Native excel file [message #753696] |
Fri, 28 October 2011 12:07 |
sam va Messages: 121 Registered: July 2011 |
We are generating excel files by using the following API
EXCELRenderOption options = new EXCELRenderOption();
options.setHideGridlines(false);
options.setOfficeVersion("office2007");
options.setWrappingText(true);
options.setEnableMultipleSheet(false);
options.setOutputFormat("xls");
options.setOutputFileName("c:\\view\\test.xls"));
task1 = birtReportEngine.createRenderTask(document);
task1.setRenderOption(options);
The issue is this code is generating an XML Spreadsheet as opposed to Native XLS. Is there anyway, we can generate native excel file?
[Updated on: Fri, 28 October 2011 12:08] Report message to a moderator
Re: Native excel file [message #753774 is a reply to message #753696] |
Fri, 28 October 2011 16:59 |
The default xls emitter uses the wordML fromat. You may want to try the
tribix emitter.
http://birtworld.blogspot.com/2010/06/birt-excel-output.html
http://birtworld.blogspot.com/2011/07/replacing-default-birt-xls-emitter.html
Jason
> options.setOfficeVersion("2007");
> options.setOutputFileName("c:\\view\test.xls"));
> Thanks
FUDForum. Page generated in 0.02930 seconds
