Home » Modeling » GMF (Graphical Modeling Framework) » GMF editors for .gmfgen, .gmfmap, .gmftool and gmfgraph
GMF editors for .gmfgen, .gmfmap, .gmftool and gmfgraph [message #754700] |
Thu, 03 November 2011 21:52 |
John Yotka Messages: 144 Registered: July 2009 |
I've downloaded the Indigo release (modeling version) and have the GMF
SDK installed but the various editors for the .gmfxxxx files are not
available. When I look at the eclipse installation details the plugin
list doesn't show any of the org.eclipse.gmf.codegen,
org.eclipse.gmf.graphdef, or org.eclipse.gmf.map plugins. but they are
in the plugins directory. I started indigo up with the -debug switch,
but nothing in that log. the error log is attached but I don't see
anything related to GMF.
!SESSION 2011-11-03 10:37:04.160 -----------------------------------------------
eclipse.buildId=I20110613-1736
java.version=1.6.0_11
Framework arguments: -product org.eclipse.epp.package.modeling.product -product org.eclipse.epp.package.modeling.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.modeling.product -data C:\eclipse\workspaces\indigo\dice -product org.eclipse.epp.package.modeling.product -clean
!ENTRY org.eclipse.jface 2 0 2011-11-03 10:37:35.537
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2011-11-03 10:37:35.537
!MESSAGE A conflict occurred for ALT+CTRL+I:
Binding(ALT+CTRL+I,
ParameterizedCommand(Command(org.eclipse.egit.ui.team.Ignore,Ignore,
Category(org.eclipse.egit.ui.commandCategory,Git,null,true),
org.eclipse.egit.ui.internal.actions.IgnoreActionHandler,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
Binding(ALT+CTRL+I,
ParameterizedCommand(Command(org.eclipse.team.svn.ui.command.AddToSVNIgnoreCommand,Add to svn:ignore...,
Category(org.eclipse.team.svn.ui.command.category,SVN,null,true),
,,true),null),
!MESSAGE A conflict occurred for ALT+CTRL+C:
Binding(ALT+CTRL+C,
ParameterizedCommand(Command(org.eclipse.egit.ui.team.Commit,Commit,
,,true),null),
Binding(ALT+CTRL+C,
ParameterizedCommand(Command(org.eclipse.team.svn.ui.command.CommitCommand,Commit...,
,,true),null),
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:02:45.014
!MESSAGE Provisioning exception
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at http://download.eclipse.org/rt/rap/1.4/incubator/20111010_2320.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:393)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:675)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:92)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.addChild(CompositeMetadataRepository.java:165)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository.<init>(CompositeMetadataRepository.java:105)
at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load(CompositeMetadataRepositoryFactory.java:122)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad(MetadataRepositoryManager.java:57)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:749)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:651)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.doLoad(LoadMetadataRepositoryJob.java:117)
at org.eclipse.equinox.p2.ui.LoadMetadataRepositoryJob.runModal(LoadMetadataRepositoryJob.java:102)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryHandler$2.runModal(PreloadingRepositoryHandler.java:82)
at org.eclipse.equinox.p2.operations.ProvisioningJob.run(ProvisioningJob.java:177)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:02:45.014
!MESSAGE No repository found at http://download.eclipse.org/rt/rap/1.4/incubator/20111010_2320.
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:05:53.030
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at http://download.eclipse.org/modeling/emf/cdo/updates/3.0-releases/.
at org.eclipse.equinox.p2.engine.ProvisioningContext.loadMetadataRepository(ProvisioningContext.java:211)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedMetadataRepositories(ProvisioningContext.java:194)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getMetadata(ProvisioningContext.java:275)
at org.eclipse.equinox.internal.p2.director.SimplePlanner.gatherAvailableInstallableUnits(SimplePlanner.java:258)
at org.eclipse.equinox.internal.p2.director.SimplePlanner.getSolutionFor(SimplePlanner.java:318)
at org.eclipse.equinox.internal.p2.director.SimplePlanner.getProvisioningPlan(SimplePlanner.java:376)
at org.eclipse.equinox.internal.p2.operations.PlannerResolutionJob.runModal(PlannerResolutionJob.java:76)
at org.eclipse.equinox.p2.operations.ProfileChangeOperation.resolveModal(ProfileChangeOperation.java:115)
at org.eclipse.equinox.internal.p2.ui.dialogs.ProvisioningOperationWizard$1.run(ProvisioningOperationWizard.java:213)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:05:53.030
!MESSAGE No repository found at http://download.eclipse.org/modeling/emf/cdo/updates/3.0-releases/.
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:07:08.860
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at http://download.eclipse.org/modeling/emf/teneo/updates/1.2.0/releases/.
