Re: rule-based adapter works from command line but fails as plugin [message #84754 is a reply to message #84724] |
Tue, 03 October 2006 14:05 |
Originally posted by: cindyjin.ca.ibm.com
Hi Chris:
Which outputter are you using? If you can execute through the command
line, I guess you are using the
" org.eclipse.hyades.logging.adapter.outputters.CBEFileOutputt er ". But
you need to use other outputters , i.e.
" org.eclipse.hyades.logging.parsers.adapter.outputters.LogImp ortOutputter ",
if you want to use the log import wizard to import logs and display logs
in the log view.
Cindy
Chris Giblin wrote:
> I created a rule-based adapter and tested it in the GLA perspective.
> Worked fine. I execute the same adapter from the command line using
> gla.bat. Also works fine.
> I create a plugin containing this rule-based adapter (plugin.xml below).
> I launch the workbench, the adapter plugin appears when I import. I fill
> in the form and start the import. However, after only 19 lines, it
> throws a ParserException. I receive a modal dialog reporting the
> ParserException and 19 lines appear in the Log View.
> Why would an adapter work in the GLA Perspective and the command line
> but throw a parsing exception as a plugin? Note I have written no Java
> code. It is just 100% pure rule-based adapter.
> I use TPTP 4.2.0, Eclipse 3.2.0, Java 1.4.2
> Thanks, chris
> My plugin.xml:
> <?eclipse version="3.2"?>
> <plugin>
> <extension
> point="org.eclipse.hyades.logging.parsers.logParser">
> <parser
> class="com.abc.ParserExtension"
> description="ABC import"
> icon="./icons/full/obj16/apache_access.gif"
> id="com.abc.Parser"
> name="ABC log"
> ui_name="ABC log">
> <field
> useBrowse="true"
> defaultValue="C:\temp\abc.log"
> name="Log path"
> helpContextId=""
> tooltip="Log path"
> id="file_path"
> browseType="*.log">
> </field>
> <field
> useBrowse="false"
> defaultValue="9.0"
> defaultRuntimeValue="9.0"
> name="Supported versions"
> helpContextId=""
> tooltip="Version"
> ui_type="combobox"
> id="version">
> </field>
> <commonFields
> timeZone="DEFAULT">
> </commonFields>
> <parserParameter
> name="9.0"
> value="./config/abc.adapter">
> </parserParameter>
> <parserParameter
> name="Default"
> </parserParameter>
> </parser>
> </extension>
> </plugin>
FUDForum. Page generated in 0.03988 seconds
