Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Can someone provide an example of using the @IdBag annotation in Elver...
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #84858 is a reply to message #84800] |
Fri, 25 May 2007 04:27 |
The syntax is: @IdBag (the source of the annotation is teneo.hibernate).
But I am not sure if this will solve your problem. The hibernate docs say this about it (section 11.3):
Note that, in the current implementation, only one collection role may be fetched in a query
(everything else would be non-performant). Note also that the fetch construct may not be used in
queries called using scroll() or iterate(). Finally, note that full join fetch and right join fetch
are not meaningful.
Afaik the join behavior of an idbag is the same as for a bag. It is more the update and insert
behavior which is better.
gr. Martin
Michael Kanaley wrote:
> What is the syntax of the annotation?
> I have attached an ecore as an example that is working with the "refs"
> EAttribute of SomeClass using bags. I would like it to use IdBags instead.
> Also, as a side note, the real problem that I am trying to work around is
> the following Hibernate exception when left joins on multiple bag attributes
> are done.
> "org.hibernate.HibernateException: cannot simultaneously fetch multiple
> bags".
> Will switching to idbags fix this issue?
> -mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #84919 is a reply to message #84858] |
Fri, 25 May 2007 14:26 |
Michael Kanaley Messages: 89 Registered: July 2009 |
Member |
Hi Martin,
Sorry it was not clear from my first email but setting the @IdBag
annotation does not work.
Simply add the @IdBag annotation to the example I sent in the beginning. The
mapping generated is:
<idbag name="refs" table="someclass_someotherclass" lazy="true"
cascade="all,delete-orphan">
<collection-id column="ID" type="long">
<generator class="increment"/>
</collection-id>
<key/>
<many-to-many entity-name="SomeOtherClass" unique="false"/>
</idbag>
This does not look right but any attempt to set something does not work. Is
there an @IdBag test suite I can look at?
And the exception thrown is:
May 25, 2007 10:13:17 AM org.apache.commons.logging.impl.SLF4JLog trace
FINE: executing flush
FINE: registering flush begin
May 25, 2007 10:13:17 AM org.apache.commons.logging.impl.SLF4JLog debug
FINE: Inserting collection: [SomeClass.refs#1]
FINE: fetching initial value: select max(ID) from someclass_someotherclass
FINE: about to open PreparedStatement (open PreparedStatements: 0, globally:
0)
FINE: select max(ID) from someclass_someotherclass
FINE: preparing statement
FINE: first free id: 1
FINE: about to close PreparedStatement (open PreparedStatements: 1,
globally: 1)
FINE: closing statement
May 25, 2007 10:13:18 AM org.apache.commons.logging.impl.SLF4JLog debug
0)
FINE: insert into someclass_someotherclass (id, ID, elt) values (?, ?, ?)
May 25, 2007 10:13:18 AM org.apache.commons.logging.impl.SLF4JLog trace
FINE: could not insert collection: [SomeClass.refs#1] [insert into
someclass_someotherclass (id, ID, elt) values (?, ?, ?)]
java.sql.SQLException: Column count does not match in statement [insert into
at org.hsqldb.jdbc.Util.throwError(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.<init>(Unknown Source)
at org.hsqldb.jdbc.jdbcConnection.prepareStatement(Unknown Source)
at
org.hibernate.jdbc.AbstractBatcher.getPreparedStatement(Abst ractBatcher.java:497)
at
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:94)
at
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:87)
at
org.hibernate.jdbc.AbstractBatcher.prepareBatchStatement(Abs tractBatcher.java:218)
at
org.hibernate.persister.collection.AbstractCollectionPersist er.recreate(AbstractCollectionPersister.java:1119)
at
org.hibernate.action.CollectionRecreateAction.execute(Collec tionRecreateAction.java:26)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:24 8)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:232)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:143)
at
org.hibernate.event.def.AbstractFlushingEventListener.perfor mExecutions(AbstractFlushingEventListener.java:298)
at
org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:27)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
at org.hibernate.impl.SessionImpl.managedFlush(SessionImpl.java :338)
at
org.hibernate.transaction.JDBCTransaction.commit(JDBCTransac tion.java:106)
at test.TestBag.test(TestBag.java:97)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:128)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Also note that the Hibernate doc section you are referring to has changed to
14.3 for Hibernate 3.2.2 and it's content is slightly different.
http://www.hibernate.org/hib_docs/v3/reference/en/html_singl e/#queryhql-joins
It no longer indicates that only one left joined collection is supported -
but in practice, I have seen it only work with one collection.
