No property editor [message #82785] |
Tue, 08 March 2005 13:35  |
I'm trying to launch the visual editor using the latest of everything (I
think, just used the update utility) on Version: 3.1.0
Build id: I20050219-1500
It is bombing out on starting the property editor
This is what the log is showing me:
!ENTRY org.eclipse.ve.java.core 4 0 2005-03-08 11:01:20.78
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.ui.internal.commands.Command
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:359)
at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:94)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.enableDelCommand(JavaVisualEditorPart.java:1968)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$3.focusLost(JavaVisualEditorPart.java:1999)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:108)
Anyone know where to get the class I seem to be missing?
Re: No property editor [message #82814 is a reply to message #82801] |
Tue, 08 March 2005 15:28  |
Ok. Thanks for the info.
Have you gotten this and webtools to work at the same time?
I was using 3.1 because I thought webtools needed it.
Luis
On Tue, 08 Mar 2005 14:02:09 -0500, Rich Kulp wrote:
> The released code (the code that is available through the update
> manager) does not work on 3.1, it only works on 3.0.1. We are in the
> process of getting a developement build out there that does work on 3.1.
> The current nightly build kinda works but there are bugs and problems
> with it.
>> !STACK 0
>> at
Re: No property editor [message #605767 is a reply to message #82785] |
Tue, 08 March 2005 14:02  |
with it.
> !STACK 0
> at
Rich Kulp
Re: No property editor [message #605769 is a reply to message #82801] |
Luis
> with it.
>> !STACK 0
>> at
FUDForum. Page generated in 0.05315 seconds
