Home » Archived » BIRT » Birt 3.7 Maven repository
Birt 3.7 Maven repository [message #755795] Wed, 09 November 2011 10:42 Go to next message
Hello everybody.
I need to use BIRT Report Engine 3.7 in a web app, built with Gradle.
Gradle uses Maven repository to fetch dependencies, so I need to find all the jars/poms required in the Maven repo. I added the dependency, poms/jars were downloaded, then I got this runtime error:
org.eclipse.birt.report.engine.api.UnsupportedFormatException: The output format pdf is not supported.
	at org.eclipse.birt.report.engine.api.impl.EngineTask.setupRenderOption(EngineTask.java:1938)
	at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:96)
	at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
As I'm new to BIRT, I had to do some investigation. It appears to me that the PDF emitter (which I need) isn't present in the Maven central repo, only the HTML one.
Is this correct or am I missing something? If that is the case, how can I do to get things working? Maybe upload all the required jars (maybe from BIRT Report Engine package) to a local Maven repo, then using it to fetch my BIRT-related project dependencies?
Thanks in advance for any hints.
Fabio
Re: Birt 3.7 Maven repository [message #755867 is a reply to message #755795] Wed, 09 November 2011 16:46 Go to previous messageGo to next message
We are currently working on getting the BIRT libs in an official Maven
Repo, but currently your best approach is to just use a local repo.
Jason
On 11/9/2011 10:42 AM, Fabio Da Soghe wrote:
> Hello everybody.
> at
> at
> at
> Fabio
Re: Birt 3.7 Maven repository [message #757516 is a reply to message #755867] Fri, 18 November 2011 12:54 Go to previous messageGo to next message
Hi all,
what about:
h-ttp://wiki.eclipse.org/Maven_Tools_4_Eclipse
They are building maven.eclipse.com with that tool, there is even a Birt 2.6.2 in there. But since Birt 3.7 seams not to be part of Eclipse 3.7 it's not automatically there.
They even have a mode where maven central dependencies are used.
It might be easier to contact them and ask if they can push Birt 3.7 with that tool
into maven.eclipse.org.
Best wishes
stephan
Re: Birt 3.7 Maven repository [message #757839 is a reply to message #757516] Fri, 18 November 2011 17:20 Go to previous message
Stephan,
We will definately look in to this. BIRT 3.7 is part of the Eclipse
indigo release train. I wonder when 2.6.2 was uploaded?
Jason
On 11/18/2011 12:54 PM, koelle wrote:
> Hi all,
> what about:
> with that tool into maven.eclipse.org.
> Best wishes
> stephan
Previous Topic:Two Platforms
Next Topic:Is it possible to remove postscript option in Export Format window?
Current Time: Sun Nov 09 23:02:16 EST 2025
Powered by FUDForum. Page generated in 0.26093 seconds
