Home » Eclipse Projects » Eclipse Website » CMS - Xoops
CMS - Xoops [message #7200] |
Mon, 30 May 2005 14:49 |
Originally posted by: andrew.geraghty.javalin.ca
------=_NextPart_000_0006_01C56505.3F5BA660
Content-Type: text/plain;
charset="iso-8859-1"
Right now Xoops is our leading choice for a CMS. Has anyone out there =
had either negative or positive experience with Xoops?
Andrew
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2627" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Right now <A=20
href=3D"http://www.xoops.org">Xoops</A> is our leading choice for a CMS. =
Has=20
anyone out there had either negative or positive experience with <A=20
href=3D"http://www.xoops.org">Xoops</A>?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Andrew</FONT></DIV></BODY></HTML>
------=_NextPart_000_0006_01C56505.3F5BA660--
Re: CMS - Xoops [message #7253 is a reply to message #7200] |
Mon, 30 May 2005 18:46 |
Originally posted by: bob.objfac.com
Andrew Geraghty wrote:
> Right now Xoops <http://www.xoops.org> is our leading choice for a CMS.
> Has anyone out there had either negative or positive experience with
> Xoops <http://www.xoops.org>?
I had a bad experience just now trying to read the Visual Introduction,
one sentence per page. :(
Bob
Re: CMS - Xoops [message #7276 is a reply to message #7200] |
Tue, 31 May 2005 05:49 |
Is there a document available, which compares the variouse candidates
and gives an explanation why Xoops is the favorite today? Just curious.
BTW, isn't there one with an Eclipse BackOffice plug-in ;)
Cu, Gunnar
Re: CMS - Xoops [message #7308 is a reply to message #7200] |
Tue, 31 May 2005 11:16 |
Roger Dudler Messages: 21 Registered: July 2009 |
Junior Member |
--------------000904080701040802060203
We, at iframe AG in Switzerland, have developed a completely new web
application framework (with cms) called S-Node XT, which would be
released in about 1 week. It is completely modular and extensible, is
plugin-based, has actions, extensionpoints and extensions. It has a
really impressive usability. Plugin programming is flexible, easy and
fast. The system is based on user, groups and roles. Each plugin can
define his own permissions based on the defined actions (per user, group
or role and per each language). The system makes use of the nested set
algorithm to build trees in most of the plugins. This makes the system
high performant (backend and frontend)
It has a full indexing an search implementation, it's blazingly fast and
is easy to implement into new plugins. You have the ability to create
a completely new system based on our framework. With your own plugins
and design if you want. It uses Smarty as Template Engine and MySQL as
database server.
Btw, It's not the one shown on www.iframe.ch - this was the version from
last year. The new one is completely redeveloped from the ground.
I'm telling you all that, only that you take a look at it, cause I think
it would be the best solution for such a project.
If you need more information, please tell me.
I attached a screenshot from the site structure management interface.
(The interface is shown in german, but is also available in other languages)
> Andrew
Content-Type: image/jpeg;
name="s_node_xt.jpg"
Content-Disposition: inline;
filename="s_node_xt.jpg"
/9j/4AAQSkZJRgABAgAAZABkAAD/7AARRHVja3kAAQAEAAAAVQAA/+4ADkFk b2JlAGTAAAAA
Af/bAIQAAgEBAQEBAgEBAgMCAQIDAwICAgIDAwMDAwMDAwQDBAQEBAMEBAUG BgYFBAcHCAgH
BwoKCgoKDAwMDAwMDAwMDAECAgIEAwQHBAQHCggHCAoMDAwMDAwMDAwMDAwM DAwMDAwMDAwM
DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgEAAUAAwERAAIRAQMR Af/EAQsAAQAB
BQEBAQEAAAAAAAAAAAAGAQQFBwgCAwkKAQEAAQUBAQEAAAAAAAAAAAAAAQID BAUGBwgJEAAA
BQMBAgUNCAoMBg4HAREBAgMEBQAGBxESCCETFBUWMVFS05TUVZVWlhcYCUGh ItJU1dZXYTJi
kiOTpJdYGXGBkbEzU+MktUZ2OMHRQrS31/CiwkM0dCU1NrY3dzkKcoKyc7N1 JkdExIWDo4TF
Zico4WOGSMZnpxEAAQMBBAQICQgJAAYJBAEFAQARAgMhEgQFMUFRE2GR0SJS FBUGcYGhMpLS
UxYH8LHhYjOTVBfBQnKisiNz0zTxgkPDdAjCY7MkZMTUVRjig0QlNaPy45S0 /9oADAMBAAIR
AxEAPwDlnB1o57yDitPK1nwjiXbFctGBWrRMTuNHJjoEcFBYpEuIBQhiHVE4 AUwDr9qIh9qd
/P8AmR7udzcw7MzerONXcb3mxvR0sKdhcVCOcBKIiYsbzyiD4Pk3wAzjvJh+ t5bGBpmqabSm
IGwAmfOYSgHEeaZSdwIliRtzC9t7w9+SRI9GRg4tN64kIqBfP5IE2kvIxyih DsUF1WRSEXV4
o3EgtsEOIAG2AmLrzmc/8x2WYPLqGbTwNaph6ghOd0gzpU5B784uHuOL4jIt aXIBK0tH4O4q
eYVsshioRrU5SgHBEZziWuxOlpfqkgPZY5ZYC5M65UtWYd21PLKs7gjnCzB8 zXSSKqg5bKmR
VSUKJNSnIcolEPcEK+gsmq5dm2EpY/B3alGtCM4SDtKMgDE2sbQXY2jWvK8b l+MwVeeGxBMa
lORjIWWEFiLLD4RYdSwzneayJt6C+MGnWInw/s6ErbjLMMP1B5eVRGnV6Z8i +frM5D+Xn+8J
8Wp7Ow3QHl5VVu6vSPk5E9ZnIfy8/wB4T4tOzsN0B5eVN3V6R8nInrM5D+Xn +8J8WnZ2G6A8
vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCfFp2dhugP Lypu6vSPk5E9
ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORP WZyH8vP94T4t
OzsN0B5eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/AHhP i07Ow3QHl5U3
dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORPWZyH8vP94T4tOzsN0B5eVN 3V6R8nInrM5D
+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ekfJyJ6zOQ /l5/vCfFp2dh
ugPLypu6vSPk5E9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnY boDy8qbur0j5
ORPWZyH8vP8AeE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCfFp2dhugPLypu6vS Pk5E9ZnIfy8/
3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORPWZyH8vP 94T4tOzsN0B5
eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAe XlTd1ekfJyJ6
zOQ/l5/vCfFp2dhugPLypu6vSPk5E9ZnIfy8/wB4T4tOzsN0B5eVN3V6R8nI nrM5D+Xn+8J8
WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCf Fp2dhugPLypu
6vSPk5E9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qb ur0j5ORPWZyH
8vP94T4tOzsN0B5eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch /Lz/AHhPi07O
w3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORPWZyH8vP94T4tOz sN0B5eVN3V6R
8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ek fJyJ6zOQ/l5/
vCfFp2dhugPLypu6vSPk5E9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef 7wnxadnYboDy
8qbur0j5ORPWZyH8vP8AeE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCfFp2dhug PLypu6vSPk5E
9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5OR PWZyH8vP94T4
tOzsN0B5eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+ LTs7DdAeXlTd
1ekfJyJ6zOQ/l5/vCfFp2dhugPLypu6vSPk5E9ZnIfy8/wB4T4tOzsN0B5eV N3V6R8nIqDvN
ZE9x+b70nxKjs7DdAeXlU7qr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zW RflxvvSfEp2d
hugPLypuqvTPkT1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6 A8vKm6q9M+RP
WayL8uN96T4lOzsN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9Zr Ivy433pPiU7O
w3QHl5U3VXpnyJ6zWRflxvvSfEp2dhugPLypuqvTPkT1msi/Ljfek+JTs7Dd AeXlTdVemfIn
rNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWayL8uN96T4lOzsN0B5eVN1V6Z8ies1 kX5cb70nxKdn
YboDy8qbqr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dhu gPLypuqvTPkT
1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWa yL8uN96T4lOz
sN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9ZrIvy433pPiU7Ow3 QHl5U3VXpnyJ
6zWRflxvvSfEp2dhugPLypuqvTPkT1msi/Ljfek+JTs7DdAeXlTdVemfInrN ZF+XG+9J8SnZ
2G6A8vKm6q9M+RPWayL8uN96T4lOzsN0B5eVN1V6Z8ies1kX5cb70nxKdnYb oDy8qbqr0z5E
9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dhugPLypuqvTPkT1m si/Ljfek+JTs
7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWayL8uN96T4lOzsN 0B5eVN1V6Z8i
es1kX5cb70nxKdnYboDy8qbqr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6z WRflxvvSfEp2
dhugPLypuqvTPkT1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G 6A8vKm6q9M+R
PWayL8uN96T4lOzsN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9Z rIvy433pPiU7
Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dhugPLypuqvTPkT1msi/Ljfek+JTs7D dAeXlTdVemfI
nrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWayL8uN96T4lOzsN0B5eVN1V6Z8ies 1kX5cb70nxKd
nYboDy8qbqr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dh ugPLypuqvTPk
T1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPW ayL8uN96T4lO
zsN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9ZrIvy433pPiU7Ow 3QHl5U3VXpny
IO81kXT/AIeb70nxKdnYboDy8qbqr0z5F49ZzIvhA/3qXxKdn4b2Y8vKqtzV 6RT1nMi+ED/e
pfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP8AepfE p2fhvZjy8qbm
r0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP96l8SnZ+G9mPLypuavSKe s5kXwgf71L4l
Oz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8vKm5q9Ip6zmRfCB/vUviU7Pw3 sx5eVNzV6RT1
nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4 QP8AepfEp2fh
vZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP96l8SnZ+G9mPL ypuavSKes5kX
wgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8vKm5q9Ip6zmRfCB/v UviU7Pw3sx5e
VNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NX pFPWcyL4QP8A
epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP96l8S nZ+G9mPLypua
vSKes5kXwgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8vKm5q9Ip6 zmRfCB/vUviU
7Pw3sx5eVNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/De zHl5U3NXpFPW
cyL4QP8AepfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL 4QP96l8SnZ+G
9mPLypuavSKes5kXwgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8v Km5q9Ip6zmRf
CB/vUviU7Pw3sx5eVNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9 S+JTs/DezHl5
U3NXpFPWcyL4QP8AepfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3N XpFPWcyL4QP9
6l8SnZ+G9mPLypuavSKes5kXwgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxK dn4b2Y8vKm5q
9Ip6zmRfCB/vUviU7Pw3sx5eVNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inr OZF8IH+9S+JT
s/DezHl5U3NXpFPWcyL4QP8AepfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/D ezHl5U3NXpFP
WcyL4QP96l8SnZ+G9mPLypuavSK643G2tu37hFXMOTCoz03ITM1b0fHTKkgh HtUoOPhnqiuk
K8jnCiqxpopQ1WApATH4JhMAl8n77ZhWo43qmEelGNOEyYiJkTUlUiB/MjOI Ed2dEXJlpDW+
id08hw9XDGvihfJlKIBMgAIiJfmmJJN7awbQXskNy5MxtAKnIexbR2S68J3F /e5+xdtYeGwO
Mqj/ACa/Fh//AE63FTLcDH/YU/Sq/wB1Ri38uWdlDKlrYSbWVARTe9JmLtAl wW27u4sjGOJh
8lHoPEiy8/JtDlSVWKc6aiA7ZAEoCQwgcuTmmHxOV4OpmHWKszRiZmE40bsh EOYm5ShIONBE
gxYkEWHHoZVg8XVjhhRjC+bt6MqjxJsBF6coltYItGzSpNuywlluN3C2sm3w 0Z3Lel0x7u4T
FuJWYRbs0ELhlbfSbtk4GSizCIjEmVOdQxtdsCgUuyImw+8mZYmeY1cPh5Sp U6UxDmCBJJp0
6hMjUhU9oAAANDkl7Lfd/u/hepQrV47ycwZc4yAAEpRAAhKPRckvp1NbLY+y b/ueGSuWwsEM
py3HHGA1kYqMyi9arCkoZE+ws1uY5DbJyCUdB4BAQrV1M0o0JmliMylTmNIl LCRIcPaDQBtF
vgW3j3cpTjep4MSB1jfkeSotNXjkNC7LiuHELiyY2zL0jIe7ZtKTgVbpRfsJ C0LekbiWZvWl
xS8okJFQjDoHJxaahDmA218ESG6YGpgY4fFxxEq9OpUpQMZiiYyjVnGAlGVK nTLi8JAuYkOG
tBGkr5Nhq8atKNIUpxhKQINRwYRMmInOQtZjYCDa+pbtwnhOxRxLahTW+hfG T5yFt64XB5Y9
xi5VXuCBZ3ADdq1t2VjSAmim9BMNSHOYSiYTAAgUvyf8Tvjvn+Dz3FYDLDTp U6FWVMR3YmTd
svPIEudLCwL6X+G/wD7vY3JMNj813spVoXzLe7uMQ5DaxY2mxR1c+Jn0qjb8 LjW2n8+9WTaM
2TZxkBZdyuscE00kk0rqE5znMIFKUAEREdK8y/8Akx3wvCMMRTJNgG5hadgD L13/AOKXc4QN
SrTrxjEEkmuwAFpJJFgAtJK5l38LVx3ce7nlWRgrQaWNe1iQqVxKuLed3GYr 9Fxc0Pabtg/b
XBJyhgMU0yVUp0zJiXizFMBtoBJ7N8DP+YjvD3gziWU5vOE6c6c2IhGBgYRJ PmgO7MQfEvNf
i5/y7d3u62Bw+a5RfEt7EETnfEntBBsZms2uo37NjL8eOHH+BknxIC9VkBUg pQ3FKGVFdMwg
YqSgAUxkVDbQFERAdep1a8A/54O5lfK+98c3qU7+HxEKZIDgfy4xgYkjReEd IZl6Z/y+5rDN
Mglg6cmq4adQGwExE5GYkAdLGRd7LOKRbslvb0c7vT2xaQRczLY9gJtO7b9u nIsMziIMAauh
I/cJOFVHbVQhUzkM2BARMU+ggUoE4wNXm/xNywdy62XCdGnUrQMKNLDylKQj IWRquIkHpv5z
kSBMmXmeK+GeN97I5jHfVBAg1J1oiIlUGuiIkuDoj0WDSADqTY43ocH2x7Ti O3rL3iFLgwQw
mFXBUlGiS6jhFGOUjGUmmg5EAESrFTeJ7Whw0AdAPwB90/Bz4eZth/hXhMlM t1jJUZSZyGFS
tKtcJFoeErktVpFoXzd37714Cp32r5g1+jGcRoBthSjTMgNYExeGtgDpWV9p NhXK943bi2+l
syxmV8Q3xETa+O72u89sWq+TYQzgrh+1m5V+SMTE7UXBSALlcpSqCdMiSRhE g9t8M81weX0c
ZQq4Wpha+GMN/TjfqxJIYVKcIiRAkzm5Frt2RMoi8Nf3ywWIx1ShVpVIV6dY y3c7IFvZykSA
W0C8XMnDA2LZTrHWEMv+z03Z90q9XENH5huxHKZcf5KSkGz+LbTtuX4i2CJU eRZ1m6zKS5xU
TBwmschFCJnKCgGrlKPeHFYbvPmOZ4K9VwsI0JVaYDE05UYvMRkxE6dhMSAW vRN1lvamR0qm
SYbCYsCnXMpxhI6BO/IiJI/VmzAhxaCHU332Nzbd7y7v9ZIyxvGSlzKJXvl6 wN320Y2zVoxt
zfISeK7fmjyD5SUQd7bcCmEOLSIU20A8I7XweW7hd/8AMctymlgMBCkTToV8 RI1LxBjCc+ZE
RMWPNkXLgkiwWk7/AL090cJjcUcXiZSAlKnTAgwN6RAEpOC/nRGogDSbAtP7 pO5xhnBuTYLL
+TZCWui7oPeNh93e0GNvqsYpgMtCyZnruVlDPG8ioo24pmcSt0QKYTF2BUAD 8Yn3vfH4g4rM
sL1PA04QhXy6piJmbyIiYyBhBjECQY84uDZzbGPJ93+51HCVpV8VORNHEwpx EWAJeJEpO9hv
RsDMHtKleS9wTdIuu9bpzDvQZLCyrjytkfOCcFcU1c9lW9A28S1b2lYtqR2x uN0jIyYrOCEA
QYCAJlMUFBT+CY/KZF8WMywOFoYPC0I1YYajQvC7VlOpfiCRGUAYU7sDZfBe 6WfzV0ebfD7C
4yvUxE5yjKrOTNdEYsNMgbZPIEm6QbRwlcw+y9yllLH+99YsxhaPPPq3Wujb crb5UhVJLwMu
ZMr5uoGpQKUEA43bMOymJAOb4JRr3f4jZVg8yyKtUxMxCEIbyE3a7OIeEhwk lmFpdhaQvJu6
2LxOBzSFKlG9IyuSjpcEtIfpc2BnNgW+vaxyGRt0K+sc7tm6fIytlbq9oxr6 47NuG2pV6g8m
p6ZWetJZ9zuwcgqJmyKwtCEA5TpgdTa1Konp5j8JMtp96Ri8zza7Wr1LtKcJ ANGERExeDWOQ
JAs14OOdF13HfrHyyKOHweABhCJM4yG1yCAfGQR0SAbCyh/tYcvZyuB5g/HM rfdzuLAlsF4w
uKeg1bimzR8vLLvZlZV/JNeV8U7cKKM0THVcFOcwkKIiIhWZ8I+62B69mVWN GAnh8bVjTIDG
EXIugi1msbQxI1lW+/mfYoYDBxvuK9EGYIBEi0S9osLl3DMbdQXMqzLEBMOp JJJTh94Q84bj
VdY8LbTtsI4RDUB/novhe6BwfguK+6r2yVLHjHACNM4U07TbvBUf0bl3/Wvc C8whPCHCkkyF
cSsFl0xbjEgfE3Cuz/ZRZUst5iSQ3SLHyA4w3veXNdrSdta/EYpi/ZTqJI4G Le25MXSZxMgZ
YyqiaZxKUypygG1qZJTxb4vd3cSMXTzeth+t4GjSMalITMZQtJNWLaCBdci2 7Euw5w9D7gZx
R3E8DCoKGJqTBhMxBBsAED5WBseVjmw/K3vZm7tMBjyGn99DJjOzMr31NZGh guM9w2BatqW/
IWXKuIVQh4uVPHupAi0ikJQJGJpkRIYpTgkGyY+px/xfxdDEbnK6O+oUadCT SjVnVqCpGM/P
i8YSETaal5zGReRsW2wfw7p4mkauKkadWc6g5t0QgYkjzTaYkiy6QwIDAWqf 7jWLcI5PndxG
LyC0lLwxVe8FmF3G2ddK9vPIGLkYZVqq4dcQlb6Dh0g7VFVYqLlcxkTCnsqG BM4K6Pvpn+Lw
9TPJ4SUaVSAwst5DeRlKEjG6PtCIzjGcY34gCQE3g8wYbHIcmozo5fHERMxf rRuSukCQE3/V
BMSYE3S5BMec0Wlpvd23Ety7IO6zjnPee78Vxt6ZumL20pO5rzsaOi7YZwC5 mjBKTTnCxL2Z
XWWFMFTxyCJCbXwypAJDH6POfixmuCxksLSoQq7iFEzAhVMqhqRjKVwxeNLm lwJ3tBaUtC12
D+HeDxNI1RUnG/OoI2xAhdJiLwNs7QzxIJcOBa2Y3Q/Z47oWfce7ukfeMldy WX94aPyDIxUh
DvIYkJFDY7lTQyzdzHKuTlXROkGyVXXa2h1ABAAyO9XxRzTL8Xj+qwoSoYMU JG8J35RrCGgi
YiCDPos3CLcLJu4uExGHoHESqRq1pVIWGN0SgZ6jF2aG3T4bIneW5nurRW4t Zu97jA10380d
srWkr7kLfm7YSi4R7Jqpc5Q71sq0UkGCwFWTI2XMm4KY5wEyegBtbnKO/eaY 3O6mV1Y0aEZX
9zfhUvzhdJp1Im8ITjY84gwLWRLvd1+Zd1MFhMvGLjKdSUWFS7KN2MgQJQNh lE2tGTSG0aH2
hvLbpm6JePtMN5yzpiBlbQwXhPHJ8iqxdguodqZ4/hrYgJZYjJqtElQboqNp AAFM51DnXA6g
qlKcEy8T3d7/AGcYLuxhMZehWq1sXuRKrfkbsjM84iQJIIDSdhE3bvNBPTZp 3Qy/FZzPDASp
xFDeEQugOCIhrDpDuGFody5A1BiLctwFlnEtg5YZr3CzYX5vBR+CGzRd7Giq 1tKRiDy6blQS
R4lGRAhQKY4DxICPAmOnD32f9+syyrHTwNWnSMoZdPEEgSbewv2DnfZm75vn W+euUyrutg8f
hetU5zEesxph28yRgNnnC/p0FvNts6uyH7OuyMs7reOo13IyiuC8DOt4xm4t S3VmS983UELk
ZSNjiRxF2xGhleLijCuoKehROUhSDt7RPFcr+KGKw2bYnFQhAVsZHCB5OKMJ GlF5StBa03Re
DOSZWF/Scd3Hw9TAUsNKUrlCVQuAL5iZSLCw26HIBdrI2htA3jgvdryThXcX sS2LNeWxLZdu
G6Im7J1CXjHUoZg3vCLg3QOHRLfai8WKd6UWZzgmRumByGTWEwGD0zCd484w WbZ3v6kKnVsP
GoINIQjIUb8boMyw1VACDM84GLCK4uvkuXYnLsBKlGUd7WuXubekDMxN4sNQ eNhu+axclYtt
7PbBTnkP8/ng5ZvRPd1j/hseOxbDPln8+/5u4X5uSfb/AMEGv8GOnDch8VMd K5/Kpc7LJYrR
L7WN+zzvszc83zrfPUVO4WGjf/mT5mKhS1Wwnc4POF/ToLebbZoje+x9g7G+ 8TdWKd31OeCz
7OlJiz5F1eTiPcu3UtBzshEuVkObGzZMrYxWyYk2i7YjtCOgaAHpfw/zPH5v llPHY6NIGqBK
O7vAXSBYRIku76CzNsc8X3uy/C5bjJYXDGZuWG82nTYQBYxGrSOGyF3Zjl9Z jaJWlJWDdO5l
tzi2j4S4oCYkG6HFoK/8oMYl86dMT7LknwHaaZ9dQ01KYA32BzbD4yvVw1K9 vKRaQlCcNtsT
OMRMWedAyDEF2kH1WKy3EYehTxNSI3dTzSJRkPAbpN08EmNhDWFv07sjdCw7 Obv26reFxv8A
iIvDsR6WcomXUaFK0tK4Dzt5N3bzjiJiDfltvqtSjoPwVB4R02g+Ws278YjC ZpnVCID4k7ml
p+0hco2Wm25O8eGI0aF7Xl3denicBl1X2fPlo82V6fFeAA4D41Cszezu3cHO 9Hft6bwUrdKy
eQc8I4dtRhaSsS2PHyN3RxryF8+VkWaoHaJJPQTTTSTA4AUA2z67QbHI/iXm WHyvCYXAwpGV
LBTrTlUvF4UZThdjdkGk1M2kkEkWBY+Z9y8HXxmIxGIlOMZVoQAgw50xC0uC 4MpiyxrdK0xj
zdA3ULTgcwXXvPsrtQxJhWWmbJlr/tefjkRue6Wk85iGEPBwDu13f4Zbiica J5QxUdQUU2Ez
al7HOfiFm0zgjlW4nLGwjONKUJmdOLC8ZzjViLok4ibkbzGIBMSToss7m4H/ ALxDHGrHq8iJ
TBiIS1hgYkg3WJDlrC9oC6G9nrbiUflv2fU2hIS54eei80r9GJhzDvI+HfRb Tkz47FVjDxzo
5HbtY6wA6VVFIoFIUeAxjcH8QMbUI7wYerCEZxjhCZQvhwZ0zESEpyBMYyEb 0RASYkx5zDpO
6+Ep3MsrU5GUL9YASA6NRyCACBIxMrpvEOBe5tuoLK3f5LeY3D9yeClwTNj+ IszOF/35Ivp5
C2mzKLirjhhUkHUmvFzXFESUcEAwlZLG2TCGhQ1OXYw72nJc6zSvKf8AMqQw cYC4al6pKlEg
XROm5IvWmcQLTaeaacR3djmOAw1GEObCtXdiI3YCcwWN2WsRsES9gs0jS3tB d2PDm7Vlez7f
wTNPpzHl52NbmUI91LiKixW1wLSCSRAUNHxShiiDATF4xqkfQfhEKOoB638M +9mK7wYfEddp
xp18PWlTkI2CxtRlJi7gtIiywrzjvp3fo5RUpSw8zOlVheiSz+QCxiCLBpW5 Paa5ZnrbxrhH
GFv5LyLDO5LA+OE17AtFwsws180kBkmLtzKOW90x5xVWbpqJnTCMX2iJEKJ9 DiBPMe4Hd+GO
znMalTB06ohjqv8ANMmqUyJExui7aHYuJgxtIDsD3nePNpYTKcIIYjdmWHjz DC9GoLsXBNoF
ha0MXYkC0SzKm67gvKeVWMhmWdvR5hqxd1SHzrFMG762TS7BnHOnwoQaLhCA YN10km5Dhxiy
QKqHEBMoBQAoYmF77Y3J6OL6rSo76WaGjIkVLkjISed01JSjIyg5AmYgWCNj mufdfD5nLCir
Odzql8ebeDGDRMhECQAmw5oLhybbIviz2fe45cOC7Py9mPIbnH8Tlh5fRrKm 7uuuxIOPtyPt
p6owjiyzSaWaPJVwuqCfG82gUie3ofiw2TH3XeH4p5vluYVMDHD06ksNGlvI xjVkakpgSlu5
ReNMAGzePoNsjYtZk3cLBZhhI4mNWYFUzuE3AIiJIF8G2VotukaRYBapxjLE Nmb0G6puS7nO
OHs1ZeP81u8hXdfzyMlmxUpgLOWQVWUftm8YgLxVQxEwZAqqCbUgAChHRyJn Lzeb59Vy7Pc2
zioIVzhKVHdAiUbgqiIjd50rBvP5gDbwmUgYPdO7y/KIV8qwuABNLfVJxnol eMDMydwG8zml
iYsBbpWtLJ3KdyfJV27ut2Wy+vdpgveNY3O1g494rFOrjhJWAlEYxJ25GOjF UHDVVRyltpES
IZMomOKogUQrsY/EPN44fHwqQw/WcFGlUPnCnOlUiJkC9MGMwDpMpAloiOtc 3X7m4GNbDmMq
po1pTp6jKNSJMQbItKJINjAgWvqWqvaC7rWPtz7NjLdxtFSXkr4godg5vi4Z fVCNdzT9IHIo
wrU8c2U5IikJfw5l1QUMYSgBRTNtdn8Ne9WL7zYerj6sIQomZFIB7zDTfLkE 6NAi3C9nOd8c
iw+Szp4eE5Sq3Xm7XbdF2wEDTpfxa9F82H6/vDXpO4K4vfJzYfr+8NNwU3yc 2H6/vDTcFN8n
Nh+v7w03BTfJzYfr+8NNwU3yc2H6/vDTcFN8nNh+v7w03BTfJzYfr+8NNwU3 yc2H6/vDTcFN
8nNh+v7w03BTfJzYfr+8NNwU3yc2H6/vDTcFN8nNh+v7w03BTfJzYfr+8NNw U3yc2H6/vDTc
FN8nNh+v7w03BTfJzYfr+8NNwU3y8mj1wHQpdQ69VjDKRVCpyBz2A1PVhtU7 0JyBz2A06sNq
b0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A 06sNqb0JyBz2
A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0 JyBz2A06sNqb
0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A0 6sNqb0JyBz2A
06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0J yBz2A06sNqb0
JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06 sNqb0JyBz2A0
6sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0Jy Bz2A06sNqb0J
yBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06s Nqb0JyBz2A06
sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyB z2A06sNqb0Jy
Bz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sN qb0JyBz2A06s
Nqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz 2A06sNqb0JyB
z2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNq b0JyBz2A06sN
qb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2 A06sNqb0JyBz
2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb 0JyBz2A06sNq
Lr7don1bZ3ObSbmHYO6vS/y9XqgWCsX/AB15L3gwV/Oa/Bh8P/2mKXo/d2uB l8OGrU/hoqUZ
T3Wd55rEvrkmMfXO0gmSKr169dQUqkg3bokFRRVVRRuBSEIQomMYwgAAGo1g 5T3ryqU40oYq
iZSIAAqQJJNgADuSTYAtlmeX4unAzNKYADk3ZMANZs0LWW62odjvj4dbrm1M fIFlFDX7NzMK
23xBheyLGEaqNT+ArS91cdfzGjH68fnC3fujJxFwR+7Li25kuPt6djG0fIte MUTFZs7yxdbZ
Um2kYhy7RDCGpRAQ9wa5LvXGeH7XxNItOnMmJYFiMJQILGzTtsXQd3DGpSwV OVolFj4DWqBb
eeb01l3vg28rFwFEz2HH1txzCZjLgZ5HvV7GxxXV3w8Y6E0a10LsGJKKqHEi ShuqJSGOIVyd
PunXw2Pw+IzCdLGirOUZQOGoRlJqNSceedbwADyiNDyAC3OJz6nPDVaeHEqB hEES3tQgPUhE
80aucSWBOwErlq8L2t3IO/DlW8bSdcstafYZzmIl1xaqXHM3tgXe5QU4tcpF C7SZwHQxQEOo
IANegVstq4XJstoVhdnTqYKMg4LSFWiCHDgsdYJC5XDZpTxWNxc6ZeMo1yDt BhMjTboW9cf5
EyBaEvj4uLnDlDITS0MYhE82kMq4O6Wx5b6ZEiJAU/GcZt7ApiUQOA7IgICI D+anxbxVWj3y
zMUSb4xVRm0u+jhfQ2vQv0h+E+WYbE9ysB1sA0jQN69YGEpFybGZndwzOCGX YWQbVXtJG6sz
YRtiBN7TYkAzkritmNeC/GEB8KpH0pFMDInTVkFEjkFRLaNptF+ErxujvW46 BpCpiMLTgceI
AyiC913eUYsxmQzjhHnXv5mhyvFDEmhgcwrVRkxqyjCpKN3eXWuU6k3BjTBB uyYaDZC5/J/I
zeKnZe6N13eNkp92q+uJ7YjZ4+evVTrLuF1sq2OooqqooJjHOcxhExhERER1 Gt5/yt4k4rvV
C8XkadYkk2k7uVpK6n/mdwcML3foxpxEYRrUwAAwAALAAWAAaAuVMeQEPcFl x3LFVGkm3Kks
0fM1TIuEDgXgMQ5BAQHWv1g7+dw8r714bqmaUhOOp9IfYV+YuW9+s27q5nLG ZVWlTk7FtEg+
gjQRwFbFio69pVrzXemQZ2dtf7U0S+dmK2OQQEOLUKkJdsggIgJTagIDwhXi Xdr/AJUO6OS4
2ONp0BOcC4vBwDpB2ONS6rvX/wAzXerO8JLB1akacZ+cYRjEngeIBbaHY61s PGeUbnwtfUZk
vFckMNfEOYyka/QTRUFEx0jNzaJuCKJmAUzmKIGKICAjqFfQ2ZZPhsxwssFi oCVKYAMbRYGI
tDEMQGYrwDA5jicFXjiaEiKkS4Om3Xp0vwq0yrl3IeapiLlMtT5pjo+yPCW4 xSZRUTGREequ
LlRBjGwTNgxRA59kTmIiBz7JAOYwELphd3u5+CyadSrhoyNSqXlOcjOcvDKR Mj4yVuM471Y3
M6UKNW7GnDRGAEYvodhZxMLTYrW8MmXnf1r2ZYV2zijvHuPms0wtCE5OwSQY FuGQQk5JTjUW
xHKp1lmyY/hVTgUA0KBdR1ycJ3YwmGzCtmdKJFavGMZlyRK6AIljoIAAsYHW HtVmv3gxdbAQ
y6bGnTkZRstDu4fWHJNoJfW1in9o7+m97YErcNw2TkmQZXLc68U/lpB00hpZ UzuFhWtvNHSR
Zxg+TTcFYs00jLkKCp9NTHE3DXL5l8JcixkBTlhxEAyIuExa+b0o2FjAlyIE GMXIiACy3uB+
IucYaQlvL/NEWkHBuuxOg3g/nAglheJIWIw/va7wuA4B7buKL0csmElKtLsf jLs4i4jLTbNx
ytOSELnYyZSuxW0OdwQAVMYAETalKIZ2cfDfKcyhShVomO6gYRMJSgbkg0oE xIeJBIMS4Ylm
cvi4DvxmeEq1KgkJbyQlISAlG8LYyAOgxIDEbA7sFlrK3998nHltTNs2hlCR bJXBLTt0SztS
Otxw5PI3K9WkJVRsZzFKlZA4WXOYxWZUSgI6gADw1qsR8HcirRpRnRL0oxiC JSBMYl4iTECT
aAZAlgA9i2UPiZm8alSYMWmXumLgFmJi5cPpIdney1RDDecsm7u848uzBdxK Wzer2PcwRppq
2j3TxFo72AW5OaTauypKGAgBxpCgcA10MGo11veTurg8+wowmOiZUxISskRa NBLG3Tok41s4
C5nI+8GLynE9aw7XmItAIY6RweEEHU7OvnIZlyFJ4QtfdrdTphwRZzhzIW/b nI40SNXDoDgo
JXYtBegQRUMYUwXBMTDtCURABCjCd0cDhcfLMqEDCtKAhIglpRDCLxdnjdDE AFrHZXcV3lxu
KwvVK5E4X74cWxJcljsLlwXGxlaZGyZeeXrgiriybOKS7mAt6GsC30VG7Bul HwMCLkzJomDJ
sgZTZM8VMKixjqGEeE2gAAXcl7sYTKquIq4WJicRUNSYckGZ0kO5Dm0h2GoA K3mneDF5hRoU
K7EUI3YkBi1jA6iwAALA7XNq+q+VrzWxKhgcJg5MQIzZrzGDIg0AikwaPGLB wdfiBcjo3HZA
gKATXh2ddBq/LIMMceMzukVxT3buWMHvXSHbzrXZ+FljwzfExwksDYaZnfYg OJMzg6bRZsZS
TE+9nnrBFsdEcN3SEFEFkiXKgBoi35Q7WUI35IDxqadjn/J1+IEU+MR2TgUR ABDWtT3j7i5f
nc95i4Sv3bhMZyi8HvXJCJAlEm1pAh1sMj71Y3Khdo3TF7zSiJNJmvA6RIDW CFfYy33t6/C+
PF8Y4tyPJxdsunEhIOFHKEVLvjOZcxlJFYj2dZP3KSjpQ5lFjoqEMY5jHEdo RGtRmnwnyLHy
hOph7soCMQYkxcRtAkAWk3CCWYOwC2uC+Iub4cz54mJklpB2JDPHWLNQLcGl Yyy96rPmPJzG
85Zl4uGJ8Rt55nj1AjOJOnFdJ3BHMsoJlWR1XBnBkwAQcHUKAagUoajrsMf8 PMqxtXE1q9Iy
OKjCNUXpNK41w6XiRdFsSNDlzasLC99Myw1ClQpSAFGZnAsHF4SBGwxN42EE 26WYLJ4034t7
HDePV8Y4tyEvBWku4fvAbR8LaqabXnMwi6RjkeZxRjkTAOgJsU0SlD7UAHhr W5l8KMmx5pzx
FOUp04xjevSEpRh5omxAmRYL0gZEAOSs7CfEPM8NKoad0RqSMrrPESl5xi5J i5csDdclg1ix
