Home » Modeling » EMF » [CDO] CDO client and server version compatibility
[CDO] CDO client and server version compatibility [message #753216] Wed, 26 October 2011 13:24 Go to next message
We've deployed a standalone CDO 4.0 SR1 server from the CDO download site and I'd like to know whether we can use the CDO 4.0 SR1 client deployed in eclipse 3.6 and EMF 2.6.1 environment to talk to the server. We're using the CDO 4.0 SR1 client from this drop:
http://download.eclipse.org/modeling/emf/cdo/drops/R20110913-0010/
We are able to connect to the server with this configuration but what was working with EMF 2.7 has stopped working (quietly) with EMF 2.6. Can anyone comment on whether the 4.0 SR1 client will run with Eclipse 3.6/EMF 2.6 with some adjustment, or:
- are Eclipse 3.6/EMF 2.6 and the 4.0 SR1 client totally incompatible?
- are there some features in the CDO 4.0 SR1 client that will never work with Eclipse 3.6/EMF 2.6 ?
- If we use a CDO 3.0 client in Eclipse 3.6/EMF 2.6 against a CDO 4.0 SR1 client then are there features of the server that are incompatible or that we will not be able to use.
We are going to use 4.0 SR1 server because of the features it has but would prefer not to require that all of our users upgrade to eclipse 3.7 in order to use our CDO enabled clients. Upgrading will require that they reconfigure all of their favourite plugins as well as reinstalling all the ones our company provides which is perceived as wasted overhead by our users. I would appreciate the community's (and of course Eike's) feedback and experience with client compatibility.
Warwick
Re: [CDO] CDO client and server version compatibility [message #753302 is a reply to message #753216] Wed, 26 October 2011 14:02 Go to previous messageGo to next message
Am 26.10.2011 19:24, schrieb Warwick Burrows:
Yes, you're generally supposed to use client and server that come from the same build. For different integration builds
we generally give no guarantee. For different builds of the same stream (x.y) it usually works but in very rare cases (I
can not even remember one now) there's a potential that client and server can not talk to each other.
As you said, both from the same build?
What exactly is not working anymore?
Please note that we *try* to provide compatibility for older EMF versions. That may not be possible for each and every
function in CDO. We neither document nor test that. We give no official guarantees nor do we officially support problems
in these situations.
Not totally, I'd say ;-)
I doubt someone has a list of such features. Others?
A client against a client?
What version of the server?
Unfortunately we still don't have a nice detection mechansim of such incompatibilities. Adding that would be nice but
not trivial.
Usually we do not care so much about the Eclipse platform version. But the official support guarantee is the same.
To summarize: I *think* all 4.0 features (SRx never has new features) work with 3.6 Eclipse and most features work with
EMF 2.6, but no guarantee.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] CDO client and server version compatibility [message #753378 is a reply to message #753302] Wed, 26 October 2011 19:11 Go to previous messageGo to next message
Hi Eike, Thanks for your reply.
We were trying eclipse 3.6/emf 3.6 with CDO client 4.0 SR1 and were able to connect to the CDO server but not able to do any of the things the developer had managed to do with EMF 2.7.
The developer was able to modify our model objects in the repository and save them and had added code to our model editor plugin allowing it to be called to edit the objects in the CDO repo. This was working with EMF 2.7 but not when she reverted to EMF 2.6. She is still working on it to see if its something simple but I thought I would send this email to ascertain whether it's worth spending time to get it working or whether the community experience has been that the CDO 4.0 client will only work with eclipse 3.6 and EMF 2.7.
I mistyped. I actually wanted to ask whether its feasible to use a CDO 3.0 client with a CDO 4.0 server (not client) but I'm guessing that some of the new CDO 4.0 features like branching and offline clone mode would require client side support and wouldn't work at all with client 3.0.
Warwick
Re: [CDO] CDO client and server version compatibility [message #753399 is a reply to message #753378] Thu, 27 October 2011 00:43 Go to previous messageGo to next message
Am 27.10.2011 01:11, schrieb Warwick Burrows:
You're welcome. I know that some folks are using newer CDOs with older EMFs. I've cc'ed Vik because he may be able to
comment.
If you hit concrete problems, e.g., in the form of exceptions please post the stack trace. Against our official support
policy we may be interested to fix minor incompatibilities if it's easily possible ;-)
Cheers
/Eike
> Quote:
>> > We are able to connect to the server with this configuration As you said, both from the same build?
> Quote:
>> > but what was working with EMF 2.7 has stopped working (quietly) with EMF 2.6. What exactly is not working anymore?
> Quote:
>> > then are there features of the server that are incompatible What version of the server?
> Warwick
Re: [CDO] CDO client and server version compatibility [message #753462 is a reply to message #753399] Thu, 27 October 2011 07:20 Go to previous messageGo to next message
Hi guys,
as Eike pointed out, CDO 4.0 with EMF 2.6.0 should be possible. There
are no API issues that would affect integration, and so far it is
working great for us, no complains!
Víctor.
> EMFs. I've cc'ed Vik because he may be able to comment.
> post the stack trace. Against our official support policy we may be
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Quote:
>> Quote:
>> Quote:
>>> 4.0 SR1 client
>> 3.0.
>> Thanks,
>> Warwick
Re: [CDO] CDO client and server version compatibility [message #753599 is a reply to message #753462] Thu, 27 October 2011 19:36 Go to previous message
Thanks to you all for your input. With a little tweaking of the 3.6 platform configuration and clearing out the old EMF model elements from our CDO server we are back on track using CDO 4.0 SR1 client on the 3.6 platform.
Of course if anyone else has words of wisdom with respect to compatibilty I'd still like to hear from you Smile
Previous Topic:[EMF] URI and Content Handler
Next Topic:Feature delegation: None vs Dynamic
Current Time: Sun Jul 27 18:38:16 EDT 2025
Powered by FUDForum. Page generated in 0.04707 seconds
