Re: Watch Expressions Crash Debugger [message #84268 is a reply to message #84208] |
Fri, 21 November 2008 22:03   |
D Kelsey Messages: 232 Registered: July 2009 |
Hi Mark. In the xdebug implementation at least, in order to evaluate a watch expression, an eval is
done. If you attempt to eval something like a function that is not defined, then php itself
terminates the script as it can put the engine into an undetermined state (this seems to not only
affect undefined functions). So the limitation is php itself rather than xdebug or PDT.
I have discussed this with the xdebug author and there is no real way round this currently. I could
stop watch expressions from being expressions but only watch variables I suppose but some people do
find it useful to do expressions.
You can of course disable expressions but you should only enable them when you know they are valid
(which is a pain). PDT should inform you if a script is unexpectedly terminated due to this scenario.
Dave Kelsey
Mark Dexter wrote:
> Hi all. I've been using (and learning) the PDT for a few months now
> using XDebug. First of all, thanks for making this such a great tool!
> One problem I have noticed both with the 1.0 version and now the 2.0.0
> M1 2008-10-30 version is that undefined Watch Expressions can sometimes
> crash the debug session. For example, I'll be debugging one section of
> code with some Watch expressions set up. If I forget to delete all of
> these expressions before starting a new debug session in a different
> section of the code (where these expressions are not defined), in some
> cases it crashes the debug session. (In other cases, it does what I
> think it is supposed to do and just shows the Watch expression in red
> with an error message.)
> My recollection using the Java debugger is that, when watch expressions
> are undefined, they just show in red but do not crash the session.
> It's not a huge deal, just an inconvenience. But I thought I would
> report it. Thanks again. Mark
Re: Watch Expressions Crash Debugger [message #84372 is a reply to message #84268] |
Sat, 22 November 2008 18:41  |
Mark Dexter Messages: 324 Registered: July 2009 |
> watch expression, an eval is done. If you attempt to eval something like
> a function that is not defined, then php itself terminates the script as
> xdebug or PDT.
> round this currently. I could stop watch expressions from being
> expressions but only watch variables I suppose but some people do find
> when you know they are valid (which is a pain). PDT should inform you if
> Regards
> Dave Kelsey
>> sometimes crash the debug session. For example, I'll be debugging one
>> section of code with some Watch expressions set up. If I forget to
>> delete all of these expressions before starting a new debug session in
>> a different section of the code (where these expressions are not
>> defined), in some cases it crashes the debug session. (In other cases,
>> it does what I think it is supposed to do and just shows the Watch
>> expression in red with an error message.)
>> expressions are undefined, they just show in red but do not crash the
>> session.
Hi Dave. Thanks for the explanation. I certainly would NOT want to
remove this capability, since I find Watch Expressions extremely
valuable. This is something that is not a big deal to live with. Thanks
again. Mark
FUDForum. Page generated in 0.02337 seconds
