.xtext.example.mydsl.generator
class MyDslGenerator implements IGenerator {
		System::out.println("Hey here is the Generator")
(5) run the workflow
and it works
=> i think you dont read any model files.
did you place them in the right folder?
~Christian
[Updated on: Fri, 11 November 2011 14:32] by Moderator
Re: Second GeneratorFragment [message #756303 is a reply to message #756291] Fri, 11 November 2011 15:57 Go to previous messageGo to next message
hi,
thanks a lot. Now it works.
But I don't know what my fault was..
The only difference this time was, that I chose "Use Stable API only"
instead of "Use Experimental 2.0 Features (Compare, Refactoring and new Serializer)".
And I named my model file like the extensions.
regards, jens
Re: Second GeneratorFragment [message #756353 is a reply to message #756303] Sat, 12 November 2011 05:44 Go to previous messageGo to next message
update of my post:
It works now, but only when the beautifier is not activated.
in the .xtend file:
		System::out.println("Hey here is the Generator!!!!!!!!!!!")
	     fsa.generateFile(
	            e.fullyQualifiedName.toString.replace(".", "/") + "/Win" + ".java",
	            b.format(e.fullyQualifiedName.toString.replace(".", "/") + "/Win" + ".java",
	            e.compile))
package org.xtext.gui.dm.generator;
import java.io.File;
import org.eclipse.xpand2.output.FileHandle;
import org.eclipse.xpand2.output.FileHandleImpl;
import org.eclipse.xpand2.output.JavaBeautifier;
import org.eclipse.xpand2.output.Outlet;
import com.google.inject.Inject;
import com.google.inject.Singleton;
@Singleton
public class Beautifier {
	@Inject
	JavaBeautifier javaBeautifier;
	* Format code with PostProcessor (XPand style).
	public CharSequence format(String fileName, CharSequence code) {
		// create fileHandle with dummy outlet.
		File file = new File(fileName);
		FileHandle fileHandle = new FileHandleImpl(new Outlet(), file);
		fileHandle.setBuffer(code);
		// call postProcessor for formatting the code.
		javaBeautifier.beforeWriteAndClose(fileHandle);
		// return formatted results.
		return fileHandle.getBuffer();
With the activated beautifier I still get the error message:
1 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems instantiating module org.xtext.gui.dm.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: Problems instantiating module org.xtext.gui.dm.generator.GuiDslGeneratorMWE: java.lang.reflect.InvocationTargetException
regards,
Jens
Re: Second GeneratorFragment [message #756364 is a reply to message #756353] Sat, 12 November 2011 06:49 Go to previous messageGo to next message
why are your error messages so short - i get a full stacktrace that tells me to add
org.eclipse.jface.text, org.eclipse.jdt.core, org.eclipse.core.runtime to the deps.
~Christian
Re: Second GeneratorFragment [message #756381 is a reply to message #756364] Sat, 12 November 2011 09:08 Go to previous messageGo to next message
hi,
here is my full stackstrace:
It seem that I don't have the necessary library installed.
is not accessable.
