| Error finding piAgent [message #81835] |
Mon, 28 August 2006 08:55  |
Originally posted by: mohsen_s.myrealbox.com
When I press start server in profiling mode on Servers view, the following
error is shown:
Error occurred during initialization of VM
Could not find agent library on the library path or in the local
directory: piAgent
I had also tried profiling on server (Tomcat 5.5) with -Djava.library.path
set to
[eclipse]\plugins\org.eclipse.hyades.execution.win32.x86_4.2 .0.v200606131519
where piAgent.dll exists.
What is the problem?
I'm using Eclipse 3.2 + TPTP 4.2 (Callisto version) + WTP 1.5.0 on a Windows
XP SP2 with JDK 1.5.02
Thanks in advance.
| Re: Error finding piAgent [message #82384 is a reply to message #82162] |
Sat, 02 September 2006 01:16  |
Thank you Ali, Eugene;
It works fine now.
By the way, why setting -Djava.library.path has no effect? Should it be set
as eclipse JVM param instead of tomcat?
Thanks.
"Eugene Chan" <ewchan@ca.ibm.com> wrote in message
news:ed4hkl$qbs$1@utils.eclipse.org...
> Hi Mohsen,
> Please make sure piAgent.dll is in your system PATH before you start
> Eclipse
> workbench in order to allow WTP tooling access to the required libraries.
> Eugene
> "Mohsen Saboorian" <mohsen_s@myrealbox.com> wrote in message
> news:ecuorf$jfk$1@utils.eclipse.org...
>> following
>> error is shown:
>> directory: piAgent
>> set to
> Windows
>> Thanks in advance.
FUDForum. Page generated in 0.04011 seconds
