Home » Eclipse Projects » Remote Application Platform (RAP) » TextArea in the Qooxdoo API
TextArea in the Qooxdoo API [message #753407] Thu, 27 October 2011 02:29 Go to next message
Hi everybody!
We want to create custom self-validating RAP widgets based on qooxdoo to minimize the traffic of our application. Because of that we build a qx.ui.form.TextField and everything went okay, but with the text area we get the following error:
Error: TypeError: qx.ui.form.TextArea is not a constructor
We searched our qooxdoo plugin (org.eclipse.rap.rwt.q07 in 1.4 and org.eclipse.rap.rwt in 1.5) and there really is no TextArea.js, other classes like PasswordField.js are missing to.
Now we learned (at least we thought so), that RAP is based on Qooxdoo, so we'd assume that RAP text area and password field would not work without them beeing present in Qooxdoo - but of course they are working.
Can someone please shed some light on how Qooxdoo and RAP are connected? And how we might be able to use the other Qooxdoo controls or at least get a decent API that only shows controls we are able to use?
Thanks in advance!
Re: TextArea in the Qooxdoo API [message #753447 is a reply to message #753407] Thu, 27 October 2011 05:48 Go to previous messageGo to next message
although the RAP client is based on qooxdoo, the development has split
up and the classes and widgets in RAP are now heavily modified.
In case of the TextArea.js it was replaced by
org.eclipse.rwt.widgets.Text.js. Be aware that Text.js is not part of
the API and thus may change without prior notice.
Rüdiger
On 27.10.2011 08:29, s.schulz wrote:
> Hi everybody!
> Thanks in advance!
Rüdiger Herrmann
Twitter: @EclipseRAP
Re: TextArea in the Qooxdoo API [message #753452 is a reply to message #753447] Thu, 27 October 2011 06:09 Go to previous messageGo to next message
Thank you, now I was able to create the text area. Are you aware of a documentation showing only the RAP branch of Qooxdoo?
> Be aware that Text.js is not part of the API and thus may change without prior notice.
So building these custom widgets is not future-oriented? Is there another way for minimizing the network traffic for basic validations?
Re: TextArea in the Qooxdoo API [message #753503 is a reply to message #753452] Thu, 27 October 2011 09:53 Go to previous messageGo to next message
Am 27.10.2011 12:09, schrieb s.schulz:
You certainly can build a custom widget based on current RWT client
widgets, but they are not API and might change with every new release.
We are toying with ideas how to easily add little pieces of logic to the
client based on the RAP protocol. That would cover such scenarios and
would be future-proof. The RAP protocol will be part of the 1.5 release.
Greetings,
Tim
Re: TextArea in the Qooxdoo API [message #753625 is a reply to message #753503] Fri, 28 October 2011 02:12 Go to previous message
That's good to hear, thanks.
Re: TextArea in the Qooxdoo API [message #753626 is a reply to message #753503] Fri, 28 October 2011 02:12 Go to previous message
Previous Topic:UICallback with HTML5 WebSocket
Next Topic:JMeter
Current Time: Wed Nov 05 07:46:15 EST 2025
Powered by FUDForum. Page generated in 0.26107 seconds
