Re: How to increase column width in excel report [message #755561 is a reply to message #755422] |
Tue, 08 November 2011 19:49 |
Does it work if you change the layout to fixed and then increase the
size of the master page?
Jason
On 11/8/2011 7:46 AM, Petr Kostroun wrote:
> Hi, I need increase column width in excel report. In report designer has column good width, but in report is very small. Can someone give me the point how to solve this issue? My report is in attachment
> Thanks.
Re: How to increase column width in excel report [message #756057 is a reply to message #755933] |
Thu, 10 November 2011 17:07 |
You set the height and width on the same property view. You should also
try fixed layout. I modified the report and it is attached.
Jason
On 11/10/2011 4:09 AM, Petr Kostroun wrote:
> Thanks for reply. I tryed to change MasterPage type from A4 to custom,
> ande then inrease page width. But IDE complains, that I have to
> specified page size, when I set page type to custom. Can I ask please
> what I have to set? (I set page width and height).
FUDForum. Page generated in 0.03271 seconds
