Home » Archived » Test and Performance Tools Platform (TPTP) » Optional fields in GLA
Optional fields in GLA [message #83919] Thu, 21 September 2006 16:51 Go to next message
I am using the GLA perspective in tptp 4.2 to develop a GLA rule-based
adapter. If a given field is present, I wish to produce a corresponding
extendedDataElement. If it is not present in a record the
extendedDataElement should not be created at all.
What do I need to do to prevent empty things like this:
<extendedDataElements>
<children name="result">
</children>
</extendedDataElements>
I am playing around with "Required by parent" and "Child choice", but
not getting what I want (ie, no extendedDataElements when given source
field is not present).
chris
Re: Optional fields in GLA [message #83953 is a reply to message #83919] Fri, 22 September 2006 07:27 Go to previous messageGo to next message
In the meantime, I set 'name' attribute of the extendedDataElement to
"Required by parent", remove the default value, and define a
substitution rule for this 'name' attribute. If the rule does not match
the given pattern, name is 'empty; and the containing
extendedDataElement is not created.
This works - I wonder, however, if this is the best way to do it.
Thanks, chris
Chris Giblin wrote:
> </children>
> chris
Re: Optional fields in GLA [message #83967 is a reply to message #83953] Fri, 22 September 2006 09:54 Go to previous message
Originally posted by: cindyjin.ca.ibm.com
Hi Chris:
I think use "Required by parent " attribute is a correct way to do it.
You can check the Required by parent check box of 'name','type' or
'value' attribute, then create substitution rule to set an invalid value
to that attribute when the given field in record is not present. You can
check Common Base Event format specification
http://www.eclipse.org/tptp/platform/documents/resources/cbe 101spec/CommonBaseEvent_SituationData_V1.0.1.pdf,
to see what are valid values for these attributes.
Bests
Cindy
Chris Giblin wrote:
> Thanks, chris
> Chris Giblin wrote:
>> corresponding extendedDataElement. If it is not present in a record
>> the extendedDataElement should not be created at all.
>> </children>
>> Thanks,
>> chris
Previous Topic:TPTP 4.2.0 installation using update mgr. fails
Next Topic:Exception generated on OS X
Current Time: Thu Oct 30 05:12:38 EDT 2025
Powered by FUDForum. Page generated in 0.45731 seconds