tl71+8JjeYx5N2FeriLdYnZXHGY8KnHwbgsMF2HBSXXLy2PXM4UXEof8JFUp NPglLw1nZp8O
MqzCpialemScVGEavOkL27MTA6bDG7HQwLc4Fy+LgO/GY4OlRpUjFqMzOHNF l4SEo7DE3pan
D2EMGs5neTzncWE4vdxnbxXXwlFxlv26EISOgWx3jK1lBWiEn0gzjUZBwRqo InTTVcGTKYRE
C6iNUYH4a5VhMZDHU4S3kCZB5yMRKQAlMRJuiUgBeugAsLFdxnf7MsTQqYed xqlhIiBK65Ii
+uMXLO5Dm1Xl7b2G8Pf9033e8/ehwvDJFsLY1u+TaQtsN3D+3nLdJm4brKJR JRVVVQQTSFyr
tuCkIUpFClKUAtj4YZTHCjBQpyFGNYVoRvyaFQa4uSWLl4l4OSREEuqqfxAz OOIjizdNQUzT
JMfPgS7SYgODoMbp2khX+G98/eQ3eLTLY+ELwG37ZLLJ3UDbmi3pTZlE0SNg cJGnI1+ZI4pE
AgmSEo7Ooa8I1ld5/h3lWf1o4jG0iakY3HjKUXg5N03SAQ5Op7bCsLIe+WY5 RTlSw5FyRdpA
FpWc4a3DDgstCtojfC3nIrIFoZQNkB44vaxHl4zVsPFY630+SyN/zB5y4XRi NoxEiou3Kg6k
UAyRC/BIQoCOutwnwlyShTq0RSMoVqcITBlLnCm1zWCDFgAYkaHLlytpjfiT m2IlCTxjKE78
SI6CYmJFpIILkl3LmwswFrIb0meJZnZjGUuzjkbAmX132uoELbSLhlKyT7nN yog5bxSa6KSj
sCrGboHIgY5CCKY7BALs8P8AD7LaNWdaMJGVSiKNR5SIqUxEQAmCWJEQAJBp aXJcvra/fPH1
ae6N0CNTeQYNu5uZExt0Ek2SvDYBYs7fe/lvcZNlrak75yCo8RtK7EspwTNG BtJigjc7duu3
Rfqc3QzY6pig5UMJVTGKcxhFQDjppp8v+EGSYKcp0qU+dTnSIM5kGnMMYWlw LSxBEhtWzxfx
KzbE0t3Mw86MnEQDegRIS2O4DgghhoWrJeWeXPcMveV4ySkvec/JydyTUo6T aoqu5GXfrybt
YybJBugTbXcHECpplKAcAAAV3OSZNRyrCU8Fhwd3TDRe0tqD62XKZzm+IzPE zxdYATmztYLA
BrJ2bV8dmJ64f7P2q2rcC1jzWwJTeu3h5iEmLWd3w7Las5akFip9GoMoVFEb Tt1w6cs40BSj
yqCUTPlwUVMYVjFUMUVNOCuAl8McnliDijSN81t896RaofOIc6JNbEvEfqiL BdpT7/5pChDD
xkLsaZp6A5iQwfhj+qQx6V5y8kjPaIb60Jd123/D5PeIXreki1npl8MRayxC PWMelFN1mjRx
DqNG6pGqJUuNSRKqYA1Mcw6DWvr/AAdyKrhqeFNE3ad64RKV6MZG8YXneUHc gTvM5bSsql8S
s2p1jXeJMgBIEc2RiGEmeyXDC6LBZYo4hvZbwjbGkJh0bsbSGNredPZeMjro tSxrqOSUknLp
29kDu7tgJZ2d0uo8VFRUyomEDCHUq9X+FOUyxPW6Iq0al2MXpVZ07Ii6PNkG sADBhrZySVH4
j5kKJoVo0qsTInnwEtJdtIcPaHc8LAAfKx96XeAx1K41l7UvZ03c4iazrKwA BlDaRprmXTcy
6xhBgBlzuTJBtAsJyFDUCFKAjWyxvw8yvGVcTVxFMzOKhCNV5Fp3Gumwi7IX R5l0WOzrW4fv
rmOHo0qFEiEaMzODC2N688bSXjzj5zm3Sr+x98XeGxxC21bdl3WRhbtpIzrG CYIwtuclbtLl
ORSUZ8QMYKYs3B0yHM0EvJtohB4vUhBLjYv4X5NipSnWomUpwhGRMpud2AIS d7JxAAEw0mcE
kEvfo9/82pWU5iIE5TAADAycyHDEmRJiXALEMQFic2byGat5OTiJjPt2LXRI QTAsLFKOmMOy
FBsVUywh/wAksGe1qY/+VqBeoUChrrs+6/cfL+7286hAx3rGTyJch7bdBL2s w4FgZ/3rxucC
EcTd/lvdYMwLWadAax7eErC5GyZeeXrgiriybOKS7mAt6GsC30VG7BulHwMC LkzJomDJsgZT
ZM8VMKixjqGEeE2gAAZuS92MJlVXEVcLExOIqGpMOSDM6SHchzaQ7DUAFjZp 3gxeYUaFCuxF
CN2JAYtYwOosAACwO1zas5N7zWfJznnlF7OU+esfIYCW4mPgQ4iw0eN1iUdu NN9vx59pc+0v
w8CgaBpoMR8Msprbx6chvK4xBaUrKwfni3W5eJeNtkRYt3hPiBmeH3N26d1T NMPHTAtZJiNF
2LEMbLSXL5zGe+9vT4VxybFGH7/eW/Y4ndKJtkWUM+Ubg+IBHRWi8uweqtQV ANTcnMmOoibX
aHWrneL4a5RneIGLxdH+aGBlGUo3hEuBIAtJtpBLMHYBY2R99syyqkaFGQNM uwkHYnSRrHgB
bgtKwMJvI5stt/jd3b94PGKGIyS5Met2iTBEIo88/QkZJTjk2pXC4uFW5AOV wqoTY1KBQKYw
Dl4juHllfEYnEVaV44qEYVQSSJCIAiWJskAAxi1ofzrVYpd78wpYelhqchEU ZmcCAxiS7jYY
kyNhB0t5tizzjfi3r3mVGub3uQnKmVYqLeW1bcrzRbSacBHvxMLksSxRiSMG qqm1odwmhx5i
6FMoJQAA0tH4SZJSwtXBxpSuVZAy583N3zQS7yjE2iMrwcAtYFtq3xHzWpWp 1yYPTdhdDF7C
eAkaTG6bSzOVFMmZsyRmZC3WmVbgUnULTikLYgjvWseDtGPbGEyaaz5JqR65 2RMOnKVlNnUR
LoJja9NkPdPBZLKqcDA041TelFyY3tchEkiJIYG6wLCywLQZx3jxmaRgMURK UHAkwEmP6pI0
gaQ9oc22qL7MT1w/2ftV0jcC0TzTZieuH+z9qjcCPNNmJ64f7P2qNwI802Yn rh/s/ao3AjzT
ZieuH+z9qjcCPNNmJ64f7P2qNwI802Ynrh/s/ao3AjzTZieuH+z9qjcCPNNm J64f7P2qNwI8
02Ynrh/s/ao3AjzTZieuH+z9qjcCPNNmJ64f7P2qNwI802Ynrh/s/ao3AjzT ZieuH+z9qjcC
PNNmJ64f7P2qNwI802Ynrh/s/ao3AjzTZieuH+z9qjcCPNeDowxjaiACPXqo EhTemqcnhexC
l6Sm9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL 0kvTTk8L2IUv
SS9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0k vTTk8L2IUvSS
9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvT Tk8L2IUvSS9N
OTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk 8L2IUvSS9NOT
wvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L 2IUvSS9NOTwv
YhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L2I UvSS9NOTwvYh
S9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUv SS9NOTwvYhS9
JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS 9NUFvDacABrU
3il6a88li/sVN4qb005LF/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9 NOSxf2KXil6a
cli/sUvFL005LF/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2K Xil6acli/sUv
FL005LF/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acl i/sUvFL005LF
/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL 005LF/YpeKXp
pyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL005LF/Y peKXppyWL+xS
8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL005LF/YpeKXppy WL+xS8UvTTks
X9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL005LF/YpeKXppyWL+xS8U vTTksX9il4pe
mt1Y7F1fe73b+PscSMMhflrXLck+/jbln4W2yuo+4Yy3WaKrV3cDti0UFFWE OCifGgpocglK
YNsS+Z945zwWZVMVUo1alKtRpQBpwnUMZU51pESjASkARVDFmsIJBZ/Ru6+I hVwYoGpCE4VJ
yachBxKNMBjIgFjAuHe0cLdEXpvy+1Qv+zpWxLqvWzHVrzbNzESTXp1g5Ljm jxAzdZPbRliH
LtEOIalMAh1QEBrybL+5vdzCV4Yill+KjOnISidzjCxiXBYxILEawy7vH5/m GIpSpHF0LsgQ
RvKFoIY61z/ijGuQcabxtgZwyrJWpF4ysm5YS8ppeNvyxp16o1hJNCUO3ax9 vzT94sssDfik
wKlsgYwCcxCamDv+8Ga9q5bXy3CYfEGrXhKEb1CtTiDIGLynOEYgB3NrsLAT YuPybL6eW4uG
Mr16VymRI3akJEtawjGRJJ0CzwsFkLZkbyu2yMW3FgmbhWd02FDuLdk28vdt vWnIsn5LunLl
avWp7ikYwFUzJypAKducxiKJm2gL8ATZGcthMVjKeLw9WpTxFQTiYUp1YmO5 pUpRkIRkxemX
EgAYyDPa13IMVGrhKBhWhCdKJiRKcYEHeTmCLxDhpC0aCLWsUpvnIO/zkK2H NoXzfsbMWs82
AdRstm3H7potxShVicYi4u06Ztk5CmDUOAQAeqFc9l1HJ8HVFahl1WnOOiUc FWBDhixFFxYS
PAtnmc8Vi6ZpSxlOUTpBxECDr0GbaVrKy7LufDl6ymXMwStss7Vb2xesE1Zw F52hc0g+kLlt
CVthmii0tmVklSgVaSKqooqBEypkN8IT7JTdNjsfLOer4TC0K4Ir0ZylUo1a UYxp1YVJEyqQ
iCSIsAHJJFjORo8DgY5ZGtWq1aZenUiBGcJkynAxFkZHWXJLABbixxmq/WV1 Wjnzduua22kh
G21asCHPV32ZASMdIwNpMLYepLMLrkWJlCKC0OchyJnSOmcPhbQGKX8/fjD8 Ge90O9+OzDL8
HVq061aVSE6cDMNPUbCH1EFffnwm+MHc+XczB5NnGIjCdKFycJuHIkZAgxtZ yGLi0KkPfm8b
ad/N8u2xdFptcmtnR5RObNlfF6rk7pQTGVOsZa5Tgrxm2YFAU2gOBhAwCAiA +QS+CHfqFYYi
jl2KFQF727k763cWvrd3tBdety+NXcDEYaWCr4yiaJjduMQGGgBhYzC6QxiQ CGIC0Xvc3XK2
5gjON3ZquOBkMgZJgUoGMZ23c9tXQ7eSa17QN2PHjkbXfv0W6REodUBFUxBM ooQCFMG0JfcP
+W34L96Mo7w1M4zfCVKNOFOoZSqRMbxnEiwEWly5bQF5R8ffi93ZzvJsLlGR 141DCpBhEFox
gGALtq0aV+tjT2E/sq2jZNm3xZst0g2Uy9JbvHQNAL1RlxHqFCu0q/GzvPUt li3/APt0v7a+
fKncnLJyMjStP1p+srgvsOfZckDQuMTAH2Llu/53qz+dHeYf/l//ANOl6it+ 4mVex/en6yr+
o99l91PRmfT+094fPFPzq7zfi/8A+nS9RR7hZT7AelL1lQ3sOvZdD1cZGH9m 5rv+eKr/ADr7
zj/8s/d0vUUe4mU+wHpT9ZeS+w69l0P/ANmJvOa7/nen5195/wAWfu6XqKT3 Eyn2P70/WVR9
hz7Ln6sTec13/O9R+dfef8Yfu6XqIe4mU+x/en6yB7Dn2XP1Ym85rv8Anen5 195/xh+7peog
7iZT7H96frIPsOfZc/Vibzmu/wCd6fnX3n/GH7ul6iHuJlPsf3p+sqB7Dn2X Q/8A2Ym85rv+
d6H42d5/xh+7peop9w8p9j+9P1kD2HPsuvqxN5zXf871P5195/xZ+7peooPc TKfY/vT9ZDew
69l0HUxibzmu/wCd6pHxs7z/AIw/d0vUU+4eU+x/en6yp+o69l19WRvOa7/n en52d5/xh+7p
eop9w8p9h+9P1k/Udey6+rE3nNd/zvUn4195/wAYfu6XqJ7h5T7D96frKoew 69l19WJvOa7/
AJ3qPzs7z/jD93S9RQe4eU+x/en6yG9h17LoOpjE3nNd/wA71A+Nnej8Yfu6 XqJ7h5T7H96f
rKn6jr2XX1ZG85rv+d6k/GzvR+MP3dL1FPuHlPsP3p+sgew69l39WRvOa7/n en52d5/xh+7p
eooHcPKfY/vT9ZDew69l0H/2ZG85rv8Aneo/OzvR+MP3dL1FA7iZT7H96frI HsOvZd/Vkbzm
u/53qr87O8/4w/d0vUUjuHlPsf3p+sqB7Dv2Xf1ZG85rv+d6p/OzvR+MP3dL 1EHcPKfYfvT9
ZUH2HnsvPqyN5y3f871P52d5/wAYfu6XqKo9w8p9h+9P1lX9R37Lv6sjec13 /O9U/nb3o/GH
7ul6ip9w8p9j+9P1lQfYeey8+rI3nLd/zvU/nZ3o/GH7ul6iqPcPKfYfvT9Z ev1HXsu/qyN5
zXf871A+Nvej8Yfu6XqKPcPKfYfvT9ZeR9h57LwP/syN5y3f871I+Nnej8Yf u6XqKPcPKfYf
vT9ZDew89l2HUxkbzmu/53qB8be9H4w/d0vUU+4eU+w/en6yF9h57Lwf/syN 5y3f870/O3vR
+MP3dL1EPcPKfYfvT9Zev1Hfsu/qyN5zXf8AO9R+dvej8Yfu6XqJ7h5T7D96 frLz+o79l39W
RvOa7/neh+Nvej8Yfu6XqKPcPKfY/vT9ZDew89l4HUxkbzlu/wCd6n87e9H4 w/d0vUUjuHlP
sP3p+sqfqPfZefVkbzlu/wCd6j87e9H4w/d0vUT3Dyn2H70/WT9R77Lz6sje ct3/ADvT87e9
H4w/d0vUT3Dyn2H70/WVR9h57Lz6sject3/O9Pzt70fjD93S9RSO4eU+w/en 6yp+o99l59WR
vOW7/nen5296Pxh+7peoo9w8p9h+9P1k/Ue+y8+rI3nLd/zvT87e9H4w/d0v UT3Dyn2H70/W
QfYe+y8+rI3nLd/zvUfnd3o/GH7ul6ik9wsp9h+9P1l5L7D72Xo//Zkbzlu/ 53p+d3ej8Yfu
6XqIe4WU+w/en6yqb2H3svQ6mMject3/ADvQfG7vR+MP3dL1FPuFlPsP3p+s n6j32Xv1ZG85
bv8Anen53d6Pxh+7peoo9w8p9h+9P1lQ3sPvZeh/9mRvOW7/AJ3qPzu70fjD 93S9RSO4WU+w
/en6yp+o/wDZffVkbzlu753qT8bu9H4w/d0vUT3Cyn2H70/WXr9R97L36sje ct3/ADvVP53d
6Pxh+7peoo9wsp9h+9P1k/Ufey9+rI3nLd/zvQ/G/vR+MP3dL1E9wsp9h+9P 1l5D2H/svvqy
N5y3d870/O7vR+MP3dL1EPcLKfYfvT9ZVN7D/wBl8HUxkbzlu/53p+d3ej8Y fu6XqKR3Cyn2
H70/WQvsP/ZfD1cZG85bv+d6fnd3o/GH7ul6iHuFlPsP3p+sqfqP/ZffVkbz lu753p+d/ej8
Yfu6XqJ7hZT7D96frJ+pA9l99WZvOW7vneoHxv70/jD93S9RT7hZT7D96frK n6kD2X31Zm85
bu+d6j87+9P4w/d0vUT3Cyn2H70/WT9SD7L/AOrM3nLd3zvU/nf3p/GH7ul6 ip9wsp9h+9P1
k/Ug+y/+rM3nLd3zvT87+9P4w/d0vUT3Cyn2H70/WQ3sQfZfh/8AZmbzlu75 3p+d/en8Yfu6
XqKodwco9h+9P1k/Ug+y/wDqzN5y3d870/O/vT+MP3dL1FT7hZT7D96frIHs QPZf/Vmbzlu7
53p+d/en8Yfu6XqKR3Cyn2H70/WQfYg+zADqYzP5zXf871T+d/en8Yfu6XqI e4WU+wHpT9ZA
9iD7MD6tD+c13/O9Pzv70fjD93S9RB3Cyn2A9KfrKhfYhezBH/7ND+c13/O9 T+d/ej8Yfu6X
qIe4WU+wHpT9ZUH2Ifswfq0P5zXf870/O/vR+MP3dL1FJ7g5R7AelP1lX9SF 7MD6tD+c13/O
9R+d/ej8Yfu6XqKn3Cyn2A9KfrKn6kP2YP1aH85rv+d6H4396Pxh+7peoqh3 Byj2A9KfrIHs
Q/ZhfVofzmu/53qPzv70/jD93S9RSO4OUewHpT9ZU/Uh+zC+rQ/nNd/zvU/n f3p/GH7ul6ij
3Byj2A9KfrJ+pD9mF9Wh/Oa7/nen5396fxh+7peonuDlHsB6U/WVf1Ifswfq 0P5zXf8AO9R+
d/en8Yfu6XqKfcHKPYD0p+sqfqRPZhfVofzmu/53ofjh3p/GH7ul6ij3Byj2 A9KfrIHsQ/Zh
fVofzmu/53qPzw70/jD93S9RSO4OUewHpT9ZP1Inswvq0P5zXf8AO9Sfjh3p /GH7ul6ij3By
j2A9KfrJ+pE9mF9Wh/Oa7/neqT8cO9P4w/d0vUT3Byj2A9KfrKhvYi+zDD/7 ND+c13/O9Vfn
h3p/GH7ul6ikdwco9gPSn6yr+pE9mF9Wh/Oa7/neqfzx70/jD93S9RR7g5R7 AelP1lQ3sRfZ
hh/9mh/Oa7/nen54d6fxh+7peopHcHKPYD0p+sqfqRvZh/Vofzmu/wCd6n88 O9P4w/d0vUU+
4OUewHpT9ZVL7EX2YY//AGaH85rv+d6j88O9P4w/d0vUUHuDlHsB6U/WVP1I 3sw/q0P5zXf8
71P54d6fxh+7peop9wco9gPSn6yfqRvZh/Vofzmu/wCd6p/PHvT+MP3dL1E9 wco9gPSn6yfq
RvZh/Vofzmu/53p+ePen8Yfu6XqJ7g5R7AelP1k/UjezD+rQ/nNd/wA70/PH vT+MP3dL1E9w
co9gPSn6yfqRvZh/Vofzmu/53p+ePen8Yfu6XqJ7g5R7AelP1k/UjezD+rQ/ nNd/zvT88e9P
4w/d0vUT3Byj2A9KfrKgexH9mJ9Wh/OW7vneo/PHvT+MP3dL+2oHcHKPYD0p +sn6kb2Yn1aH
85ru+d6fnj3p/GH7ul/bU+4GUewHpT9Zef1JHsxfq1P5y3d871P5496fxh+7 peop9wMo9gPS
n6y9B7Ef2Yn1aH85bu+d6j88e9P4w/d0v7apHcHKPYD0p+sqF9iP7MQerjU/ nLd3zvUfnj3p
/GH7ul/bVR7gZR7AelP1lUPYj+zE+rU/nLd3zvT88u9P4w/d0v7apHcHKPYD 0p+svJvYkezF
D/7NT+ct3fO9Pzy70/jD93S/toO4OUewHpT9Zev1I3sxPq0P5y3d871H55d6 vxh+7pf21PuB
lHsB6U/WXkPYkezF+rU/nLd3zvU/nj3p/GH7ul/bUjuBlHsB6U/WVf1I/sxf q1P5y3d871B+
OXer8Yfu6X9tU+4OUewHpT9ZU/UkezF+rU/nLd3zvT88u9X4w/d0v7ar9wMo 9gPSn6yoHsSf
Zi/Vqfzlu753p+eXer8Yfu6X9tQO4GUewHpT9ZP1JPsxvq1P5y3d870/PLvV +MP3dL+2o9wM
o9gPSn6yr+pI9mL9Wp/OW7vnen55d6vxh+7pf21V7gZR7AelP1lT9ST7Mb6t T+ct3fO9Qfjl
3q/GH7ul/bUDuBlHsB6U/WQfYk+zG+rU/nLd3zvUfnn3q/GH7ul/bQ9wMo9g PSn6yB7En2Y3
1an85bu+d6fnn3q/GH7ul/bQdwMo9gPSn6yB7En2Y31an85bu+d6fnn3q/GH 7ul/bQdwMo9g
PSn6yoPsSvZjfVqfzlu753qfzz71fjD93S/tqR3Ayj2A9KfrKv6kn2Yv1an8 5bu+d6j88+9X
4w/d0v7ae4GUewHpT9ZUN7Er2YwdTGp/OW7vnepHxz71fjD93S/tp7gZR7Ae lP1k/Uk+zG+r
U/nLd3zvUH4596vxh+7pf21HuBlHsB6U/WT9SV7Mb6tT+ct3fO9D8c+9X4w/ d0v7ak9wMo9g
PSn6yfqSvZjfVqfzlu753qPzz71fjD93S/tqPcDKPYD0p+svP6kv2Y/1an85 bu+d6H4596vx
h+7pf21PuBlHsB6U/WQfYl+zHHgHGp9P7S3d871P5596vxh+7pf209wMo9h+ 9P1lT9SP7MP6
sx85Lt+dqn89O9X4w/d0vUU+4OUew/en6yfqR/Zh/VmPnJdvztT89O9X4w/d 0vUT3Byj2H70
/WT9SP7MP6sx85Lt+dqfnp3q/GH7ul6ie4OUew/en6yfqR/Zh/VmPnJdvztV P5696/xp+7pe
onuDlHsP3p+sqfqR/Zh/VmPnJdvztQfHXvX+NP3dL+2nuDlHsP3p+sq/qR/Z h/VmPnJdvztT
89e9f40/d0vUT3Byj2H70/WXn9SR7MT6sx85Lt+dqD4696/xp+7peog7g5R7 D96frJ+pJ9mJ
9WY+cl2/O1Pz171/jT93S/tqr3Ayj2H70/WQvsSPZiD/APZmPnJdvztUfnr3 r/Gn7ul/bUHu
DlHsP3p+sq/qSPZh/VmPnJdvztVP57d6/wAafu6X9tPcHKPYfvT9ZUN7Ej2Y gf8A2Zj5yXb8
7VV+evev8afu6X9tB3Byj2H70/WQvsSPZiD/APZmPnJdvztUfnt3r/Gn7ul/ bQ9wMo9h+9P1
lT9ST7MT6sx85Lt+dqfnt3r/ABp+7pf21PuBlHsP3p+sqm9iR7MQP/szHzku 352p+e3ev8af
u6X9tQO4GUew/en6yF9iT7MQerjMfOS7fnah+O3ev8afu6X9tPcHKPYfvT9Z UH2JXsxfqzHz
ju352oPjt3r/ABp+7pf20PcDKPYfvT9ZUD2JXsxfqzHzju352qPz271/jT93 S/tqR3Ayj2H7
0/WT9SV7MX6tB847t+dqfnt3r/Gn7ul/bUe4OUew/en6yB7Er2Yv1Zj5x3b8 7U/PbvX+NP3d
L+2pHcDKPYfvT9ZDexL9mKH/ANmg+cd2/O1R+e/ev8afu6X9tSO4GUew/en6 yD7Er2Yv1Zj5
x3b87VP57d6/xp+7pf21B7gZR7D96frJ+pK9mL9WY+cd2/O1U/nv3r/Gn7ul /bT3Ayj2H70/
WQfYlezF+rQfOO7fnap/PfvX+NP3dL+2h7gZR7D96frLyHsTPZjfVoPnHdnz tU/nt3r/ABp+
7pf21I7gZR7D96frJ+pM9mP9Wg+cd2fO1Qfjv3r/ABp+7pf21HuBlHsP3p+s vQ+xK9mL9Wg+
cd2/O1Pz371/jT93S/toe4GUew/en6y8j7Ez2Y31aD5x3Z87VH5797Pxp+7p f21J7gZR7D96
frIPsTPZjfVoPnHdnztT89+9n40/d0v7aHuBlHsP3p+sg+xM9mN9Wg+cd2fO 1Pz372fjT93S
/toe4GUew/en6yp+pM9mP9Wg+cd2fO1Pz371/jT93S/tp7gZR7D96frJ+pN9 mP8AVoPnHdnz
tQ/HfvZ+NP3dL+2nuBlHsP3p+sn6k32Y/wBWg+cd2fO1R+e/ez8afu6X9tPc DKPYfvT9ZVD2
Jnsx/q0Hzjuz52p+fHez8afu6X9tSO4GUew/en6yp+pN9mP9Wg+cd2fO1Pz3 72fjT93S/tqP
cDKPYfvT9Zef1J3syPq0Hzjuz52qfz372fjT93S/tqfy/wAo9h+9P1k/Unez I+rQfOO7Pnaq
fz472fjT93S/tp+X+Uew/en6yfqTvZkfVoPnHdnztT8+O9n40/d0v7afl/lH sP3p+sql9id7
Mgf/ALNB847s+dqfnx3s/Gn7ul/bQ/D/ACj2H70/WQvsTvZkD/8AZoPnHdnz tT8+O9n40/d0
v7aH4f5R7D96frKn6k72ZH1aD5x3Z87U/PjvZ+NP3dL+2n5f5R7D96frKpfY nezIH/7NB847
s+dqp/PnvZ+NP3dL+2h+H+Uew/en6yp+pP8AZkfVoPnHdnztVQ+PHez8afu6 X9tPy/yj2H70
/WT9Sf7Mj6tB847s+dqj8+O9n40/d0v7afl/lHsP3p+sn6k/2ZP1aD5x3Z87 VB+PPez8afu6
X9tT+X+Uew/en6yfqT/Zk/VoPnHdnztQfHnvZ+NP3dL+2n5f5R7D96frJ+pP 9mT9Wg+cd2fO
1D8ee9n40/d0v7afl/lHsP3p+sn6k/2ZP1aD5x3Z87UHx572fjT93S/tp+X+ Uew/en6yob2K
HsyQ6mNB847s+dqn8+O9n40/d0v7aD4f5R7D96frKhfYoezJH/7NB847s+dq j8+e9n40/d0v
7aH4f5R7D96frL5PvYuey/jmir99joqDFAhll1lrluoiaaZC7RjGMaXAAAAD URHqVT+fXez8
afu6X9tTH4e5TIsKDk/Wn6y54nMD+xcZyjlK1cJ3PctpNDEIvcsJKzgR2hx2 CnTCRuZm6VIY
dQKdNAxT9UgmAQEcaX/ML3pFnXjZ/wBXS/trusL/AMvNOvTjU6tGN7QDOYJb YHt8S3VjP2UH
si8y2a2vvHNilk7XdCYhVS3DeCZ01Ux2VEVkVpQiqSpDcBiKFAxR6oBWVH49 965BxjT93S/t
rj8b8MstwdQ0q2GMZDUZT9ZXt1ex19k/ZMSM5dGPCNI0DFS4w9w3cYTHOPAU pE5QxjD1R0AB
4AEeoA1ch8du90y0cYfu6P8AbWJ7h5QNNH96frKIt/Zl+yVGfmI2dxWowgIz ieKlVbhuxVJ1
xwgBNgqUoYfwgDxiWztbaYCfgAKvn43d7mBGNJJ1bul/b4+FUjuNlL/Y/vT9 ZTJz7D/2Vc7F
AQuMiLxDtPaAyNy3ZsKpKF1ASnTlw1AQHUBAawq3x572mMqcsaWNhG7o/wBt ZNDuTldOQnGl
aNHOn6y7kANK4x1uV+dm6xltruk7qO69vKXTfV0zDLJFhJX1nsL3ua7b74i3 YjFLy85S7mrK
XeSrthyOXSZtDmYFTbH5wKiqiosdkKMKVj197j2kOSN4vG+65e6TXF2fmN5w c0nNTduIJw8v
b9yY1y2cGMjbVp5MuMrpJF1ZxliKHnUhFYUzC2Lycp3Aoybw/tLN9FvYGZ75 DHzVjuxsmua7
LtaWeP42BWGVxrD3cQrtpNxOQULifqunNpratGUEwXbJqnWI8ErPjnAlLq/S ICgFS6pVahF+
VzXeNz/uldJt9i9BlJawiX7vFsGqS2TbxuDpW0sX0mzzK3HFqXA1GCtpqila ZARkYs7lwXkq
SPEgk7cCmVTLdcPv0b+UHa9yYky7aDWJ3u3zq222Ko9OCtNR7OqzCVwSb1qt a0fl6TQQSbxl
pyDhN8+uRkm4MCiSSRlW2w5KGdajzLvy72G9vuXby9h3dbcDadl2fg++3l+p vE3J7gVuBrJZ
Yx04aNGzCTkY5sku4sxN6Ig+dg1Ap2xTvQWK8btKlbczpvxb9GAskl3RGkVA 5K3nJx1aKluX
HZltDFMkWVyxWQZdVFS27mvxmm6VbJ45caqGuJqUxXZTFTEzbi3QlGdaxV3t 99jOu9TinH8E
+i8Z5oWlLfjZ9Ny4fXTAruGsRvERT9vKQNr3saKLxilmt3JmjeROs0dbKTly 7Fklswiz+XPa
m78NixGVc0Q+Ootvu8W76Y7dsyRuEYBq3Um8WRl1qJOSvSX2MvL8rd2irxke jbzM6SKqigOj
ptBVcFIXVG7zlbPBs8XvuybwsjAXHelrQFp341umzISRtlksyuyRuWKJHqRc lNXEpxrZS11F
RcA82VCrlJxRBSE6suqXW6tdKIVzt7T/ADkvh7dnRtaFczzW9MmT8Ji6NWx/ F3BLXQ2ZTbrj
LjkIRK2mrx2m/jLaayck2VBIxU1W5REig6JHjQpZaF3Ut77emzEvYO6Ngm5m sHelstcpwt2X
BnexL2k7ocssd3BZ8fai8iykpuznfL5e2ruYSrxypqVRVX4KSQiZMkKVgc2e 1A3jpzdif54u
KAa42xBfOI5O+8ZQ7yMuOcVvOVPht7kV03aXvZtxwykArHqJqoik8YN13CbU 6zJwJ1DAzh0U
t3o8m7z+8Pu5S2S4ectaBxqlmWzMf2Zbzm2JaRk46bs3eXgLNSlpSUJcrJF8 1XWh1XRmaLJq
cpVSpA5EUxVVlQzK/sfO++Pkb2kFs7vr27oFlLY4a5DhchuWUBNkt+8GTdDD F1oLsYM1ziaN
foNbxOyRcuHb8qYlWUBLZcCkmdSy7k6lFGhUEoVLqSV+b474Udu/YRsjf3zl bOR7r3g7msy5
bxllmd+vYzHUZfcBYNz3RNWI7tMly8WwVjE7aeR4cbb7g6CqRBcrKvgWVGlG VLozP7QjL+c8
L4iy3GQOPc+wWR2U7bM9ccFCrJKMprEWWW6xHtn2nlC5nQJELDqlQeKTLcq6 ihilR/migrCV
KyF2e1O34XT6ajcRY6i570Txc1M5Sl9YBhCynMOQL3sRQ/L7rvu2ejbVz0Bc u+PFOa5MRxoo
Q/JgM7KF+iOmvVqdCMhuGoCC1cdRG9Nl/DPs+rwzPb7R1fGX/S3fWOrZZSS5 XivGze8PLY/h
kylkZCNTVSYJvEASanfNUzJpFQ5Q2IIKpwSjKI3Fv+b/ABZmGH915dtWLx/G 2LKTrfLGTXNu
s71b23GR8DBz0erJ2FYORZWVZcrTm1AMdCWfGQRaldLopNngHaSyK+t32hW9 zcmYJ9/P2/A2
JuirT2S8dweQb26NtoqGe4+Lcrc84u8UyE2k5dIy9rLrLxxISPMkgdRTlgpN DLOIZGVhce+P
7UeF6H4whLPi7ky3fvTC9bbkoeyQjHaVj2t0VjEjytoXnk23TsnT1/cR1i7U 4ZdFuVEizJNw
quRmQJu877+89vM5jksRYjLa9i37c/GX+eXnlpbJsKwj4zGGHpVxEsixNzQ7 NbjXmQBFN5HO
UWhiNhUBsoq6UcARRG0t8LO+4Tu/XVm+fJA3ngKSyPvMJwdls42Qg7gYvbXn cp5DOs7uFSVl
GrlJwa1V2wJkikTJg4IfjD8QYi5SpdA753tMH2QrW3bL8hbWsTNF03RFRTW4 rvt+Lc7ELIWV
f1yHE1o2flW4nKey5skqaL1eYSIvxypCN9WpjqQEC6l3R8zXRnXCwXje6DVG 9IuevCxJdWKI
qiyevbKu+Ws5xINm7hVwo3SeKRJnJG51ljIlUBMVVRJxhhRbMoFC4rzxjTLu e/aezePY0JSQ
wxBWFjWRlm8dmTJeNOZuersv1s/fsIyxETtpR0s2jEwEHazfTiEyAoAHMYhS sfv1b3OdovFO
8tgu15yBh70x3jjId9hdtuvZBtMLMjWo8dQ8fFtknJVGUzEKPWTiTccoVKki pHrESIMsQseR
Twm9HvHYgzteNlbys9Zp8BYjxxEZiydfUJb1xxz1VKTkL7QM2joUJacMmkk1 t1Bc6ouV1AMi
omRBTlZDMila0t7fo9pf/wDV+HrtxdyXM9s9ELlk7k6MRa/M1n3N0qSWlOhd tZLuRzL8lc2m
KPFMpwj1XlW0kyUFsVN5Chl2JgPIsfmDBFk5biJprccVdMDD3G1uGKjXsMyl EpKPReketo2S
XcumiS5VQUIguqdRMogU5jGARGFIUtANalCvzv3u87791rYs39nWGmcW9xta HPPNt2yt/wBw
wdxWnxeCLSl1uj8YxtmTR/ALOTvUdmRbbblQ+vFiIqmMjLSt0uL/AN67fdHF 6Z4Eja67yTsm
YichRUxfNqSsVad3b1x2iExCyU81UepApb7ZyigLwiDZymidBNNNBJEsFF1r gjfm3uMp71yc
FP2C1jd0aavK+8Vwk08UttgqV7Y7m4WJ3rWQUvVxJyqrle2FxFgS2mpkU1Dq coUSaGUcmUSX
Yp6pUhC0QryA0QIPBQBCqmDTqVACOqaUKMqCFQhQaKXQAooCr1KJoVNdaMpK dSqU0KhQqSpI
XkRoi9G4OpQKGVBDSoKmKoFFIVRAKhQFQQqUKa1BR0DhqCVITqUIUKlETSoK kKhqqCBBHSqQ
EQPhdWiLzRSvQ/B6lFCoIaURDBpUKQhg0ogVKhEGpQpUBFQeCoRVqFK8iGlS pVahUoAaUUqg
DQKDYglAahFTbGpZSqdSinQqiOlQypCprUKp1SihAopCqFECoI6VBUxVRCoR eSjVTKEERDqV
CBKKoBVEdKhF5MOtAhVS/C6tFDJRlJCptDUMoZUoiUKJUOiDR1JCBR0AVBHS iJUIlQ6KghUh
AmyFCjoAaVCKm0NQApZV+26tSbEVC1SUKpUqVU40CpQfgdT3ahF5EanQiDwV ClUNwdSgRk10
opCqIVDI6oI0CC1NoaghSyCNFAtXktQ6OmlSqmTbGoVKDRVFVKG11ahQvIjR FXShKllQah1B
QQopKGHZ6lESoKheKqCqVRAKpQIAa0UIWhQoWoKFUqVKqPwepVKhUqVKpUIg 0ZClESoRBHSg
Qqn23Vo6Aqgjs9SilaJ9pjIT0XuPX3JQKSi5UEoxSWSREwbUKE0y54A4lAR4 vm7j+M9zY114
Kx8UTGnIx0suq7kUqNTNsPCuQIGdpOjQW8ujhXMO7RvpbsNuboGRLZyNj28J eQOZoGQLghm1
sHbR6j52o0iAaBITrN0sCaxNsBKhwHERMAF0GtdluOwwwkxOMj0jZY+jX8iv fe+3dTOZd4ML
LC1acRbuYkz5wiAajtAgOLDbbFgHKmPsaLxuO9neUJQWqzaxSntwiHGCPFnl +Tv+VjpwlBXk
HN+2ACPBs8OmlTk1UzpknQ9i4j454GjhsfSjEgzuc9tINjfpZdLZ9GSGSh+k vIfQ5xpOduWb
fHcdtj9pxP8AONri/wCD4jh12uM+BrXSYVmLPe1fLRx+K1eFVA3gWbykOOhx efn7kPRrik+a
eN43kvHcWPJeK5D+F2dP4rh2Nfc1q1Qv37HfX+nT+lVSAa1fXD/TToCz6b8m 5dw8j5BxHF8j
0LxOvJPwHU+14v4Oxs+7rVrF3b/N+RU0na1TEc2YbDqXbC+NGPba6Lew6Q41 g3DsXK+7LuM7
t+6LdBp/AuelbbiXrqOeXHB27b+79bzK4EY1Y6iTSTPbOPYt0dLZWVJqmuRQ hVD8Wchh2qb2
HSHGFJidi2Zb27X7Ku0rHuHGNq2DiiMxrd3IOldvR8HaDaMmuanBnbHnFoig VFzyZYwqI8aU
2wYRMXQeGoNaG0cai7LYs9JY+9n3M3xc+TpiFx67yVe0Wrat53C5Z22rJz8I u3QaKxso7OQV
nTU6LVJMyKxjEEpClENCgATvobRxqbstinwZsw2P9bYXxox7bUb6HSHGouHY q+mvDXlbC+NG
Pbab6HSHGlw7FzLYm5huvYt3oJnetxjmRK3L9uOUdzFwt4GCwXH86NJCWJMO 4p7KtLGTnV2q
6qZQUMpIi4PoBzLCqAKU30OkOMIIy2LZkRhX2advYfld3q37SxmxwDOuiSs5 YzOLtZG35F6m
Zscjl3GJpFarKlMzQEDnTEwCmTh+CXQK0No40EJbFf2nj/2fdh2PIYxsWEx7 CY1los1qytvR
LO22cY9hDuJF2aNcNG5CIqNRWl3igomKJBM4WNpqocTN9DaONLktisIjC/s0 7dw/K7vNv2lj
NjgGedElZyxmcXayNvyL1MzY5HLuMTSK1WVKZmgIHOmJgFMnD8Eujew6Q40u y2K+m8f+z8ue
x3GMbkhceyGNncXC2q6t58ztteMWhLbcKu4aNUaKkMiZqwWWOo1REuwiYxjJ gUREaGtDaONL
ktirKWB7PyZvi58nS8Jj13kq9otW1bzuFyzttWTn4Rdug0VjZR2cgrOmp0Wy SZkVjGIJSFKI
aFAACtDaONBCWxS1C/8AdzaXQ8vdpN22leki1ZxUhLpvIwr1yyjlnbhm2WcF OCh0kFH7g6ZD
GEpDKqCUAE5tY30No40EDsV+OasN+VsN40Y9tqd9DaONSYHYoFn5viXOMRBN 4fLSVjXXbkoF
ww9y2wpYkhJtXAxj6IUKh0xh7gbI8Y2kFSGURRItsiJAUBM6hDxvodIcam6d iwOAsa4OwnfE
5k658upZEyVOa7Vw3ehjFjJtOObsWjzindmW5bqynK0YiPTX5SZXUrNuUuyC QBTfQ2jjUXDs
WQiMLezTt2RlZe37Sxmxlp2AJj+cdM4u1kVpG102TaNJCOzppFMswK1ZoIA2 OIpAmmQmzslK
AUirDpDjS4divXtgez9kcoSObn8Jj1fNEvzdztd6zO2zzb3mh2wfx3KJAxBc qclcxTRZHbOP
FnQSMXQUyCE76G0caGJ2LIXJFbkl5SCcvd7ax5WWRnmN/pOpJOBcqkuiLZIx rGbKdYDGB+3a
t00EnIDxpEyFIUwFKABG+htHGpunYpb6acOD/W2G8aMe21O+h0hxqLh2IOac N+VsN40Y9tpv
obRxpcOxcr2ruM7uFvbzEbvdy+eVZ3PrF03eOrnlbf3f05iRSRaljjtHMzG4 9ZS5UlmJRaHF
B2moCIiQhy8Ag3sNo41Jidi3XjCwPZ+4TiGNv4ZhMe2jAxkotdUaxthnbcW3 aTbiMUhVpJBJ
iRIibpRgqdsZYoAcUTCmI7AiFDVh0hxqLp2Klw2B7P27Je3rguqEx7Jz1oyj +6rUfSDO23Di
FmpSTLNPpKPVWIY7Z05flBysskJTnWAFDCJ+Go3sOkONLh2KfBmnDnlbDeNG PbaGtDaONTdO
xU9NOHB/rZDeNGPbab6G0caXCNS5osrce3J7L3iLv3g078hn/T/pC2va1HNu 4Ubxk9GXMdVZ
7GSb6Ms1nOvGplTlUMVxJHMsZMormV+FtRvYbRxpdOxbLaYU9mqxj7MiGVpY zRiscul5XHrV
KLtYiVrvXL1OSXcwxCpAVkqo6SIuc7cCGMoUDiO0ADU76G0cai7LYr6TsD2f 01fFz5OmITHz
vJN7Ratq3ncLlnbisnPwq7dBorGybs5BWdNTotkkzIrGMQSkKUQ0KABArQ2j jVV07FgR3a/Z
XejD0I9AMU+hfnTpV0Q5jtDmXnrknIOcub+I5Nyrk34Hjtjb2Pg66cFN9DaO NQInYs/k6wPZ
/ZsiH1v5mhMe3dAycojdUkxudnbco3dzTeMThUZJdJ8RUijpNgkRsVYwCcES gmA7AAFDVhtH
Gm7KzrOU3TWHN3IHNpIczykjdUTxKkMTkU1L8v5xkm+yIcW6dc6u+OWJodTj 1doR4w+o1o7R
xoYnYsDjHH/s/sKRDG38MwmPbRgYyUWuqNY2wztyLbtJpzGKQq0kgkxIkRN0 owVO2MsUAOKJ
hTEdgRCoFWO0caXCpbbd+7utnR6kRaM3bkVFLOn0qq1jXkY2SO9lHq0k+cmI ichRVcOnCi6p
xDaOocxzCJjCIjVjtCXTsV/6aMO+VkN40Y9toKsdoS6di1lmXCvs19426EL3 3hbSxpfd6NWp
IprL3nF2tNvUWSSqrgjZNxJJLqFSKouocCAbZAxjDpqI03sdo41Nw7FEmmBc Yx2T46/o/eGk
ELUiLokchRNkIssLkhWT+Xdv3MgRuqWyglU+VJyrtBZwR6DtQi6omXFRQ5xb 2O0caXDsWy8U
RG5PgePLEYPbWRZsUVqjFFa2onAxCQMm719JItgIwBEvFEdSjtcpNNkFF1Tg G0ocRjfR2jjS
6digbfdA9kQ0th5ZDTF+H0rLkHTOVkIhO27LKycvY9J03ZuVm5WwJnVQTfuC JnMUTEKqcCiA
HNq3sdo40unYt0mzPh3yshvGjLttRvY7QgidiqGZ8Oh/WyG8aMe203sdoQxO xaFzDgPGOVbh
vR5Gbwz+1LDyDp0rsuBZYYeQsltQrS31+WhctlzDx3x7NmmkpytwrqQATDRI pEyzvY7Rxqbp
2KeWDaO5vYPNEwm8tKSyTFbDk95u0LUbTTyT/wCVzuJNZWJasUSOnC1xSiyp kEky7b1yJSlB
ZQDQasTrCXTsV/ERG5PbuX5XeEgG1kMc+zrUkVN3wzTgUbgkGSZWxCNnUmmB XSqRSs0AAh1B
KAJk4Pgl0b2O0KDAlS70z4eN/WyGD/8ACjLttRvY7QpunYqFzRh4P61w3jRl 22m8jtCXTsVA
zPh7yshvGbLttDUjtCCJ2IOZsPeVkN4zZdtpvY7Qlwqpsz4eH+tkN4zZdtpv I7Qlwqnpnw95
Vw3jNl22oNWO0JdOxPTNh4f62Q3jNl22o3kdoQxKDmbD3lZDeM2XbabyO0Jd Kp6Z8Ph/WuG8
Zsu203kdoUiBVRzNh7yshvGbLttN5HaFF0qhczYfHq3XDeM2Xbab2O0KTElU 9NGHx/rXD+M2
XbajeR2hLhVfTNh8v9a4bxmy7bTeR2hTdK8jmXD/AJVw/jNl22m8jtCi6VU+ ZsPj/WuG8Zsu
203kdoS6U9M2Hx/rXD+M2XbaX47QgiVQMzYg8q4fxmy7bUbyO0KWOxPTNiAf 61w/jNl22m8j
tCgRKDmXEHlXD+M2XbabyO0KTEqnplxB5Vw/jNl22oNSO0JdKqGZcP8AlXD+ M2XbajeR2hTd
Kp6ZcQeVcP4zZdtqd5HaFTdKoOZsQB/WuH8Zsu20vx2hTdKr6ZsQB/WqH8Zs u21F+O0IIlUH
MmIB/rXD+M2XbaneR2hLpVBzLiEf61Q/jNl22oFSO0KbpVQzJiAP61w/jNl2 2oM47VDFefTJ