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:07:08.860
!MESSAGE No repository found at http://download.eclipse.org/modeling/emf/teneo/updates/1.2.0/releases/.
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:08:22.301
!STACK 1
org.eclipse.equinox.p2.core.ProvisionException: No repository found at http://download.eclipse.org/modeling/mdt/uml2tools/updates/releases/.
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:08:22.301
!MESSAGE No repository found at http://download.eclipse.org/modeling/mdt/uml2tools/updates/releases/.
!ENTRY org.eclipse.equinox.p2.operations 2 0 2011-11-03 11:08:44.318
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.operations 2 10001 2011-11-03 11:08:44.318
!MESSAGE Your original request has been modified.
!SUBENTRY 2 org.eclipse.equinox.p2.operations 2 10004 2011-11-03 11:08:44.318
!MESSAGE "EMF Compare" will be ignored because a newer version is already installed.
!MESSAGE "EMF Compare Documentation" will be ignored because a newer version is already installed.
!MESSAGE "EMF Compare SDK" will be ignored because a newer version is already installed.
!MESSAGE "EMF Compare Source" will be ignored because a newer version is already installed.
!MESSAGE "EMF Compare UI capabilities" will be ignored because a newer version is already installed.
!MESSAGE "EMF Compare UI Capabilities Source" will be ignored because a newer version is already installed.
!ENTRY org.eclipse.equinox.p2.operations 2 0 2011-11-03 11:08:44.333
!SUBENTRY 1 org.eclipse.equinox.p2.operations 2 10001 2011-11-03 11:08:44.333
!SUBENTRY 2 org.eclipse.equinox.p2.operations 2 10004 2011-11-03 11:08:44.333
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:08:51.443
!STACK 1
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:100)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.loadRepository(ArtifactRepositoryManager.java:96)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.load(CompositeArtifactRepository.java:474)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.addChild(CompositeArtifactRepository.java:171)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepository.<init>(CompositeArtifactRepository.java:95)
at org.eclipse.equinox.internal.p2.artifact.repository.CompositeArtifactRepositoryFactory.load(CompositeArtifactRepositoryFactory.java:116)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.factoryLoad(ArtifactRepositoryManager.java:69)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getLoadedArtifactRepositories(ProvisioningContext.java:160)
at org.eclipse.equinox.p2.engine.ProvisioningContext.getArtifactRepositories(ProvisioningContext.java:143)
at org.eclipse.equinox.internal.p2.engine.phases.Sizing.completePhase(Sizing.java:91)
at org.eclipse.equinox.internal.p2.engine.Phase.postPerform(Phase.java:216)
at org.eclipse.equinox.internal.p2.engine.Phase.perform(Phase.java:84)
at org.eclipse.equinox.internal.p2.engine.PhaseSet.perform(PhaseSet.java:44)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:75)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:44)
at org.eclipse.equinox.internal.p2.ui.ProvUI.getSize(ProvUI.java:230)
at org.eclipse.equinox.internal.p2.ui.dialogs.SizeComputingWizardPage$1.run(SizeComputingWizardPage.java:63)
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1000 2011-11-03 11:08:51.443
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:09:07.100
!STACK 1
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository(AbstractRepositoryManager.java:636)
at org.eclipse.equinox.internal.p2.engine.EngineSession.rollBackPhase(EngineSession.java:239)
at org.eclipse.equinox.internal.p2.engine.EngineSession.rollback(EngineSession.java:178)
at org.eclipse.equinox.internal.p2.engine.Engine.perform(Engine.java:84)
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1000 2011-11-03 11:09:07.100
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:09:12.288
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1000 2011-11-03 11:09:12.288
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:09:52.868
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1000 2011-11-03 11:09:52.868
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:10:19.791
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 1000 2011-11-03 11:10:19.791
!SESSION 2011-11-03 11:13:02.170 -----------------------------------------------
!ENTRY org.eclipse.jface 2 0 2011-11-03 11:13:34.529
!SUBENTRY 1 org.eclipse.jface 2 0 2011-11-03 11:13:34.529
Binding(ALT+CTRL+I,
,,true),null),
Binding(ALT+CTRL+I,
,,true),null),
Binding(ALT+CTRL+C,
,,true),null),
Binding(ALT+CTRL+C,
,,true),null),
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:19:17.063
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:19:17.063
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:19:33.781
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:19:33.781
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:19:55.375
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:19:55.375
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:20:27.969
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.p2.metadata.repository 4 1000 2011-11-03 11:20:27.969
!ENTRY org.eclipse.equinox.p2.core 4 0 2011-11-03 11:25:37.412
!STACK 1
Current Time: Wed Sep 25 15:58:47 GMT 2024
Powered by FUDForum. Page generated in 0.03153 seconds
