Re: Table (id=585) - Can not load the report query [message #740652 is a reply to message #740615] |
Tue, 18 October 2011 18:50 |
What data source are you using?
Jason
On 10/18/2011 2:03 PM, sswaine wrote:
> I am brand new to BIRT and am trying to run a report
> TransactionStatus.rptdesign. I am using CGI's Momentum to run the
> report. Unfortunately, I cannot copy the error stack trace due to the
> fact that it is being produced on a classified machine. The error that I
> am getting looks something like this -
> The following items have errors :
> Table(id=585):
> -Can not load the report query:585.
> Error. ReportQueryLoadingError (1 time(s) )
> detail : org.eclipse.birt.report.engine.api.EngineException: Can not
> load the report query: 585.
> I was hoping that someone has run into this error before and can provide
> me with some ideas on where to look or how to fix this issue. Any help
> is greatly appreciated!
Re: Table (id=585) - Can not load the report query [message #740694 is a reply to message #740663] |
Tue, 18 October 2011 19:46 |
If you look at the report design the table that is failing will be tied
to a dataset. This dataset will be tied to a datasource like jdbc, flat
file, xml etc. If you are using JDBC, do you have the particular jdbc
driver deployed with the the report engine?
Jason
On 10/18/2011 3:04 PM, sswaine wrote:
> What are some examples of data sources? I know we query against oracle
> databases for our custom reports that report on the same data.
Re: Table (id=585) - Can not load the report query [message #741408 is a reply to message #740791] |
Wed, 19 October 2011 13:56 |
If the version of BIRT you are using is 2.6.2 or earlier you need to
find where the engine is deployed and put the jdbc driver in the
\birt-runtime-version\ReportEngine\plugins\org.eclipse.birt.report.data.oda.jdbc_version\drivers
directory.
Jason
On 10/18/2011 6:25 PM, sswaine wrote:
> Ok, the datasource is JDBC. How can I check to make sure that the driver
> is deployed with the report engine?
Re: Table (id=585) - Can not load the report query [message #741450 is a reply to message #741433] |
Wed, 19 October 2011 14:47 |
It depends on how many different jdbc sources your are using. Is your
report using the ojdbc6-0.0.jar for the driver?
Jason
On 10/19/2011 10:23 AM, sswaine wrote:
> I found that directory and there are 2 files in the drivers folder -
> ojdbc6-0.0.jar and readme.txt. Is that all that's supposed to be there?
FUDForum. Page generated in 0.03394 seconds