iHyqh/GbLttTfjtCm6VX0yYgN/WuH8Zsu21F+O1RdKGzLiDyrh/GbLttBUG1 BEoOZcQj/WqH
8Zsu21F8bVN0oOZcQj/WqH8Zsu20vjal0qnpkxD5VQ/jNl22l8bUYoOY8Q+V UP4zZdtpvBtS
6U9MmIfKqH8Zsu20vjajFUHMeIR/rVD+M2Xbai+NqXSnpkxD5VQ/jNl22ovj ajFBzHiEf61Q
/jNl22pvjapYp6ZcReVUP4zZdtpeG1LpQMy4iH+tUP4zZdtqDMbUYqhcx4i9 26ofxmy7bS+N
qEEqvplxF5VQ/jNl22oMxtQgryGYcRD/AFqh/GbLttSZjajFVHMOIfKuH8Zs u21F8bUYqg5j
xEP9aofxmy7bS+NqCJVPTDiLyqh/GbLttLw2qbqemLEXlVD+M2Xbai+NqXU9 MWIg/rVD+M2X
baXhtRinpixEH9aofxmy7bS8NqMU9MOIh/rVD+MmXbaXhtQAp6Y8RD/WqH8Z su21F4bUYqgZ
hxEH9aofxky7bVV8bUIKDmHEQ/1qh/GTLttU3ggBT0w4j8qofxky7bS8NqqC DmLEY/1qh/Gb
LttLw2qLU9MGIh/rVD+MmXbaXglqoXMWIy/1piPGTLttReG1SyemLEflTEeM mXbam+FLIOYM
Rh1LqiB//CTLttReCpZPTBiPyqiPGTLttLwQhUDMGIx/rVEeMmXbagyCMVT0 w4k8qYjxky7b
UXgjKo5hxJ5UxHjJl22jhSgZhxJ5UxHjJl22jhF5NmDEnlTEeMmXbakSCAKo 5ixJ5UxHjJl2
2oEgjJ6YcSeVMR4yZdtqHChlQ2YMSeVMR4yZdtqRIBSAq+mHEnlTEeMmXbai 8FDKnpixL5UR
HjJn22jhSyel7EnlTEeMmXbaOEVAzDiUP60RHjJn22jgqWVS5gxJ5UxHjJl2 2oJCghU9MGJf
KmI8ZM+20cKWQcw4lN/WiI8ZM+20cKGQ2YMSm/rTEeMmfbahwjKnpfxL5UxH jJn22pdGQcwY
lH+tER4yZ9toSEVBy9iU39aYjxkz7bUOpQcvYl8qYjxkz7bR00IOYMS+VER4 yZ9to6hPS9iU
f60xHjJn22oBUhPS9iXypiPGTPttLyqVBy/iXyoiPGTPttQ6pFiFy9ib3boi PGTPttCjJ6X8
TeVER4yZ9tqXVS8+l7E3lREeMmfbahQq+l7Ew/1oiPGTPttEKFy/iYP60RHj Jn22oKMqel7E
3lREeMmfbaIq+l7E3lREeMmfbaKpUHL2J/KiI8ZM+21ChPS9iYf60RHjJn22 iFDZdxOP9aIj
xkz7bRE9L2J/KiI8ZM+21BULyOXMTh/WiJ8ZM+21IKlVHL2J/KeJ8ZM+21DK RYgZcxOH9aIj
xkz7bRQqBl7E4f1nifGTPttET0u4nD+tESP/AOEmfbagogZdxOP9aInxkz7b R1KGy7icf6zx
PjJn22oZQFT0u4o8p4nxkz7bUqU9LuKPKeJ8ZM+20RBy5ijynifGLPttET0u 4o8p4nxkz7bR
E9LuKPKeJ8Ys+21DIqelzFA/1nifGLPttQyFPS5igP6zxPjFn22jIqDlzFBv 6zxIf/hFn22m
hSvm8yfhyRZrR0jcMM4j3BDILoLv2J01EzlEpiHKZQQEogOggPAIVBtUxmYk EWELki8/ZY+z
vum8RuiFvd5bkSJ+MLAQk9AGYJa/bEQPJsnrtAg+4RJcpShwFAoAABr55TRk XIXp+A+MOeYa
jGiKkZXQwMg8uNwulsRpbr+CbEZ41xRJQkPZzLbMk2Rk26h1FVDbSiyyyy51 VVTm4TqKGMYw
9URrNhTEA0QwXnmY5nXx9aVfEzM5y0krJ3Rd2Br2iTQd0TsO7jBMVUEzyTUo lOQeAxTkWKYo
9UNQEOARDqCNXoTlAvFYMgDpUSa2tu+8/wAxIzd2x0hASnFcTFKSTRNJrxIg JNgyS5R/BgHF
pbOzsJiJOEBGsg4qTAAMRr+Xl4VQKYU5TyliBm2SZMbih0WaJQSSSSfsikIQ oAUpSlKoAAAA
GgAFYUwTarosW1TST0eosp9+b/HXU3wtZaqc6PA6qyn35v8AHU3gUdfBpdCE goulHvgXVaqC
2dFRWA4orAUpxTUAph2TbJwHQeHQQ69W41IydrWVMagk7F2LHgOxXHOrv+OU +/N/jqu8FXaq
c5vA6qyn35v8dReCKoSrseosp9+b/HS8EVOdXf8AHKffm/x0vBACrVzeDNpK toNzIAnMvCLK
tGh1tFViN9jjTJkE2pgJxhdoQ6moa9WjgIFdc6PC9VZT783+Ol8IqGlHg9RZ T783+Ol4JagS
jwOqsp9+b/HUGQS1DSjweosp9+b/AB0vBLVgsiZisvE1umuvJM8lDQAHKgRd 6uJBVWPrsIok
AROqqbTQpCAJjD1AGszA4Gtjam6w8DOWwDVtOwbSbAsbFYylhYGpWkIx2krX TX2hO7WqsUsp
cEpCMDCBecrot26YGNLtHEgCd/NRrRqUNS9UygBpoPUEBroKncrM4BxSEuCM 6c5ejGRl5Fo6
PfHLasrkawfhEgOMgDyqas94vFsllRDCcZcyLrKDmJNdSUS1VUWPzUVZBAHJ lEgMkUDGcE2A
MYDHARMUBKAiGknleIhh+typkUr9xzZzmJZtOgF7GGg2st3HH0ZVtwJAzu3m +q4D7NYbbqUs
51e/xyn35v8AHWtMgstWVy31H2jDLT9xPjtopDTbUMKhhExjAUpCET2jnOYw gBSlAREeAAEa
CQRRI29FjgOq7mA/Zgbi7xpeRSu2b8jrxhkrgtt+d1Era7ChTKFEDFESmIci mychiiAgYpgA
QHgEAGhkivwlHv8AHKffm/x0vhAnOr3+OU+/N/jqLwRaufb72BI1+5ZOrhe8 maLLM1JJKInl
Ysyzc4pKkSkUmRmauwoAkNxaptDAJR+EGlc7V745ZTqmjOvESjYR8rFsxk+J lESELDwh+J3U
sxvnXHGYGDmTxZdLK4WTJQGz00Q+SdC2VMUDlTXKkcTJmEogYAOACICAhwCF bnC5hQxUb9GQ
kNoIKw6+GqUTdqRMTwqRjLPfcXV+/N/jrKvBWFg7lzLYVlvyRd5XQxiZNRMH CbaTkm7VUyRj
GIBwIuqQwlExBDXTTUBq7ToVKgeESRwAlWp14QLSkAeErHBvJYW8vIXx2x7f Vzqdb2cuIqg4
yl048YQd5PCwf18hfHbHt9Op1vZy4io65S6ceMIO8nhYP6+Qvjtj2+nU63s5 cRTrlLpx4wqe
slhjy8hfHbHt9R1Ot7OXEVV1yl048YVR3k8L+5fkL47Y9voMHW9nLiKjrdLp x4wqesnhfy8h
vHbHt9Op1vZy4ip65R6ceMIG8nhcOrfkL47Y9vp1Ov7OXEVBxdLpx4wgbyeG PLyG8dse31HU
6/QlxFT1yj048YQN5PC/u35C+O2Pb6nqdf2cuIqOt0unHjCp6yeGPLyG8dse 31HU6/s5cRU9
cpdOPGEDeSwz7t+Q3jtj2+pODrezlxFOuUenHjCDvJYZHqX5DeO2Pb6jqdf2 cuIp1yj048YQ
d5PDAf18hvHbHt9Op1/Zy4inXKXTjxhB3k8MB/XyG8dse31HU6/s5cRTrdLp x4wqDvJYZHqX
5DeO2Pb6dTr+zlxFOuUenHjCesphjy7hvHTHt9Op1+hLiKdbpdOPGEHeTwyP UvyG8dse306n
X9nLiKdco9OPGEHeTwz7l+Q3jtj2+nU6/QlxFOuUenHjCDvJ4ZHqX5DeO2Pb 6dTr+zlxFT1y
j048YQN5LDIdW/Ibx2x7fUdTr+znxFR1yj048YVA3ksN+XkN47Y9vp1Ov7OX EVPW6PTjxhPW
Sw35eQ3jtj2+hwlf2c+IoMXR6ceMJ6yeGvLyG8dse306nX9nLiKdco9OPGE9 ZPDXl5DeO2Pb
6dTr+znxFOuUenHjCoG8lhvy8hvHbHt9R1Ov0J8RTrlHpx4wnrJ4a8vIbx2x 7fTqdf2c+Ip1
yj048YQd5PDYf18h/HbHt9R1PEdCfEVPXKPTjxhB3k8Nj1L8hvHbHt9T1Ov7 OfEU65R6ceMJ
6yeG/LyG8dse31HU8R7OfEU65R6ceMKhd5LDgdW/Ibx2x7fTqeI9nPiKjrlH px4wgbyOHfL2
G8dse306niPZz4ip65R6ceMKo7yWHB6l+Q3jtj2+o6niOhPiKdco9OPGF59Z LDvl5D+O2Pb6
nqeI9nPiKHGUenHjCqO8nhwepfkOH/4bY9vqDg8R0J8RQYyj048YVA3k8O+X kP47Y9vqep4j
oT4inXKPTjxhA3ksOj/XyH8dsu31HU8R0J8RUdco9OPGEDeRw75eQ3jtj2+o 6niPZz4ipGMo
9OPGFQd5PDvl5D+O2Pb6nqeI6E+Ip1yj048YVfWSw75eQ/jtj2+oODxHQnxF T1yj048YVPWT
w75eQ/jtj2+o6liOhPiKdco9OPGE9ZLD3l5D+O2Xb6dTxHQnxFR1yj048YVB 3ksPD1L8h/Hb
Lt9T1PEeznxFOuUenHjCDvI4f9y/Ifx2y7fTqeI6E+IqeuUenHjCr6yWHvLy H8dsu31HU8R0
J8RUdco9OPGF59ZHEHl5D+O2Xb6dTxHs58RU9co9OPGF69ZLD3l5D+O2Xb6d TxHQnxFR1yj0
48YXn1kcQeXkP47Zdvp1PEeznxFT1yj048YVQ3ksPh1b8h/HbLt9R1PEdCfE U65R6ceMIO8l
h/3L8h/HbLt9Bg8T0J8RTrlHpx4wqesjiDy9h/HbLt9R1PE9CfEU65R6ceMJ 6yOIPLyH8dsu
306nifZz4inXKPTjxhA3kcQeXsP47Zdvp1PE+znxFOuUenHjCesjiDy8h/Hb Lt9QcHifZz4i
nXKPTjxhPWRxB5eQ/jtl2+p6pifZz4inXKPTjxhPWRxB5eQ/jtl2+o6nifZz 4ip65R6ceMKg
7yOIfL2H8dsu306nifZz4io65R6ceMKvrI4g8vIfx2y7fTqeJ9nPiKnrlHpx 4wvI7yOIg/r7
D+O2Xb6dTxPs58RU9codOPGFUN5DEQdW/Yfx2y7fUHB4n2c+IqOuUenHjCoX eQxEHVv2H8ds
u306nifZz4inXKPTjxhA3kcReXsR47Zdvp1PE+znxFDjKPTjxhA3kcRB1b9i PHbLt9DhMSf9
nPiKdco9OPGFX1ksQ+XkR47ZdvqOp4n2c+Ip1yj048YVPWQxH5ew/jtl2+hw mJ9nPiKDGUOn
HjCDvI4i8vYjx2y7fTqeJ9nPiKnrlDpx4wqDvI4iD+vsR47Zdvp1PE+znxFO uUOnHjCeshiM
f6+xHjtl2+o6pifZz4ihxlDpx4wg7yGI/L2I8dsu306pifZz4inXKHTjxhPW RxH5exHjtl2+
p6nifZz4inXKHTjxhA3kMR+XsR47ZdvqOp4n2c+Ip1yh048YQd5HEfl7EeO2 Xb6dUxPs58RT
rlDpx4wgbyOI/L2I8dsu31HU8V7OfEU65Q6ceMKg7yGJPL2I8dsu31PU8V7O fEUGModOPGE9
ZHEfl7EeO2Xb6jqmK9nPiKdcodOPGEDeRxH5exHjtl2+nU8V7OfEU65Q6ceM KnrIYk8vYjx2
y7fTqmK9nPiKq67Q6ceMJ6yGJPL2I8dsu31HU8V7OfEU67Q6ceMKpt5DEg9S /Yjx2y7fU9Ux
Xs58RUdcodOPGFQN5LEnl5EeO2Xb6jqeK9nPiKHGUOnHjCBvI4k92/Ijx2y7 fTqeK9nPiKdb
odOPGFT1j8TeXsR47Z9vqOqYr2c+Ip1yh048YQN5DEw/19iPHbPt9Op4r2c+ Ip1yh048YQN5
DEw/19iPHbPt9Op4r2c+Ip1yh048YQd4/E3uX7EeO2fb6dUxXs58RTrlDpx4 wqDvIYm9y/Yj
x2z7fQYPFeznxFT1yh048YVfWQxMH9fYjx2z7fQYPFeznxFR1yh048YVDbyG Jvcv2I8ds+30
6pivZ1OIqRjKHTjxhPWRxN5exHjtn2+o6nivZz4inXKHTjxhU9Y/E/l7EeO2 fb6nqmK9nPiK
dcodOPGFX1kcTeXsT47Z9vqOp4r2dTiKjrlDpx4wqeshijy9ifHbPt9OqYr2 dTiKq65Q6ceM
Kpd5DE/u37EeO2fb6g4TFezqcRUdcodOPGFT1kMUeXsT47Z9vp1TFezqcRU9 codOPGEDePxR
5exPjtn2+nVMV7OpxFR1yh048YT1j8UeXsT47Z9vp1TFezqcRU9codOPGE9Z DFHl7E+O2fb6
jqmL9nU4inXKHTjxhU9Y/FPl7E+O2fb6k4TF+zqcRVPXKHTjxhPWQxQH9fYn x2z7fUdTxfs6
nEVUMZQ6ceMIO8higP6+xPjtn2+nU8X7OpxFR1yh048YVPWQxT5exPjtn2+n U8X7OpxFOt0O
nHjCqG8hiny9ifHbPt9R1TF+zqcUk65Q6ceMIO8higP6+xPjtn2+o6ni/Z1O KSnrlDpx4wqe
shiny9ifHbPt9T1PF+zqcUlHW6HTjxhA3j8Uh1b9iR//AA2z7fTqmL9nU4pK euUOnHjCoG8f
iry9ifHbPt9OqYv2dTiKnrlDpx4wnrHYr8vonx2z7fTqmL9nU4pKOuUOnHjC BvIYq92/Ynx2
z7fQ4PF+zqcUk65Q6ceMIG8firy9ifHbPt9R1TF+zqcUlIxmH6ceMKg7x+Kw /r7E+O2fb6dU
xfs6nFJR1yh048YVfWQxV5exPjtn2+nVMX7OpxSU9dw/TjxhU9Y/Ffl7E+O2 fb6jqmL9nU4p
J1yh048YX1YbwOOZR8jGRl7xrmScqEQbt0JlqoqqqoYCEIQhFhExjCIAAAGo jVMsNiogylCo
AOAqRiqBLCcSTwhSXnqa+WLfjVP8dYXWZbSsm6FTn2a+WL/jVP8AHTrEtp40 uhUGcmh6jxf8
ap/joMRLaeNTdGxV55nB6jxb8ap/jp1mW0ow2IE5ND/92L/jVP8AHTrMtpUX QqDNTgf/AHYv
+NU/x1HWZbSpujYsVc+VoOy+I6Y3IhE8p2+Tc5yCbXjeL2dvY49Qm1s7Ya6d TUKv0Y16z7sT
k2lnPzK1Uq06fnkB9rBYsN4/FodW/orx207fV7qmM9nU4pK0cZh+nHjCoO8h i3y9ivHbTt9S
cHjPZ1OKSgYyh048YVPWPxb5exXjtp2+nVMZ7OpxSU9cw/TjxhPWPxb5exXj tp2+nVMZ7Opx
STrmH6ceMKvrH4t8vYrx207fUdUxns6nFJOuYfpx4wqesfi7y9ivHbTt9T1T GezqcUk65h+n
HjCesfi7y9ivHbTt9OqYz2dTiknXMP048YQN5DFvl7FeO2nb6jqmM9nU4pJ1 zD9OPGEHePxd
5exXjtp2+o6pjPZ1OKSdcw/TjxhUDePxf7t+xXjtp2+hweM9nU4pKeuYfpx4 wg7x+Lw/r7Fe
O2nb6jqeM9nU4pKOt4fpx4wg7x+L/L2K8dtO31UMJjPZ1OKSkYzD9OPGEHeP xeH9fYrx207f
VPVMZ7OpxSUdbw/TjxhC7x+Lw6t/RXjtp2+nVMZ7OpxSTrmH6ceMIO8fi8ep fsUH/wCG2nb6
DCYz2dTikp65h+nHjCyNv5Xhry47odcqEtybY5TzZIkdcVxm1sbfEKG2drZH TXq6DWJipV6D
b0Ti+h3D8av0atKq9wgtsYqYmUTIUTGHQocIiPUAK3qwlz7kTP8AL5lFe38L yZ4rD6JzIS9/
MhKLqTMmYSqs7cEwCQeEuyo+MApk6iQHP8JPzrvH3zhTBp4eVmuQ0ngh+meg anOjzrPe9sZA
ww0mhrmNMvq0/wBM9A/Vc2iEYUvku6/eF9x8Bj6TfY7uCRipyCVt6WtHiSk6 KwzF0CwT1wsH
fHC8arGUMoQROYdsTCJhGtb3e714fAUpxnCRvyEhdMDphAF70wXcF7OFafI+ 9WHyyNSJpyac
hMXZU2tp0wXv1Iye9Eu4t0vat4YV3loDM9zStmFgZS3LqiWTGZVZzikIvxzK RcPGqKyKsFJy
iIhxjBUogY4GDQODhrvMl7wUczvbqMhdZ3u63ZrspDUV32Q95aOamYpRlEwA JvXdErwDGMpD
9U61sgxyj7tbxdCEKYperQqFD7tzJGWpdqtnFiX0hIN2jWTcLtDxiSCab1Z0 giUTP3rURMIt
FB0KAgAacPDRStc5QkozJd2RVySsS5YMISOk0m7lV7GEeIvnj6JOgszNHPHR yqETaqiJhAA0
4B1ARCpQBSPGeclSO2tm5KcpHeuDFbRNwkKCLeQUHgKg4J9qg74PtddhQeFM eHZClmQhbS2y
1KJtlqFKbZaIvzG3r95/JmTt5+7C4ws1/djy25JbH1snK4GPQYCyODeS5IYU FxO4cvSqFWUL
sFBJNMon+Ccoe/8AdnA4TLMBSGIqRgakRVnY9htjetDARYgWkyJLWheId6+t ZtjZQpRJhA3I
+Eed5dewDYplYtr5Tt28Use3nEGhslnii3E4QipYk4wI3OcEQSdKC3ZLoqqm 2gTIoiYimwfZ
OIFHTY0M/wANjaJq0+dSErryjcL7RbIEDWQQQ4cB1xudd1q+WTjGUhfIdgX4 7AfIx1FbB3dc
fW9jvenshlA2+0t0ruFvd24bRzYrUqypndqgKpilAOEdNkNOACgBQAAAArj+ /GKNfL5G+ZgV
aWku3Nr2fLwrs/hoZnGSMwx3cv4oLsUDFrx4r20Lne/77e3neCisw6TZMmkk 8h44y+0LSNTb
SC0Ws+VAugnUNxRjbQ6AQg7ICXU5xkBSssruz5BWvXmEzwgWTs8r6Rhs7PEd hxHGbXHe51dj
T4Wv+RUoopjrJj7H9+mQiXicjHLP2sW/Ub7QNJJFd+jGJvUwNqJVS8aUwGDU Dk+CImACmCCi
6cKcohr16pUBaG3pcuplyNFbuUq9PAwNwx5pIzsFlGTi4RBwdspDRrsBIVNQ oAU7gSHBbi1C
AkGpjHJ5V8U+82OyvCXcHSkbwtmNA02PqNj+DQum7vYClWlfmQ4OjZ9YjZs1 PpWrclXxIWlG
soq1o7i54wBEWnbDUp2iBjNUylDaSQAopM2pDFFQQAOqVMvwzlCvlnuZ3Xx3 efMRAkgO8jaG
GvxfOV3+PxlHAUCbD5dPzk/ToWvrUxZnPBl2k3pMQLHncmJPHkNfDZ2KiCdy maLl5bHOtsCE
TVTMptMlg+AmYNgPwQmAfvOn3Qhk2HpUMLG6YwBH14nbwm0jYeAlePUO8MMy nUMi8RMxNnmy
GzaBr26dK7bwNnTHG8jiqJzFip7y2z5dMTp7YbC7dYhhTWbOU9RFNZFQBIoQ eEpgEKuU6wqR
vD6QdYOwjWpqUzAsflwjgWexr/27XZ/8htj+kLirYf7CP7UvmisOH20v2Y/P JI+7cuXBBSt2
xkpDtYplIzUcizVhnrlYE4qUdR5dtUswgUxjA3Aw6EANR6lbCpRw9MxgYzJM Yl7wGmIOi4du
1WIzrSBkJRAcjzSdBI6Q2LI4py8zvmUk7NkF2a14Q4JqOVohUizNy3WOqRJd LZVWMmIiiYDJ
HMJiCHVMAlMONjcKKTTg92W3SCGcHRtFuvyK9hq5m8ZaRxHTaOLRqWXvLKVi Y/uK07Tu59yS
4L5lVrWtZvxLhXlso3g5O5FENtFM5E9GEO6V2lRKUdjZAdsxSmwVlJceWMWW dz/0uuWKiuik
Undl085SLNtzNBrct4uTkOOULydobm11srK7JB4lTQfgG0IpBRFH8sZSsTB2 LLlzXlJ9zXjK
z4qRum45PiXDnkkXFM1H7xfiWiayynFoomNspkMY2mhQEdAoiRuUrEl8pzOF I99xmTbfioa6
ZeM4lwXk8XcDyWYRy/HGTBE/HLQbwuyQ4mLxepgKBiCYiyDa7LVeXU9sVpJt Fb2jmjOWkIdN
wiZ81YyKztuzcrNymFUiS6rBwRI5igU5klAKIiQ2hFD8xb0eCcEcazyDO7V2 p838ValvMpC4
rndc684GZ8jt+3m7+Wc8anDvlQ4hsf8ABNXCg6JoKmIRbAoiURKIlEUfs3KV iZAuK7LTtF9y
u4LGlUbWulvxLhLkUo4g4y5E0NtZMhFNWEw1V2khMUNvZEdspilIsfa2fsNX pky4MM25cLRb
K1sO14yYt9QxkHxFmsTAzjgyKLgqZnCSLS540yqyG2mQzlMhjAcdkCKYURR/ E+UrEzjiy2s1
4tfc6YyvCKjrptyT4lw25XFyrNN+zX4l2misnxiKxTbKhCmLroYAHUKIpBRE oij+J8pWJnHF
ltZrxa+50xleEVHXTbknxLhtyuLlWab9mvxLtNFZPjEVim2VCFMXXQwAOoUR Y/I+8LgLDl1W
xYuXb4t+1b2vZ2MTZkPckzHRj6ffAs3bi2i271dJV0rxrtEmwiUxtpQgaamD Uih6/tCdwVtf
cvi1znDH6eTbf535+tw95W4WUjej7dw7l+WMxe8cjyFFmso54wocUVM5j7IF MIEUgxbvY7rG
cYdjcWFMl2peFvykqtacY+ta4YiVbu5xtFqTa0YgqwcrEUdpsETujIlETlRK KghsAI0RbAoi
j9xZYxZaF925i27LliovJt4cv6JW5IyLNtKTfNTcrt/zczWUKs55MiYFFuKK biyiBjaBw0RQ
91vu7l7GOvWYfZespGIxq7QicjOlbqgiI2q+dPlIxBtNnM7ArFVR2kdAhHAk MZQokANoBCiJ
ae+7uX37asZfVi5esqasmauBvj2HmIm6oJ4xf3U8RK4bwbZw3dnSVkFUjlOR sQwqmKICBRAa
ItoURR+8spWJj+4rTtO7n3JLgvmVWta1m/EuFeWyjeDk7kUQ20UzkT0YQ7pX aVEpR2NkB2zF
KYiyF2XZathWrJ31fUm0hbJhWjiWmJiWcIs2LBizRM4cOXLhwYiSSSSRDHOc 5gKUoCIiABRF
kKIlESiKP40ylYmYLdc3Zjp9zjb7SVnbWcOOJcN9iUtmce23KIbDpNI48Q/j 10toA2T7O0QT
EEphIpBRFj212Wq8up7YrSTaK3tHNGctIQ6bhEz5qxkVnbdm5WblMKpEl1WD giRzFApzJKAU
REhtCLIURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiU RKIlESiJREoi
URKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESi JREoiURKIlES
iJREoiURKIlESiJREoiURYHJss5g7KdyTQ4prkO2JtkMJTACrpJI2hi8IcBh 6lZ+WUhUrxiQ
+nyAlY+KkY0yRwfOtDymUJFws/Rip10q5j1waPEkJR2Yzdc6KTkqSpSLakOK SxDgUQAdkwD1
BAa7vD5dSkwMI+iORaGeImLbx4ysKyyFJXvaxniUytK2w7c2pINFDPVHrdUp rvhRSWROc6hR
KYigiAlHQQH3eCtf3hwdKlQvQiAWnaAB+pLYq8JWlOTEk2x1/WitwGXSIUTn HQoBqI8PUCvH
mXXBco39vjZpvObcuMIcjhMYNiySzSefQcjczuRaw71GOfyBI9g6jwRYJOXJ EwcKLiJgEVAI
CQcYPF4/vRWNWdHA0t4aYeWnQ7FgLbDr/QvOM176V95OGBgJCAJJIMiQCxIi DHmg2O9ulmtU
i3Vt8mfyPeSOKMr83LXLINlpO27ktwVQjJhu34sV0+JWE527hMqxD8XtqFOQ dshzABwJk93O
9EcyMqU43KkQ7aiNoWV3R77wzaZw9UCNUBwztIa9OgjY5stB0t0YCpOvXUrv goJhPel3ZN5L
nP1dci2xf3MvJ+eOhU9FTnIOV8byflPNjhfiuN4hTY29NrZNproNVzpyjpDK NOhTsyhB92qF
UFZWiIDvEQenk5cf9J2/W/yr7Gp+1D5prX4j7aP7MvnitDY73iM+ZCtfHNiY 0u2evLeRuSzI
S/buRE9mw1v24jJxabhNWTeltWRWQF04MJG6CaCqpwAx9kEyGOHZ573Pp0MV i69TFVMPhoYi
pCnEQjKRAqMIwEokkRjplOVugyJXFYLEYqvTpXa1QylTjKR/lMHi7fZ7Vf39 kDfwxpjXIc3k
daYiZy0rNnL5iLlgJOyrhtZ29jGqqqUauLu04KSKsYU+MEoNgJxfUW2q43vJ gaGDwc8XgsdU
qMJG7OnTgbA4PNjMN/rfR13dDIMTmma4fA4rEVadOrVhC9E0iWlO6WehpAL6 Cux6yVlJREoi
URKIlESiJREoiURKIlESiLTl8GAu8RNa+Tlu/wBJ3BWsz0fyaX7U/mgmF+2n +zH55LxvA4rP
m/D03ixGSPFLSySRCvCEFUmqDhJyCS6QGT41urxXFLJ7RdtMxi6hrrUZrgeu 4edC8Y3hpHH4
wdBGsOFqc5yw4/Czw14xvDSPCDaNYLMRrBIXKdxZCuazZg+NMoRpLdySwbgK US1ETxz5kgAJ
g5hFRKmCrYoAACnsgoiGgHLpoYfnfvDlmIwNa5XDE6DqI+qdnBpC+de8eHxW BrbnERuy1dEg
a4nZwaRsWsrxyAW5HbyLgDSTp2zFFJ6MPbdyyqaCzhoi+KkdzGxzhHb4lwmY QA2oahWvwuU4
jExv0qc5gFnjGRD7HA0rQ0corYsGdKnUqAFiYwlIAsCzgEPaFub2b7a4V8u3 RMybKSQik7Yt
+FRdzMVKxQruGszPPFippyzZsoYCEfJ6iBdOGvXvh1gq+GFbf05QBEALwIdr 7s44V7H8L8vx
GG3++pTphqYF6Ji7GoSwIHSC3Rvubr8tvgbvExhq1ch3Riu/F9H1u35juYk4 iTipNEhyoKLF
jXTPljU22JVmqpwKoUdSmTVKmqn6ZeC9aUuwTiOMwHiC38PRc9PXQ2gWpWZr jvyZe3BcEmqJ
jKrOpCRkDnUVVVUOYwgXZTIAgRIiaZSELDoy1ln188hswPXizGQUi30PCpIO 2EXIvkTKs3sw
dVMTsm6wFMUrkg6DpwCFBIIy19OXyI7TFMHbR1xRnCSUhGyTE6yaaqSJxTF6 3SKbZMuTUAHU
NQqp0WMs21boyTOubZtshXTlYvJ5Q7kBUYs01OH+cBr+FVAPhESAQEB0Ewlq klF11ZUIva9o
xttvHar5ywbIszPHRhOstxJAIB1D/wCUYQDUR90aXgjKJXBgc09m2Oy8S7rh Zw7NLV5aTOXf
pQ7x2lxYNlzoEWApSlKBuMSKGwqOyJg/hAVi8ipvbTMrb+6pk2et92uwnmVp 3E7YvmKyjdy2
cIw7lRJZFZExTkOQ5QMUxRAQENQHWt33Zpwq5lhoTAlGVamCCHBBkHBBsIOs LWZ3OVPBV5xJ
BFOZBGkERNoXJOR8I2tAHmDW+7uVjexk3hoKTksgZIFEXo7ZElnJ0p0yokEf thIAiOte4YOE
asYyMKUo2XgKNB22D+Wz7HXzfLvDiqdQiVWoNLG/Pj0rVeS28FJwtt2G2wUh fuVCIpI3DkbI
Ty1p+Uk1EfgkLzm8eKu1y6F+3cAQxCACZEgKAAFrC5Zi4TqVTjTRgSbtOlvK cIg/UiAAeCLu
XkZE6ewxPejAVKUIwoCc2506gjORP7RcnwlmFgDLoT2TODrVjLEls6SVq23F 3fLSkgjByVqQ
zONBOFIKLUrZJZsgios3Oq1MuQ6n8IBgPoAbJS+e/EbM5yxQwUa1WcKcY3hO cpPUtJLEkAgS
ukDQxFtpPoPcvCDq3WpU4QlUJa7ERIjYwcAEhw9ul/AuxtstecuuyXLd1xpo u85GMuYVmTRO
YkHEgdBLjXCUfIzTp4m5SIOoHKZFbgENdDAIaCYBKNYKlbJPvE4YIf0LHZKB hMWXMnOwqL66
bHFfaacdxOz8HjNddeHTZ+FUui0xbMHzhfjdtahln0SpKMjRZ10uLcLsmMw1 dqOFCBoBSlSR
4RHTUwgGgGHZCCUXYJDlAoaj7gVQ6gBc677GKsfZjyLZ9l5IblXiXUHdSUcJ jbBucSv7ccJl
SE3wTK8nQXOBRAdSlMOnBqG1y+nTq0506kRKJZwQ4I52kLBxlSdMxnTJEg7E adS++5nu3MbT
bvr0u2Rc3JcLZyeHi38wus6cIxzdBBVFADrmMYAIdY4/bCIiOoiOhdNHS7t4 DJ5yjgKYpipb
Lw7BwcCz6ea18bAGuXulhY3jLa1CfZJ76Wd9+9zkZPeHg4KPg4ZG2nEGyt9v IE/BTAywuQcK
SD12JzfzFIQEgE0HXg6mmyqU7hBdUQILrb24lCwsFuk2InDNUmhHUQxfOSt0 ypgo4XbJnVVM
BAABOc3CYR4RHhGreMYVpt0j86pok3I+ALZeNBAc63Zp4Btj+kLiq6D/ACI/ tS+aKtx+2l+z
H55KKY4vpdjas3HJpnVALlvEvwCGOHBdkoTTgAexrqI4EVTCZI8yH8IWsxNa dN4xiTp0AnWV
88DPiOt5GeTK35MYLZh1TpcXxY6nmZwNoS6BwiBQrFz6mKcYRBe2XzQWRld4 xvSBBbX4ZLEe
0BwQvvB39u52k7a3AeyWOSn0tcslZUrcUA+i2JMTX81ScqTFrumL5mkd84bt xOVchTmVKiYR
BTYNza2i4vvHdc3hMptc9QWQYLIEjmC9cVZHwRgg672804uX6M3fmmIi2t1O E3BIpTW3piEM
xkLoP/OjLceguq4FZSiLIZfuxk8y1fFi7rknnVXKMdh+15bdwh37jeAMVrkG Ru3JzdJzd7e4
TC3IkvIsGBAPdxQaHapAGosyH0IukN7b/wCqYe6cCselbq4Mm5qxxaZYG9eC AnYNlF2fdl3x
lvcZo3Pb61owcuL1FcwEcuyv2+ih1SpHIo+r6U72dZ0z1u+c6v8AOVwZVStP B0815YaLP0Et
Blab2MujXgRtRjcrO5geIuil1Mos4jQNIuGCqpE3a8WtYjf6iM134xyqm9uD H8Ba1tyd4LXe
blF12/ceR394oXijbKg20TiRnEDR5nZAjDcYUIMTIlIBSKH50sbLW+1vyYYu S4rbyVb265Lt
MY3qpH8pu2z31rPnuPc9mk03Ty2nrVWMkE1XsMzkQRdFMJjt0FTGKomUxFkL ktHect3dEvyc
uqRyA+ui/Mq35ESsw+NkaWd2DYkTki7nttuIK2sbSNvXK9aOQSZtyDHuiri3 ekUVWUjGabZM
i0/hS0d/DKECe8clyOVV5OH9GdhW05bmylZTd7ak1vHX5ZlyPVYGQkeV8r9H 3N66jyTM4k2S
IoPTOiuQK6EiZQtz2lcxc7eCVvLIFp2/b3Sq2sKnjrNyVeEo/l4bK98REYpI uLfuy2Io/wD9
PM7aMi7vs7mOelOK51BIaRUVIuwN9W/7xvFjH26nCZAisAWpkBCAzC+sZnc7 acmbYWx47m2T
221bFOa5HDQtySUS1XUiwKqB0XKaockI4ESLR9mYIvizr0yTvRYHa5KZXS6z BhNhaCMzK5JB
GVx9I2riO2bgfSttXG6FB8qnFqyiTx9JslHbdRFQ6iqa7UDJEWv5W2t5XK1n 4zv3ESl6qYpz
VcF43/cdy2C/uWMczFpXZvOYrVtWRkJK31mz1sqGMzrItxWUTcs41JZHREiC pCEWwLqtrKGP
M3z+Jc7KZgcezitS4LjjLXd2U/y5NXUvIu7NxnNQZlJqyFnd5yMeDyQu0grL uVmaaoFbqmKd
FkmmRaf3IcYe0BtObwLbl7z962Y5t638KxNq2M2sXIj1iFnsLCtNK6m0vIJX VDWEwV5wLOoO
CT0atLolLtNQUVGMTKRdYYCv/KeKOmuUsmwmVblxxbVqTE/hG3HjN5IS8rZk fxLtdlJM9tNy
vda7lNJNknOmB6eOFqXUJEZ4aItXzN2Xxce/7l2HxhJ5Kf7y0BmDGsTbTVk4 ySvjaOx8paON
5O7mzshjGsNFU0U9mlwI7AHYrKEOgHKTNREi0g+xpmLcv3Cd2u3WrnKttYyu nH+LEM3sWs7k
+QlIqcQyhhmE5oi0kXrqTg3a0ZOTzUsdCg2OuXaTBE4t0gSIun7Ax1knOOHZ vdyfHusm4xkf
IDy0GKeS2l9rXm7xQtjAjyaj1Xd1s3U8x5ddTV+zM5njIqFZKmIyXSOeMNRE 3+MT5TvH12+i
NtSsr0r3aoK07W5tjnjnnmcR9LvGRkfxKZuUOy85NdpFLaOHHJ6h8MupFj8+ YZy1gfeRxBvu
7xck7yNexL1i4S63GGcb3adjEWrBYxyy0ilxt6Je3rLnVPL3qoku5BYUtk6B eKTEh1FSKQZ3
sP2qGXsmOsn7qF6u4Dd8nWkVJ21ES1125aT5sivEtTqlcwd0bv12SjJUVxUE 6LqRUUKYR2io
/wACmRa/sO299rDG+FOT8/NXrMbwd3XBi2NSt41uxlw4+mrCYWza8VdL1/e7 OyYgrJWPdqXO
/aMgkIsh3YFVTjf59xLoi1/aWB7qyRhDd+xlfFsZKt5zu3YfjbKyZK2jaiza Zg71gbyxHPsV
Ld6WxK8dciTZxYb5yqMOjIkWQQ2USqquWhFyLIZrtzNmdIcj7Oa2QHm7KvFZ Mxfb2VHeMJ+S
vu5IC6Yuw3Awd3WRasBGyTaKkZJpNIOHDSIinYIRrPiH7YzoF3xFH98DNftK 7rwSFxyUHkDH
e9bZkVdd120yhLOyVeHON5ykg+nYy0CBhucaWu4aQbEIds3lZ1vIMpHjzgq3 SXbybSiLH7+N
p7xdxnlJi2ozMD/2gcBcGfJZm6t9vlRe0o62lMXZVjLBcwJ40prMRkDM3sEg keOEH4uVDEVH
lRnICRTDe4xpvr4fsrMTPdfc5VdvY6VvjGljCSdv65nB7McbssjfDFyzUlHs gou7DIipUW0t
qZ6RbYj03AIlI2AibxuNN9exN1i8sxYRc5VX3mr0uveWtqVaITt/S/J7YQiM sPrKUiIJ09dM
ovV7E2+Ec7jmyCptpFNJQSuTFVIpBl/Gm/1h+ev1nuXucgO76jrrujGmMhum duO5os9sON3F
7fEU5XUvp7IRq+mSFSIllnwmVIbSPFwDUoNgIj/p/wBIlvRR6av1XPOtp9O+ efTV6Q+V8x3/
AM8c08/f/tH5Jzp0O2uav5vpx2z+C5zoi0hbGMN9+LtqOh8Tz+SseYpF3kCW wm1VsXMFx3E+
uWXzbkKTK5myJ3VaiCCqsWvALkPkEFmC4KicwlIEgJyLq/LGDfbOS+U7llcW 5D5FjJ1KyLi3
GXpDsZlyeLUeKHZpcmd7uE4sjsIiUOLUfujF00MuqICoYi2BhhlbsH7XDO7y BtGViekuP8Xc
5XX0RnI+DnZy3pK8Cvf/AKgUjkY167bxs1EpfBcnPsBxZdeTKlSIun6IlESi JREoiURKIlES
iJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiUR KIlESiJREoiU
RKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJ REoiURKIodn1
fk2KZFbXTZUYcIfZkW4VuMgjexcB+1/CVh5gWonxfOF+f+dtxwt9389u/FVy ubNt28xBnlKK
ivgJzLQomX49uXQSJulDgKShhDQxFDmHURUIv6FGFrLmKsgA627jmzbTxvZp LBsZinG2pGK2
0gzZIAOymQL0hDCIiIiYxjGMJjmMImMYRMIiIiNarvPFsL4pf9nNXcsqXp+O P8cVv85SnKJD
/aiGg/sDXikSxXdELh7d1zc63OcqxNnX5DPJK9LBsy
Re: CMS - Xoops [message #7310 is a reply to message #7309] |
Wed, 01 June 2005 05:08 |
Philippe Ombredanne wrote:
> Have you checked Xaraya?
Very impressive multi-lingual home page. Occurs to me I haven't seen any
discussion of internationalization requirements for the Eclipse website,
but I know there are very strong clusters of interest in the US/UK,
Germany and Japan.
Bob Foster
Re: CMS - Xoops (CMS Wish List Revised [message #7311 is a reply to message #7200] |
Wed, 01 June 2005 18:43 |
Originally posted by: andrew.geraghty.javalin.ca
------=_NextPart_000_004E_01C566B8.3E78FFE0
charset="iso-8859-1"
This was sent out on the phoenix-dev mailing list on April 21
Andrew
-----Original Message-----
[mailto:phoenix-dev-bounces@eclipse.org] On Behalf Of andrew geraghty
Sent: Thursday, April 21, 2005 2:19 PM
To: For developers on the new Eclipse.org website project.
Subject: [phoenix-dev] CMS Wish List Revised
Requirement Type
definition
Priority
Additional Details
=20
System Requirements
=20
=20
=20
=20
Application Server
Server or application environment required to run CMS
=20
Tomcat or other Open Application Server
=20
Database
Database the CMS uses to store content
Must run off a relational database
.My SQL (we already use it)
.PostgreSQL (has XML support)
=20
License
Type of license
=20
Open
=20
Operating System
OS this CMS is Compatible with
=20
Linux
=20
Programming Language
Language is written in
=20
PHP, Java
=20
Web Server
Web server this CMS is compatible with
Should
Apache, Tomcat
=20
Security
=20
=20
=20
=20
Audit Trail
Does this system keep track of who made changes/ additions
Must
=20
=20
Content Approval
Does this system have some sort of system wide approval?
Must
=20
=20
Email Verification
Does this system send an activation key to make sure users have =
entered a valid email address?
Must
=20
=20
Granular Privileges
Does this system allow read/ write functions on a per page and per =
content item basis as well as other privileges for other system =
functions?
Must
=20
=20
LDAP Authentication
Does this allow for LADP based Authentication?
Must
=20
=20
Problem Notification
Mechanism for alerting administrators when there is a problem
Nice to Have
=20
=20
Sandbox
Private area for content managers to try new ideas
Nice to have
=20
=20
Session Mgt
Some facility for an administrator to see who has logged in and if =
required log them out
Nice to Have
=20
=20
SSL compatible
Can this system be used with an SSL certificate on the web server?
Should
=20
=20
SSL Logins
Can this System be configured to switch to SSL mode (HTTP) for =
logins?
Should
=20
=20
SSL pages
Can this system be configure to switch to SSL mode for certain =
pages?
Should
=20
=20
Versioning
Does this system provide some kind of system wide content =
versioning?
Should
=20
=20
Support
=20
Nice to Have
=20
=20
=20
=20
=20
=20
=20
Ease of Use
=20
=20
=20
=20
Drag & Drop content
=20
Nice to Have
=20
=20
Friendly URLs
Does this system have human readable and search engine friendly =
URL's?
Nice to Have
=20
=20
Image Resizing
Does this system allow users to edit uploaded images?
Nice to Have
=20
