| NPE starting Eclipse 2.1 Motif on RedHat 8.0 [message #83705] |
Fri, 27 June 2003 05:01 |
Originally posted by: g.wagenknecht.intershop.de
I can't start Eclipse 2.1 on my RedHat 8.0 Box. Any ideas why the NPE which
causes the crash occures? It is the first time I un Eclipse there (a new
workspace).
The DISPLAY is exported to a Windows machine running an X server.
Thanks, Gunnar
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 Jun 27, 2003 11:01:24.360
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Caused by: java.lang.reflect.InvocationTargetException
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:848)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
... 7 more
Caused by: java.lang.ExceptionInInitializerError
org.eclipse.ui.internal.WorkbenchPlugin.initializeDefaultPre ferences(Workben
chPlugin.java:441)
org.eclipse.ui.plugin.AbstractUIPlugin.initializeDefaultPlug inPreferences(Ab
stractUIPlugin.java:631
org.eclipse.core.runtime.Plugin.getPluginPreferences(Plugin. java:347)
org.eclipse.ui.plugin.AbstractUIPlugin$CompatibilityPreferen ceStore.initiali
ze(AbstractUIPlugin.jav
a:176)
org.eclipse.ui.plugin.AbstractUIPlugin.getPreferenceStore(Ab stractUIPlugin.j
ava:568)
org.eclipse.ui.internal.Workbench.getPreferenceStore(Workben ch.java:701)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:844)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
a:845)
... 8 more
Caused by: java.lang.NullPointerException
org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverte
r.java:75)
... 17 more
FUDForum. Page generated in 0.03212 seconds
