Home » Eclipse Projects » Linux Tools Project » Error installing linuxtools through update manager
Re: Error installing linuxtools through update manager [message #7522 is a reply to message #7510] |
Fri, 15 May 2009 12:37 |
Andrew Overholt Messages: 55 Registered: July 2009 |
Member |
On Thu, 2009-05-14 at 22:00 +0000, Pankaj Gupta wrote:
> I was finally able to use the update manager to install the linux tools.
> In order to make that work, I had to run eclipse as the super-user.
That doesn't make any sense if you extracted eclipse from an eclipse.org
download into some directory in your home directory.
> Unfortunately, when I use the OProfile, I don't get any output. Instead, I
> get an error:
> FATAL: An error occurred with opxml.
> Reason: The opxml binary cannot be read or executed. Either your user does
> not have sufficient permissions, or the install script was not run.
> I'm not able to find the opxml binary, although I did install OProfile
> using install-noconsolehelper.sh.
consolehelper isn't a Debian thing AFAIK. Kent will be able to provide
more guidance here.
Andrew
Re: Error installing linuxtools through update manager [message #566125 is a reply to message #7510] |
Member |
> get an error:
more guidance here.
Andrew
Current Time: Sat Sep 21 04:52:39 GMT 2024
Powered by FUDForum. Page generated in 0.05221 seconds
