Virgo web extender standalone [message #755654] |
Wed, 09 November 2011 08:41 |
I would like to benefit of the Virgo web-extender capability without using Virgo server (I already use Pax to compile and run my projects, which is fully server agnostic).
Would it be possible to improve Virgo structure in order to make it possible?
This is for me a serious issue because I can't use any servlet3 compliant web container without brainstorming for a long time on the source code of one of these projects (Gemini web, Jetty 8/Tomcat 7, Spring-Dm/Virgo web-extender).
I made an example on Spring-DM that has this functionnality, you can use it for your tests:
http://hudson.osgiliath.net/job/orthank-sample%20Tag/ws/
In order to compile, you just need to have maven 3 and run: mvn clean install -DskipTests=true (integration tests are not stable for now).
Then, in order to launch run: mvn pax:provision -Dframework=equinox (or -Dframework=felix) and point your browser to http://localhost:8080/net.osgiliath.orthank-sample.java.web.simple_1.0.1.SNAPSHOT
You'll be able to say hello with web services.
You can desactivate ws client module to run it without ws.
Charlie (tcharl on twitter, cmordant1@gmail.com on gtalk)
FUDForum. Page generated in 0.04549 seconds
