Invalid JAXP setup, javax.xml.transform.TransformerConfigurationException [message #741963] |
Thu, 20 October 2011 03:50 |
Srinivasan Iyer Messages: 36 Registered: October 2011 |
Member |
I made a fresh Stardust Installation on Tomcat 5.5. I deployed the WAR file and the process portal login screen is comming up, but I get the stack trace below when I try to deploy a process model.
25.01.2010 09:15:59 *INFO * AuditTrailLogger: Logged in. (User: motu (Realm: carnot) (Of the Universe, Master)) (Log4j12Logger.java, line 70)
25.01.2010 09:15:59 *INFO * Security: Partition: default, Domain: default. (Log4j12Logger.java, line 70)
25.01.2010 09:15:59 *INFO * DebugInterceptor: <-- login (Log4j12Logger.java, line 70)
25.01.2010 09:15:59 *INFO * DebugInterceptor: --> deployModel (Log4j12Logger.java, line 70)
ERROR: 'PermGen space'
FATAL ERROR: 'Could not compile stylesheet'
25.01.2010 09:16:02 *WARN * ApplicationException: Invalid JAXP setup (Log4j12Logger.java, line 85)
javax.xml.transform.TransformerConfigurationException: Could not compile stylesheet
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTemplates(Unknown Source)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerFactoryImpl.newTransformer(Unknown Source)
at ag.carnot.workflow.model.xpdl.XpdlUtils.convertXpdl2Carnot(XpdlUtils.java:400)
at ag.carnot.workflow.model.xpdl.XpdlUtils.convertXpdl2Carnot(XpdlUtils.java:365)
at ag.carnot.workflow.runtime.beans.AdministrationServiceImpl.deployModel(AdministrationServiceImpl.java:116)
[Updated on: Thu, 20 October 2011 10:33] Report message to a moderator
FUDForum. Page generated in 0.03407 seconds
