Home » Archived » Test and Performance Tools Platform (TPTP) » Running a JUnit test remotly on 2 (or more) machine in PARALLEL
Running a JUnit test remotly on 2 (or more) machine in PARALLEL [message #84409] Wed, 27 September 2006 09:21 Go to next message
I've problems with parallel test execution (it simply doesn't work).
I've created a JUnit test (the simplest test ever), and its associated
artifact.
I've created 2 locations: A and B,
I've paired the artifact with both location A and location B in a
deployment.
Of course, agent controllers are running on machine A and B.
When I execute the test suite with this deployment, test runs on machine A
when the location pair "artifact/A" is the top most in the deployment,
and, similarly, runs on machine B when the location "artifact/B" is the
topmost in the deployment pairs list.
What i'd expect is to have the testsuite running in parallel on machine A
& B and get 2 test execution results. Is it possible ? If yes, how can i
achieve this ?
Re: Running a JUnit test remotly on 2 (or more) machine in PARALLEL [message #84632 is a reply to message #84409] Fri, 29 September 2006 14:50 Go to previous messageGo to next message
Hi Bertrand,
What you describe is something that was envisioned in the design but
never implemented. As you point out, today the test is executed on the
first paired location. Please submit an enhancement request for this
type of functionality, and also consider contributing if you'd like to
see it implemented promptly. I'd be happy to assist in explaining how
the current implementation works.
--Joe
Re: Running a JUnit test remotly on 2 (or more) machine in PARALLEL [message #84709 is a reply to message #84632] Mon, 02 October 2006 04:10 Go to previous message
Joe Toomey wrote:
> Hi Bertrand,
Done, here it is: https://bugs.eclipse.org/bugs/show_bug.cgi?id=159434
I would be pleased too. As I'm a bit in a hurry, i's love to implement
this with your help. I've reverse the TPTP core code a lot of times and i
know approximately how it works.
An ideal solution would be to implement this in an extension, this way,
I could work in parallel of current developments.
Eventually, i've no ideo about becoming a contributor, how does it work ?
Thanks for your help.
> --Joe
Previous Topic:where does TPTP sit in relation to pde-build?
Next Topic:rule-based adapter works from command line but fails as plugin
Current Time: Wed Sep 10 13:52:07 EDT 2025
Powered by FUDForum. Page generated in 0.04894 seconds
