Home » Eclipse Projects » GEF » How can I enable/disable certain parts of my editor ?
How can I enable/disable certain parts of my editor ? [message #83495] Wed, 11 June 2003 17:57 Go to next message
Originally posted by: DjShark.softhome.net
Hello again good people,
My editor extends GraphicalEditorWithPalette and I also use a toolbar of
supported actions. Some of my actions run certain tests on my models in the
editor, and therefore I wish to cause some of the actions (such as adding
new nodes, connections or deleting them) both from the palette and the
toolbar - to be disabled during those tests (and enabled when the tests are
done). In other words, what is the best way to cause my editor to be
"read-only" at certain times ?
Thanks in advance,
Dj Shark
Re: How can I enable/disable certain parts of my editor ? [message #83811 is a reply to message #83495] Fri, 13 June 2003 14:04 Go to previous messageGo to next message
One thing you can do is show a progress monitor during the operation that blocks
on your test. The downside to this is the entire workbench will be unavailable.
Maybe there's a way to get the ActionRegistry and disable the actions before
running the test and then enabling them afterwards. As for the palette, I'd
have to look into it more.
How about putting a boolean in your model that can turn the read/write state on
and off?
This is just me throwing out ideas. I'm not sure what the best way would be.
If I come across something, I'll post another reply.
Eric
> Thanks in advance,
> Dj Shark
Re: How can I enable/disable certain parts of my editor ? [message #83978 is a reply to message #83811] Mon, 16 June 2003 14:35 Go to previous messageGo to next message
Hello again Eric,
Thanks for the tips, I did manage to disable/enable the needed actions in
the toolbar, however I still face two problems:
1. During the mentioned tests, I wish to cause my whole Graphical Editor to
be "read-only" -> no Drag n' drop allowed and no modifying the current
editparts (like changing their location or size), what method should be
called (possibly from the graphical editor itself) to acheive this ?
2. I did manage to "reach" the pallete - but I can only get the tool
entries, and not the tools themselves - I tried all the methods that exist
in the tool entries classes (like setVisable, or
setUserModificationPermission) but the tools themselves are still enabled (I
can create new nodes and connections).
Perhaps if I were to be able to force my graphical editor to be "read-only",
then the tools themselves wouldn't work. Or maybe there is a way to get the
tool from the tool entry ?
Thanks again for all your help,
Dj Shark
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:bcd3n4$op3$2@rogue.oti.com...
blocks
unavailable.
before
I'd
state on
> and off?
be.
> Eric
the
adding
are
> > Thanks in advance,
> > Dj Shark
Re: How can I enable/disable certain parts of my editor ? [message #83993 is a reply to message #83978] Mon, 16 June 2003 16:28 Go to previous messageGo to next message
"Dj Shark" <DjShark@softhome.net> wrote in message
news:bckv64$isd$1@rogue.oti.com...
> Hello again Eric,
to
Maybe you could do this centrally by extending EditDomain to have
isReadOnly(), and add the necessary checks everywhere.
Or by telling the CommandStack not to execute any commands.
(I
"read-only",
the
You can disable the entire SWT Control by calling Control.setEnabled(false).
I'm just wondering, if you are running a test, why do expect someone to be
clicking the mouse?
> Dj Shark
that
> blocks
> unavailable.
> before
> I'd
> state on
> > and off?
would
> be.
> > Eric
of
in
> the
> adding
tests
> are
> > > Thanks in advance,
> > > Dj Shark
Re: How can I enable/disable certain parts of my editor ? [message #84008 is a reply to message #83993] Mon, 16 June 2003 18:05 Go to previous message
Hello Randy,
Unfortunately, extending EditDomain is not an option.
In addition, since I do not see any public method in class CommandStack that
allows me to disable the commands (like: canExecute(false)) - I assume your
solution is the same principle as the solution of extending EditDomain, and
therefore it too isn't an option.
Regarding Control.setEnabled(false) - I tried that doing the following from
my graphical editor: I get the editor's graphical viewer, from it I get the
control and to that control I do disable.
It works fine (it "freezes" the entire canvas area); Though, I am a little
greedy: Is there a way to disable all editing actions/tools, but still allow
those which are non-editing such as the scroll pane to be active ? Or even
allow the user to select any of the nodes and connections - but not change
any of their properties like size, location, etc. Or delete them, or copy &
paste, etc. ?
Btw, Even after the "freeze" I'm still able to use my outline for
navigation - which is desired, since it's a non-editing action...
Regarding the tests -> These tests are actions on a special bar that "my
client" can run when he or she wants to. I assume I have an adversary
client, who may wish to delibrately try to edit whilst running the tests,
thus causing instability or worse...(Example: a test that checks if all
nodes are alligned - the test is run in animation (You see the editor
highlight each node it passes - this shows that test's progress), if the
user can still move the nodes while the test progresses, then that test is
useless. On the other hand, I do want the user to
see the animation (and not just progress bar...).
Thanks for all the help,
Dj Shark
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bcl9ad$s01$1@rogue.oti.com...
> > Hello again Eric,
in
> to
exist
enabled
> (I
> "read-only",
> the
> clicking the mouse?
> > Dj Shark
> that
> > blocks
> > unavailable.
> > before
palette,
> > I'd
> > state on
> > > and off?
> would
> > be.
> > > Eric
toolbar
> of
> in
> > the
> > adding
the
> tests
> > are
> > > > Thanks in advance,
> > > > Dj Shark
Re: How can I enable/disable certain parts of my editor ? [message #84022 is a reply to message #84008] Mon, 16 June 2003 17:16 Go to previous message
Why can't you extend EditDomain or the CommandStack?
news:bclbep$u1p$1@rogue.oti.com...
> Hello Randy,
that
your
and
from
the
allow
> paste, etc. ?
is
> Dj Shark
> > > Hello again Eric,
> in
Editor
> > to
be
> exist
> enabled
> > (I
> > "read-only",
get
> > the
be
> > clicking the mouse?
> > > Dj Shark
> > that
> > > blocks
> > > unavailable.
actions
> > > before
> palette,
> > > I'd
read/write
> > > state on
> > > > and off?
> > would
> > > be.
> > > > Eric
> toolbar
> > of
models
> > in
> > > the
> > > adding
> the
> > tests
> > > are
be
> > > > > Thanks in advance,
> > > > > Dj Shark
Re: How can I enable/disable certain parts of my editor ? [message #84037 is a reply to message #84008] Mon, 16 June 2003 17:19 Go to previous message
is
Test could add itself as a listener to the CommandStack. If the user does
anything, the test will be notified of the change. I don't think you can do
any better, given the presence of popup menus, toolbar actions, and key
accelerators.
Previous Topic:Moving EditPart effect on other EditParts
Next Topic:draw2d connections with bends
Current Time: Fri Nov 07 10:13:28 EST 2025
Powered by FUDForum. Page generated in 0.04102 seconds