=20
Macro Language
Is there a Macro Language that allows content managers to place =
powerful functionality (like auto generated navigation systems) without =
any programming knowledge?
Nice to Have
=20
=20
Mass Upload
Does the system have a way of uploading/importing many images and =
other files all at once to save time?
Nice to Have
=20
=20
Prototyping
Does the system allow the user to create custom default settings =
for the different kinds of content objects to save them extra clicks =
when creating those object types. For instance, if there is a particular =
template they like to use, can they set it as a default?
Nice to Have
=20
=20
Server Page Language
s there a server page language available like PHP, JSP, or ASP for =
easy one-off functionality?
Nice to Have
PHP or JSP3
=20
Spell Checker
Does the system have an integrated spell checker
Nice to Have
=20
=20
Subscriptions
Can the user subscribe to various sections of the site and receive =
notifications on new/updated content? These types of functions are =
typically found in the news feeds, forums, and blogs.
MUST
=20
=20
Template Language
Is there a templating language for powerful layout controls? (Note =
that templating languages are different from server page languages in =
that they are not capable of full programmatic functions, and are fully =
HTML compliant
Nice to Have
=20
=20
UI levels
s there a means of dumbing down the publishing interface for less =
sophisticated publishers while keeping a more sophisticated interface =
for power users?
Nice to Have
=20
=20
Undo=20
Does the system allow users to operations if they make a mistake?
Nice to Have
=20
=20
WYSIWYG Editor
Is there a web-based rich text editor to allow publishers to create =
formatted content without knowing HTML, CSS, XML, or XSL?
Nice to Have
=20
=20
Performance
=20
=20
=20
=20
Advanced Caching
Does the system have advanced caching mechanisms that go beyond =
simple page caching? For instance, navigation, template, or content =
object caching?
Must
=20
=20
Database Replication
Can the system take advantage of database replication for better =
scalability? The system would need to be able to perform reads from =
slaves and writes to the database master.
N/A
=20
=20
Load Balancing
Does the system allow you to put a load balancer in front of it to =
split the load between multiple servers? This would require that user =
sessions can be passed between all the nodes transparently.
Must
=20
=20
Static Content Export
Does the system have the ability to export it\'s content as static =
HTML so it may be served up from regional cache servers, or from static =
HTML web servers?
Nice to Have
=20
=20
Page Caching
Does the system have a mechanism for caching the contents of a page =
so that if it\'s requested again it can skip most of the work to create =
the page
Nice to Have
=20
=20
Management
=20
=20
=20
=20
Content Staging
Can content be created on one server and easily pushed; to another =
server?
Nice to Have
=20
=20
Inline Administration
Is content edited directly in the page that it will be placed? (The =
alternative is that there is a wholly separate interface for managing =
content.
Must
=20
=20
Online Administration
Can the system be completely managed through a web browser? (The =
alternative is that there is some sort of offline client software that =
must be used to manage at least some components.
Must
=20
=20
Sub-sites / Roots
Does the system allow for sub-sites within a site that are =
self-contained with their own navigation and content hierarchy?
Nice to Have
=20
=20
Web Statistics
Does the system have built in web site statistics reporting for =
things such as pages/content items viewed, number of users per time =
period, etc?
Should
=20
=20
Web-based Style/Template Management
Is there a web-based interface for adding styles and templates to =
the system for design and layout control?
Nice to Have
=20
=20
Workflow Engine
Is there a full-fledged workflow system integrated into the CMS =
that can be used for business process management (or other duties beyond =
just content approval)?
Must
=20
=20
Interoperability
=20
=20
=20
=20
Content Syndication (RSS)
Can the system export RSS/XML feeds so that the content can be =
republished on other sites? Note that if it can only syndicate content =
from one function, such a news then it should be labelled as only =
limited support?
Must
=20
=20
UTF-8 Support
Does the system support UTF-8 character encoding to enable =
multi-lingual sites without the use of separate code pages for each =
language?
Must
=20
=20
WAI Compliant
Does the system follow the W3C specification for WAI compliance?
Nice to Have
=20
=20
WebDAV Support
Does the system allow users to upload internal content and/or files =
via WebDAV?
Should
Emphasis on user management - system that can implement a =
DEV/Stage/UAT model with the ability to maintain a separate promotional =
path for code and content
=20
XHTML Compliant
Does the system follow the W3C specification for XHTML compliance?
N/A
=20
=20
Flexibility
=20
=20
=20
=20
CGI-mode Support
Can the system run in CGI mode for development purposes or on =
low-end systems?
N/A
=20
=20
Content Reuse
Does the system allow content to be mirrored (not copied, but =
reused) from one location to another on a site?
=20
=20
=20
Extensible User Profiles
Does the system provide a user profiling that can be extended with =
new profile properties through an administrative interface?
Must
LDAP
=20
Metadata
Does the system support the adding of arbitrary metadata properties =
to all the content objects? The metadata is typically then used for =
profiling, indexing, or even auxiliary display functions.
Must
=20
=20
Multi-lingual Content
Does the system support the creation of sites with multiple =
languages?
Must
=20
=20
Multi-lingual Content Integration
Does the system support a multi-lingual version of each content =
object without republishing the content object. For example, if you =
create an FAQ in English, then all that needs to be done to display the =
FAQ in Spanish or another language is to translate the content, not =
create another page with another FAQ content object. Then depending upon =
user preferences it either shows one version or the other.
Must
=20
=20
Multi-Site Deployment
Is the system capable of hosting multiple sites from one software =
deployment? This means you can install the software once and host as =
many sites as you want. It also means that when it comes time to upgrade =
you only need to upgrade the software in one place, not for each =
separate site.
Nice to Have
=20
=20
Wiki Aware
Does the system support wiki or wiki-like functionality? Wiki =
provides online collaboration functionality as well as a simple text =
formatting language.
Nice to Have
=20
=20
Built-in Applications
=20
=20
=20
=20
Blog
Does the system have a blog or web log? (See slashdot.org for an =
example.
Nice to Have
=20
=20
Discussion / Forum
Does the system have a message board?
Should
=20
=20
Document Management
Does the system have an application for managing offline document =
storage and versioning?=20
N/A
=20
=20
FAQ Management
Does the system have an application to organize frequently asked =
questions?
Nice to Have
=20
=20
My Page / Dashboard
Does the CMS have a dashboard application (sometimes called a =
portal)
Nice to Have
=20
=20
Newsletter
oes the system have the ability to allow users to add/delete =
themselves to/from a list so that they can be sent email from the system =
on various topics?
Nice to Have
=20
=20
Polls
Does the system have an application for conducting simple single =
question polls?
Nice to Have
=20
=20
Search Engine
Does the system have an integrated search engine that can index the =
managed content and allow the user to search the indexed content?
Should
Google Search is preferred
=20
Site Map
Can the system generate a tree showing all of the pages in the =
system dynamically so it doesn't\'t have to be maintained separately by =
the content managers?
Must
=20
=20
Surveys
Does the CMS have an application for conducting complex =
multi-question surveys?
Nice to Have
=20
=20
Syndicated Content (RSS)
Does the CMS have an application for retrieving and displaying =
RDF/RSS/XML syndicated content?
Must
=20
=20
=20
"Andrew Geraghty" <andrew.geraghty@javalin.ca> wrote in message =
news:d7f9ev$hel$1@news.eclipse.org...
Right now Xoops is our leading choice for a CMS. Has anyone out there =
had either negative or positive experience with Xoops?
Andrew
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2627" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>
<DIV><FONT face=3DArial color=3D#000080 size=3D2>This was sent out on =
the phoenix-dev=20
mailing list on April 21</FONT></DIV>
<DIV><FONT color=3D#000080></FONT> </DIV>
<DIV><FONT color=3D#000080>Andrew</FONT></DIV>
<DIV><FONT face=3DArial color=3D#000080 size=3D2></FONT> </DIV>
<DIV><FONT face=3DTahoma size=3D2>-----Original =
Message-----<BR><B>From:</B>=20
phoenix-dev-bounces@eclipse.org [mailto:phoenix-dev-bounces@eclipse.org] =
<B>On=20
Behalf Of </B>andrew geraghty<BR><B>Sent:</B> Thursday, April 21, 2005 =
2:19=20
PM<BR><B>To:</B> For developers on the new Eclipse.org website=20
project.<BR><B>Subject:</B> [phoenix-dev] CMS Wish List =
Revised</FONT></DIV>
<DIV align=3Dcenter>
<TABLE class=3DMsoTableGrid=20
style=3D"BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: =
auto auto auto -0.3in; BORDER-LEFT: medium none; WIDTH: 441pt; =
BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: =
solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0in 5.4pt =
0in 5.4pt; mso-border-insideh: .5pt solid windowtext; =
mso-border-insidev: .5pt solid windowtext"=20
cellSpacing=3D0 cellPadding=3D0 width=3D588 border=3D1>
<TBODY>
<TR style=3D"mso-yfti-irow: 0">
<TD=20
style=3D"BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; =
BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BACKGROUND: =
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: =
99pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; =
mso-border-alt: solid windowtext .5pt"=20
vAlign=3Dtop width=3D132>
<P class=3DMsoNormal style=3D"MARGIN: 0in 12.6pt 0pt 0in"><B><SPAN =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Requirement=20
Type<?xml:namespace prefix =3D o ns =3D=20
"urn:schemas-microsoft-com:office:office" =
/><o:p></o:p></SPAN></B></P></TD>
<TD=20
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 135pt; =
PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; mso-border-alt: =
solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt"=20
vAlign=3Dtop width=3D180>
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><B><SPAN =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: =
Helvetica">definition<o:p></o:p></SPAN></B></P></TD>
<TD=20
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 92.45pt; =
vAlign=3Dtop width=3D123>
lang=3DEN-GB=20
Helvetica">Priority<o:p></o:p></SPAN></B></P></TD>
<TD=20
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 114.55pt; =
vAlign=3Dtop width=3D153>
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Additional=20
Details<o:p></o:p></SPAN></B></P></TD></TR>
<TR style=3D"mso-yfti-irow: 1">
<TD=20
BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; BACKGROUND: #f3f3f3; =
PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: 99pt; =
solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10.5pt; FONT-FAMILY: Helvetica">System=20
Requirements</SPAN></B><SPAN lang=3DEN-GB=20
style=3D"FONT-FAMILY: Helvetica"><o:p></o:p></SPAN></P></TD>
<TD=20
PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 135pt; PADDING-TOP: =
0in; BORDER-BOTTOM: windowtext 1pt solid; mso-border-alt: solid =
windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; =
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><SPAN =
lang=3DEN-GB=20
style=3D"FONT-FAMILY: Helvetica"><o:p> </o:p></SPAN></P></TD>
<TD=20
PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 92.45pt; PADDING-TOP: =
lang=3DEN-GB=20
<TD=20
PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 114.55pt; PADDING-TOP: =
lang=3DEN-GB=20
style=3D"FONT-FAMILY: =
Helvetica"><o:p> </o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 2">
<TD=20
BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; =
BORDER-LEFT: windowtext 1pt solid; WIDTH: 99pt; PADDING-TOP: 0in; =
BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; =
mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid =
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Application=20
Server<o:p></o:p></SPAN></P></TD>
<TD=20
BORDER-LEFT: #ece9d8; WIDTH: 135pt; PADDING-TOP: 0in; BORDER-BOTTOM: =
windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: =
solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Server or =
application=20
environment required to run CMS<o:p></o:p></SPAN></P></TD>
<TD=20
BORDER-LEFT: #ece9d8; WIDTH: 92.45pt; PADDING-TOP: 0in; BORDER-BOTTOM: =
lang=3DEN-GB=20
<TD=20
BORDER-LEFT: #ece9d8; WIDTH: 114.55pt; PADDING-TOP: 0in; BORDER-BOTTOM: =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Tomcat or other =
Open=20
Application Server<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 3">
<TD=20
BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; BACKGROUND: #ffff99; =
lang=3DEN-GB=20
Helvetica">Database<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Database the CMS =
uses to=20
store content<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Must<SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>run off a relational=20
database<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">=95My SQL (we =
already use=20
it)<o:p></o:p></SPAN></P>
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">=95PostgreSQL =
(has XML=20
support)<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 4">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 8.5pt; FONT-FAMILY: =
Helvetica">License</SPAN><SPAN=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Type of=20
license<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
Helvetica">Open<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 5">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Operating=20
System<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">OS this CMS is =
Compatible=20
with<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
Helvetica">Linux<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 6">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Programming=20
Language<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Language is =
written=20
in<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">PHP,=20
Java<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 7">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Web=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Web server this =
CMS is=20
compatible with<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
Helvetica">Should<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Apache,=20
Tomcat<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 8">
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10.5pt; FONT-FAMILY: =
Helvetica">Security</SPAN></B><SPAN=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 9">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 8.5pt; FONT-FAMILY: Helvetica">Audit =
Trail</SPAN><SPAN=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Does this system =
keep=20
track of who made changes/ additions<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
Helvetica">Must<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 10">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Content=20
Approval<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
have some=20
sort of system wide approval?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 11">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Email=20
Verification<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
send an=20
activation key to make sure users have entered a valid email=20
address?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 12">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Granular=20
Privileges<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
allow=20
read/ write functions on a per page and per content item basis as =
well as=20
functions?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 13">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">LDAP=20
Authentication<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Does this allow =
for LADP=20
based Authentication?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 14">
<TD=20
Re: CMS - Drupal [message #7987 is a reply to message #7311] |
Mon, 06 June 2005 07:27 |
Originally posted by: ckng.nrg.cs.usm.my
From your requirements, I would recommend Drupal (www.drupal.org)
Drupal currently powers SpreadFirefox, JavaLobby, KernelTrap,
LinuxJournal...
CK Ng
Re: CMS - Drupal [message #8015 is a reply to message #7987] |
Tue, 07 June 2005 18:42 |
> LinuxJournal...
> CK Ng
JavaLobby considered Drupal for future sites, but they did not choose
it. Instead they are focusing on Java Portlet technology from JSR-168,
http://tinyurl.com/8n3r7 It be nice to see the two groups work together,
since they both need the functionality. I'm not sure that Eclipse.org
was to create new system from scratch.
Re: CMS - Drupal [message #8376 is a reply to message #8344] |
Sat, 18 June 2005 00:08 |
Eclipse Webmaster Messages: 607343 Registered: July 2009 |
Stavros,
If you look at Andrew Geraghty's CMS Wish List, you'll see that we
weren't looking for a PHP-based CMS specifically. We wanted to choose a
CMS based on our requirements, not on language.
Our short list included Xoops (php), Plone/Zope (Python, I believe) and
Apache Lenya (Java).
We opted out of Lenya because the codebase didn't seem mature enough.
version 1.4 was in heavy development, and version 1.2 was not as
polished as we would have liked.
As for Zope, we felt the uncommon storage engine and uncommon web server
hindered its scalability (we need redundant databases and scalable
webservers) - and these were not as easy to configure as with Xoops.
As it turns out, we hired a CMS consultant who looked at our
requirements and suggested we use PHPNuke instead of Xoops, and based on
that, we have opted to use PHPNuke instead.
By the way, Eclipse is about much more than just Java :)
Thanks for your comments,
Denis
Stavros Kounis wrote:
> hi all
> http://www.spreadcocoon.com/ is based in drupal too.
> This site is not official but is many around Cocoon has accepted as a 3rd
> party work.
> Here i want to make a question.
> We you are net looking for a JAVA based solution?
> People at Cocoon like spreadcocoon.com but they would like to see a Cocoon
> based solution. In Eclipse's case (where almost everything is about JAVA)
> choose something in PHP and not in JAVA?
> regards
> --stavros
> "CK Ng" <ckng@nrg.cs.usm.my> wrote in message
> news:d80ttv$nqf$1@news.eclipse.org...
>>LinuxJournal...
>>Regards,
>>CK Ng
Re: CMS - Drupal [message #8407 is a reply to message #8376] |
Fri, 17 June 2005 20:25 |
Stavros Kounis Messages: 51 Registered: July 2009 |
Member |
Hi Denis
I dont want to start a "war" with your consultant. Im sure that he knows the
factors to choose the right tool much better than me. I want just
to share my experiences as someone that has moved from PHPNuke to PostNuke
and has setup a sufficient number of *Nukes.
PHPNuke was the reference point for OpenSource CMS.
The REAL community-based OpenSource PHPNuke was PostNuke,
There is a big diffirence between Post and PHP nuke.
PostNuke is supported from a real-open-source-community, PHPnuke is
developed by 1 person.
Personaly i think that PostNuke provides a better API.
Now, Drupal can be sayd that is the Post/PHP Nuke's next generation. The big
difference here is that Drupal's code is Object-Oriented.
Recently is have see a graph that brings Drupal at first place based on
popularity [1] (compared to PHPNuke, PostNuke etc).
.... just my 2 cents to help you make the right choice.
regards
--stavros
[1] http://drupal.org/node/18834
"Eclipse WebMaster (Denis Roy)" <webmaster@eclipse.org> wrote in message
news:d8volk$4mf$1@news.eclipse.org...
> Stavros,
> If you look at Andrew Geraghty's CMS Wish List, you'll see that we weren't
> looking for a PHP-based CMS specifically. We wanted to choose a CMS based
> version 1.4 was in heavy development, and version 1.2 was not as polished
> As it turns out, we hired a CMS consultant who looked at our requirements
> and suggested we use PHPNuke instead of Xoops, and based on that, we have
> Denis
>> hi all
>> party work.
>> Cocoon based solution. In Eclipse's case (where almost everything is
>> about JAVA) choose something in PHP and not in JAVA?
>> regards
>> --stavros
>>>LinuxJournal...
>>>Regards,
>>>CK Ng
Re: CMS - Xoops [message #563746 is a reply to message #7200] |
Mon, 30 May 2005 18:46 |
Originally posted by: bob.objfac.com
Andrew Geraghty wrote:
> Right now Xoops <http://www.xoops.org> is our leading choice for a CMS.
> Has anyone out there had either negative or positive experience with
> Xoops <http://www.xoops.org>?