-mike
"Martin Taal" <mtaal@elver.org> wrote in message
news:f35oj1$irq$1@build.eclipse.org...
> fetched in a query (everything else would be non-performant). Note also
> that the fetch construct may not be used in queries called using scroll()
> or iterate(). Finally, note that full join fetch and right join fetch are
> not meaningful.
> the update and insert behavior which is better.
> gr. Martin
>> instead.
>> attributes are done.
>> bags".
>> Thanks,
>> -mike
> The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #85089 is a reply to message #84919] |
Fri, 25 May 2007 18:34 |
Hi Mike,
The mapping looks fine afaics. How many (and which) columns does the someclass_someotherclass table
have?
gr. Martin
> Hi Martin,
> </collection-id>
> <key/>
> </idbag>
> 0)
> globally: 1)
> 0)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> -mike
>> not meaningful.
>> gr. Martin
>>> instead.
>>> bags".
>>> Thanks,
>>> -mike
>> The Netherlands
The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #85104 is a reply to message #85089] |
Fri, 25 May 2007 20:48 |
Member |
The attached image indicates that there are only 2 generated, ID and ELT.
That seems right - why does the Teneo commit fail?
-mike
news:f37a8j$38d$2@build.eclipse.org...
> Hi Mike,
> have?
> gr. Martin
>> Hi Martin,
>> The
>> </collection-id>
>> <key/>
>> </idbag>
>> Is
>> globally:
>> 0)
>> globally: 1)
>> globally:
>> 0)
>> into
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> to
>> supported -
>> Thanks,
>> -mike
>>> say
>>> be
>>> scroll()
>>> are
>>> not meaningful.
>>> gr. Martin
>>>> instead.
>>>> is
>>>> bags".
>>>> Thanks,
>>>> -mike
>>> The Netherlands
> The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #85121 is a reply to message #85104] |
Fri, 25 May 2007 21:33 |
There should be three, two for the joins to both tables (parent and child) (id and elt) and one for
the id of the idbag entry itself (ID). My guess is that there is a nameclash between the id fields.
Although one is lowercase (id) and the other uppercase (ID) hsqldb does not seem to make a difference.
I encountered the same thing in a customer project I am doing right now. I have added an option to
set the name of the idbag id element and this solved the issue for me.
However, it will take a few weeks before I do a new release with this solution.
gr. Martin
> -mike
>> Hi Mike,
>> have?
>> gr. Martin
>>> Hi Martin,
>>> The
>>> </collection-id>
>>> <key/>
>>> </idbag>
>>> Is
>>> globally:
>>> 0)
>>> globally: 1)
>>> globally:
>>> 0)
>>> into
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> to
>>> supported -
>>> Thanks,
>>> -mike
>>>> say
>>>> be
>>>> scroll()
>>>> are
>>>> not meaningful.
>>>> gr. Martin
>>>>> instead.
>>>>> is
>>>>> bags".
>>>>> Thanks,
>>>>> -mike
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #85442 is a reply to message #85121] |
Fri, 01 June 2007 11:46 |
Member |
Hi Martin,
Did you file a bug for this issue below. I am interested in this fix (for
the 0.7.5 releases) and want to track it so I know which version of Teneo it
is supported in.
-mike
news:f37kn7$71f$1@build.eclipse.org...
> (id and elt) and one for the id of the idbag entry itself (ID). My guess
> is that there is a nameclash between the id fields. Although one is
> difference.
> have added an option to set the name of the idbag id element and this
> solution.
> gr. Martin
>> -mike
>>> Hi Mike,
>>> have?
>>> gr. Martin
>>>> Hi Martin,
>>>> beginning. The
>>>> </collection-id>
>>>> <key/>
>>>> </idbag>
>>>> work. Is
>>>> globally:
>>>> 0)
>>>> globally: 1)
>>>> globally:
>>>> 0)
>>>> into
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> changed to
>>>> supported -
>>>> Thanks,
>>>> -mike
>>>>> teneo.hibernate).
>>>>> say
>>>>> be
>>>>> also
>>>>> scroll()
>>>>> are
>>>>> not meaningful.
>>>>> more
>>>>> gr. Martin
>>>>>> "refs"
>>>>>> instead.
>>>>>> around is
>>>>>> multiple
>>>>>> bags".
>>>>>> Thanks,
>>>>>> -mike
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #85472 is a reply to message #85442] |
Sat, 02 June 2007 04:53 |
Hi Mike,
I solved this in the 0.8.0 release. Please enter a bugzilla to get it also back into 0.7.5.
gr. Martin
> Hi Martin,
> is supported in.
