Home » Language IDEs » ServerTools (WTP) » VE & WST don't work together
VE & WST don't work together [message #83789] Tue, 15 March 2005 10:22 Go to next message
Originally posted by: adamNoSpam_._NoSPAMsoftfab.com
Dear All,
I have installed the Eclipse 3.1M5 package and the Web Services Tools.
They all work fine.
If I then install the visual editor (1.02) then there are lots & lots of
problems when I try & open a swing class with the VE such as :
Exception thrown:
java.lang.ClassNotFoundException: org.eclipse.ui.internal.commands.Command
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:359)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:94)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.enableDelCommand(JavaVisualEditorPart.java:1968)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.focusGained(JavaVisualEditorPart.java:1978)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:104)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:866)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:847)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 1838)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:1914)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:361 5)
at org.eclipse.swt.widgets.Canvas.WM_SETFOCUS(Canvas.java:245)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3088 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3480 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:647)
at org.eclipse.swt.widgets.Control.setSavedFocus(Control.java:2 347)
at org.eclipse.swt.widgets.Decorations.restoreFocus(Decorations .java:738)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1541)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:1461)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3022 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1493)
at org.eclipse.swt.internal.win32.OS.DestroyWindow(Native Method)
at org.eclipse.swt.widgets.Control.destroyWidget(Control.java:5 22)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:381)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java :373)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:492)
at org.eclipse.jface.window.Window.close(Window.java:278)
at org.eclipse.jface.dialogs.Dialog.close(Dialog.java:878)
org.eclipse.jface.dialogs.MessageDialog.buttonPressed(Messag eDialog.java:167)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
at org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:319)
at org.eclipse.jface.util.SafeRunnable.handleException(SafeRunn able.java:53)
org.eclipse.core.internal.runtime.InternalPlatform.handleExc eption(InternalPlatform.java:697)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1017)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
org.eclipse.ui.internal.AbstractSelectionService.fireSelecti on(AbstractSelectionService.java:158)
org.eclipse.ui.internal.AbstractSelectionService.partActivat ed(AbstractSelectionService.java:255)
org.eclipse.ui.internal.WorkbenchPage.firePartActivated(Work benchPage.java:1502)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2821)
at org.eclipse.ui.internal.WorkbenchPage.activate(WorkbenchPage .java:559)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart.openVCEViewersIfRequired(JavaVisualEditorPart.java: 450)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$25.run(JavaVisualEditorPart.java:483)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:118)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2544)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Is it possible to use both the Web services tools and the visual editor
in the same copy of eclipse?
What is it that both are sharing which is so incompatiable between VE & WST?
TIA
Adam
Re: VE & WST don't work together [message #83821 is a reply to message #83789] Tue, 15 March 2005 11:17 Go to previous messageGo to next message
Hi Adam,
I'll give a shot at this..... My understanding is that VE 1.0.2 pre-reqs
Eclipse 3.0.1, this version of VE does not run on Eclipse 3.1 (of course,
you should confirm this with the VE group). If you want to use Eclipse
3.1M5, Web Services Tools and VE in the same Eclipse instance, you'll need
to get one of the VE 1.1.0 nighty builds. I have not tried this myself, but
I'm interested to know whether it works or not.
Jeff
"Adam Flinton" <adamNoSpam_@_NoSPAMsoftfab.com> wrote in message
news:d16uk6$f93$1@www.eclipse.org...
> Dear All,
> They all work fine.
> Exception thrown:
> at
..java:359)
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> at
> at
> at
> at
latform.java:697)
> at
:1017)
> at
> at
> at
502)
> at
> at
ViewersIfRequired(JavaVisualEditorPart.java:450)
> at
> at
> at
> at
java:228)
> at
> at
WST?
> TIA
> Adam
Re: VE & WST don't work together [message #83851 is a reply to message #83789] Tue, 15 March 2005 12:12 Go to previous message
> They all work fine.
Please see the thread "VE and Eclipse 3.1M5" at
http://www.eclipse.org/newsportal/article.php?id=2923&gr oup=eclipse.tools.ve
or news://news.eclipse.org:119/cvc95p$bnf$1@www.eclipse.org
- Nitin
Previous Topic:Bogus Errors in Project
Next Topic:Milestone plan
Current Time: Sun Sep 21 21:45:27 EDT 2025
Powered by FUDForum. Page generated in 0.04486 seconds
