Re: What Should I do? [message #755808 is a reply to message #755765] |
Wed, 09 November 2011 16:11 |
On 09-Nov-11 07:15, connorcactus wrote:
> Well, in order to make an android app, should I learn basic java code?
> Or is there some other type of code that coding apps requires? I would
> like to learn how to make an app and the java for video games, but I'm
> not sure if the code is the same, or what.
> I got a book: Java: a Beginner's Guide by Herbert Schildt
> Will that help me? Or do I need something else? Thanks in advance! :p
Start with the first tutorial link at
http://www.vogella.de/android.html. Lars' tutorials are simply the cat's
meow. You can't go wrong.
Best of luck.
Re: What Should I do? [message #755823 is a reply to message #755817] |
Wed, 09 November 2011 17:00 |
On 09-Nov-11 09:41, Khono wrote:
> Russell Bateman wrote on Wed, 09 November 2011 11:11
>> Start with the first tutorial link at Lars' tutorials are simply the
>> cat's meow. You can't go wrong.
>> Best of luck.
> The link in the above post didn't work because he put a period at the
> end :p.
> I still can't post links so just be sure to remove the period if you
> follow his link. Tried to send him a PM but he's blocking :(
> P.S. LOL I couldn't even quote the link from his message >D
I'm sure you can figure out how to work around the fact that you have to
remove the period to make the resulting link work. (The link made as
received by those of us using NNTP to work this forum isn't wrong, but
neither does the surreptitious addition of a dot break the usefulness of
a post.)
FUDForum. Page generated in 0.06547 seconds