> -mike
>> difference.
>> solution.
>> gr. Martin
>>> -mike
>>>> Hi Mike,
>>>> have?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> beginning. The
>>>>> </collection-id>
>>>>> <key/>
>>>>> </idbag>
>>>>> work. Is
>>>>> globally:
>>>>> 0)
>>>>> globally: 1)
>>>>> globally:
>>>>> 0)
>>>>> into
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> changed to
>>>>> supported -
>>>>> Thanks,
>>>>> -mike
>>>>>> teneo.hibernate).
>>>>>> say
>>>>>> be
>>>>>> also
>>>>>> scroll()
>>>>>> are
>>>>>> not meaningful.
>>>>>> more
>>>>>> gr. Martin
>>>>>>> "refs"
>>>>>>> instead.
>>>>>>> around is
>>>>>>> multiple
>>>>>>> bags".
>>>>>>> Thanks,
>>>>>>> -mike
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #85547 is a reply to message #85472] |
Tue, 05 June 2007 19:57 |
Member |
Filed bug 191110: Backport fix for using @IdBag annotation from 0.8.0 to
0.7.5
-mike
news:f3qt4b$nnm$2@build.eclipse.org...
> Hi Mike,
> back into 0.7.5.
> gr. Martin
>> Hi Martin,
>> (for the 0.7.5 releases) and want to track it so I know which version of
>> Teneo it is supported in.
>> Thanks,
>> -mike
>>> child) (id and elt) and one for the id of the idbag entry itself (ID).
>>> My guess is that there is a nameclash between the id fields. Although
>>> I have added an option to set the name of the idbag id element and this
>>> solution.
>>> gr. Martin
>>>> ELT.
>>>> -mike
>>>>> Hi Mike,
>>>>> have?
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> beginning. The
>>>>>> </collection-id>
>>>>>> <key/>
>>>>>> </idbag>
>>>>>> work. Is
>>>>>> trace
>>>>>> trace
>>>>>> debug
>>>>>> debug
>>>>>> debug
>>>>>> globally:
>>>>>> 0)
>>>>>> debug
>>>>>> trace
>>>>>> debug
>>>>>> debug
>>>>>> globally: 1)
>>>>>> trace
>>>>>> debug
>>>>>> globally:
>>>>>> 0)
>>>>>> debug
>>>>>> trace
>>>>>> debug
>>>>>> [insert into
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> changed to
>>>>>> supported -
>>>>>> Thanks,
>>>>>> -mike
>>>>>>> teneo.hibernate).
>>>>>>> docs say
>>>>>>> may be
>>>>>>> also
>>>>>>> scroll()
>>>>>>> fetch are
>>>>>>> not meaningful.
>>>>>>> more
>>>>>>> gr. Martin
>>>>>>>> "refs"
>>>>>>>> instead.
>>>>>>>> around is
>>>>>>>> multiple
>>>>>>>> bags".
>>>>>>>> Thanks,
>>>>>>>> -mike
>>>>>>> The Netherlands
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606787 is a reply to message #84800] |
are not meaningful.
gr. Martin
> are done.
> bags".
> -mike
The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606791 is a reply to message #84858] |
Member |
Hi Martin,
</collection-id>
<key/>
</idbag>
0)
globally: 1)
0)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
-mike
> not meaningful.
> gr. Martin
>> instead.
>> bags".
>> Thanks,
>> -mike
> The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606802 is a reply to message #84919] |
Hi Mike,
have?
gr. Martin
> Hi Martin,
> </collection-id>
> <key/>
> </idbag>
> 0)
> globally: 1)
> 0)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> -mike
>> not meaningful.
>> gr. Martin
>>> instead.
>>> bags".
>>> Thanks,
>>> -mike
>> The Netherlands
The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606803 is a reply to message #85089] |
Member |
-mike
> Hi Mike,
> have?
> gr. Martin
>> Hi Martin,
>> The
>> </collection-id>
>> <key/>
>> </idbag>
>> Is
>> globally:
>> 0)
>> globally: 1)
>> globally:
>> 0)
>> into
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> to
>> supported -
>> Thanks,
>> -mike
>>> say
>>> be
>>> scroll()
>>> are
>>> not meaningful.
>>> gr. Martin
>>>> instead.
>>>> is
>>>> bags".
>>>> Thanks,
>>>> -mike
>>> The Netherlands
> The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606804 is a reply to message #85104] |
gr. Martin
> -mike
>> Hi Mike,
>> have?