"java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException"
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.reflect.InvocationTargetException
	at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:56)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:137)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:112)
	at org.eclipse.xtext.util.PolymorphicDispatcher.invoke(PolymorphicDispatcher.java:291)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalSwitch(Mwe2ExecutionEngine.java:64)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.internalApplyAssignments(Mwe2ExecutionEngine.java:136)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.inCase(Mwe2ExecutionEngine.java:78)
	at org.eclipse.emf.mwe2.language.factory.Mwe2ExecutionEngine.create(Mwe2ExecutionEngine.java:60)
	at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:88)
	... 5 more
Caused by: java.lang.reflect.InvocationTargetException
	at org.eclipse.emf.mwe2.language.factory.SettingProviderImpl$1$1.setValue(SettingProviderImpl.java:54)
	... 30 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
	at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:553)
	at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:419)
	at com.google.inject.internal.CustomConcurrentHashMap$ComputingImpl.get(CustomConcurrentHashMap.java:2041)
	at com.google.inject.internal.FailableCache.get(FailableCache.java:46)
	at com.google.inject.ConstructorInjectorStore.get(ConstructorInjectorStore.java:52)
	at com.google.inject.ConstructorBindingImpl.initialize(ConstructorBindingImpl.java:57)
	at com.google.inject.InjectorImpl.initializeBinding(InjectorImpl.java:377)
	at com.google.inject.InjectorImpl.createJustInTimeBinding(InjectorImpl.java:645)
	at com.google.inject.InjectorImpl.createJustInTimeBindingRecursive(InjectorImpl.java:581)
	at com.google.inject.InjectorImpl.getJustInTimeBinding(InjectorImpl.java:172)
	at com.google.inject.InjectorImpl.getBindingOrThrow(InjectorImpl.java:132)
	at com.google.inject.InjectorImpl.getInternalFactory(InjectorImpl.java:651)
	at com.google.inject.FactoryProxy.notify(FactoryProxy.java:48)
	at com.google.inject.BindingProcessor.runCreationListeners(BindingProcessor.java:230)
	at com.google.inject.InjectorBuilder.initializeStatically(InjectorBuilder.java:131)
	at com.google.inject.InjectorBuilder.build(InjectorBuilder.java:105)
	at com.google.inject.Guice.createInjector(Guice.java:92)
	at com.google.inject.Guice.createInjector(Guice.java:69)
	at com.google.inject.Guice.createInjector(Guice.java:59)
	at org.xtext.gui.dm.GuiDslStandaloneSetupGenerated.createInjector(GuiDslStandaloneSetupGenerated.java:26)
	at org.xtext.gui.dm.GuiDslStandaloneSetupGenerated.createInjectorAndDoEMFRegistration(GuiDslStandaloneSetupGenerated.java:20)
	at org.eclipse.xtext.mwe.AbstractReader.addRegister(AbstractReader.java:53)
	... 35 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
	at com.google.inject.MembersInjectorStore.get(MembersInjectorStore.java:66)
	at com.google.inject.ConstructorInjectorStore.createConstructor(ConstructorInjectorStore.java:69)
	at com.google.inject.ConstructorInjectorStore.access$000(ConstructorInjectorStore.java:31)
	at com.google.inject.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:39)
	at com.google.inject.ConstructorInjectorStore$1.create(ConstructorInjectorStore.java:35)
	at com.google.inject.internal.FailableCache$1.apply(FailableCache.java:35)
	at com.google.inject.internal.MapMaker$StrategyImpl.compute(MapMaker.java:549)
	... 56 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
	at com.google.inject.SingleFieldInjector.<init>(SingleFieldInjector.java:44)
	at com.google.inject.MembersInjectorStore.getInjectors(MembersInjectorStore.java:113)
	at com.google.inject.MembersInjectorStore.createWithListeners(MembersInjectorStore.java:83)
	at com.google.inject.MembersInjectorStore.access$000(MembersInjectorStore.java:35)
	at com.google.inject.MembersInjectorStore$1.create(MembersInjectorStore.java:43)
	at com.google.inject.MembersInjectorStore$1.create(MembersInjectorStore.java:40)
	... 66 more
Caused by: com.google.inject.internal.ComputationException: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
	... 85 more
Caused by: com.google.inject.internal.ComputationException: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
	... 95 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jface/text/BadLocationException
	at java.lang.Class.getDeclaredConstructors0(Native Method)
	at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
	at java.lang.Class.getDeclaredConstructors(Unknown Source)
	at com.google.inject.spi.InjectionPoint.forConstructorOf(InjectionPoint.java:185)
	at com.google.inject.ConstructorInjectorStore.createConstructor(ConstructorInjectorStore.java:61)
	... 114 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.jface.text.BadLocationException
	at java.net.URLClassLoader$1.run(Unknown Source)
	at java.net.URLClassLoader.findClass(Unknown Source)
	at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
	... 124 more
regards,
jens.
[Updated on: Sat, 12 November 2011 09:09] by Moderator
Re: Second GeneratorFragment [message #756384 is a reply to message #756381] Sat, 12 November 2011 09:12 Go to previous messageGo to next message
same as the message i got - the solution is clear
Re: Second GeneratorFragment [message #756405 is a reply to message #756384] Sat, 12 November 2011 14:40 Go to previous message
now it works, great. Thanks for your help.
Previous Topic:Extend javascript grammer
Next Topic:How to write Language Intellesense
Current Time: Sat Nov 01 18:49:32 EDT 2025
Powered by FUDForum. Page generated in 0.04385 seconds