I had a bad experience just now trying to read the Visual Introduction,
one sentence per page. :(
Bob
Re: CMS - Xoops [message #563767 is a reply to message #7200] |
Tue, 31 May 2005 05:49 |
Is there a document available, which compares the variouse candidates
and gives an explanation why Xoops is the favorite today? Just curious.
BTW, isn't there one with an Eclipse BackOffice plug-in ;)
Cu, Gunnar
Re: CMS - Xoops [message #563794 is a reply to message #7200] |
Tue, 31 May 2005 11:16 |
Roger Dudler Messages: 21 Registered: July 2009 |
Junior Member |
--------------000904080701040802060203
We, at iframe AG in Switzerland, have developed a completely new web
application framework (with cms) called S-Node XT, which would be
released in about 1 week. It is completely modular and extensible, is
plugin-based, has actions, extensionpoints and extensions. It has a
really impressive usability. Plugin programming is flexible, easy and
fast. The system is based on user, groups and roles. Each plugin can
define his own permissions based on the defined actions (per user, group
or role and per each language). The system makes use of the nested set
algorithm to build trees in most of the plugins. This makes the system
high performant (backend and frontend)
It has a full indexing an search implementation, it's blazingly fast and
is easy to implement into new plugins. You have the ability to create
a completely new system based on our framework. With your own plugins
and design if you want. It uses Smarty as Template Engine and MySQL as
database server.
Btw, It's not the one shown on www.iframe.ch - this was the version from
last year. The new one is completely redeveloped from the ground.
I'm telling you all that, only that you take a look at it, cause I think
it would be the best solution for such a project.
If you need more information, please tell me.
I attached a screenshot from the site structure management interface.
(The interface is shown in german, but is also available in other languages)
> Andrew
Content-Type: image/jpeg;
name="s_node_xt.jpg"
Content-Disposition: inline;
filename="s_node_xt.jpg"
/9j/4AAQSkZJRgABAgAAZABkAAD/7AARRHVja3kAAQAEAAAAVQAA/+4ADkFk b2JlAGTAAAAA
Af/bAIQAAgEBAQEBAgEBAgMCAQIDAwICAgIDAwMDAwMDAwQDBAQEBAMEBAUG BgYFBAcHCAgH
BwoKCgoKDAwMDAwMDAwMDAECAgIEAwQHBAQHCggHCAoMDAwMDAwMDAwMDAwM DAwMDAwMDAwM
DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgEAAUAAwERAAIRAQMR Af/EAQsAAQAB
BQEBAQEAAAAAAAAAAAAGAQQFBwgCAwkKAQEAAQUBAQEAAAAAAAAAAAAAAQID BAUGBwgJEAAA
BQMBAgUNCAoMBg4HAREBAgMEBQAGBxESCCETFBUWMVFS05TUVZVWlhcYCUGh ItJU1dZXYTJi
kiOTpJdYGXGBkbEzU+MktUZ2OMHRQrS31/CiwkM0dCU1NrY3dzkKcoKyc7N1 JkdExIWDo4TF
Zico4WOGSMZnpxEAAQMBBAQICQgJAAYJBAEFAQARAgMhEgQFMUFRE2GR0SJS FBUGcYGhMpLS
UxYH8LHhYjOTVBfBQnKisiNz0zTxgkPDdAjCY7MkZMTUVRjig0QlNaPy45S0 /9oADAMBAAIR
AxEAPwDlnB1o57yDitPK1nwjiXbFctGBWrRMTuNHJjoEcFBYpEuIBQhiHVE4 AUwDr9qIh9qd
/P8AmR7udzcw7MzerONXcb3mxvR0sKdhcVCOcBKIiYsbzyiD4Pk3wAzjvJh+ t5bGBpmqabSm
IGwAmfOYSgHEeaZSdwIliRtzC9t7w9+SRI9GRg4tN64kIqBfP5IE2kvIxyih DsUF1WRSEXV4
o3EgtsEOIAG2AmLrzmc/8x2WYPLqGbTwNaph6ghOd0gzpU5B784uHuOL4jIt aXIBK0tH4O4q
eYVsshioRrU5SgHBEZziWuxOlpfqkgPZY5ZYC5M65UtWYd21PLKs7gjnCzB8 zXSSKqg5bKmR
VSUKJNSnIcolEPcEK+gsmq5dm2EpY/B3alGtCM4SDtKMgDE2sbQXY2jWvK8b l+MwVeeGxBMa
lORjIWWEFiLLD4RYdSwzneayJt6C+MGnWInw/s6ErbjLMMP1B5eVRGnV6Z8i +frM5D+Xn+8J
8Wp7Ow3QHl5VVu6vSPk5E9ZnIfy8/wB4T4tOzsN0B5eVN3V6R8nInrM5D+Xn +8J8WnZ2G6A8
vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCfFp2dhugP Lypu6vSPk5E9
ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORP WZyH8vP94T4t
OzsN0B5eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/AHhP i07Ow3QHl5U3
dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORPWZyH8vP94T4tOzsN0B5eVN 3V6R8nInrM5D
+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ekfJyJ6zOQ /l5/vCfFp2dh
ugPLypu6vSPk5E9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnY boDy8qbur0j5
ORPWZyH8vP8AeE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCfFp2dhugPLypu6vS Pk5E9ZnIfy8/
3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORPWZyH8vP 94T4tOzsN0B5
eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAe XlTd1ekfJyJ6
zOQ/l5/vCfFp2dhugPLypu6vSPk5E9ZnIfy8/wB4T4tOzsN0B5eVN3V6R8nI nrM5D+Xn+8J8
WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCf Fp2dhugPLypu
6vSPk5E9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qb ur0j5ORPWZyH
8vP94T4tOzsN0B5eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch /Lz/AHhPi07O
w3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5ORPWZyH8vP94T4tOz sN0B5eVN3V6R
8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+LTs7DdAeXlTd1ek fJyJ6zOQ/l5/
vCfFp2dhugPLypu6vSPk5E9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef 7wnxadnYboDy
8qbur0j5ORPWZyH8vP8AeE+LTs7DdAeXlTd1ekfJyJ6zOQ/l5/vCfFp2dhug PLypu6vSPk5E
9ZnIfy8/3hPi07Ow3QHl5U3dXpHycieszkP5ef7wnxadnYboDy8qbur0j5OR PWZyH8vP94T4
tOzsN0B5eVN3V6R8nInrM5D+Xn+8J8WnZ2G6A8vKm7q9I+TkT1mch/Lz/eE+ LTs7DdAeXlTd
1ekfJyJ6zOQ/l5/vCfFp2dhugPLypu6vSPk5E9ZnIfy8/wB4T4tOzsN0B5eV N3V6R8nIqDvN
ZE9x+b70nxKjs7DdAeXlU7qr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zW RflxvvSfEp2d
hugPLypuqvTPkT1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6 A8vKm6q9M+RP
WayL8uN96T4lOzsN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9Zr Ivy433pPiU7O
w3QHl5U3VXpnyJ6zWRflxvvSfEp2dhugPLypuqvTPkT1msi/Ljfek+JTs7Dd AeXlTdVemfIn
rNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWayL8uN96T4lOzsN0B5eVN1V6Z8ies1 kX5cb70nxKdn
YboDy8qbqr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dhu gPLypuqvTPkT
1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWa yL8uN96T4lOz
sN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9ZrIvy433pPiU7Ow3 QHl5U3VXpnyJ
6zWRflxvvSfEp2dhugPLypuqvTPkT1msi/Ljfek+JTs7DdAeXlTdVemfInrN ZF+XG+9J8SnZ
2G6A8vKm6q9M+RPWayL8uN96T4lOzsN0B5eVN1V6Z8ies1kX5cb70nxKdnYb oDy8qbqr0z5E
9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dhugPLypuqvTPkT1m si/Ljfek+JTs
7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWayL8uN96T4lOzsN 0B5eVN1V6Z8i
es1kX5cb70nxKdnYboDy8qbqr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6z WRflxvvSfEp2
dhugPLypuqvTPkT1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G 6A8vKm6q9M+R
PWayL8uN96T4lOzsN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9Z rIvy433pPiU7
Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dhugPLypuqvTPkT1msi/Ljfek+JTs7D dAeXlTdVemfI
nrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPWayL8uN96T4lOzsN0B5eVN1V6Z8ies 1kX5cb70nxKd
nYboDy8qbqr0z5E9ZrIvy433pPiU7Ow3QHl5U3VXpnyJ6zWRflxvvSfEp2dh ugPLypuqvTPk
T1msi/Ljfek+JTs7DdAeXlTdVemfInrNZF+XG+9J8SnZ2G6A8vKm6q9M+RPW ayL8uN96T4lO
zsN0B5eVN1V6Z8ies1kX5cb70nxKdnYboDy8qbqr0z5E9ZrIvy433pPiU7Ow 3QHl5U3VXpny
IO81kXT/AIeb70nxKdnYboDy8qbqr0z5F49ZzIvhA/3qXxKdn4b2Y8vKqtzV 6RT1nMi+ED/e
pfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP8AepfE p2fhvZjy8qbm
r0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP96l8SnZ+G9mPLypuavSKe s5kXwgf71L4l
Oz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8vKm5q9Ip6zmRfCB/vUviU7Pw3 sx5eVNzV6RT1
nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4 QP8AepfEp2fh
vZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP96l8SnZ+G9mPL ypuavSKes5kX
wgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8vKm5q9Ip6zmRfCB/v UviU7Pw3sx5e
VNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NX pFPWcyL4QP8A
epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL4QP96l8S nZ+G9mPLypua
vSKes5kXwgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8vKm5q9Ip6 zmRfCB/vUviU
7Pw3sx5eVNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/De zHl5U3NXpFPW
cyL4QP8AepfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3NXpFPWcyL 4QP96l8SnZ+G
9mPLypuavSKes5kXwgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxKdn4b2Y8v Km5q9Ip6zmRf
CB/vUviU7Pw3sx5eVNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inrOZF8IH+9 S+JTs/DezHl5
U3NXpFPWcyL4QP8AepfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/DezHl5U3N XpFPWcyL4QP9
6l8SnZ+G9mPLypuavSKes5kXwgf71L4lOz8N7MeXlTc1ekU9ZzIvhA/3qXxK dn4b2Y8vKm5q
9Ip6zmRfCB/vUviU7Pw3sx5eVNzV6RT1nMi+ED/epfEp2fhvZjy8qbmr0inr OZF8IH+9S+JT
s/DezHl5U3NXpFPWcyL4QP8AepfEp2fhvZjy8qbmr0inrOZF8IH+9S+JTs/D ezHl5U3NXpFP
WcyL4QP96l8SnZ+G9mPLypuavSK643G2tu37hFXMOTCoz03ITM1b0fHTKkgh HtUoOPhnqiuk
K8jnCiqxpopQ1WApATH4JhMAl8n77ZhWo43qmEelGNOEyYiJkTUlUiB/MjOI Ed2dEXJlpDW+
id08hw9XDGvihfJlKIBMgAIiJfmmJJN7awbQXskNy5MxtAKnIexbR2S68J3F /e5+xdtYeGwO
Mqj/ACa/Fh//AE63FTLcDH/YU/Sq/wB1Ri38uWdlDKlrYSbWVARTe9JmLtAl wW27u4sjGOJh
8lHoPEiy8/JtDlSVWKc6aiA7ZAEoCQwgcuTmmHxOV4OpmHWKszRiZmE40bsh EOYm5ShIONBE
gxYkEWHHoZVg8XVjhhRjC+bt6MqjxJsBF6coltYItGzSpNuywlluN3C2sm3w 0Z3Lel0x7u4T
FuJWYRbs0ELhlbfSbtk4GSizCIjEmVOdQxtdsCgUuyImw+8mZYmeY1cPh5Sp U6UxDmCBJJp0
6hMjUhU9oAAANDkl7Lfd/u/hepQrV47ycwZc4yAAEpRAAhKPRckvp1NbLY+y b/ueGSuWwsEM
py3HHGA1kYqMyi9arCkoZE+ws1uY5DbJyCUdB4BAQrV1M0o0JmliMylTmNIl LCRIcPaDQBtF
vgW3j3cpTjep4MSB1jfkeSotNXjkNC7LiuHELiyY2zL0jIe7ZtKTgVbpRfsJ C0LekbiWZvWl
xS8okJFQjDoHJxaahDmA218ESG6YGpgY4fFxxEq9OpUpQMZiiYyjVnGAlGVK nTLi8JAuYkOG
tBGkr5Nhq8atKNIUpxhKQINRwYRMmInOQtZjYCDa+pbtwnhOxRxLahTW+hfG T5yFt64XB5Y9
xi5VXuCBZ3ADdq1t2VjSAmim9BMNSHOYSiYTAAgUvyf8Tvjvn+Dz3FYDLDTp U6FWVMR3YmTd
svPIEudLCwL6X+G/wD7vY3JMNj813spVoXzLe7uMQ5DaxY2mxR1c+Jn0qjb8 LjW2n8+9WTaM
2TZxkBZdyuscE00kk0rqE5znMIFKUAEREdK8y/8Akx3wvCMMRTJNgG5hadgD L13/AOKXc4QN
SrTrxjEEkmuwAFpJJFgAtJK5l38LVx3ce7nlWRgrQaWNe1iQqVxKuLed3GYr 9Fxc0Pabtg/b
XBJyhgMU0yVUp0zJiXizFMBtoBJ7N8DP+YjvD3gziWU5vOE6c6c2IhGBgYRJ PmgO7MQfEvNf
i5/y7d3u62Bw+a5RfEt7EETnfEntBBsZms2uo37NjL8eOHH+BknxIC9VkBUg pQ3FKGVFdMwg
YqSgAUxkVDbQFERAdep1a8A/54O5lfK+98c3qU7+HxEKZIDgfy4xgYkjReEd IZl6Z/y+5rDN
Mglg6cmq4adQGwExE5GYkAdLGRd7LOKRbslvb0c7vT2xaQRczLY9gJtO7b9u nIsMziIMAauh
I/cJOFVHbVQhUzkM2BARMU+ggUoE4wNXm/xNywdy62XCdGnUrQMKNLDylKQj IWRquIkHpv5z
kSBMmXmeK+GeN97I5jHfVBAg1J1oiIlUGuiIkuDoj0WDSADqTY43ocH2x7Ti O3rL3iFLgwQw
mFXBUlGiS6jhFGOUjGUmmg5EAESrFTeJ7Whw0AdAPwB90/Bz4eZth/hXhMlM t1jJUZSZyGFS
tKtcJFoeErktVpFoXzd37714Cp32r5g1+jGcRoBthSjTMgNYExeGtgDpWV9p NhXK943bi2+l
syxmV8Q3xETa+O72u89sWq+TYQzgrh+1m5V+SMTE7UXBSALlcpSqCdMiSRhE g9t8M81weX0c
ZQq4Wpha+GMN/TjfqxJIYVKcIiRAkzm5Frt2RMoi8Nf3ywWIx1ShVpVIV6dY y3c7IFvZykSA
W0C8XMnDA2LZTrHWEMv+z03Z90q9XENH5huxHKZcf5KSkGz+LbTtuX4i2CJU eRZ1m6zKS5xU
TBwmschFCJnKCgGrlKPeHFYbvPmOZ4K9VwsI0JVaYDE05UYvMRkxE6dhMSAW vRN1lvamR0qm
SYbCYsCnXMpxhI6BO/IiJI/VmzAhxaCHU332Nzbd7y7v9ZIyxvGSlzKJXvl6 wN320Y2zVoxt
zfISeK7fmjyD5SUQd7bcCmEOLSIU20A8I7XweW7hd/8AMctymlgMBCkTToV8 RI1LxBjCc+ZE
RMWPNkXLgkiwWk7/AL090cJjcUcXiZSAlKnTAgwN6RAEpOC/nRGogDSbAtP7 pO5xhnBuTYLL
+TZCWui7oPeNh93e0GNvqsYpgMtCyZnruVlDPG8ioo24pmcSt0QKYTF2BUAD 8Yn3vfH4g4rM
sL1PA04QhXy6piJmbyIiYyBhBjECQY84uDZzbGPJ93+51HCVpV8VORNHEwpx EWAJeJEpO9hv
RsDMHtKleS9wTdIuu9bpzDvQZLCyrjytkfOCcFcU1c9lW9A28S1b2lYtqR2x uN0jIyYrOCEA
QYCAJlMUFBT+CY/KZF8WMywOFoYPC0I1YYajQvC7VlOpfiCRGUAYU7sDZfBe 6WfzV0ebfD7C
4yvUxE5yjKrOTNdEYsNMgbZPIEm6QbRwlcw+y9yllLH+99YsxhaPPPq3Wujb crb5UhVJLwMu
ZMr5uoGpQKUEA43bMOymJAOb4JRr3f4jZVg8yyKtUxMxCEIbyE3a7OIeEhwk lmFpdhaQvJu6
2LxOBzSFKlG9IyuSjpcEtIfpc2BnNgW+vaxyGRt0K+sc7tm6fIytlbq9oxr6 47NuG2pV6g8m
p6ZWetJZ9zuwcgqJmyKwtCEA5TpgdTa1Konp5j8JMtp96Ri8zza7Wr1LtKcJ ANGERExeDWOQ
JAs14OOdF13HfrHyyKOHweABhCJM4yG1yCAfGQR0SAbCyh/tYcvZyuB5g/HM rfdzuLAlsF4w
uKeg1bimzR8vLLvZlZV/JNeV8U7cKKM0THVcFOcwkKIiIhWZ8I+62B69mVWN GAnh8bVjTIDG
EXIugi1msbQxI1lW+/mfYoYDBxvuK9EGYIBEi0S9osLl3DMbdQXMqzLEBMOp JJJTh94Q84bj
VdY8LbTtsI4RDUB/novhe6BwfguK+6r2yVLHjHACNM4U07TbvBUf0bl3/Wvc C8whPCHCkkyF
cSsFl0xbjEgfE3Cuz/ZRZUst5iSQ3SLHyA4w3veXNdrSdta/EYpi/ZTqJI4G Le25MXSZxMgZ
YyqiaZxKUypygG1qZJTxb4vd3cSMXTzeth+t4GjSMalITMZQtJNWLaCBdci2 7Euw5w9D7gZx
R3E8DCoKGJqTBhMxBBsAED5WBseVjmw/K3vZm7tMBjyGn99DJjOzMr31NZGh guM9w2BatqW/
IWXKuIVQh4uVPHupAi0ikJQJGJpkRIYpTgkGyY+px/xfxdDEbnK6O+oUadCT SjVnVqCpGM/P
i8YSETaal5zGReRsW2wfw7p4mkauKkadWc6g5t0QgYkjzTaYkiy6QwIDAWqf 7jWLcI5PndxG
LyC0lLwxVe8FmF3G2ddK9vPIGLkYZVqq4dcQlb6Dh0g7VFVYqLlcxkTCnsqG BM4K6Pvpn+Lw
9TPJ4SUaVSAwst5DeRlKEjG6PtCIzjGcY34gCQE3g8wYbHIcmozo5fHERMxf rRuSukCQE3/V
BMSYE3S5BMec0Wlpvd23Ety7IO6zjnPee78Vxt6ZumL20pO5rzsaOi7YZwC5 mjBKTTnCxL2Z
XWWFMFTxyCJCbXwypAJDH6POfixmuCxksLSoQq7iFEzAhVMqhqRjKVwxeNLm lwJ3tBaUtC12
D+HeDxNI1RUnG/OoI2xAhdJiLwNs7QzxIJcOBa2Y3Q/Z47oWfce7ukfeMldy WX94aPyDIxUh
DvIYkJFDY7lTQyzdzHKuTlXROkGyVXXa2h1ABAAyO9XxRzTL8Xj+qwoSoYMU JG8J35RrCGgi
YiCDPos3CLcLJu4uExGHoHESqRq1pVIWGN0SgZ6jF2aG3T4bIneW5nurRW4t Zu97jA10380d
srWkr7kLfm7YSi4R7Jqpc5Q71sq0UkGCwFWTI2XMm4KY5wEyegBtbnKO/eaY 3O6mV1Y0aEZX
9zfhUvzhdJp1Im8ITjY84gwLWRLvd1+Zd1MFhMvGLjKdSUWFS7KN2MgQJQNh lE2tGTSG0aH2
hvLbpm6JePtMN5yzpiBlbQwXhPHJ8iqxdguodqZ4/hrYgJZYjJqtElQboqNp AAFM51DnXA6g
qlKcEy8T3d7/AGcYLuxhMZehWq1sXuRKrfkbsjM84iQJIIDSdhE3bvNBPTZp 3Qy/FZzPDASp
xFDeEQugOCIhrDpDuGFody5A1BiLctwFlnEtg5YZr3CzYX5vBR+CGzRd7Giq 1tKRiDy6blQS
R4lGRAhQKY4DxICPAmOnD32f9+syyrHTwNWnSMoZdPEEgSbewv2DnfZm75vn W+euUyrutg8f
hetU5zEesxph28yRgNnnC/p0FvNts6uyH7OuyMs7reOo13IyiuC8DOt4xm4t S3VmS983UELk
ZSNjiRxF2xGhleLijCuoKehROUhSDt7RPFcr+KGKw2bYnFQhAVsZHCB5OKMJ GlF5StBa03Re
DOSZWF/Scd3Hw9TAUsNKUrlCVQuAL5iZSLCw26HIBdrI2htA3jgvdryThXcX sS2LNeWxLZdu
G6Im7J1CXjHUoZg3vCLg3QOHRLfai8WKd6UWZzgmRumByGTWEwGD0zCd484w WbZ3v6kKnVsP
GoINIQjIUb8boMyw1VACDM84GLCK4uvkuXYnLsBKlGUd7WuXubekDMxN4sNQ eNhu+axclYtt
7PbBTnkP8/ng5ZvRPd1j/hseOxbDPln8+/5u4X5uSfb/AMEGv8GOnDch8VMd K5/Kpc7LJYrR
L7WN+zzvszc83zrfPUVO4WGjf/mT5mKhS1Wwnc4POF/ToLebbZoje+x9g7G+ 8TdWKd31OeCz
7OlJiz5F1eTiPcu3UtBzshEuVkObGzZMrYxWyYk2i7YjtCOgaAHpfw/zPH5v llPHY6NIGqBK
O7vAXSBYRIku76CzNsc8X3uy/C5bjJYXDGZuWG82nTYQBYxGrSOGyF3Zjl9Z jaJWlJWDdO5l
tzi2j4S4oCYkG6HFoK/8oMYl86dMT7LknwHaaZ9dQ01KYA32BzbD4yvVw1K9 vKRaQlCcNtsT
OMRMWedAyDEF2kH1WKy3EYehTxNSI3dTzSJRkPAbpN08EmNhDWFv07sjdCw7 Obv26reFxv8A
iIvDsR6WcomXUaFK0tK4Dzt5N3bzjiJiDfltvqtSjoPwVB4R02g+Ws278YjC ZpnVCID4k7ml
p+0hco2Wm25O8eGI0aF7Xl3denicBl1X2fPlo82V6fFeAA4D41Cszezu3cHO 9Hft6bwUrdKy
eQc8I4dtRhaSsS2PHyN3RxryF8+VkWaoHaJJPQTTTSTA4AUA2z67QbHI/iXm WHyvCYXAwpGV
LBTrTlUvF4UZThdjdkGk1M2kkEkWBY+Z9y8HXxmIxGIlOMZVoQAgw50xC0uC 4MpiyxrdK0xj
zdA3ULTgcwXXvPsrtQxJhWWmbJlr/tefjkRue6Wk85iGEPBwDu13f4Zbiica J5QxUdQUU2Ez
al7HOfiFm0zgjlW4nLGwjONKUJmdOLC8ZzjViLok4ibkbzGIBMSToss7m4H/ ALxDHGrHq8iJ
TBiIS1hgYkg3WJDlrC9oC6G9nrbiUflv2fU2hIS54eei80r9GJhzDvI+HfRb Tkz47FVjDxzo
5HbtY6wA6VVFIoFIUeAxjcH8QMbUI7wYerCEZxjhCZQvhwZ0zESEpyBMYyEb 0RASYkx5zDpO
6+Ep3MsrU5GUL9YASA6NRyCACBIxMrpvEOBe5tuoLK3f5LeY3D9yeClwTNj+ IszOF/35Ivp5
C2mzKLirjhhUkHUmvFzXFESUcEAwlZLG2TCGhQ1OXYw72nJc6zSvKf8AMqQw cYC4al6pKlEg
XROm5IvWmcQLTaeaacR3djmOAw1GEObCtXdiI3YCcwWN2WsRsES9gs0jS3tB d2PDm7Vlez7f
wTNPpzHl52NbmUI91LiKixW1wLSCSRAUNHxShiiDATF4xqkfQfhEKOoB638M +9mK7wYfEddp
xp18PWlTkI2CxtRlJi7gtIiywrzjvp3fo5RUpSw8zOlVheiSz+QCxiCLBpW5 Paa5ZnrbxrhH
GFv5LyLDO5LA+OE17AtFwsws180kBkmLtzKOW90x5xVWbpqJnTCMX2iJEKJ9 DiBPMe4Hd+GO
znMalTB06ohjqv8ANMmqUyJExui7aHYuJgxtIDsD3nePNpYTKcIIYjdmWHjz DC9GoLsXBNoF
ha0MXYkC0SzKm67gvKeVWMhmWdvR5hqxd1SHzrFMG762TS7BnHOnwoQaLhCA YN10km5Dhxiy
QKqHEBMoBQAoYmF77Y3J6OL6rSo76WaGjIkVLkjISed01JSjIyg5AmYgWCNj mufdfD5nLCir
Odzql8ebeDGDRMhECQAmw5oLhybbIviz2fe45cOC7Py9mPIbnH8Tlh5fRrKm 7uuuxIOPtyPt
p6owjiyzSaWaPJVwuqCfG82gUie3ofiw2TH3XeH4p5vluYVMDHD06ksNGlvI xjVkakpgSlu5
ReNMAGzePoNsjYtZk3cLBZhhI4mNWYFUzuE3AIiJIF8G2VotukaRYBapxjLE Nmb0G6puS7nO
OHs1ZeP81u8hXdfzyMlmxUpgLOWQVWUftm8YgLxVQxEwZAqqCbUgAChHRyJn Lzeb59Vy7Pc2
zioIVzhKVHdAiUbgqiIjd50rBvP5gDbwmUgYPdO7y/KIV8qwuABNLfVJxnol eMDMydwG8zml
iYsBbpWtLJ3KdyfJV27ut2Wy+vdpgveNY3O1g494rFOrjhJWAlEYxJ25GOjF UHDVVRyltpES
IZMomOKogUQrsY/EPN44fHwqQw/WcFGlUPnCnOlUiJkC9MGMwDpMpAloiOtc 3X7m4GNbDmMq
po1pTp6jKNSJMQbItKJINjAgWvqWqvaC7rWPtz7NjLdxtFSXkr4godg5vi4Z fVCNdzT9IHIo
wrU8c2U5IikJfw5l1QUMYSgBRTNtdn8Ne9WL7zYerj6sIQomZFIB7zDTfLkE 6NAi3C9nOd8c
iw+Szp4eE5Sq3Xm7XbdF2wEDTpfxa9F82H6/vDXpO4K4vfJzYfr+8NNwU3yc 2H6/vDTcFN8n
Nh+v7w03BTfJzYfr+8NNwU3yc2H6/vDTcFN8nNh+v7w03BTfJzYfr+8NNwU3 yc2H6/vDTcFN
8nNh+v7w03BTfJzYfr+8NNwU3yc2H6/vDTcFN8nNh+v7w03BTfJzYfr+8NNw U3yc2H6/vDTc
FN8nNh+v7w03BTfJzYfr+8NNwU3y8mj1wHQpdQ69VjDKRVCpyBz2A1PVhtU7 0JyBz2A06sNq
b0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A 06sNqb0JyBz2
A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0 JyBz2A06sNqb
0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A0 6sNqb0JyBz2A
06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0J yBz2A06sNqb0
JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06 sNqb0JyBz2A0
6sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0Jy Bz2A06sNqb0J
yBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06s Nqb0JyBz2A06
sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyB z2A06sNqb0Jy
Bz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sN qb0JyBz2A06s
Nqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz 2A06sNqb0JyB
z2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNq b0JyBz2A06sN
qb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2 A06sNqb0JyBz
2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb0JyBz2A06sNqb 0JyBz2A06sNq
Lr7don1bZ3ObSbmHYO6vS/y9XqgWCsX/AB15L3gwV/Oa/Bh8P/2mKXo/d2uB l8OGrU/hoqUZ
T3Wd55rEvrkmMfXO0gmSKr169dQUqkg3bokFRRVVRRuBSEIQomMYwgAAGo1g 5T3ryqU40oYq
iZSIAAqQJJNgADuSTYAtlmeX4unAzNKYADk3ZMANZs0LWW62odjvj4dbrm1M fIFlFDX7NzMK
23xBheyLGEaqNT+ArS91cdfzGjH68fnC3fujJxFwR+7Li25kuPt6djG0fIte MUTFZs7yxdbZ
Um2kYhy7RDCGpRAQ9wa5LvXGeH7XxNItOnMmJYFiMJQILGzTtsXQd3DGpSwV OVolFj4DWqBb
eeb01l3vg28rFwFEz2HH1txzCZjLgZ5HvV7GxxXV3w8Y6E0a10LsGJKKqHEi ShuqJSGOIVyd
PunXw2Pw+IzCdLGirOUZQOGoRlJqNSceedbwADyiNDyAC3OJz6nPDVaeHEqB hEES3tQgPUhE
80aucSWBOwErlq8L2t3IO/DlW8bSdcstafYZzmIl1xaqXHM3tgXe5QU4tcpF C7SZwHQxQEOo
IANegVstq4XJstoVhdnTqYKMg4LSFWiCHDgsdYJC5XDZpTxWNxc6ZeMo1yDt BhMjTboW9cf5
EyBaEvj4uLnDlDITS0MYhE82kMq4O6Wx5b6ZEiJAU/GcZt7ApiUQOA7IgICI D+anxbxVWj3y
zMUSb4xVRm0u+jhfQ2vQv0h+E+WYbE9ysB1sA0jQN69YGEpFybGZndwzOCGX YWQbVXtJG6sz
YRtiBN7TYkAzkritmNeC/GEB8KpH0pFMDInTVkFEjkFRLaNptF+ErxujvW46 BpCpiMLTgceI
AyiC913eUYsxmQzjhHnXv5mhyvFDEmhgcwrVRkxqyjCpKN3eXWuU6k3BjTBB uyYaDZC5/J/I
zeKnZe6N13eNkp92q+uJ7YjZ4+evVTrLuF1sq2OooqqooJjHOcxhExhERER1 Gt5/yt4k4rvV
C8XkadYkk2k7uVpK6n/mdwcML3foxpxEYRrUwAAwAALAAWAAaAuVMeQEPcFl x3LFVGkm3Kks
0fM1TIuEDgXgMQ5BAQHWv1g7+dw8r714bqmaUhOOp9IfYV+YuW9+s27q5nLG ZVWlTk7FtEg+
gjQRwFbFio69pVrzXemQZ2dtf7U0S+dmK2OQQEOLUKkJdsggIgJTagIDwhXi Xdr/AJUO6OS4
2ONp0BOcC4vBwDpB2ONS6rvX/wAzXerO8JLB1akacZ+cYRjEngeIBbaHY61s PGeUbnwtfUZk
vFckMNfEOYyka/QTRUFEx0jNzaJuCKJmAUzmKIGKICAjqFfQ2ZZPhsxwssFi oCVKYAMbRYGI
tDEMQGYrwDA5jicFXjiaEiKkS4Om3Xp0vwq0yrl3IeapiLlMtT5pjo+yPCW4 xSZRUTGREequ
LlRBjGwTNgxRA59kTmIiBz7JAOYwELphd3u5+CyadSrhoyNSqXlOcjOcvDKR Mj4yVuM471Y3
M6UKNW7GnDRGAEYvodhZxMLTYrW8MmXnf1r2ZYV2zijvHuPms0wtCE5OwSQY FuGQQk5JTjUW
xHKp1lmyY/hVTgUA0KBdR1ycJ3YwmGzCtmdKJFavGMZlyRK6AIljoIAAsYHW HtVmv3gxdbAQ
y6bGnTkZRstDu4fWHJNoJfW1in9o7+m97YErcNw2TkmQZXLc68U/lpB00hpZ UzuFhWtvNHSR
Zxg+TTcFYs00jLkKCp9NTHE3DXL5l8JcixkBTlhxEAyIuExa+b0o2FjAlyIE GMXIiACy3uB+
IucYaQlvL/NEWkHBuuxOg3g/nAglheJIWIw/va7wuA4B7buKL0csmElKtLsf jLs4i4jLTbNx
ytOSELnYyZSuxW0OdwQAVMYAETalKIZ2cfDfKcyhShVomO6gYRMJSgbkg0oE xIeJBIMS4Ylm
cvi4DvxmeEq1KgkJbyQlISAlG8LYyAOgxIDEbA7sFlrK3998nHltTNs2hlCR bJXBLTt0SztS
Otxw5PI3K9WkJVRsZzFKlZA4WXOYxWZUSgI6gADw1qsR8HcirRpRnRL0oxiC JSBMYl4iTECT
aAZAlgA9i2UPiZm8alSYMWmXumLgFmJi5cPpIdney1RDDecsm7u848uzBdxK Wzer2PcwRppq
2j3TxFo72AW5OaTauypKGAgBxpCgcA10MGo11veTurg8+wowmOiZUxISskRa NBLG3Tok41s4
C5nI+8GLynE9aw7XmItAIY6RweEEHU7OvnIZlyFJ4QtfdrdTphwRZzhzIW/b nI40SNXDoDgo
JXYtBegQRUMYUwXBMTDtCURABCjCd0cDhcfLMqEDCtKAhIglpRDCLxdnjdDE AFrHZXcV3lxu
KwvVK5E4X74cWxJcljsLlwXGxlaZGyZeeXrgiriybOKS7mAt6GsC30VG7Bul HwMCLkzJomDJ
sgZTZM8VMKixjqGEeE2gAAXcl7sYTKquIq4WJicRUNSYckGZ0kO5Dm0h2GoA K3mneDF5hRoU
K7EUI3YkBi1jA6iwAALA7XNq+q+VrzWxKhgcJg5MQIzZrzGDIg0AikwaPGLB wdfiBcjo3HZA
gKATXh2ddBq/LIMMceMzukVxT3buWMHvXSHbzrXZ+FljwzfExwksDYaZnfYg OJMzg6bRZsZS
TE+9nnrBFsdEcN3SEFEFkiXKgBoi35Q7WUI35IDxqadjn/J1+IEU+MR2TgUR ABDWtT3j7i5f
nc95i4Sv3bhMZyi8HvXJCJAlEm1pAh1sMj71Y3Khdo3TF7zSiJNJmvA6RIDW CFfYy33t6/C+
PF8Y4tyPJxdsunEhIOFHKEVLvjOZcxlJFYj2dZP3KSjpQ5lFjoqEMY5jHEdo RGtRmnwnyLHy
hOph7soCMQYkxcRtAkAWk3CCWYOwC2uC+Iub4cz54mJklpB2JDPHWLNQLcGl Yyy96rPmPJzG
85Zl4uGJ8Rt55nj1AjOJOnFdJ3BHMsoJlWR1XBnBkwAQcHUKAagUoajrsMf8 PMqxtXE1q9Iy
OKjCNUXpNK41w6XiRdFsSNDlzasLC99Myw1ClQpSAFGZnAsHF4SBGwxN42EE 26WYLJ4034t7
HDePV8Y4tyEvBWku4fvAbR8LaqabXnMwi6RjkeZxRjkTAOgJsU0SlD7UAHhr W5l8KMmx5pzx
FOUp04xjevSEpRh5omxAmRYL0gZEAOSs7CfEPM8NKoad0RqSMrrPESl5xi5J i5csDdclg1ix
tl71+8JjeYx5N2FeriLdYnZXHGY8KnHwbgsMF2HBSXXLy2PXM4UXEof8JFUp NPglLw1nZp8O
MqzCpialemScVGEavOkL27MTA6bDG7HQwLc4Fy+LgO/GY4OlRpUjFqMzOHNF l4SEo7DE3pan
D2EMGs5neTzncWE4vdxnbxXXwlFxlv26EISOgWx3jK1lBWiEn0gzjUZBwRqo InTTVcGTKYRE
C6iNUYH4a5VhMZDHU4S3kCZB5yMRKQAlMRJuiUgBeugAsLFdxnf7MsTQqYed xqlhIiBK65Ii
+uMXLO5Dm1Xl7b2G8Pf9033e8/ehwvDJFsLY1u+TaQtsN3D+3nLdJm4brKJR JRVVVQQTSFyr
tuCkIUpFClKUAtj4YZTHCjBQpyFGNYVoRvyaFQa4uSWLl4l4OSREEuqqfxAz OOIjizdNQUzT
JMfPgS7SYgODoMbp2khX+G98/eQ3eLTLY+ELwG37ZLLJ3UDbmi3pTZlE0SNg cJGnI1+ZI4pE
AgmSEo7Ooa8I1ld5/h3lWf1o4jG0iakY3HjKUXg5N03SAQ5Op7bCsLIe+WY5 RTlSw5FyRdpA
FpWc4a3DDgstCtojfC3nIrIFoZQNkB44vaxHl4zVsPFY630+SyN/zB5y4XRi NoxEiou3Kg6k
UAyRC/BIQoCOutwnwlyShTq0RSMoVqcITBlLnCm1zWCDFgAYkaHLlytpjfiT m2IlCTxjKE78
