Timeout problem [message #753906] |
Sun, 30 October 2011 14:24  |
domc Mising name Messages: 5 Registered: October 2011 |
I'm fairly new to using Eclipse and having trouble setting up Xdebug to work correctly on my local server (using MAMP).
I think I have set it up correctly having found various helpful articles on the web
-I've configured the php.ini file within MAMP to turn on Xdebug, point to the right file location use port 9001
-I've configuered preferences in eclipse to use the MAMP PHP version, to look at port 9001 for the debugger, to use Xdebug etc.
When I run or debug a file, it seems to work correctly. I.e. I can step through code and it brings up a completed Joomla screen at a certain point.
However the debug session stops after 45 secs and I get the message:
[directory pathname on local server]....index.php/XDEBUG_SESSION_START=ECLIPSE_DBGP&KEY=13199828067401
Page load failed with error: The request timed out.
Is there something I can change in Eclipse to stop this as it seems to be an Eclipse generated error? Or any help on this gratefully received. Cheers, Domc
[Updated on: Sun, 30 October 2011 14:25] Report message to a moderator
FUDForum. Page generated in 0.08151 seconds
