Error InterfaceRealization and values upper- lower [message #749671] |
Tue, 25 October 2011 11:09 |
Flower Missing name Messages: 8 Registered: October 2011 |
If anyone can help I thank you tremendously!
- ** The problem is I can not read the InterfaceRealization relationship classes in the UML model input the transformation, therefore we can not draw the
- ** Interfaces it implements. The problem is, as in the case of upper-Bound coming empty values for more
- ** In the model are setpoint. Here also something strange happens when we created the model we set the InterfaceRealization instance and tells us
- ** OwnedMember the relationship class is a namespace InterfaceRealization opposition are not mutually seteadas
- ** And how they are created by the program to perform the analysis, and also on the other side are read-only attributes
- ** We can not change by hand. The same goes for the relation "feature" of the interface and "featiringClassifier" of operation of the class
Here is the unfinished transformation and pureba comments
- Rule for Class Transformation to JavaClass
rule Class2JavaClass extends Classifier2Type{
from e: UML2! Class - (not e.isService ())
to s: JAVA! JavaClass (
superclass <- e.generalization -> collect (c | c.general) -> asSequence (),
- name <- e.generalization -> collect (c | c.general) -> first (). name,--!! SEE! q I had put a cabbage in java, how to not take me first q
nestedType <- e.nestedClassifier,
constructor <- e.getConstructorMethods (),--,
- implements <- UML2! InterfaceRealization.allInstances () -> collect (elem | elem.contract)
Implemented <- e.clientDependency -> select (a | a.oclIsKindOf (UML2! InterfaceRealization)) -> collect (c | c.contract)
- interface <- e.clientDependency-> select (a | a.oclIsKindOf (UML2! Abstraction))
- implements <- e.clientDependency -> collect (c | c.contract)
[Updated on: Tue, 25 October 2011 11:12] Report message to a moderator
FUDForum. Page generated in 0.03128 seconds