SI6CYmJFpIILkl3LmwswFrIb0meJZnZjGUuzjkbAmX132uoELbSLhlKyT7nN yog5bxSa6KSj
sCrGboHIgY5CCKY7BALs8P8AD7LaNWdaMJGVSiKNR5SIqUxEQAmCWJEQAJBp aXJcvra/fPH1
ae6N0CNTeQYNu5uZExt0Ek2SvDYBYs7fe/lvcZNlrak75yCo8RtK7EspwTNG BtJigjc7duu3
Rfqc3QzY6pig5UMJVTGKcxhFQDjppp8v+EGSYKcp0qU+dTnSIM5kGnMMYWlw LSxBEhtWzxfx
KzbE0t3Mw86MnEQDegRIS2O4DgghhoWrJeWeXPcMveV4ySkvec/JydyTUo6T aoqu5GXfrybt
YybJBugTbXcHECpplKAcAAAV3OSZNRyrCU8Fhwd3TDRe0tqD62XKZzm+IzPE zxdYATmztYLA
BrJ2bV8dmJ64f7P2q2rcC1jzWwJTeu3h5iEmLWd3w7Las5akFip9GoMoVFEb Tt1w6cs40BSj
yqCUTPlwUVMYVjFUMUVNOCuAl8McnliDijSN81t896RaofOIc6JNbEvEfqiL BdpT7/5pChDD
xkLsaZp6A5iQwfhj+qQx6V5y8kjPaIb60Jd123/D5PeIXreki1npl8MRayxC PWMelFN1mjRx
DqNG6pGqJUuNSRKqYA1Mcw6DWvr/AAdyKrhqeFNE3ad64RKV6MZG8YXneUHc gTvM5bSsql8S
s2p1jXeJMgBIEc2RiGEmeyXDC6LBZYo4hvZbwjbGkJh0bsbSGNredPZeMjro tSxrqOSUknLp
29kDu7tgJZ2d0uo8VFRUyomEDCHUq9X+FOUyxPW6Iq0al2MXpVZ07Ii6PNkG sADBhrZySVH4
j5kKJoVo0qsTInnwEtJdtIcPaHc8LAAfKx96XeAx1K41l7UvZ03c4iazrKwA BlDaRprmXTcy
6xhBgBlzuTJBtAsJyFDUCFKAjWyxvw8yvGVcTVxFMzOKhCNV5Fp3Gumwi7IX R5l0WOzrW4fv
rmOHo0qFEiEaMzODC2N688bSXjzj5zm3Sr+x98XeGxxC21bdl3WRhbtpIzrG CYIwtuclbtLl
ORSUZ8QMYKYs3B0yHM0EvJtohB4vUhBLjYv4X5NipSnWomUpwhGRMpud2AIS d7JxAAEw0mcE
kEvfo9/82pWU5iIE5TAADAycyHDEmRJiXALEMQFic2byGat5OTiJjPt2LXRI QTAsLFKOmMOy
FBsVUywh/wAksGe1qY/+VqBeoUChrrs+6/cfL+7286hAx3rGTyJch7bdBL2s w4FgZ/3rxucC
EcTd/lvdYMwLWadAax7eErC5GyZeeXrgiriybOKS7mAt6GsC30VG7BulHwMC LkzJomDJsgZT
ZM8VMKixjqGEeE2gAAZuS92MJlVXEVcLExOIqGpMOSDM6SHchzaQ7DUAFjZp 3gxeYUaFCuxF
CN2JAYtYwOosAACwO1zas5N7zWfJznnlF7OU+esfIYCW4mPgQ4iw0eN1iUdu NN9vx59pc+0v
w8CgaBpoMR8Msprbx6chvK4xBaUrKwfni3W5eJeNtkRYt3hPiBmeH3N26d1T NMPHTAtZJiNF
2LEMbLSXL5zGe+9vT4VxybFGH7/eW/Y4ndKJtkWUM+Ubg+IBHRWi8uweqtQV ANTcnMmOoibX
aHWrneL4a5RneIGLxdH+aGBlGUo3hEuBIAtJtpBLMHYBY2R99syyqkaFGQNM uwkHYnSRrHgB
bgtKwMJvI5stt/jd3b94PGKGIyS5Met2iTBEIo88/QkZJTjk2pXC4uFW5AOV wqoTY1KBQKYw
Dl4juHllfEYnEVaV44qEYVQSSJCIAiWJskAAxi1ofzrVYpd78wpYelhqchEU ZmcCAxiS7jYY
kyNhB0t5tizzjfi3r3mVGub3uQnKmVYqLeW1bcrzRbSacBHvxMLksSxRiSMG qqm1odwmhx5i
6FMoJQAA0tH4SZJSwtXBxpSuVZAy583N3zQS7yjE2iMrwcAtYFtq3xHzWpWp 1yYPTdhdDF7C
eAkaTG6bSzOVFMmZsyRmZC3WmVbgUnULTikLYgjvWseDtGPbGEyaaz5JqR65 2RMOnKVlNnUR
LoJja9NkPdPBZLKqcDA041TelFyY3tchEkiJIYG6wLCywLQZx3jxmaRgMURK UHAkwEmP6pI0
gaQ9oc22qL7MT1w/2ftV0jcC0TzTZieuH+z9qjcCPNNmJ64f7P2qNwI802Yn rh/s/ao3AjzT
ZieuH+z9qjcCPNNmJ64f7P2qNwI802Ynrh/s/ao3AjzTZieuH+z9qjcCPNNm J64f7P2qNwI8
02Ynrh/s/ao3AjzTZieuH+z9qjcCPNNmJ64f7P2qNwI802Ynrh/s/ao3AjzT ZieuH+z9qjcC
PNNmJ64f7P2qNwI802Ynrh/s/ao3AjzTZieuH+z9qjcCPNeDowxjaiACPXqo EhTemqcnhexC
l6Sm9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL 0kvTTk8L2IUv
SS9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0k vTTk8L2IUvSS
9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvT Tk8L2IUvSS9N
OTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk 8L2IUvSS9NOT
wvYhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L 2IUvSS9NOTwv
YhS9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L2I UvSS9NOTwvYh
S9JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUv SS9NOTwvYhS9
JL005PC9iFL0kvTTk8L2IUvSS9NOTwvYhS9JL005PC9iFL0kvTTk8L2IUvSS 9NUFvDacABrU
3il6a88li/sVN4qb005LF/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9 NOSxf2KXil6a
cli/sUvFL005LF/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2K Xil6acli/sUv
FL005LF/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acl i/sUvFL005LF
/YpeKXppyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL 005LF/YpeKXp
pyWL+xS8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL005LF/Y peKXppyWL+xS
8UvTTksX9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL005LF/YpeKXppy WL+xS8UvTTks
X9il4pemnJYv7FLxS9NOSxf2KXil6acli/sUvFL005LF/YpeKXppyWL+xS8U vTTksX9il4pe
mt1Y7F1fe73b+PscSMMhflrXLck+/jbln4W2yuo+4Yy3WaKrV3cDti0UFFWE OCifGgpocglK
YNsS+Z945zwWZVMVUo1alKtRpQBpwnUMZU51pESjASkARVDFmsIJBZ/Ru6+I hVwYoGpCE4VJ
yachBxKNMBjIgFjAuHe0cLdEXpvy+1Qv+zpWxLqvWzHVrzbNzESTXp1g5Ljm jxAzdZPbRliH
LtEOIalMAh1QEBrybL+5vdzCV4Yill+KjOnISidzjCxiXBYxILEawy7vH5/m GIpSpHF0LsgQ
RvKFoIY61z/ijGuQcabxtgZwyrJWpF4ysm5YS8ppeNvyxp16o1hJNCUO3ax9 vzT94sssDfik
wKlsgYwCcxCamDv+8Ga9q5bXy3CYfEGrXhKEb1CtTiDIGLynOEYgB3NrsLAT YuPybL6eW4uG
Mr16VymRI3akJEtawjGRJJ0CzwsFkLZkbyu2yMW3FgmbhWd02FDuLdk28vdt vWnIsn5LunLl
avWp7ikYwFUzJypAKducxiKJm2gL8ATZGcthMVjKeLw9WpTxFQTiYUp1YmO5 pUpRkIRkxemX
EgAYyDPa13IMVGrhKBhWhCdKJiRKcYEHeTmCLxDhpC0aCLWsUpvnIO/zkK2H NoXzfsbMWs82
AdRstm3H7potxShVicYi4u06Ztk5CmDUOAQAeqFc9l1HJ8HVFahl1WnOOiUc FWBDhixFFxYS
PAtnmc8Vi6ZpSxlOUTpBxECDr0GbaVrKy7LufDl6ymXMwStss7Vb2xesE1Zw F52hc0g+kLlt
CVthmii0tmVklSgVaSKqooqBEypkN8IT7JTdNjsfLOer4TC0K4Ir0ZylUo1a UYxp1YVJEyqQ
iCSIsAHJJFjORo8DgY5ZGtWq1aZenUiBGcJkynAxFkZHWXJLABbixxmq/WV1 Wjnzduua22kh
G21asCHPV32ZASMdIwNpMLYepLMLrkWJlCKC0OchyJnSOmcPhbQGKX8/fjD8 Ge90O9+OzDL8
HVq061aVSE6cDMNPUbCH1EFffnwm+MHc+XczB5NnGIjCdKFycJuHIkZAgxtZ yGLi0KkPfm8b
ad/N8u2xdFptcmtnR5RObNlfF6rk7pQTGVOsZa5Tgrxm2YFAU2gOBhAwCAiA +QS+CHfqFYYi
jl2KFQF727k763cWvrd3tBdety+NXcDEYaWCr4yiaJjduMQGGgBhYzC6QxiQ CGIC0Xvc3XK2
5gjON3ZquOBkMgZJgUoGMZ23c9tXQ7eSa17QN2PHjkbXfv0W6REodUBFUxBM ooQCFMG0JfcP
+W34L96Mo7w1M4zfCVKNOFOoZSqRMbxnEiwEWly5bQF5R8ffi93ZzvJsLlGR 141DCpBhEFox
gGALtq0aV+tjT2E/sq2jZNm3xZst0g2Uy9JbvHQNAL1RlxHqFCu0q/GzvPUt li3/APt0v7a+
fKncnLJyMjStP1p+srgvsOfZckDQuMTAH2Llu/53qz+dHeYf/l//ANOl6it+ 4mVex/en6yr+
o99l91PRmfT+094fPFPzq7zfi/8A+nS9RR7hZT7AelL1lQ3sOvZdD1cZGH9m 5rv+eKr/ADr7
zj/8s/d0vUUe4mU+wHpT9ZeS+w69l0P/ANmJvOa7/nen5195/wAWfu6XqKT3 Eyn2P70/WVR9
hz7Ln6sTec13/O9R+dfef8Yfu6XqIe4mU+x/en6yB7Dn2XP1Ym85rv8Anen5 195/xh+7peog
7iZT7H96frIPsOfZc/Vibzmu/wCd6fnX3n/GH7ul6iHuJlPsf3p+sqB7Dn2X Q/8A2Ym85rv+
d6H42d5/xh+7peop9w8p9j+9P1kD2HPsuvqxN5zXf871P5195/xZ+7peooPc TKfY/vT9ZDew
69l0HUxibzmu/wCd6pHxs7z/AIw/d0vUU+4eU+x/en6yp+o69l19WRvOa7/n en52d5/xh+7p
eop9w8p9h+9P1k/Udey6+rE3nNd/zvUn4195/wAYfu6XqJ7h5T7D96frKoew 69l19WJvOa7/
AJ3qPzs7z/jD93S9RQe4eU+x/en6yG9h17LoOpjE3nNd/wA71A+Nnej8Yfu6 XqJ7h5T7H96f
rKn6jr2XX1ZG85rv+d6k/GzvR+MP3dL1FPuHlPsP3p+sgew69l39WRvOa7/n en52d5/xh+7p
eooHcPKfY/vT9ZDew69l0H/2ZG85rv8Aneo/OzvR+MP3dL1FA7iZT7H96frI HsOvZd/Vkbzm
u/53qr87O8/4w/d0vUUjuHlPsf3p+sqB7Dv2Xf1ZG85rv+d6p/OzvR+MP3dL 1EHcPKfYfvT9
ZUH2HnsvPqyN5y3f871P52d5/wAYfu6XqKo9w8p9h+9P1lX9R37Lv6sjec13 /O9U/nb3o/GH
7ul6ip9w8p9j+9P1lQfYeey8+rI3nLd/zvU/nZ3o/GH7ul6iqPcPKfYfvT9Z ev1HXsu/qyN5
zXf871A+Nvej8Yfu6XqKPcPKfYfvT9ZeR9h57LwP/syN5y3f871I+Nnej8Yf u6XqKPcPKfYf
vT9ZDew89l2HUxkbzmu/53qB8be9H4w/d0vUU+4eU+w/en6yF9h57Lwf/syN 5y3f870/O3vR
+MP3dL1EPcPKfYfvT9Zev1Hfsu/qyN5zXf8AO9R+dvej8Yfu6XqJ7h5T7D96 frLz+o79l39W
RvOa7/neh+Nvej8Yfu6XqKPcPKfY/vT9ZDew89l4HUxkbzlu/wCd6n87e9H4 w/d0vUUjuHlP
sP3p+sqfqPfZefVkbzlu/wCd6j87e9H4w/d0vUT3Dyn2H70/WT9R77Lz6sje ct3/ADvT87e9
H4w/d0vUT3Dyn2H70/WVR9h57Lz6sject3/O9Pzt70fjD93S9RSO4eU+w/en 6yp+o99l59WR
vOW7/nen5296Pxh+7peoo9w8p9h+9P1k/Ue+y8+rI3nLd/zvT87e9H4w/d0v UT3Dyn2H70/W
QfYe+y8+rI3nLd/zvUfnd3o/GH7ul6ik9wsp9h+9P1l5L7D72Xo//Zkbzlu/ 53p+d3ej8Yfu
6XqIe4WU+w/en6yqb2H3svQ6mMject3/ADvQfG7vR+MP3dL1FPuFlPsP3p+s n6j32Xv1ZG85
bv8Anen53d6Pxh+7peoo9w8p9h+9P1lQ3sPvZeh/9mRvOW7/AJ3qPzu70fjD 93S9RSO4WU+w
/en6yp+o/wDZffVkbzlu753qT8bu9H4w/d0vUT3Cyn2H70/WXr9R97L36sje ct3/ADvVP53d
6Pxh+7peoo9wsp9h+9P1k/Ufey9+rI3nLd/zvQ/G/vR+MP3dL1E9wsp9h+9P 1l5D2H/svvqy
N5y3d870/O7vR+MP3dL1EPcLKfYfvT9ZVN7D/wBl8HUxkbzlu/53p+d3ej8Y fu6XqKR3Cyn2
H70/WQvsP/ZfD1cZG85bv+d6fnd3o/GH7ul6iHuFlPsP3p+sqfqP/ZffVkbz lu753p+d/ej8
Yfu6XqJ7hZT7D96frJ+pA9l99WZvOW7vneoHxv70/jD93S9RT7hZT7D96frK n6kD2X31Zm85
bu+d6j87+9P4w/d0vUT3Cyn2H70/WT9SD7L/AOrM3nLd3zvU/nf3p/GH7ul6 ip9wsp9h+9P1
k/Ug+y/+rM3nLd3zvT87+9P4w/d0vUT3Cyn2H70/WQ3sQfZfh/8AZmbzlu75 3p+d/en8Yfu6
XqKodwco9h+9P1k/Ug+y/wDqzN5y3d870/O/vT+MP3dL1FT7hZT7D96frIHs QPZf/Vmbzlu7
53p+d/en8Yfu6XqKR3Cyn2H70/WQfYg+zADqYzP5zXf871T+d/en8Yfu6XqI e4WU+wHpT9ZA
9iD7MD6tD+c13/O9Pzv70fjD93S9RB3Cyn2A9KfrKhfYhezBH/7ND+c13/O9 T+d/ej8Yfu6X
qIe4WU+wHpT9ZUH2Ifswfq0P5zXf870/O/vR+MP3dL1FJ7g5R7AelP1lX9SF 7MD6tD+c13/O
9R+d/ej8Yfu6XqKn3Cyn2A9KfrKn6kP2YP1aH85rv+d6H4396Pxh+7peoqh3 Byj2A9KfrIHs
Q/ZhfVofzmu/53qPzv70/jD93S9RSO4OUewHpT9ZU/Uh+zC+rQ/nNd/zvU/n f3p/GH7ul6ij
3Byj2A9KfrJ+pD9mF9Wh/Oa7/nen5396fxh+7peonuDlHsB6U/WVf1Ifswfq 0P5zXf8AO9R+
d/en8Yfu6XqKfcHKPYD0p+sqfqRPZhfVofzmu/53ofjh3p/GH7ul6ij3Byj2 A9KfrIHsQ/Zh
fVofzmu/53qPzw70/jD93S9RSO4OUewHpT9ZP1Inswvq0P5zXf8AO9Sfjh3p /GH7ul6ij3By
j2A9KfrJ+pE9mF9Wh/Oa7/neqT8cO9P4w/d0vUT3Byj2A9KfrKhvYi+zDD/7 ND+c13/O9Vfn
h3p/GH7ul6ikdwco9gPSn6yr+pE9mF9Wh/Oa7/neqfzx70/jD93S9RR7g5R7 AelP1lQ3sRfZ
hh/9mh/Oa7/nen54d6fxh+7peopHcHKPYD0p+sqfqRvZh/Vofzmu/wCd6n88 O9P4w/d0vUU+
4OUewHpT9ZVL7EX2YY//AGaH85rv+d6j88O9P4w/d0vUUHuDlHsB6U/WVP1I 3sw/q0P5zXf8
71P54d6fxh+7peop9wco9gPSn6yfqRvZh/Vofzmu/wCd6p/PHvT+MP3dL1E9 wco9gPSn6yfq
RvZh/Vofzmu/53p+ePen8Yfu6XqJ7g5R7AelP1k/UjezD+rQ/nNd/wA70/PH vT+MP3dL1E9w
co9gPSn6yfqRvZh/Vofzmu/53p+ePen8Yfu6XqJ7g5R7AelP1k/UjezD+rQ/ nNd/zvT88e9P
4w/d0vUT3Byj2A9KfrKgexH9mJ9Wh/OW7vneo/PHvT+MP3dL+2oHcHKPYD0p +sn6kb2Yn1aH
85ru+d6fnj3p/GH7ul/bU+4GUewHpT9Zef1JHsxfq1P5y3d871P5496fxh+7 peop9wMo9gPS
n6y9B7Ef2Yn1aH85bu+d6j88e9P4w/d0v7apHcHKPYD0p+sqF9iP7MQerjU/ nLd3zvUfnj3p
/GH7ul/bVR7gZR7AelP1lUPYj+zE+rU/nLd3zvT88u9P4w/d0v7apHcHKPYD 0p+svJvYkezF
D/7NT+ct3fO9Pzy70/jD93S/toO4OUewHpT9Zev1I3sxPq0P5y3d871H55d6 vxh+7pf21PuB
lHsB6U/WXkPYkezF+rU/nLd3zvU/nj3p/GH7ul/bUjuBlHsB6U/WVf1I/sxf q1P5y3d871B+
OXer8Yfu6X9tU+4OUewHpT9ZU/UkezF+rU/nLd3zvT88u9X4w/d0v7ar9wMo 9gPSn6yoHsSf
Zi/Vqfzlu753p+eXer8Yfu6X9tQO4GUewHpT9ZP1JPsxvq1P5y3d870/PLvV +MP3dL+2o9wM
o9gPSn6yr+pI9mL9Wp/OW7vnen55d6vxh+7pf21V7gZR7AelP1lT9ST7Mb6t T+ct3fO9Qfjl
3q/GH7ul/bUDuBlHsB6U/WQfYk+zG+rU/nLd3zvUfnn3q/GH7ul/bQ9wMo9g PSn6yB7En2Y3
1an85bu+d6fnn3q/GH7ul/bQdwMo9gPSn6yB7En2Y31an85bu+d6fnn3q/GH 7ul/bQdwMo9g
PSn6yoPsSvZjfVqfzlu753qfzz71fjD93S/tqR3Ayj2A9KfrKv6kn2Yv1an8 5bu+d6j88+9X
4w/d0v7ae4GUewHpT9ZUN7Er2YwdTGp/OW7vnepHxz71fjD93S/tp7gZR7Ae lP1k/Uk+zG+r
U/nLd3zvUH4596vxh+7pf21HuBlHsB6U/WT9SV7Mb6tT+ct3fO9D8c+9X4w/ d0v7ak9wMo9g
PSn6yfqSvZjfVqfzlu753qPzz71fjD93S/tqPcDKPYD0p+svP6kv2Y/1an85 bu+d6H4596vx
h+7pf21PuBlHsB6U/WQfYl+zHHgHGp9P7S3d871P5596vxh+7pf209wMo9h+ 9P1lT9SP7MP6
sx85Lt+dqn89O9X4w/d0vUU+4OUew/en6yfqR/Zh/VmPnJdvztT89O9X4w/d 0vUT3Byj2H70
/WT9SP7MP6sx85Lt+dqfnp3q/GH7ul6ie4OUew/en6yfqR/Zh/VmPnJdvztV P5696/xp+7pe
onuDlHsP3p+sqfqR/Zh/VmPnJdvztQfHXvX+NP3dL+2nuDlHsP3p+sq/qR/Z h/VmPnJdvztT
89e9f40/d0vUT3Byj2H70/WXn9SR7MT6sx85Lt+dqD4696/xp+7peog7g5R7 D96frJ+pJ9mJ
9WY+cl2/O1Pz171/jT93S/tqr3Ayj2H70/WQvsSPZiD/APZmPnJdvztUfnr3 r/Gn7ul/bUHu
DlHsP3p+sq/qSPZh/VmPnJdvztVP57d6/wAafu6X9tPcHKPYfvT9ZUN7Ej2Y gf8A2Zj5yXb8
7VV+evev8afu6X9tB3Byj2H70/WQvsSPZiD/APZmPnJdvztUfnt3r/Gn7ul/ bQ9wMo9h+9P1
lT9ST7MT6sx85Lt+dqfnt3r/ABp+7pf21PuBlHsP3p+sqm9iR7MQP/szHzku 352p+e3ev8af
u6X9tQO4GUew/en6yF9iT7MQerjMfOS7fnah+O3ev8afu6X9tPcHKPYfvT9Z UH2JXsxfqzHz
ju352oPjt3r/ABp+7pf20PcDKPYfvT9ZUD2JXsxfqzHzju352qPz271/jT93 S/tqR3Ayj2H7
0/WT9SV7MX6tB847t+dqfnt3r/Gn7ul/bUe4OUew/en6yB7Er2Yv1Zj5x3b8 7U/PbvX+NP3d
L+2pHcDKPYfvT9ZDexL9mKH/ANmg+cd2/O1R+e/ev8afu6X9tSO4GUew/en6 yD7Er2Yv1Zj5
x3b87VP57d6/xp+7pf21B7gZR7D96frJ+pK9mL9WY+cd2/O1U/nv3r/Gn7ul /bT3Ayj2H70/
WQfYlezF+rQfOO7fnap/PfvX+NP3dL+2h7gZR7D96frLyHsTPZjfVoPnHdnz tU/nt3r/ABp+
7pf21I7gZR7D96frJ+pM9mP9Wg+cd2fO1Qfjv3r/ABp+7pf21HuBlHsP3p+s vQ+xK9mL9Wg+
cd2/O1Pz371/jT93S/toe4GUew/en6y8j7Ez2Y31aD5x3Z87VH5797Pxp+7p f21J7gZR7D96
frIPsTPZjfVoPnHdnztT89+9n40/d0v7aHuBlHsP3p+sg+xM9mN9Wg+cd2fO 1Pz372fjT93S
/toe4GUew/en6yp+pM9mP9Wg+cd2fO1Pz371/jT93S/tp7gZR7D96frJ+pN9 mP8AVoPnHdnz
tQ/HfvZ+NP3dL+2nuBlHsP3p+sn6k32Y/wBWg+cd2fO1R+e/ez8afu6X9tPc DKPYfvT9ZVD2
Jnsx/q0Hzjuz52p+fHez8afu6X9tSO4GUew/en6yp+pN9mP9Wg+cd2fO1Pz3 72fjT93S/tqP
cDKPYfvT9Zef1J3syPq0Hzjuz52qfz372fjT93S/tqfy/wAo9h+9P1k/Unez I+rQfOO7Pnaq
fz472fjT93S/tp+X+Uew/en6yfqTvZkfVoPnHdnztT8+O9n40/d0v7afl/lH sP3p+sql9id7
Mgf/ALNB847s+dqfnx3s/Gn7ul/bQ/D/ACj2H70/WQvsTvZkD/8AZoPnHdnz tT8+O9n40/d0
v7aH4f5R7D96frKn6k72ZH1aD5x3Z87U/PjvZ+NP3dL+2n5f5R7D96frKpfY nezIH/7NB847
s+dqp/PnvZ+NP3dL+2h+H+Uew/en6yp+pP8AZkfVoPnHdnztVQ+PHez8afu6 X9tPy/yj2H70
/WT9Sf7Mj6tB847s+dqj8+O9n40/d0v7afl/lHsP3p+sn6k/2ZP1aD5x3Z87 VB+PPez8afu6
X9tT+X+Uew/en6yfqT/Zk/VoPnHdnztQfHnvZ+NP3dL+2n5f5R7D96frJ+pP 9mT9Wg+cd2fO
1D8ee9n40/d0v7afl/lHsP3p+sn6k/2ZP1aD5x3Z87UHx572fjT93S/tp+X+ Uew/en6yob2K
HsyQ6mNB847s+dqn8+O9n40/d0v7aD4f5R7D96frKhfYoezJH/7NB847s+dq j8+e9n40/d0v
7aH4f5R7D96frL5PvYuey/jmir99joqDFAhll1lrluoiaaZC7RjGMaXAAAAD URHqVT+fXez8
afu6X9tTH4e5TIsKDk/Wn6y54nMD+xcZyjlK1cJ3PctpNDEIvcsJKzgR2hx2 CnTCRuZm6VIY
dQKdNAxT9UgmAQEcaX/ML3pFnXjZ/wBXS/trusL/AMvNOvTjU6tGN7QDOYJb YHt8S3VjP2UH
si8y2a2vvHNilk7XdCYhVS3DeCZ01Ux2VEVkVpQiqSpDcBiKFAxR6oBWVH49 965BxjT93S/t
rj8b8MstwdQ0q2GMZDUZT9ZXt1ex19k/ZMSM5dGPCNI0DFS4w9w3cYTHOPAU pE5QxjD1R0AB
4AEeoA1ch8du90y0cYfu6P8AbWJ7h5QNNH96frKIt/Zl+yVGfmI2dxWowgIz ieKlVbhuxVJ1
xwgBNgqUoYfwgDxiWztbaYCfgAKvn43d7mBGNJJ1bul/b4+FUjuNlL/Y/vT9 ZTJz7D/2Vc7F
AQuMiLxDtPaAyNy3ZsKpKF1ASnTlw1AQHUBAawq3x572mMqcsaWNhG7o/wBt ZNDuTldOQnGl
aNHOn6y7kANK4x1uV+dm6xltruk7qO69vKXTfV0zDLJFhJX1nsL3ua7b74i3 YjFLy85S7mrK
XeSrthyOXSZtDmYFTbH5wKiqiosdkKMKVj197j2kOSN4vG+65e6TXF2fmN5w c0nNTduIJw8v
b9yY1y2cGMjbVp5MuMrpJF1ZxliKHnUhFYUzC2Lycp3Aoybw/tLN9FvYGZ75 DHzVjuxsmua7
LtaWeP42BWGVxrD3cQrtpNxOQULifqunNpratGUEwXbJqnWI8ErPjnAlLq/S ICgFS6pVahF+
VzXeNz/uldJt9i9BlJawiX7vFsGqS2TbxuDpW0sX0mzzK3HFqXA1GCtpqila ZARkYs7lwXkq
SPEgk7cCmVTLdcPv0b+UHa9yYky7aDWJ3u3zq222Ko9OCtNR7OqzCVwSb1qt a0fl6TQQSbxl
pyDhN8+uRkm4MCiSSRlW2w5KGdajzLvy72G9vuXby9h3dbcDadl2fg++3l+p vE3J7gVuBrJZ
Yx04aNGzCTkY5sku4sxN6Ig+dg1Ap2xTvQWK8btKlbczpvxb9GAskl3RGkVA 5K3nJx1aKluX
HZltDFMkWVyxWQZdVFS27mvxmm6VbJ45caqGuJqUxXZTFTEzbi3QlGdaxV3t 99jOu9TinH8E
+i8Z5oWlLfjZ9Ny4fXTAruGsRvERT9vKQNr3saKLxilmt3JmjeROs0dbKTly 7Fklswiz+XPa
m78NixGVc0Q+Ootvu8W76Y7dsyRuEYBq3Um8WRl1qJOSvSX2MvL8rd2irxke jbzM6SKqigOj
ptBVcFIXVG7zlbPBs8XvuybwsjAXHelrQFp341umzISRtlksyuyRuWKJHqRc lNXEpxrZS11F
RcA82VCrlJxRBSE6suqXW6tdKIVzt7T/ADkvh7dnRtaFczzW9MmT8Ji6NWx/ F3BLXQ2ZTbrj
LjkIRK2mrx2m/jLaayck2VBIxU1W5REig6JHjQpZaF3Ut77emzEvYO6Ngm5m sHelstcpwt2X
BnexL2k7ocssd3BZ8fai8iykpuznfL5e2ruYSrxypqVRVX4KSQiZMkKVgc2e 1A3jpzdif54u
KAa42xBfOI5O+8ZQ7yMuOcVvOVPht7kV03aXvZtxwykArHqJqoik8YN13CbU 6zJwJ1DAzh0U
t3o8m7z+8Pu5S2S4ectaBxqlmWzMf2Zbzm2JaRk46bs3eXgLNSlpSUJcrJF8 1XWh1XRmaLJq
cpVSpA5EUxVVlQzK/sfO++Pkb2kFs7vr27oFlLY4a5DhchuWUBNkt+8GTdDD F1oLsYM1ziaN
foNbxOyRcuHb8qYlWUBLZcCkmdSy7k6lFGhUEoVLqSV+b474Udu/YRsjf3zl bOR7r3g7msy5
bxllmd+vYzHUZfcBYNz3RNWI7tMly8WwVjE7aeR4cbb7g6CqRBcrKvgWVGlG VLozP7QjL+c8
L4iy3GQOPc+wWR2U7bM9ccFCrJKMprEWWW6xHtn2nlC5nQJELDqlQeKTLcq6 ihilR/migrCV
KyF2e1O34XT6ajcRY6i570Txc1M5Sl9YBhCynMOQL3sRQ/L7rvu2ejbVz0Bc u+PFOa5MRxoo
Q/JgM7KF+iOmvVqdCMhuGoCC1cdRG9Nl/DPs+rwzPb7R1fGX/S3fWOrZZSS5 XivGze8PLY/h
kylkZCNTVSYJvEASanfNUzJpFQ5Q2IIKpwSjKI3Fv+b/ABZmGH915dtWLx/G 2LKTrfLGTXNu
s71b23GR8DBz0erJ2FYORZWVZcrTm1AMdCWfGQRaldLopNngHaSyK+t32hW9 zcmYJ9/P2/A2
JuirT2S8dweQb26NtoqGe4+Lcrc84u8UyE2k5dIy9rLrLxxISPMkgdRTlgpN DLOIZGVhce+P
7UeF6H4whLPi7ky3fvTC9bbkoeyQjHaVj2t0VjEjytoXnk23TsnT1/cR1i7U 4ZdFuVEizJNw
quRmQJu877+89vM5jksRYjLa9i37c/GX+eXnlpbJsKwj4zGGHpVxEsixNzQ7 NbjXmQBFN5HO
UWhiNhUBsoq6UcARRG0t8LO+4Tu/XVm+fJA3ngKSyPvMJwdls42Qg7gYvbXn cp5DOs7uFSVl
GrlJwa1V2wJkikTJg4IfjD8QYi5SpdA753tMH2QrW3bL8hbWsTNF03RFRTW4 rvt+Lc7ELIWV
f1yHE1o2flW4nKey5skqaL1eYSIvxypCN9WpjqQEC6l3R8zXRnXCwXje6DVG 9IuevCxJdWKI
qiyevbKu+Ws5xINm7hVwo3SeKRJnJG51ljIlUBMVVRJxhhRbMoFC4rzxjTLu e/aezePY0JSQ
wxBWFjWRlm8dmTJeNOZuersv1s/fsIyxETtpR0s2jEwEHazfTiEyAoAHMYhS sfv1b3OdovFO
8tgu15yBh70x3jjId9hdtuvZBtMLMjWo8dQ8fFtknJVGUzEKPWTiTccoVKki pHrESIMsQseR
Twm9HvHYgzteNlbys9Zp8BYjxxEZiydfUJb1xxz1VKTkL7QM2joUJacMmkk1 t1Bc6ouV1AMi
omRBTlZDMila0t7fo9pf/wDV+HrtxdyXM9s9ELlk7k6MRa/M1n3N0qSWlOhd tZLuRzL8lc2m
KPFMpwj1XlW0kyUFsVN5Chl2JgPIsfmDBFk5biJprccVdMDD3G1uGKjXsMyl EpKPReketo2S
XcumiS5VQUIguqdRMogU5jGARGFIUtANalCvzv3u87791rYs39nWGmcW9xta HPPNt2yt/wBw
wdxWnxeCLSl1uj8YxtmTR/ALOTvUdmRbbblQ+vFiIqmMjLSt0uL/AN67fdHF 6Z4Eja67yTsm
YichRUxfNqSsVad3b1x2iExCyU81UepApb7ZyigLwiDZymidBNNNBJEsFF1r gjfm3uMp71yc
FP2C1jd0aavK+8Vwk08UttgqV7Y7m4WJ3rWQUvVxJyqrle2FxFgS2mpkU1Dq coUSaGUcmUSX
Yp6pUhC0QryA0QIPBQBCqmDTqVACOqaUKMqCFQhQaKXQAooCr1KJoVNdaMpK dSqU0KhQqSpI
XkRoi9G4OpQKGVBDSoKmKoFFIVRAKhQFQQqUKa1BR0DhqCVITqUIUKlETSoK kKhqqCBBHSqQ
EQPhdWiLzRSvQ/B6lFCoIaURDBpUKQhg0ogVKhEGpQpUBFQeCoRVqFK8iGlS pVahUoAaUUqg
DQKDYglAahFTbGpZSqdSinQqiOlQypCprUKp1SihAopCqFECoI6VBUxVRCoR eSjVTKEERDqV
CBKKoBVEdKhF5MOtAhVS/C6tFDJRlJCptDUMoZUoiUKJUOiDR1JCBR0AVBHS iJUIlQ6KghUh
AmyFCjoAaVCKm0NQApZV+26tSbEVC1SUKpUqVU40CpQfgdT3ahF5EanQiDwV ClUNwdSgRk10
opCqIVDI6oI0CC1NoaghSyCNFAtXktQ6OmlSqmTbGoVKDRVFVKG11ahQvIjR FXShKllQah1B
QQopKGHZ6lESoKheKqCqVRAKpQIAa0UIWhQoWoKFUqVKqPwepVKhUqVKpUIg 0ZClESoRBHSg
Qqn23Vo6Aqgjs9SilaJ9pjIT0XuPX3JQKSi5UEoxSWSREwbUKE0y54A4lAR4 vm7j+M9zY114
Kx8UTGnIx0suq7kUqNTNsPCuQIGdpOjQW8ujhXMO7RvpbsNuboGRLZyNj28J eQOZoGQLghm1
sHbR6j52o0iAaBITrN0sCaxNsBKhwHERMAF0GtdluOwwwkxOMj0jZY+jX8iv fe+3dTOZd4ML
LC1acRbuYkz5wiAajtAgOLDbbFgHKmPsaLxuO9neUJQWqzaxSntwiHGCPFnl +Tv+VjpwlBXk
HN+2ACPBs8OmlTk1UzpknQ9i4j454GjhsfSjEgzuc9tINjfpZdLZ9GSGSh+k vIfQ5xpOduWb
fHcdtj9pxP8AONri/wCD4jh12uM+BrXSYVmLPe1fLRx+K1eFVA3gWbykOOhx efn7kPRrik+a
eN43kvHcWPJeK5D+F2dP4rh2Nfc1q1Qv37HfX+nT+lVSAa1fXD/TToCz6b8m 5dw8j5BxHF8j
0LxOvJPwHU+14v4Oxs+7rVrF3b/N+RU0na1TEc2YbDqXbC+NGPba6Lew6Q41 g3DsXK+7LuM7
t+6LdBp/AuelbbiXrqOeXHB27b+79bzK4EY1Y6iTSTPbOPYt0dLZWVJqmuRQ hVD8Wchh2qb2
HSHGFJidi2Zb27X7Ku0rHuHGNq2DiiMxrd3IOldvR8HaDaMmuanBnbHnFoig VFzyZYwqI8aU
2wYRMXQeGoNaG0cai7LYs9JY+9n3M3xc+TpiFx67yVe0Wrat53C5Z22rJz8I u3QaKxso7OQV
nTU6LVJMyKxjEEpClENCgATvobRxqbstinwZsw2P9bYXxox7bUb6HSHGouHY q+mvDXlbC+NG
Pbab6HSHGlw7FzLYm5huvYt3oJnetxjmRK3L9uOUdzFwt4GCwXH86NJCWJMO 4p7KtLGTnV2q
6qZQUMpIi4PoBzLCqAKU30OkOMIIy2LZkRhX2advYfld3q37SxmxwDOuiSs5 YzOLtZG35F6m
Zscjl3GJpFarKlMzQEDnTEwCmTh+CXQK0No40EJbFf2nj/2fdh2PIYxsWEx7 CY1los1qytvR
LO22cY9hDuJF2aNcNG5CIqNRWl3igomKJBM4WNpqocTN9DaONLktisIjC/s0 7dw/K7vNv2lj
NjgGedElZyxmcXayNvyL1MzY5HLuMTSK1WVKZmgIHOmJgFMnD8Eujew6Q40u y2K+m8f+z8ue
x3GMbkhceyGNncXC2q6t58ztteMWhLbcKu4aNUaKkMiZqwWWOo1REuwiYxjJ gUREaGtDaONL
ktirKWB7PyZvi58nS8Jj13kq9otW1bzuFyzttWTn4Rdug0VjZR2cgrOmp0Wy SZkVjGIJSFKI
aFAACtDaONBCWxS1C/8AdzaXQ8vdpN22leki1ZxUhLpvIwr1yyjlnbhm2WcF OCh0kFH7g6ZD
GEpDKqCUAE5tY30No40EDsV+OasN+VsN40Y9tqd9DaONSYHYoFn5viXOMRBN 4fLSVjXXbkoF
ww9y2wpYkhJtXAxj6IUKh0xh7gbI8Y2kFSGURRItsiJAUBM6hDxvodIcam6d iwOAsa4OwnfE
5k658upZEyVOa7Vw3ehjFjJtOObsWjzindmW5bqynK0YiPTX5SZXUrNuUuyC QBTfQ2jjUXDs
WQiMLezTt2RlZe37Sxmxlp2AJj+cdM4u1kVpG102TaNJCOzppFMswK1ZoIA2 OIpAmmQmzslK
AUirDpDjS4divXtgez9kcoSObn8Jj1fNEvzdztd6zO2zzb3mh2wfx3KJAxBc qclcxTRZHbOP
FnQSMXQUyCE76G0caGJ2LIXJFbkl5SCcvd7ax5WWRnmN/pOpJOBcqkuiLZIx rGbKdYDGB+3a
t00EnIDxpEyFIUwFKABG+htHGpunYpb6acOD/W2G8aMe21O+h0hxqLh2IOac N+VsN40Y9tpv
obRxpcOxcr2ruM7uFvbzEbvdy+eVZ3PrF03eOrnlbf3f05iRSRaljjtHMzG4 9ZS5UlmJRaHF
B2moCIiQhy8Ag3sNo41Jidi3XjCwPZ+4TiGNv4ZhMe2jAxkotdUaxthnbcW3 aTbiMUhVpJBJ
iRIibpRgqdsZYoAcUTCmI7AiFDVh0hxqLp2Klw2B7P27Je3rguqEx7Jz1oyj +6rUfSDO23Di
FmpSTLNPpKPVWIY7Z05flBysskJTnWAFDCJ+Go3sOkONLh2KfBmnDnlbDeNG PbaGtDaONTdO
xU9NOHB/rZDeNGPbab6G0caXCNS5osrce3J7L3iLv3g078hn/T/pC2va1HNu 4Ubxk9GXMdVZ
7GSb6Ms1nOvGplTlUMVxJHMsZMormV+FtRvYbRxpdOxbLaYU9mqxj7MiGVpY zRiscul5XHrV
KLtYiVrvXL1OSXcwxCpAVkqo6SIuc7cCGMoUDiO0ADU76G0cai7LYr6TsD2f 01fFz5OmITHz
vJN7Ratq3ncLlnbisnPwq7dBorGybs5BWdNTotkkzIrGMQSkKUQ0KABArQ2j jVV07FgR3a/Z
XejD0I9AMU+hfnTpV0Q5jtDmXnrknIOcub+I5Nyrk34Hjtjb2Pg66cFN9DaO NQInYs/k6wPZ
/ZsiH1v5mhMe3dAycojdUkxudnbco3dzTeMThUZJdJ8RUijpNgkRsVYwCcES gmA7AAFDVhtH
Gm7KzrOU3TWHN3IHNpIczykjdUTxKkMTkU1L8v5xkm+yIcW6dc6u+OWJodTj 1doR4w+o1o7R
xoYnYsDjHH/s/sKRDG38MwmPbRgYyUWuqNY2wztyLbtJpzGKQq0kgkxIkRN0 owVO2MsUAOKJ
hTEdgRCoFWO0caXCpbbd+7utnR6kRaM3bkVFLOn0qq1jXkY2SO9lHq0k+cmI ichRVcOnCi6p
xDaOocxzCJjCIjVjtCXTsV/6aMO+VkN40Y9toKsdoS6di1lmXCvs19426EL3 3hbSxpfd6NWp
IprL3nF2tNvUWSSqrgjZNxJJLqFSKouocCAbZAxjDpqI03sdo41Nw7FEmmBc Yx2T46/o/eGk
ELUiLokchRNkIssLkhWT+Xdv3MgRuqWyglU+VJyrtBZwR6DtQi6omXFRQ5xb 2O0caXDsWy8U
RG5PgePLEYPbWRZsUVqjFFa2onAxCQMm719JItgIwBEvFEdSjtcpNNkFF1Tg G0ocRjfR2jjS
6digbfdA9kQ0th5ZDTF+H0rLkHTOVkIhO27LKycvY9J03ZuVm5WwJnVQTfuC JnMUTEKqcCiA
HNq3sdo40unYt0mzPh3yshvGjLttRvY7QgidiqGZ8Oh/WyG8aMe203sdoQxO xaFzDgPGOVbh
vR5Gbwz+1LDyDp0rsuBZYYeQsltQrS31+WhctlzDx3x7NmmkpytwrqQATDRI pEyzvY7Rxqbp
2KeWDaO5vYPNEwm8tKSyTFbDk95u0LUbTTyT/wCVzuJNZWJasUSOnC1xSiyp kEky7b1yJSlB
ZQDQasTrCXTsV/ERG5PbuX5XeEgG1kMc+zrUkVN3wzTgUbgkGSZWxCNnUmmB XSqRSs0AAh1B
KAJk4Pgl0b2O0KDAlS70z4eN/WyGD/8ACjLttRvY7QpunYqFzRh4P61w3jRl 22m8jtCXTsVA
zPh7yshvGbLttDUjtCCJ2IOZsPeVkN4zZdtpvY7Qlwqpsz4eH+tkN4zZdtpv I7Qlwqnpnw95
Vw3jNl22oNWO0JdOxPTNh4f62Q3jNl22o3kdoQxKDmbD3lZDeM2XbabyO0Jd Kp6Z8Ph/WuG8
Zsu203kdoUiBVRzNh7yshvGbLttN5HaFF0qhczYfHq3XDeM2Xbab2O0KTElU 9NGHx/rXD+M2
XbajeR2hLhVfTNh8v9a4bxmy7bTeR2hTdK8jmXD/AJVw/jNl22m8jtCi6VU+ ZsPj/WuG8Zsu
203kdoS6U9M2Hx/rXD+M2XbaX47QgiVQMzYg8q4fxmy7bUbyO0KWOxPTNiAf 61w/jNl22m8j
tCgRKDmXEHlXD+M2XbabyO0KTEqnplxB5Vw/jNl22oNSO0JdKqGZcP8AlXD+ M2XbajeR2hTd
Kp6ZcQeVcP4zZdtqd5HaFTdKoOZsQB/WuH8Zsu20vx2hTdKr6ZsQB/WqH8Zs u21F+O0IIlUH
MmIB/rXD+M2XbaneR2hLpVBzLiEf61Q/jNl22oFSO0KbpVQzJiAP61w/jNl2 2oM47VDFefTJ
iHyqh/GbLttTfjtCm6VX0yYgN/WuH8Zsu21F+O1RdKGzLiDyrh/GbLttBUG1 BEoOZcQj/WqH
8Zsu21F8bVN0oOZcQj/WqH8Zsu20vjal0qnpkxD5VQ/jNl22l8bUYoOY8Q+V UP4zZdtpvBtS
6U9MmIfKqH8Zsu20vjajFUHMeIR/rVD+M2Xbai+NqXSnpkxD5VQ/jNl22ovj ajFBzHiEf61Q