>> gr. Martin
>>> Hi Martin,
>>> The
>>> </collection-id>
>>> <key/>
>>> </idbag>
>>> Is
>>> globally:
>>> 0)
>>> globally: 1)
>>> globally:
>>> 0)
>>> into
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> to
>>> supported -
>>> Thanks,
>>> -mike
>>>> say
>>>> be
>>>> scroll()
>>>> are
>>>> not meaningful.
>>>> gr. Martin
>>>>> instead.
>>>>> is
>>>>> bags".
>>>>> Thanks,
>>>>> -mike
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606848 is a reply to message #85121] |
Member |
Hi Martin,
is supported in.
-mike
> difference.
> solution.
> gr. Martin
>> -mike
>>> Hi Mike,
>>> have?
>>> gr. Martin
>>>> Hi Martin,
>>>> beginning. The
>>>> </collection-id>
>>>> <key/>
>>>> </idbag>
>>>> work. Is
>>>> globally:
>>>> 0)
>>>> globally: 1)
>>>> globally:
>>>> 0)
>>>> into
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> changed to
>>>> supported -
>>>> Thanks,
>>>> -mike
>>>>> teneo.hibernate).
>>>>> say
>>>>> be
>>>>> also
>>>>> scroll()
>>>>> are
>>>>> not meaningful.
>>>>> more
>>>>> gr. Martin
>>>>>> "refs"
>>>>>> instead.
>>>>>> around is
>>>>>> multiple
>>>>>> bags".
>>>>>> Thanks,
>>>>>> -mike
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606851 is a reply to message #85442] |
Hi Mike,
gr. Martin
> Hi Martin,
> is supported in.
> -mike
>> difference.
>> solution.
>> gr. Martin
>>> -mike
>>>> Hi Mike,
>>>> have?
>>>> gr. Martin
>>>>> Hi Martin,
>>>>> beginning. The
>>>>> </collection-id>
>>>>> <key/>
>>>>> </idbag>
>>>>> work. Is
>>>>> globally:
>>>>> 0)
>>>>> globally: 1)
>>>>> globally:
>>>>> 0)
>>>>> into
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> changed to
>>>>> supported -
>>>>> Thanks,
>>>>> -mike
>>>>>> teneo.hibernate).
>>>>>> say
>>>>>> be
>>>>>> also
>>>>>> scroll()
>>>>>> are
>>>>>> not meaningful.
>>>>>> more
>>>>>> gr. Martin
>>>>>>> "refs"
>>>>>>> instead.
>>>>>>> around is
>>>>>>> multiple
>>>>>>> bags".
>>>>>>> Thanks,
>>>>>>> -mike
>>>>>> The Netherlands
>>>> The Netherlands
>> The Netherlands
The Netherlands
Re: Can someone provide an example of using the @IdBag annotation in Elver... [message #606859 is a reply to message #85472] |
Member |
0.7.5
-mike
> Hi Mike,
> back into 0.7.5.
> gr. Martin
>> Hi Martin,
>> Thanks,
>> -mike
>>> solution.
>>> gr. Martin
>>>> ELT.
>>>> -mike
>>>>> Hi Mike,
>>>>> have?
>>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> beginning. The
>>>>>> </collection-id>
>>>>>> <key/>
>>>>>> </idbag>
>>>>>> work. Is
>>>>>> trace
>>>>>> trace
>>>>>> debug
>>>>>> debug
>>>>>> debug
>>>>>> globally:
>>>>>> 0)
>>>>>> debug
>>>>>> trace
>>>>>> debug
>>>>>> debug
>>>>>> globally: 1)
>>>>>> trace
>>>>>> debug
>>>>>> globally:
>>>>>> 0)
>>>>>> debug
>>>>>> trace
>>>>>> debug
>>>>>> [insert into
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> changed to
>>>>>> supported -
>>>>>> Thanks,
>>>>>> -mike
>>>>>>> teneo.hibernate).
>>>>>>> docs say
>>>>>>> may be
>>>>>>> also
>>>>>>> scroll()
>>>>>>> fetch are
>>>>>>> not meaningful.
>>>>>>> more
>>>>>>> gr. Martin
>>>>>>>> "refs"
>>>>>>>> instead.
>>>>>>>> around is
>>>>>>>> multiple
>>>>>>>> bags".
>>>>>>>> Thanks,
>>>>>>>> -mike
>>>>>>> The Netherlands
>>>>> The Netherlands
>>> The Netherlands
> The Netherlands
Current Time: Sat Apr 27 04:21:02 GMT 2024
Powered by FUDForum. Page generated in 0.04650 seconds
