Re: Iterative export of ecore to UML2 [message #755689 is a reply to message #755667] |
Wed, 09 November 2011 10:18 |
Ed Willink Messages: 7655 Registered: July 2009 |
Hi Vlad
I recommend using *.uml as your primary artefact and *.ecore as a
derived artefact.
Sadly the editor tooling isn't as good.
Papyrus Class Diagrams are ok.
UML Model editor is quite painful.
OCLinEcore can load but cannot yet save UML.
Ed Willink
On 09/11/2011 09:12, Vlad Gheorghe wrote:
> Hello,
> Suppose that we have an ecore model (M.ecore), which we want to
> convert to an UML model, so that it can be referenced in other UML
> models as a design artefact.
> During development, it is expected that M.ecore is changed several
> times, and M.uml must be updated each time.
> The problem is that at each 'Export model...' run on M.genmodel, M.uml
> is generated, but with different xmi:id attributes.
> How can the xmi:id attributes be preserved from the existing target
> model for the unchanged model elements ?
> Regards,
> Vlad Gheorghe
FUDForum. Page generated in 0.03633 seconds