/jNl22pvjapYp6ZcReVUP4zZdtpeG1LpQMy4iH+tUP4zZdtqDMbUYqhcx4i9 26ofxmy7bS+N
qEEqvplxF5VQ/jNl22oMxtQgryGYcRD/AFqh/GbLttSZjajFVHMOIfKuH8Zs u21F8bUYqg5j
xEP9aofxmy7bS+NqCJVPTDiLyqh/GbLttLw2qbqemLEXlVD+M2Xbai+NqXU9 MWIg/rVD+M2X
baXhtRinpixEH9aofxmy7bS8NqMU9MOIh/rVD+MmXbaXhtQAp6Y8RD/WqH8Z su21F4bUYqgZ
hxEH9aofxky7bVV8bUIKDmHEQ/1qh/GTLttU3ggBT0w4j8qofxky7bS8NqqC DmLEY/1qh/Gb
LttLw2qLU9MGIh/rVD+MmXbaXglqoXMWIy/1piPGTLttReG1SyemLEflTEeM mXbam+FLIOYM
Rh1LqiB//CTLttReCpZPTBiPyqiPGTLttLwQhUDMGIx/rVEeMmXbagyCMVT0 w4k8qYjxky7b
UXgjKo5hxJ5UxHjJl22jhSgZhxJ5UxHjJl22jhF5NmDEnlTEeMmXbakSCAKo 5ixJ5UxHjJl2
2oEgjJ6YcSeVMR4yZdtqHChlQ2YMSeVMR4yZdtqRIBSAq+mHEnlTEeMmXbai 8FDKnpixL5UR
HjJn22jhSyel7EnlTEeMmXbaOEVAzDiUP60RHjJn22jgqWVS5gxJ5UxHjJl2 2oJCghU9MGJf
KmI8ZM+20cKWQcw4lN/WiI8ZM+20cKGQ2YMSm/rTEeMmfbahwjKnpfxL5UxH jJn22pdGQcwY
lH+tER4yZ9toSEVBy9iU39aYjxkz7bUOpQcvYl8qYjxkz7bR00IOYMS+VER4 yZ9to6hPS9iU
f60xHjJn22oBUhPS9iXypiPGTPttLyqVBy/iXyoiPGTPttQ6pFiFy9ib3boi PGTPttCjJ6X8
TeVER4yZ9tqXVS8+l7E3lREeMmfbahQq+l7Ew/1oiPGTPttEKFy/iYP60RHj Jn22oKMqel7E
3lREeMmfbaIq+l7E3lREeMmfbaKpUHL2J/KiI8ZM+21ChPS9iYf60RHjJn22 iFDZdxOP9aIj
xkz7bRE9L2J/KiI8ZM+21BULyOXMTh/WiJ8ZM+21IKlVHL2J/KeJ8ZM+21DK RYgZcxOH9aIj
xkz7bRQqBl7E4f1nifGTPttET0u4nD+tESP/AOEmfbagogZdxOP9aInxkz7b R1KGy7icf6zx
PjJn22oZQFT0u4o8p4nxkz7bUqU9LuKPKeJ8ZM+20RBy5ijynifGLPttET0u 4o8p4nxkz7bR
E9LuKPKeJ8Ys+21DIqelzFA/1nifGLPttQyFPS5igP6zxPjFn22jIqDlzFBv 6zxIf/hFn22m
hSvm8yfhyRZrR0jcMM4j3BDILoLv2J01EzlEpiHKZQQEogOggPAIVBtUxmYk EWELki8/ZY+z
vum8RuiFvd5bkSJ+MLAQk9AGYJa/bEQPJsnrtAg+4RJcpShwFAoAABr55TRk XIXp+A+MOeYa
jGiKkZXQwMg8uNwulsRpbr+CbEZ41xRJQkPZzLbMk2Rk26h1FVDbSiyyyy51 VVTm4TqKGMYw
9URrNhTEA0QwXnmY5nXx9aVfEzM5y0krJ3Rd2Br2iTQd0TsO7jBMVUEzyTUo lOQeAxTkWKYo
9UNQEOARDqCNXoTlAvFYMgDpUSa2tu+8/wAxIzd2x0hASnFcTFKSTRNJrxIg JNgyS5R/BgHF
pbOzsJiJOEBGsg4qTAAMRr+Xl4VQKYU5TyliBm2SZMbih0WaJQSSSSfsikIQ oAUpSlKoAAAA
GgAFYUwTarosW1TST0eosp9+b/HXU3wtZaqc6PA6qyn35v8AHU3gUdfBpdCE goulHvgXVaqC
2dFRWA4orAUpxTUAph2TbJwHQeHQQ69W41IydrWVMagk7F2LHgOxXHOrv+OU +/N/jqu8FXaq
c5vA6qyn35v8dReCKoSrseosp9+b/HS8EVOdXf8AHKffm/x0vBACrVzeDNpK toNzIAnMvCLK
tGh1tFViN9jjTJkE2pgJxhdoQ6moa9WjgIFdc6PC9VZT783+Ol8IqGlHg9RZ T783+Ol4JagS
jwOqsp9+b/HUGQS1DSjweosp9+b/AB0vBLVgsiZisvE1umuvJM8lDQAHKgRd 6uJBVWPrsIok
AROqqbTQpCAJjD1AGszA4Gtjam6w8DOWwDVtOwbSbAsbFYylhYGpWkIx2krX TX2hO7WqsUsp
cEpCMDCBecrot26YGNLtHEgCd/NRrRqUNS9UygBpoPUEBroKncrM4BxSEuCM 6c5ejGRl5Fo6
PfHLasrkawfhEgOMgDyqas94vFsllRDCcZcyLrKDmJNdSUS1VUWPzUVZBAHJ lEgMkUDGcE2A
MYDHARMUBKAiGknleIhh+typkUr9xzZzmJZtOgF7GGg2st3HH0ZVtwJAzu3m +q4D7NYbbqUs
51e/xyn35v8AHWtMgstWVy31H2jDLT9xPjtopDTbUMKhhExjAUpCET2jnOYw gBSlAREeAAEa
CQRRI29FjgOq7mA/Zgbi7xpeRSu2b8jrxhkrgtt+d1Era7ChTKFEDFESmIci mychiiAgYpgA
QHgEAGhkivwlHv8AHKffm/x0vhAnOr3+OU+/N/jqLwRaufb72BI1+5ZOrhe8 maLLM1JJKInl
Ysyzc4pKkSkUmRmauwoAkNxaptDAJR+EGlc7V745ZTqmjOvESjYR8rFsxk+J lESELDwh+J3U
sxvnXHGYGDmTxZdLK4WTJQGz00Q+SdC2VMUDlTXKkcTJmEogYAOACICAhwCF bnC5hQxUb9GQ
kNoIKw6+GqUTdqRMTwqRjLPfcXV+/N/jrKvBWFg7lzLYVlvyRd5XQxiZNRMH CbaTkm7VUyRj
GIBwIuqQwlExBDXTTUBq7ToVKgeESRwAlWp14QLSkAeErHBvJYW8vIXx2x7f Vzqdb2cuIqg4
yl048YQd5PCwf18hfHbHt9Op1vZy4io65S6ceMIO8nhYP6+Qvjtj2+nU63s5 cRTrlLpx4wqe
slhjy8hfHbHt9R1Ot7OXEVV1yl048YVR3k8L+5fkL47Y9voMHW9nLiKjrdLp x4wqesnhfy8h
vHbHt9Op1vZy4ip65R6ceMIG8nhcOrfkL47Y9vp1Ov7OXEVBxdLpx4wgbyeG PLyG8dse31HU
6/QlxFT1yj048YQN5PC/u35C+O2Pb6nqdf2cuIqOt0unHjCp6yeGPLyG8dse 31HU6/s5cRU9
cpdOPGEDeSwz7t+Q3jtj2+pODrezlxFOuUenHjCDvJYZHqX5DeO2Pb6jqdf2 cuIp1yj048YQ
d5PDAf18hvHbHt9Op1/Zy4inXKXTjxhB3k8MB/XyG8dse31HU6/s5cRTrdLp x4wqDvJYZHqX
5DeO2Pb6dTr+zlxFOuUenHjCesphjy7hvHTHt9Op1+hLiKdbpdOPGEHeTwyP UvyG8dse306n
X9nLiKdco9OPGEHeTwz7l+Q3jtj2+nU6/QlxFOuUenHjCDvJ4ZHqX5DeO2Pb 6dTr+zlxFT1y
j048YQN5LDIdW/Ibx2x7fUdTr+znxFR1yj048YVA3ksN+XkN47Y9vp1Ov7OX EVPW6PTjxhPW
Sw35eQ3jtj2+hwlf2c+IoMXR6ceMJ6yeGvLyG8dse306nX9nLiKdco9OPGE9 ZPDXl5DeO2Pb
6dTr+znxFOuUenHjCoG8lhvy8hvHbHt9R1Ov0J8RTrlHpx4wnrJ4a8vIbx2x 7fTqdf2c+Ip1
yj048YQd5PDYf18h/HbHt9R1PEdCfEVPXKPTjxhB3k8Nj1L8hvHbHt9T1Ov7 OfEU65R6ceMJ
6yeG/LyG8dse31HU8R7OfEU65R6ceMKhd5LDgdW/Ibx2x7fTqeI9nPiKjrlH px4wgbyOHfL2
G8dse306niPZz4ip65R6ceMKo7yWHB6l+Q3jtj2+o6niOhPiKdco9OPGF59Z LDvl5D+O2Pb6
nqeI9nPiKHGUenHjCqO8nhwepfkOH/4bY9vqDg8R0J8RQYyj048YVA3k8O+X kP47Y9vqep4j
oT4inXKPTjxhA3ksOj/XyH8dsu31HU8R0J8RUdco9OPGEDeRw75eQ3jtj2+o 6niPZz4ipGMo
9OPGFQd5PDvl5D+O2Pb6nqeI6E+Ip1yj048YVfWSw75eQ/jtj2+oODxHQnxF T1yj048YVPWT
w75eQ/jtj2+o6liOhPiKdco9OPGE9ZLD3l5D+O2Xb6dTxHQnxFR1yj048YVB 3ksPD1L8h/Hb
Lt9T1PEeznxFOuUenHjCDvI4f9y/Ifx2y7fTqeI6E+IqeuUenHjCr6yWHvLy H8dsu31HU8R0
J8RUdco9OPGF59ZHEHl5D+O2Xb6dTxHs58RU9co9OPGF69ZLD3l5D+O2Xb6d TxHQnxFR1yj0
48YXn1kcQeXkP47Zdvp1PEeznxFT1yj048YVQ3ksPh1b8h/HbLt9R1PEdCfE U65R6ceMIO8l
h/3L8h/HbLt9Bg8T0J8RTrlHpx4wqesjiDy9h/HbLt9R1PE9CfEU65R6ceMJ 6yOIPLyH8dsu
306nifZz4inXKPTjxhA3kcQeXsP47Zdvp1PE+znxFOuUenHjCesjiDy8h/Hb Lt9QcHifZz4i
nXKPTjxhPWRxB5eQ/jtl2+p6pifZz4inXKPTjxhPWRxB5eQ/jtl2+o6nifZz 4ip65R6ceMKg
7yOIfL2H8dsu306nifZz4io65R6ceMKvrI4g8vIfx2y7fTqeJ9nPiKnrlHpx 4wvI7yOIg/r7
D+O2Xb6dTxPs58RU9codOPGFUN5DEQdW/Yfx2y7fUHB4n2c+IqOuUenHjCoX eQxEHVv2H8ds
u306nifZz4inXKPTjxhA3kcReXsR47Zdvp1PE+znxFDjKPTjxhA3kcRB1b9i PHbLt9DhMSf9
nPiKdco9OPGFX1ksQ+XkR47ZdvqOp4n2c+Ip1yj048YVPWQxH5ew/jtl2+hw mJ9nPiKDGUOn
HjCDvI4i8vYjx2y7fTqeJ9nPiKnrlDpx4wqDvI4iD+vsR47Zdvp1PE+znxFO uUOnHjCeshiM
f6+xHjtl2+o6pifZz4ihxlDpx4wg7yGI/L2I8dsu306pifZz4inXKHTjxhPW RxH5exHjtl2+
p6nifZz4inXKHTjxhA3kMR+XsR47ZdvqOp4n2c+Ip1yh048YQd5HEfl7EeO2 Xb6dUxPs58RT
rlDpx4wgbyOI/L2I8dsu31HU8V7OfEU65Q6ceMKg7yGJPL2I8dsu31PU8V7O fEUGModOPGE9
ZHEfl7EeO2Xb6jqmK9nPiKdcodOPGEDeRxH5exHjtl2+nU8V7OfEU65Q6ceM KnrIYk8vYjx2
y7fTqmK9nPiKq67Q6ceMJ6yGJPL2I8dsu31HU8V7OfEU67Q6ceMKpt5DEg9S /Yjx2y7fU9Ux
Xs58RUdcodOPGFQN5LEnl5EeO2Xb6jqeK9nPiKHGUOnHjCBvI4k92/Ijx2y7 fTqeK9nPiKdb
odOPGFT1j8TeXsR47Z9vqOqYr2c+Ip1yh048YQN5DEw/19iPHbPt9Op4r2c+ Ip1yh048YQN5
DEw/19iPHbPt9Op4r2c+Ip1yh048YQd4/E3uX7EeO2fb6dUxXs58RTrlDpx4 wqDvIYm9y/Yj
x2z7fQYPFeznxFT1yh048YVfWQxMH9fYjx2z7fQYPFeznxFR1yh048YVDbyG Jvcv2I8ds+30
6pivZ1OIqRjKHTjxhPWRxN5exHjtn2+o6nivZz4inXKHTjxhU9Y/E/l7EeO2 fb6nqmK9nPiK
dcodOPGFX1kcTeXsT47Z9vqOp4r2dTiKjrlDpx4wqeshijy9ifHbPt9OqYr2 dTiKq65Q6ceM
Kpd5DE/u37EeO2fb6g4TFezqcRUdcodOPGFT1kMUeXsT47Z9vp1TFezqcRU9 codOPGEDePxR
5exPjtn2+nVMV7OpxFR1yh048YT1j8UeXsT47Z9vp1TFezqcRU9codOPGE9Z DFHl7E+O2fb6
jqmL9nU4inXKHTjxhU9Y/FPl7E+O2fb6k4TF+zqcRVPXKHTjxhPWQxQH9fYn x2z7fUdTxfs6
nEVUMZQ6ceMIO8higP6+xPjtn2+nU8X7OpxFR1yh048YVPWQxT5exPjtn2+n U8X7OpxFOt0O
nHjCqG8hiny9ifHbPt9R1TF+zqcUk65Q6ceMIO8higP6+xPjtn2+o6ni/Z1O KSnrlDpx4wqe
shiny9ifHbPt9T1PF+zqcUlHW6HTjxhA3j8Uh1b9iR//AA2z7fTqmL9nU4pK euUOnHjCoG8f
iry9ifHbPt9OqYv2dTiKnrlDpx4wnrHYr8vonx2z7fTqmL9nU4pKOuUOnHjC BvIYq92/Ynx2
z7fQ4PF+zqcUk65Q6ceMIG8firy9ifHbPt9R1TF+zqcUlIxmH6ceMKg7x+Kw /r7E+O2fb6dU
xfs6nFJR1yh048YVfWQxV5exPjtn2+nVMX7OpxSU9dw/TjxhU9Y/Ffl7E+O2 fb6jqmL9nU4p
J1yh048YX1YbwOOZR8jGRl7xrmScqEQbt0JlqoqqqoYCEIQhFhExjCIAAAGo jVMsNiogylCo
AOAqRiqBLCcSTwhSXnqa+WLfjVP8dYXWZbSsm6FTn2a+WL/jVP8AHTrEtp40 uhUGcmh6jxf8
ap/joMRLaeNTdGxV55nB6jxb8ap/jp1mW0ow2IE5ND/92L/jVP8AHTrMtpUX QqDNTgf/AHYv
+NU/x1HWZbSpujYsVc+VoOy+I6Y3IhE8p2+Tc5yCbXjeL2dvY49Qm1s7Ya6d TUKv0Y16z7sT
k2lnPzK1Uq06fnkB9rBYsN4/FodW/orx207fV7qmM9nU4pK0cZh+nHjCoO8h i3y9ivHbTt9S
cHjPZ1OKSgYyh048YVPWPxb5exXjtp2+nVMZ7OpxSU9cw/TjxhPWPxb5exXj tp2+nVMZ7Opx
STrmH6ceMKvrH4t8vYrx207fUdUxns6nFJOuYfpx4wqesfi7y9ivHbTt9T1T GezqcUk65h+n
HjCesfi7y9ivHbTt9OqYz2dTiknXMP048YQN5DFvl7FeO2nb6jqmM9nU4pJ1 zD9OPGEHePxd
5exXjtp2+o6pjPZ1OKSdcw/TjxhUDePxf7t+xXjtp2+hweM9nU4pKeuYfpx4 wg7x+Lw/r7Fe
O2nb6jqeM9nU4pKOt4fpx4wg7x+L/L2K8dtO31UMJjPZ1OKSkYzD9OPGEHeP xeH9fYrx207f
VPVMZ7OpxSUdbw/TjxhC7x+Lw6t/RXjtp2+nVMZ7OpxSTrmH6ceMIO8fi8ep fsUH/wCG2nb6
DCYz2dTikp65h+nHjCyNv5Xhry47odcqEtybY5TzZIkdcVxm1sbfEKG2drZH TXq6DWJipV6D
b0Ti+h3D8av0atKq9wgtsYqYmUTIUTGHQocIiPUAK3qwlz7kTP8AL5lFe38L yZ4rD6JzIS9/
MhKLqTMmYSqs7cEwCQeEuyo+MApk6iQHP8JPzrvH3zhTBp4eVmuQ0ngh+meg anOjzrPe9sZA
ww0mhrmNMvq0/wBM9A/Vc2iEYUvku6/eF9x8Bj6TfY7uCRipyCVt6WtHiSk6 KwzF0CwT1wsH
fHC8arGUMoQROYdsTCJhGtb3e714fAUpxnCRvyEhdMDphAF70wXcF7OFafI+ 9WHyyNSJpyac
hMXZU2tp0wXv1Iye9Eu4t0vat4YV3loDM9zStmFgZS3LqiWTGZVZzikIvxzK RcPGqKyKsFJy
iIhxjBUogY4GDQODhrvMl7wUczvbqMhdZ3u63ZrspDUV32Q95aOamYpRlEwA JvXdErwDGMpD
9U61sgxyj7tbxdCEKYperQqFD7tzJGWpdqtnFiX0hIN2jWTcLtDxiSCab1Z0 giUTP3rURMIt
FB0KAgAacPDRStc5QkozJd2RVySsS5YMISOk0m7lV7GEeIvnj6JOgszNHPHR yqETaqiJhAA0
4B1ARCpQBSPGeclSO2tm5KcpHeuDFbRNwkKCLeQUHgKg4J9qg74PtddhQeFM eHZClmQhbS2y
1KJtlqFKbZaIvzG3r95/JmTt5+7C4ws1/djy25JbH1snK4GPQYCyODeS5IYU FxO4cvSqFWUL
sFBJNMon+Ccoe/8AdnA4TLMBSGIqRgakRVnY9htjetDARYgWkyJLWheId6+t ZtjZQpRJhA3I
+Eed5dewDYplYtr5Tt28Use3nEGhslnii3E4QipYk4wI3OcEQSdKC3ZLoqqm 2gTIoiYimwfZ
OIFHTY0M/wANjaJq0+dSErryjcL7RbIEDWQQQ4cB1xudd1q+WTjGUhfIdgX4 7AfIx1FbB3dc
fW9jvenshlA2+0t0ruFvd24bRzYrUqypndqgKpilAOEdNkNOACgBQAAAArj+ /GKNfL5G+ZgV
aWku3Nr2fLwrs/hoZnGSMwx3cv4oLsUDFrx4r20Lne/77e3neCisw6TZMmkk 8h44y+0LSNTb
SC0Ws+VAugnUNxRjbQ6AQg7ICXU5xkBSssruz5BWvXmEzwgWTs8r6Rhs7PEd hxHGbXHe51dj
T4Wv+RUoopjrJj7H9+mQiXicjHLP2sW/Ub7QNJJFd+jGJvUwNqJVS8aUwGDU Dk+CImACmCCi
6cKcohr16pUBaG3pcuplyNFbuUq9PAwNwx5pIzsFlGTi4RBwdspDRrsBIVNQ oAU7gSHBbi1C
AkGpjHJ5V8U+82OyvCXcHSkbwtmNA02PqNj+DQum7vYClWlfmQ4OjZ9YjZs1 PpWrclXxIWlG
soq1o7i54wBEWnbDUp2iBjNUylDaSQAopM2pDFFQQAOqVMvwzlCvlnuZ3Xx3 efMRAkgO8jaG
GvxfOV3+PxlHAUCbD5dPzk/ToWvrUxZnPBl2k3pMQLHncmJPHkNfDZ2KiCdy maLl5bHOtsCE
TVTMptMlg+AmYNgPwQmAfvOn3Qhk2HpUMLG6YwBH14nbwm0jYeAlePUO8MMy nUMi8RMxNnmy
GzaBr26dK7bwNnTHG8jiqJzFip7y2z5dMTp7YbC7dYhhTWbOU9RFNZFQBIoQ eEpgEKuU6wqR
vD6QdYOwjWpqUzAsflwjgWexr/27XZ/8htj+kLirYf7CP7UvmisOH20v2Y/P JI+7cuXBBSt2
xkpDtYplIzUcizVhnrlYE4qUdR5dtUswgUxjA3Aw6EANR6lbCpRw9MxgYzJM Yl7wGmIOi4du
1WIzrSBkJRAcjzSdBI6Q2LI4py8zvmUk7NkF2a14Q4JqOVohUizNy3WOqRJd LZVWMmIiiYDJ
HMJiCHVMAlMONjcKKTTg92W3SCGcHRtFuvyK9hq5m8ZaRxHTaOLRqWXvLKVi Y/uK07Tu59yS
4L5lVrWtZvxLhXlso3g5O5FENtFM5E9GEO6V2lRKUdjZAdsxSmwVlJceWMWW dz/0uuWKiuik
Undl085SLNtzNBrct4uTkOOULydobm11srK7JB4lTQfgG0IpBRFH8sZSsTB2 LLlzXlJ9zXjK
z4qRum45PiXDnkkXFM1H7xfiWiayynFoomNspkMY2mhQEdAoiRuUrEl8pzOF I99xmTbfioa6
ZeM4lwXk8XcDyWYRy/HGTBE/HLQbwuyQ4mLxepgKBiCYiyDa7LVeXU9sVpJt Fb2jmjOWkIdN
wiZ81YyKztuzcrNymFUiS6rBwRI5igU5klAKIiQ2hFD8xb0eCcEcazyDO7V2 p838ValvMpC4
rndc684GZ8jt+3m7+Wc8anDvlQ4hsf8ABNXCg6JoKmIRbAoiURKIlEUfs3KV iZAuK7LTtF9y
u4LGlUbWulvxLhLkUo4g4y5E0NtZMhFNWEw1V2khMUNvZEdspilIsfa2fsNX pky4MM25cLRb
K1sO14yYt9QxkHxFmsTAzjgyKLgqZnCSLS540yqyG2mQzlMhjAcdkCKYURR/ E+UrEzjiy2s1
4tfc6YyvCKjrptyT4lw25XFyrNN+zX4l2misnxiKxTbKhCmLroYAHUKIpBRE oij+J8pWJnHF
ltZrxa+50xleEVHXTbknxLhtyuLlWab9mvxLtNFZPjEVim2VCFMXXQwAOoUR Y/I+8LgLDl1W
xYuXb4t+1b2vZ2MTZkPckzHRj6ffAs3bi2i271dJV0rxrtEmwiUxtpQgaamD Uih6/tCdwVtf
cvi1znDH6eTbf535+tw95W4WUjej7dw7l+WMxe8cjyFFmso54wocUVM5j7IF MIEUgxbvY7rG
cYdjcWFMl2peFvykqtacY+ta4YiVbu5xtFqTa0YgqwcrEUdpsETujIlETlRK KghsAI0RbAoi
j9xZYxZaF925i27LliovJt4cv6JW5IyLNtKTfNTcrt/zczWUKs55MiYFFuKK biyiBjaBw0RQ
91vu7l7GOvWYfZespGIxq7QicjOlbqgiI2q+dPlIxBtNnM7ArFVR2kdAhHAk MZQokANoBCiJ
ae+7uX37asZfVi5esqasmauBvj2HmIm6oJ4xf3U8RK4bwbZw3dnSVkFUjlOR sQwqmKICBRAa
ItoURR+8spWJj+4rTtO7n3JLgvmVWta1m/EuFeWyjeDk7kUQ20UzkT0YQ7pX aVEpR2NkB2zF
KYiyF2XZathWrJ31fUm0hbJhWjiWmJiWcIs2LBizRM4cOXLhwYiSSSSRDHOc 5gKUoCIiABRF
kKIlESiKP40ylYmYLdc3Zjp9zjb7SVnbWcOOJcN9iUtmce23KIbDpNI48Q/j 10toA2T7O0QT
EEphIpBRFj212Wq8up7YrSTaK3tHNGctIQ6bhEz5qxkVnbdm5WblMKpEl1WD giRzFApzJKAU
REhtCLIURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiU RKIlESiJREoi
URKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESi JREoiURKIlES
iJREoiURKIlESiJREoiURYHJss5g7KdyTQ4prkO2JtkMJTACrpJI2hi8IcBh 6lZ+WUhUrxiQ
+nyAlY+KkY0yRwfOtDymUJFws/Rip10q5j1waPEkJR2Yzdc6KTkqSpSLakOK SxDgUQAdkwD1
BAa7vD5dSkwMI+iORaGeImLbx4ysKyyFJXvaxniUytK2w7c2pINFDPVHrdUp rvhRSWROc6hR
KYigiAlHQQH3eCtf3hwdKlQvQiAWnaAB+pLYq8JWlOTEk2x1/WitwGXSIUTn HQoBqI8PUCvH
mXXBco39vjZpvObcuMIcjhMYNiySzSefQcjczuRaw71GOfyBI9g6jwRYJOXJ EwcKLiJgEVAI
CQcYPF4/vRWNWdHA0t4aYeWnQ7FgLbDr/QvOM176V95OGBgJCAJJIMiQCxIi DHmg2O9ulmtU
i3Vt8mfyPeSOKMr83LXLINlpO27ktwVQjJhu34sV0+JWE527hMqxD8XtqFOQ dshzABwJk93O
9EcyMqU43KkQ7aiNoWV3R77wzaZw9UCNUBwztIa9OgjY5stB0t0YCpOvXUrv goJhPel3ZN5L
nP1dci2xf3MvJ+eOhU9FTnIOV8byflPNjhfiuN4hTY29NrZNproNVzpyjpDK NOhTsyhB92qF
UFZWiIDvEQenk5cf9J2/W/yr7Gp+1D5prX4j7aP7MvnitDY73iM+ZCtfHNiY 0u2evLeRuSzI
S/buRE9mw1v24jJxabhNWTeltWRWQF04MJG6CaCqpwAx9kEyGOHZ573Pp0MV i69TFVMPhoYi
pCnEQjKRAqMIwEokkRjplOVugyJXFYLEYqvTpXa1QylTjKR/lMHi7fZ7Vf39 kDfwxpjXIc3k
daYiZy0rNnL5iLlgJOyrhtZ29jGqqqUauLu04KSKsYU+MEoNgJxfUW2q43vJ gaGDwc8XgsdU
qMJG7OnTgbA4PNjMN/rfR13dDIMTmma4fA4rEVadOrVhC9E0iWlO6WehpAL6 Cux6yVlJREoi
URKIlESiJREoiURKIlESiLTl8GAu8RNa+Tlu/wBJ3BWsz0fyaX7U/mgmF+2n +zH55LxvA4rP
m/D03ixGSPFLSySRCvCEFUmqDhJyCS6QGT41urxXFLJ7RdtMxi6hrrUZrgeu 4edC8Y3hpHH4
wdBGsOFqc5yw4/Czw14xvDSPCDaNYLMRrBIXKdxZCuazZg+NMoRpLdySwbgK US1ETxz5kgAJ
g5hFRKmCrYoAACnsgoiGgHLpoYfnfvDlmIwNa5XDE6DqI+qdnBpC+de8eHxW BrbnERuy1dEg
a4nZwaRsWsrxyAW5HbyLgDSTp2zFFJ6MPbdyyqaCzhoi+KkdzGxzhHb4lwmY QA2oahWvwuU4
jExv0qc5gFnjGRD7HA0rQ0corYsGdKnUqAFiYwlIAsCzgEPaFub2b7a4V8u3 RMybKSQik7Yt
+FRdzMVKxQruGszPPFippyzZsoYCEfJ6iBdOGvXvh1gq+GFbf05QBEALwIdr 7s44V7H8L8vx
GG3++pTphqYF6Ji7GoSwIHSC3Rvubr8tvgbvExhq1ch3Riu/F9H1u35juYk4 iTipNEhyoKLF
jXTPljU22JVmqpwKoUdSmTVKmqn6ZeC9aUuwTiOMwHiC38PRc9PXQ2gWpWZr jvyZe3BcEmqJ
jKrOpCRkDnUVVVUOYwgXZTIAgRIiaZSELDoy1ln188hswPXizGQUi30PCpIO 2EXIvkTKs3sw
dVMTsm6wFMUrkg6DpwCFBIIy19OXyI7TFMHbR1xRnCSUhGyTE6yaaqSJxTF6 3SKbZMuTUAHU
NQqp0WMs21boyTOubZtshXTlYvJ5Q7kBUYs01OH+cBr+FVAPhESAQEB0Ewlq klF11ZUIva9o
xttvHar5ywbIszPHRhOstxJAIB1D/wCUYQDUR90aXgjKJXBgc09m2Oy8S7rh Zw7NLV5aTOXf
pQ7x2lxYNlzoEWApSlKBuMSKGwqOyJg/hAVi8ipvbTMrb+6pk2et92uwnmVp 3E7YvmKyjdy2
cIw7lRJZFZExTkOQ5QMUxRAQENQHWt33Zpwq5lhoTAlGVamCCHBBkHBBsIOs LWZ3OVPBV5xJ
BFOZBGkERNoXJOR8I2tAHmDW+7uVjexk3hoKTksgZIFEXo7ZElnJ0p0yokEf thIAiOte4YOE
asYyMKUo2XgKNB22D+Wz7HXzfLvDiqdQiVWoNLG/Pj0rVeS28FJwtt2G2wUh fuVCIpI3DkbI
Ty1p+Uk1EfgkLzm8eKu1y6F+3cAQxCACZEgKAAFrC5Zi4TqVTjTRgSbtOlvK cIg/UiAAeCLu
XkZE6ewxPejAVKUIwoCc2506gjORP7RcnwlmFgDLoT2TODrVjLEls6SVq23F 3fLSkgjByVqQ
zONBOFIKLUrZJZsgios3Oq1MuQ6n8IBgPoAbJS+e/EbM5yxQwUa1WcKcY3hO cpPUtJLEkAgS
ukDQxFtpPoPcvCDq3WpU4QlUJa7ERIjYwcAEhw9ul/AuxtstecuuyXLd1xpo u85GMuYVmTRO
YkHEgdBLjXCUfIzTp4m5SIOoHKZFbgENdDAIaCYBKNYKlbJPvE4YIf0LHZKB hMWXMnOwqL66
bHFfaacdxOz8HjNddeHTZ+FUui0xbMHzhfjdtahln0SpKMjRZ10uLcLsmMw1 dqOFCBoBSlSR
4RHTUwgGgGHZCCUXYJDlAoaj7gVQ6gBc677GKsfZjyLZ9l5IblXiXUHdSUcJ jbBucSv7ccJl
SE3wTK8nQXOBRAdSlMOnBqG1y+nTq0506kRKJZwQ4I52kLBxlSdMxnTJEg7E adS++5nu3MbT
bvr0u2Rc3JcLZyeHi38wus6cIxzdBBVFADrmMYAIdY4/bCIiOoiOhdNHS7t4 DJ5yjgKYpipb
Lw7BwcCz6ea18bAGuXulhY3jLa1CfZJ76Wd9+9zkZPeHg4KPg4ZG2nEGyt9v IE/BTAywuQcK
SD12JzfzFIQEgE0HXg6mmyqU7hBdUQILrb24lCwsFuk2InDNUmhHUQxfOSt0 ypgo4XbJnVVM
BAABOc3CYR4RHhGreMYVpt0j86pok3I+ALZeNBAc63Zp4Btj+kLiq6D/ACI/ tS+aKtx+2l+z
H55KKY4vpdjas3HJpnVALlvEvwCGOHBdkoTTgAexrqI4EVTCZI8yH8IWsxNa dN4xiTp0AnWV
88DPiOt5GeTK35MYLZh1TpcXxY6nmZwNoS6BwiBQrFz6mKcYRBe2XzQWRld4 xvSBBbX4ZLEe
0BwQvvB39u52k7a3AeyWOSn0tcslZUrcUA+i2JMTX81ScqTFrumL5mkd84bt xOVchTmVKiYR
BTYNza2i4vvHdc3hMptc9QWQYLIEjmC9cVZHwRgg672804uX6M3fmmIi2t1O E3BIpTW3piEM
xkLoP/OjLceguq4FZSiLIZfuxk8y1fFi7rknnVXKMdh+15bdwh37jeAMVrkG Ru3JzdJzd7e4
TC3IkvIsGBAPdxQaHapAGosyH0IukN7b/wCqYe6cCselbq4Mm5qxxaZYG9eC AnYNlF2fdl3x
lvcZo3Pb61owcuL1FcwEcuyv2+ih1SpHIo+r6U72dZ0z1u+c6v8AOVwZVStP B0815YaLP0Et
Blab2MujXgRtRjcrO5geIuil1Mos4jQNIuGCqpE3a8WtYjf6iM134xyqm9uD H8Ba1tyd4LXe
blF12/ceR394oXijbKg20TiRnEDR5nZAjDcYUIMTIlIBSKH50sbLW+1vyYYu S4rbyVb265Lt
MY3qpH8pu2z31rPnuPc9mk03Ty2nrVWMkE1XsMzkQRdFMJjt0FTGKomUxFkL ktHect3dEvyc
uqRyA+ui/Mq35ESsw+NkaWd2DYkTki7nttuIK2sbSNvXK9aOQSZtyDHuiri3 ekUVWUjGabZM
i0/hS0d/DKECe8clyOVV5OH9GdhW05bmylZTd7ak1vHX5ZlyPVYGQkeV8r9H 3N66jyTM4k2S
IoPTOiuQK6EiZQtz2lcxc7eCVvLIFp2/b3Sq2sKnjrNyVeEo/l4bK98REYpI uLfuy2Io/wD9
PM7aMi7vs7mOelOK51BIaRUVIuwN9W/7xvFjH26nCZAisAWpkBCAzC+sZnc7 acmbYWx47m2T
221bFOa5HDQtySUS1XUiwKqB0XKaockI4ESLR9mYIvizr0yTvRYHa5KZXS6z BhNhaCMzK5JB
GVx9I2riO2bgfSttXG6FB8qnFqyiTx9JslHbdRFQ6iqa7UDJEWv5W2t5XK1n 4zv3ESl6qYpz
VcF43/cdy2C/uWMczFpXZvOYrVtWRkJK31mz1sqGMzrItxWUTcs41JZHREiC pCEWwLqtrKGP
M3z+Jc7KZgcezitS4LjjLXd2U/y5NXUvIu7NxnNQZlJqyFnd5yMeDyQu0grL uVmaaoFbqmKd
FkmmRaf3IcYe0BtObwLbl7z962Y5t638KxNq2M2sXIj1iFnsLCtNK6m0vIJX VDWEwV5wLOoO
CT0atLolLtNQUVGMTKRdYYCv/KeKOmuUsmwmVblxxbVqTE/hG3HjN5IS8rZk fxLtdlJM9tNy
vda7lNJNknOmB6eOFqXUJEZ4aItXzN2Xxce/7l2HxhJ5Kf7y0BmDGsTbTVk4 ySvjaOx8paON
5O7mzshjGsNFU0U9mlwI7AHYrKEOgHKTNREi0g+xpmLcv3Cd2u3WrnKttYyu nH+LEM3sWs7k
+QlIqcQyhhmE5oi0kXrqTg3a0ZOTzUsdCg2OuXaTBE4t0gSIun7Ax1knOOHZ vdyfHusm4xkf
IDy0GKeS2l9rXm7xQtjAjyaj1Xd1s3U8x5ddTV+zM5njIqFZKmIyXSOeMNRE 3+MT5TvH12+i
NtSsr0r3aoK07W5tjnjnnmcR9LvGRkfxKZuUOy85NdpFLaOHHJ6h8MupFj8+ YZy1gfeRxBvu
7xck7yNexL1i4S63GGcb3adjEWrBYxyy0ilxt6Je3rLnVPL3qoku5BYUtk6B eKTEh1FSKQZ3
sP2qGXsmOsn7qF6u4Dd8nWkVJ21ES1125aT5sivEtTqlcwd0bv12SjJUVxUE 6LqRUUKYR2io
/wACmRa/sO299rDG+FOT8/NXrMbwd3XBi2NSt41uxlw4+mrCYWza8VdL1/e7 OyYgrJWPdqXO
/aMgkIsh3YFVTjf59xLoi1/aWB7qyRhDd+xlfFsZKt5zu3YfjbKyZK2jaiza Zg71gbyxHPsV
Ld6WxK8dciTZxYb5yqMOjIkWQQ2USqquWhFyLIZrtzNmdIcj7Oa2QHm7KvFZ Mxfb2VHeMJ+S
vu5IC6Yuw3Awd3WRasBGyTaKkZJpNIOHDSIinYIRrPiH7YzoF3xFH98DNftK 7rwSFxyUHkDH
e9bZkVdd120yhLOyVeHON5ykg+nYy0CBhucaWu4aQbEIds3lZ1vIMpHjzgq3 SXbybSiLH7+N
p7xdxnlJi2ozMD/2gcBcGfJZm6t9vlRe0o62lMXZVjLBcwJ40prMRkDM3sEg keOEH4uVDEVH
lRnICRTDe4xpvr4fsrMTPdfc5VdvY6VvjGljCSdv65nB7McbssjfDFyzUlHs gou7DIipUW0t
qZ6RbYj03AIlI2AibxuNN9exN1i8sxYRc5VX3mr0uveWtqVaITt/S/J7YQiM sPrKUiIJ09dM
ovV7E2+Ec7jmyCptpFNJQSuTFVIpBl/Gm/1h+ev1nuXucgO76jrrujGmMhum duO5os9sON3F
7fEU5XUvp7IRq+mSFSIllnwmVIbSPFwDUoNgIj/p/wBIlvRR6av1XPOtp9O+ efTV6Q+V8x3/
AM8c08/f/tH5Jzp0O2uav5vpx2z+C5zoi0hbGMN9+LtqOh8Tz+SseYpF3kCW wm1VsXMFx3E+
uWXzbkKTK5myJ3VaiCCqsWvALkPkEFmC4KicwlIEgJyLq/LGDfbOS+U7llcW 5D5FjJ1KyLi3
GXpDsZlyeLUeKHZpcmd7uE4sjsIiUOLUfujF00MuqICoYi2BhhlbsH7XDO7y BtGViekuP8Xc
5XX0RnI+DnZy3pK8Cvf/AKgUjkY167bxs1EpfBcnPsBxZdeTKlSIun6IlESi JREoiURKIlES
iJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiUR KIlESiJREoiU
RKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJREoiURKIlESiJ REoiURKIodn1
fk2KZFbXTZUYcIfZkW4VuMgjexcB+1/CVh5gWonxfOF+f+dtxwt9389u/FVy ubNt28xBnlKK
ivgJzLQomX49uXQSJulDgKShhDQxFDmHURUIv6FGFrLmKsgA627jmzbTxvZp LBsZinG2pGK2
0gzZIAOymQL0hDCIiIiYxjGMJjmMImMYRMIiIiNarvPFsL4pf9nNXcsqXp+O P8cVv85SnKJD
/aiGg/sDXikSxXdELh7d1zc63OcqxNnX5DPJK9LBsy
Re: CMS - Xoops [message #563838 is a reply to message #7309] |
Wed, 01 June 2005 05:08 |
Philippe Ombredanne wrote:
> Have you checked Xaraya?
Very impressive multi-lingual home page. Occurs to me I haven't seen any
discussion of internationalization requirements for the Eclipse website,
but I know there are very strong clusters of interest in the US/UK,
Germany and Japan.
Bob Foster
Re: CMS - Xoops (CMS Wish List Revised [message #563876 is a reply to message #7200] |
Wed, 01 June 2005 18:43 |
Andrew Geraghty Messages: 30 Registered: July 2009 |
Member |
------=_NextPart_000_004E_01C566B8.3E78FFE0
charset="iso-8859-1"
This was sent out on the phoenix-dev mailing list on April 21
Andrew
-----Original Message-----
[mailto:phoenix-dev-bounces@eclipse.org] On Behalf Of andrew geraghty
Sent: Thursday, April 21, 2005 2:19 PM
To: For developers on the new Eclipse.org website project.
Subject: [phoenix-dev] CMS Wish List Revised
Requirement Type
definition
Priority
Additional Details
=20
System Requirements
=20
=20
=20
=20
Application Server
Server or application environment required to run CMS
=20
Tomcat or other Open Application Server
=20
Database
Database the CMS uses to store content
Must run off a relational database
.My SQL (we already use it)
.PostgreSQL (has XML support)
=20
License
Type of license
=20
Open
=20
Operating System
OS this CMS is Compatible with
=20
Linux
=20
Programming Language
Language is written in
=20
PHP, Java
=20
Web Server
Web server this CMS is compatible with
Should
Apache, Tomcat
=20
Security
=20
=20
=20
=20
Audit Trail
Does this system keep track of who made changes/ additions
Must
=20
=20
Content Approval
Does this system have some sort of system wide approval?
Must
=20
=20
Email Verification
Does this system send an activation key to make sure users have =
entered a valid email address?
Must
=20
=20
Granular Privileges
Does this system allow read/ write functions on a per page and per =
content item basis as well as other privileges for other system =
functions?
Must
=20
=20
LDAP Authentication
Does this allow for LADP based Authentication?
Must
=20
=20
Problem Notification
Mechanism for alerting administrators when there is a problem
Nice to Have
=20
=20
Sandbox
Private area for content managers to try new ideas
Nice to have
=20
=20
Session Mgt
Some facility for an administrator to see who has logged in and if =
required log them out
Nice to Have
=20
=20
SSL compatible
Can this system be used with an SSL certificate on the web server?
Should
=20
=20
SSL Logins
Can this System be configured to switch to SSL mode (HTTP) for =
logins?
Should
=20
=20
SSL pages
Can this system be configure to switch to SSL mode for certain =
pages?
Should
=20
=20
Versioning
Does this system provide some kind of system wide content =
versioning?
Should
=20
=20
Support
=20
Nice to Have
=20
=20
=20
=20
=20
=20
=20
Ease of Use
=20
=20
=20
=20
Drag & Drop content
=20
Nice to Have
