Home » Modeling » TMF (Xtext) » left recursion problem(I don't understand the left recursion)
left recursion problem [message #754645] Thu, 03 November 2011 14:01 Go to next message
I have a problem with the left recursion. I looked it up in the xtext documentation, but I didn't understand it. I hope you can help me out.
The error message is:
error(211): ../org.xtext.gui/src-gen/org/xtext/gui/parser/antlr/internal/InternalGuiDsl.g:257:1: [fatal] rule ruleWindow has non-LL(*) decision due to recursive rule invocations reachable from alts 1,2. Resolve by left-factoring or using syntactic predicates or using backtrack=true option.
warning(200): ../org.xtext.gui/src-gen/org/xtext/gui/parser/antlr/internal/InternalGuiDsl.g:257:1: Decision can match input such as "'tabContainer' RULE_ID '{' '}'" using multiple alternatives: 1, 2
As a result, alternative(s) 2 were disabled for that input
Here is my dsl:
Window:
'window' name=ID '{'
(tabContainer+=TabContainer)? /* HERE IS THE PROBLEM */
(components+=Component)*
TabContainer:
'tabContainer' name=ID '{'
(tabItems+=TabItem)*
TabItem:
'tabItem' name=ID '{'
panel+=Panel
Component:
Panel | TabContainer | Label | Button | ComboBox | ListBox | CheckBox | DropDown
Panel:
'panel' name=ID '{'
(layoutManager+=LayoutManager)?
(components+= Component)+
Re: left recursion problem [message #754648 is a reply to message #754645] Thu, 03 November 2011 14:09 Go to previous messageGo to next message
If you have one tabcontainer - is this the optional one or one from
the components list? Regards Christian
Re: left recursion problem [message #754653 is a reply to message #754648] Thu, 03 November 2011 14:45 Go to previous messageGo to next message
hi Christian,
sorry I updated my dsl.
The window can have either one TabContainer or 1-* Panels. I have still the
left recursion problem. The problem exists now in the panel (because of the OR-statement.
Remark:
If I try it like this, it works (instead of the OR-statement):
Panel:
'panel' name=ID '{'
DSL:
Window:
(tabContainer+=TabContainer) |
(panel+=Panel)+
Panel:
'panel' name=ID '{'
(layoutManager+=LayoutManager)? | /* here is the problem */
LayoutManager:
'layoutManager' name=ID '{'
Component:
[Updated on: Thu, 03 November 2011 14:49] by Moderator
Re: left recursion problem [message #754655 is a reply to message #754653] Thu, 03 November 2011 14:58 Go to previous messageGo to next message
No,
the problem is still the same.
if you have only one tabcontainer. is this the tabcontainer or one panel?
~Christian
Re: left recursion problem [message #754662 is a reply to message #754653] Thu, 03 November 2011 15:16 Go to previous messageGo to next message
How does your layout mgr rule look like?
On 2011-11-03 18:45:08 +0000, Jens said:
> hi Christian,
> the left recursion problem. The problem exists now in the panel
> Window:
> (tabContainer+=TabContainer) | (panel+=Panel)+
> Panel:
> 'panel' name=ID '{'
Re: left recursion problem [message #754663 is a reply to message #754662] Thu, 03 November 2011 15:22 Go to previous messageGo to next message
hi,
LayoutManager:
Re: left recursion problem [message #754664 is a reply to message #754663] Thu, 03 November 2011 15:32 Go to previous messageGo to next message
On 2011-11-03 19:22:25 +0000, Jens said:
> LayoutManager:
Works perfect for me,
can you post a complete reproducable grammar?
thx Christian
Re: left recursion problem [message #754678 is a reply to message #754664] Thu, 03 November 2011 16:28 Go to previous messageGo to next message
sure.
DomainModel:
(elements+=PackageDeclaration);
PackageDeclaration:
'package' name=QualifiedName '{'
(elements+=Window)*
QualifiedNameWithWildcard:
QualifiedName '.*'?;
QualifiedName:
ID ('.' ID)*;
Window:
tabContainer+=TabContainer |
(components+=Component)+
TabContainer:
TabItem:
panel+=Panel
Component:
Panel:
'panel' name=ID '{'
LayoutManager:
Array:
'array' name=ID '' datatype[] array2 '{' QualifiedName '}';
Label:
'label' name=ID '{' text=ID '}'
CheckBox:
'checkbox' name=ID
ListBox:
'listbox' name=ID
ComboBox:
'combobox' name=ID
DropDown:
'dropdown' name=ID
Button:
'button' name=ID
Re: left recursion problem [message #754679 is a reply to message #754664] Thu, 03 November 2011 16:30 Go to previous messageGo to next message
sorry i have posted the wrong one - here you go:
DomainModel:
PackageDeclaration:
(elements+=Window)*
QualifiedName:
ID ('.' ID)*;
Window:
TabContainer:
TabItem:
panel+=Panel
Component:
Panel:
'panel' name=ID '{'
(layoutManager+=LayoutManager) |
LayoutManager:
Label:
CheckBox:
'checkbox' name=ID
ListBox:
'listbox' name=ID
ComboBox:
'combobox' name=ID
DropDown:
'dropdown' name=ID
Button:
'button' name=ID
Re: left recursion problem [message #754680 is a reply to message #754679] Thu, 03 November 2011 16:35 Go to previous messageGo to next message
i guess there is a missunderstanding obout precedence in xtext in your grammar. you might actually want to have
Panel:
'panel' name=ID '{'
((layoutManager+=LayoutManager) |
(components+= Component)+)
~Christian
Re: left recursion problem [message #754684 is a reply to message #754680] Thu, 03 November 2011 16:39 Go to previous message
hi,
that works, thanks a lot.
So I don't need the left recursion right now.
Previous Topic:Scoping problem
Next Topic:xtext-utils: multiple test methods in single class causes exception??
Current Time: Sun Oct 19 14:14:13 EDT 2025
Powered by FUDForum. Page generated in 0.18380 seconds