=20
=20
Friendly URLs
Does this system have human readable and search engine friendly =
URL's?
Nice to Have
=20
=20
Image Resizing
Does this system allow users to edit uploaded images?
Nice to Have
=20
=20
Macro Language
Is there a Macro Language that allows content managers to place =
powerful functionality (like auto generated navigation systems) without =
any programming knowledge?
Nice to Have
=20
=20
Mass Upload
Does the system have a way of uploading/importing many images and =
other files all at once to save time?
Nice to Have
=20
=20
Prototyping
Does the system allow the user to create custom default settings =
for the different kinds of content objects to save them extra clicks =
when creating those object types. For instance, if there is a particular =
template they like to use, can they set it as a default?
Nice to Have
=20
=20
Server Page Language
s there a server page language available like PHP, JSP, or ASP for =
easy one-off functionality?
Nice to Have
PHP or JSP3
=20
Spell Checker
Does the system have an integrated spell checker
Nice to Have
=20
=20
Subscriptions
Can the user subscribe to various sections of the site and receive =
notifications on new/updated content? These types of functions are =
typically found in the news feeds, forums, and blogs.
MUST
=20
=20
Template Language
Is there a templating language for powerful layout controls? (Note =
that templating languages are different from server page languages in =
that they are not capable of full programmatic functions, and are fully =
HTML compliant
Nice to Have
=20
=20
UI levels
s there a means of dumbing down the publishing interface for less =
sophisticated publishers while keeping a more sophisticated interface =
for power users?
Nice to Have
=20
=20
Undo=20
Does the system allow users to operations if they make a mistake?
Nice to Have
=20
=20
WYSIWYG Editor
Is there a web-based rich text editor to allow publishers to create =
formatted content without knowing HTML, CSS, XML, or XSL?
Nice to Have
=20
=20
Performance
=20
=20
=20
=20
Advanced Caching
Does the system have advanced caching mechanisms that go beyond =
simple page caching? For instance, navigation, template, or content =
object caching?
Must
=20
=20
Database Replication
Can the system take advantage of database replication for better =
scalability? The system would need to be able to perform reads from =
slaves and writes to the database master.
N/A
=20
=20
Load Balancing
Does the system allow you to put a load balancer in front of it to =
split the load between multiple servers? This would require that user =
sessions can be passed between all the nodes transparently.
Must
=20
=20
Static Content Export
Does the system have the ability to export it\'s content as static =
HTML so it may be served up from regional cache servers, or from static =
HTML web servers?
Nice to Have
=20
=20
Page Caching
Does the system have a mechanism for caching the contents of a page =
so that if it\'s requested again it can skip most of the work to create =
the page
Nice to Have
=20
=20
Management
=20
=20
=20
=20
Content Staging
Can content be created on one server and easily pushed; to another =
server?
Nice to Have
=20
=20
Inline Administration
Is content edited directly in the page that it will be placed? (The =
alternative is that there is a wholly separate interface for managing =
content.
Must
=20
=20
Online Administration
Can the system be completely managed through a web browser? (The =
alternative is that there is some sort of offline client software that =
must be used to manage at least some components.
Must
=20
=20
Sub-sites / Roots
Does the system allow for sub-sites within a site that are =
self-contained with their own navigation and content hierarchy?
Nice to Have
=20
=20
Web Statistics
Does the system have built in web site statistics reporting for =
things such as pages/content items viewed, number of users per time =
period, etc?
Should
=20
=20
Web-based Style/Template Management
Is there a web-based interface for adding styles and templates to =
the system for design and layout control?
Nice to Have
=20
=20
Workflow Engine
Is there a full-fledged workflow system integrated into the CMS =
that can be used for business process management (or other duties beyond =
just content approval)?
Must
=20
=20
Interoperability
=20
=20
=20
=20
Content Syndication (RSS)
Can the system export RSS/XML feeds so that the content can be =
republished on other sites? Note that if it can only syndicate content =
from one function, such a news then it should be labelled as only =
limited support?
Must
=20
=20
UTF-8 Support
Does the system support UTF-8 character encoding to enable =
multi-lingual sites without the use of separate code pages for each =
language?
Must
=20
=20
WAI Compliant
Does the system follow the W3C specification for WAI compliance?
Nice to Have
=20
=20
WebDAV Support
Does the system allow users to upload internal content and/or files =
via WebDAV?
Should
Emphasis on user management - system that can implement a =
DEV/Stage/UAT model with the ability to maintain a separate promotional =
path for code and content
=20
XHTML Compliant
Does the system follow the W3C specification for XHTML compliance?
N/A
=20
=20
Flexibility
=20
=20
=20
=20
CGI-mode Support
Can the system run in CGI mode for development purposes or on =
low-end systems?
N/A
=20
=20
Content Reuse
Does the system allow content to be mirrored (not copied, but =
reused) from one location to another on a site?
=20
=20
=20
Extensible User Profiles
Does the system provide a user profiling that can be extended with =
new profile properties through an administrative interface?
Must
LDAP
=20
Metadata
Does the system support the adding of arbitrary metadata properties =
to all the content objects? The metadata is typically then used for =
profiling, indexing, or even auxiliary display functions.
Must
=20
=20
Multi-lingual Content
Does the system support the creation of sites with multiple =
languages?
Must
=20
=20
Multi-lingual Content Integration
Does the system support a multi-lingual version of each content =
object without republishing the content object. For example, if you =
create an FAQ in English, then all that needs to be done to display the =
FAQ in Spanish or another language is to translate the content, not =
create another page with another FAQ content object. Then depending upon =
user preferences it either shows one version or the other.
Must
=20
=20
Multi-Site Deployment
Is the system capable of hosting multiple sites from one software =
deployment? This means you can install the software once and host as =
many sites as you want. It also means that when it comes time to upgrade =
you only need to upgrade the software in one place, not for each =
separate site.
Nice to Have
=20
=20
Wiki Aware
Does the system support wiki or wiki-like functionality? Wiki =
provides online collaboration functionality as well as a simple text =
formatting language.
Nice to Have
=20
=20
Built-in Applications
=20
=20
=20
=20
Blog
Does the system have a blog or web log? (See slashdot.org for an =
example.
Nice to Have
=20
=20
Discussion / Forum
Does the system have a message board?
Should
=20
=20
Document Management
Does the system have an application for managing offline document =
storage and versioning?=20
N/A
=20
=20
FAQ Management
Does the system have an application to organize frequently asked =
questions?
Nice to Have
=20
=20
My Page / Dashboard
Does the CMS have a dashboard application (sometimes called a =
portal)
Nice to Have
=20
=20
Newsletter
oes the system have the ability to allow users to add/delete =
themselves to/from a list so that they can be sent email from the system =
on various topics?
Nice to Have
=20
=20
Polls
Does the system have an application for conducting simple single =
question polls?
Nice to Have
=20
=20
Search Engine
Does the system have an integrated search engine that can index the =
managed content and allow the user to search the indexed content?
Should
Google Search is preferred
=20
Site Map
Can the system generate a tree showing all of the pages in the =
system dynamically so it doesn't\'t have to be maintained separately by =
the content managers?
Must
=20
=20
Surveys
Does the CMS have an application for conducting complex =
multi-question surveys?
Nice to Have
=20
=20
Syndicated Content (RSS)
Does the CMS have an application for retrieving and displaying =
RDF/RSS/XML syndicated content?
Must
=20
=20
=20
"Andrew Geraghty" <andrew.geraghty@javalin.ca> wrote in message =
news:d7f9ev$hel$1@news.eclipse.org...
Right now Xoops is our leading choice for a CMS. Has anyone out there =
had either negative or positive experience with Xoops?
Andrew
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2900.2627" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>
<DIV><FONT face=3DArial color=3D#000080 size=3D2>This was sent out on =
the phoenix-dev=20
mailing list on April 21</FONT></DIV>
<DIV><FONT color=3D#000080></FONT> </DIV>
<DIV><FONT color=3D#000080>Andrew</FONT></DIV>
<DIV><FONT face=3DArial color=3D#000080 size=3D2></FONT> </DIV>
<DIV><FONT face=3DTahoma size=3D2>-----Original =
Message-----<BR><B>From:</B>=20
phoenix-dev-bounces@eclipse.org [mailto:phoenix-dev-bounces@eclipse.org] =
<B>On=20
Behalf Of </B>andrew geraghty<BR><B>Sent:</B> Thursday, April 21, 2005 =
2:19=20
PM<BR><B>To:</B> For developers on the new Eclipse.org website=20
project.<BR><B>Subject:</B> [phoenix-dev] CMS Wish List =
Revised</FONT></DIV>
<DIV align=3Dcenter>
<TABLE class=3DMsoTableGrid=20
style=3D"BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: =
auto auto auto -0.3in; BORDER-LEFT: medium none; WIDTH: 441pt; =
BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: =
solid windowtext .5pt; mso-yfti-tbllook: 480; mso-padding-alt: 0in 5.4pt =
0in 5.4pt; mso-border-insideh: .5pt solid windowtext; =
mso-border-insidev: .5pt solid windowtext"=20
cellSpacing=3D0 cellPadding=3D0 width=3D588 border=3D1>
<TBODY>
<TR style=3D"mso-yfti-irow: 0">
<TD=20
style=3D"BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; =
BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BACKGROUND: =
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: =
99pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; =
mso-border-alt: solid windowtext .5pt"=20
vAlign=3Dtop width=3D132>
<P class=3DMsoNormal style=3D"MARGIN: 0in 12.6pt 0pt 0in"><B><SPAN =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Requirement=20
Type<?xml:namespace prefix =3D o ns =3D=20
"urn:schemas-microsoft-com:office:office" =
/><o:p></o:p></SPAN></B></P></TD>
<TD=20
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 135pt; =
PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; mso-border-alt: =
solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt"=20
vAlign=3Dtop width=3D180>
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><B><SPAN =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: =
Helvetica">definition<o:p></o:p></SPAN></B></P></TD>
<TD=20
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 92.45pt; =
vAlign=3Dtop width=3D123>
lang=3DEN-GB=20
Helvetica">Priority<o:p></o:p></SPAN></B></P></TD>
<TD=20
#cccccc; PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 114.55pt; =
vAlign=3Dtop width=3D153>
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Additional=20
Details<o:p></o:p></SPAN></B></P></TD></TR>
<TR style=3D"mso-yfti-irow: 1">
<TD=20
BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; BACKGROUND: #f3f3f3; =
PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 1pt solid; WIDTH: 99pt; =
solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10.5pt; FONT-FAMILY: Helvetica">System=20
Requirements</SPAN></B><SPAN lang=3DEN-GB=20
style=3D"FONT-FAMILY: Helvetica"><o:p></o:p></SPAN></P></TD>
<TD=20
PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 135pt; PADDING-TOP: =
0in; BORDER-BOTTOM: windowtext 1pt solid; mso-border-alt: solid =
windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; =
<P class=3DMsoNormal style=3D"MARGIN: 0in 0in 0pt"><SPAN =
lang=3DEN-GB=20
style=3D"FONT-FAMILY: Helvetica"><o:p> </o:p></SPAN></P></TD>
<TD=20
PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 92.45pt; PADDING-TOP: =
lang=3DEN-GB=20
<TD=20
PADDING-BOTTOM: 0in; BORDER-LEFT: #ece9d8; WIDTH: 114.55pt; PADDING-TOP: =
lang=3DEN-GB=20
style=3D"FONT-FAMILY: =
Helvetica"><o:p> </o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 2">
<TD=20
BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0in; =
BORDER-LEFT: windowtext 1pt solid; WIDTH: 99pt; PADDING-TOP: 0in; =
BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; =
mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid =
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Application=20
Server<o:p></o:p></SPAN></P></TD>
<TD=20
BORDER-LEFT: #ece9d8; WIDTH: 135pt; PADDING-TOP: 0in; BORDER-BOTTOM: =
windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: =
solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Server or =
application=20
environment required to run CMS<o:p></o:p></SPAN></P></TD>
<TD=20
BORDER-LEFT: #ece9d8; WIDTH: 92.45pt; PADDING-TOP: 0in; BORDER-BOTTOM: =
lang=3DEN-GB=20
<TD=20
BORDER-LEFT: #ece9d8; WIDTH: 114.55pt; PADDING-TOP: 0in; BORDER-BOTTOM: =
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Tomcat or other =
Open=20
Application Server<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 3">
<TD=20
BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; BACKGROUND: #ffff99; =
lang=3DEN-GB=20
Helvetica">Database<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Database the CMS =
uses to=20
store content<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Must<SPAN=20
style=3D"mso-spacerun: yes"> </SPAN>run off a relational=20
database<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">=95My SQL (we =
already use=20
it)<o:p></o:p></SPAN></P>
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">=95PostgreSQL =
(has XML=20
support)<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 4">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 8.5pt; FONT-FAMILY: =
Helvetica">License</SPAN><SPAN=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Type of=20
license<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
Helvetica">Open<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 5">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Operating=20
System<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">OS this CMS is =
Compatible=20
with<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
Helvetica">Linux<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 6">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Programming=20
Language<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Language is =
written=20
in<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">PHP,=20
Java<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 7">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Web=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Web server this =
CMS is=20
compatible with<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
Helvetica">Should<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Apache,=20
Tomcat<o:p></o:p></SPAN></P></TD></TR>
<TR style=3D"mso-yfti-irow: 8">
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10.5pt; FONT-FAMILY: =
Helvetica">Security</SPAN></B><SPAN=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 9">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 8.5pt; FONT-FAMILY: Helvetica">Audit =
Trail</SPAN><SPAN=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Does this system =
keep=20
track of who made changes/ additions<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
Helvetica">Must<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 10">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Content=20
Approval<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
have some=20
sort of system wide approval?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 11">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Email=20
Verification<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
send an=20
activation key to make sure users have entered a valid email=20
address?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 12">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Granular=20
Privileges<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
allow=20
read/ write functions on a per page and per content item basis as =
well as=20
functions?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 13">
<TD=20
windowtext .5pt"=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">LDAP=20
Authentication<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
style=3D"FONT-SIZE: 10pt; FONT-FAMILY: Helvetica">Does this allow =
for LADP=20
based Authentication?<o:p></o:p></SPAN></P></TD>
<TD=20
lang=3DEN-GB=20
<TD=20
lang=3DEN-GB=20
<TR style=3D"mso-yfti-irow: 14">
<TD=20
Re: CMS - Drupal [message #564221 is a reply to message #8344] |
Sat, 18 June 2005 00:08 |
Eclipse Webmaster Messages: 607343 Registered: July 2009 |
Stavros,
If you look at Andrew Geraghty's CMS Wish List, you'll see that we
weren't looking for a PHP-based CMS specifically. We wanted to choose a
CMS based on our requirements, not on language.
Our short list included Xoops (php), Plone/Zope (Python, I believe) and
Apache Lenya (Java).
We opted out of Lenya because the codebase didn't seem mature enough.
version 1.4 was in heavy development, and version 1.2 was not as
polished as we would have liked.
As for Zope, we felt the uncommon storage engine and uncommon web server
hindered its scalability (we need redundant databases and scalable
webservers) - and these were not as easy to configure as with Xoops.
As it turns out, we hired a CMS consultant who looked at our
requirements and suggested we use PHPNuke instead of Xoops, and based on
that, we have opted to use PHPNuke instead.
By the way, Eclipse is about much more than just Java :)
Thanks for your comments,
Denis
Stavros Kounis wrote:
> hi all
> http://www.spreadcocoon.com/ is based in drupal too.
> This site is not official but is many around Cocoon has accepted as a 3rd
> party work.
> Here i want to make a question.
> We you are net looking for a JAVA based solution?
> People at Cocoon like spreadcocoon.com but they would like to see a Cocoon
> based solution. In Eclipse's case (where almost everything is about JAVA)
> choose something in PHP and not in JAVA?
> regards
> --stavros
> "CK Ng" <ckng@nrg.cs.usm.my> wrote in message
> news:d80ttv$nqf$1@news.eclipse.org...
>>From your requirements, I would recommend Drupal (www.drupal.org)
>>Drupal currently powers SpreadFirefox, JavaLobby, KernelTrap,
>>LinuxJournal...
>>Regards,
>>CK Ng
Re: CMS - Drupal [message #564244 is a reply to message #8376] |
Fri, 17 June 2005 20:25 |
Stavros Kounis Messages: 51 Registered: July 2009 |
Member |
Hi Denis
I dont want to start a "war" with your consultant. Im sure that he knows the
factors to choose the right tool much better than me. I want just
to share my experiences as someone that has moved from PHPNuke to PostNuke
and has setup a sufficient number of *Nukes.
PHPNuke was the reference point for OpenSource CMS.
The REAL community-based OpenSource PHPNuke was PostNuke,
There is a big diffirence between Post and PHP nuke.
PostNuke is supported from a real-open-source-community, PHPnuke is
developed by 1 person.
Personaly i think that PostNuke provides a better API.
Now, Drupal can be sayd that is the Post/PHP Nuke's next generation. The big
difference here is that Drupal's code is Object-Oriented.
Recently is have see a graph that brings Drupal at first place based on
popularity [1] (compared to PHPNuke, PostNuke etc).
.... just my 2 cents to help you make the right choice.
regards
--stavros
[1] http://drupal.org/node/18834
"Eclipse WebMaster (Denis Roy)" <webmaster@eclipse.org> wrote in message
news:d8volk$4mf$1@news.eclipse.org...
> Stavros,
> If you look at Andrew Geraghty's CMS Wish List, you'll see that we weren't
> looking for a PHP-based CMS specifically. We wanted to choose a CMS based
> version 1.4 was in heavy development, and version 1.2 was not as polished
> As it turns out, we hired a CMS consultant who looked at our requirements
> and suggested we use PHPNuke instead of Xoops, and based on that, we have
> Denis
>> hi all
>> party work.
>> Cocoon based solution. In Eclipse's case (where almost everything is
>> about JAVA) choose something in PHP and not in JAVA?
>> regards
>> --stavros
>>>LinuxJournal...
>>>Regards,
>>>CK Ng
Current Time: Fri Apr 26 14:38:53 GMT 2024
Powered by FUDForum. Page generated in 0.26281 seconds
